nkourtzis
mAP Lite Ethernet susceptible to interference!
Fri Feb 05, 2016 12:43 am
Today I had the following experience with my new mAP lite: I used the integrated magnet to stick it onto a metallic TP-Link 8-port gigabit soho switch. It took me about an hour to debug what I was seeing, but at last I figured that when the surfaces of the two devices were in contact, the ethernet port would connect at 10Mbps full duplex after a long negotiation process and no data would pass through! As soon as the mAP was detached from the switch, everything worked just fine. The exact place on the surface of the switch on which the mAP attached did not seem to make any significant difference.
Obviously there was some kind of interference that impaired the ethernet controller.
I suppose minuscule size comes at a price, but could there be a second revision with some kind of shielding around the board?
PS: The offending switch: http://www.tp-link.com/lk/products/deta ... SG108.html
Passionate about networks
Enthusiastic about Mikrotik
MTCNA | MTCRE | MTCINE
No trees were killed to send this message,
but a large number of electrons were terribly inconvenienced.
ZeroByte
Re: mAP Lite Ethernet susceptible to interference!
Fri Feb 05, 2016 12:50 am
have you tried putting some insulator between the map lite and the switch? It could be some kind of grounding issue that's leading to it.
Then I would try touching the MAP lite to the switch, but backwards so the magnet wasn't sticking.
Basically - if it interferes just based on proximity (with insulator, but sticking with magnet, or touching but backwards so no magnet) then try it in proximity to other ethernet devices, monitors, tv sets, electric appliances, etc.
Since I'm assuming it's plugged into the same switch that you're sticking it to with the magnet, I wonder if a grounding loop is interfering with the signal propagation along the cat5. Have you tried other cables?
When given a spoon,
you should not cling to your fork.
The soup will get cold.
nkourtzis
Fri Feb 05, 2016 1:01 am
Unfortunately I cannot do further tests right now, since it is a production environment (and my only mAPL so far). But I will put them in my to-do list. Thing is, the outside of the mAPL is plastic, except from the ethernet post shield which is exposed and was almost certainly touching the switch case. The cable was not shielded though, just an ordinary cat5e patch with plastic plugs. I should probably try to put just a sheet of paper/plastic between them.
kiler129
Fri Feb 05, 2016 3:32 am
Some ethernet poor quality RJ45 sockets MAY be affected by magnets and EMI. Since it's TP-Link I'm not really surprised ;)
bazzer
Trainer
Trainer
Sun Feb 07, 2016 6:12 pm
I too have discovered issues with the magnets within the mAP lite. I find if the device is stuck in place with the magnet or the small backing plate that comes with it is placed on the back, the ethernet port will fail and sync to 10mbit with no data passed through it. If you boot the lite without it attached to a metal surface, the etherport works fine
Barry Higgins
Mikrotik Certified Trainer
MTCRE MTCWE MTCTCE MTCUME MTCIPv6E MTCINE MTCSE
https://www.allness.it
Cha0s
Forum Veteran
Forum Veteran
Wed Mar 02, 2016 8:05 pm
I confirm the issue.
I have 3 mAP Lite and all 3 exhibit the same behavior as mentioned.
The surface does not seem to matter.
I've 'stuck' it over a switch, on a server, on a UPS, on the rack itself and the result is the same. No data passes through the ethernet.
The moment I remove it from any metallic surface the ethernet works like a charm.
I wonder if we can request a refund from the distributors since this is obviously a design flaw and the device does not work as advertised (at least in my country you are entitled by law for a replacement or full refund in case the product does not work as advertised).
I'll contact my distributor about returning these.
To add to the design flaw, when data passes through wifi, it will make a high pitch sound which is rather annoying when using the device in a silent room.
http://forum.mikrotik.com/viewtopic.php ... 04#p519204
ZeroByte
Wed Mar 02, 2016 8:24 pm
Does this happen if there's an insulator between the magnet and the surface it's stuck to?
(like if you had a strip of electrical tape on the metal, and stuck the magnet to that tape only)
When given a spoon,
doneware
Trainer
Trainer
Wed Mar 02, 2016 8:53 pm
try to put it onto a non-metallic surface.
tmbk they tested it thoroughly, but the magnetic field generated by the magnets that hold the device onto something is influenced and deformed by the attached metallic surface itself. this causes interference in the wireless part for sure, and i guess this interference can also influence the ethernet side transformers too.
#TR0359
darkprocess
Wed Mar 02, 2016 10:37 pm
Same issue here. Bad design ? What can be the solution, remove the magnets?
chechito
Wed Mar 02, 2016 10:40 pm
i think ehernet is vulnerable to interference by itself, you have to guarantee good cabling and avoid any source of interference to be safe
of course i think a strong magnet so close to a electronic device is a bad idea
Sob
Wed Mar 02, 2016 10:44 pm
Magnets are inside, so no matter what you stick it on, there's always mAP's plastic body between magnets and surface. Not even ethernet connector can touch it, because it's covered from back side.
People who quote full posts should be spanked with ethernet cable. Some exceptions for multi-topic threads may apply. Not intended as incentive for masochists.
doneware
Trainer
Trainer
Thu Mar 03, 2016 12:20 am
must be ok as long you do NOT attach it to anything metallic (ferromagnetic)
#TR0359
darkprocess
Sun Mar 06, 2016 2:34 pm
Can someone from mikrotik provide an answer to this issue
ALDISBEHMANIS
Tue Mar 15, 2016 2:21 pm
Same problem here.
Even tried changing unit.
Design flaw!
darkprocess
Tue Mar 15, 2016 7:48 pm
Mikrotik could you please provide an answer. Maplite is a great product anyway
bazzer
Trainer
Trainer
Tue Mar 15, 2016 10:56 pm
Remove internal magnets and stick flexi sticky backed magnet to outside of mAP lite (also works for fat mAP)
Barry Higgins
3bs
Thu Mar 17, 2016 11:17 am
And again, no comments from mikrotik :)
WBR, 3bs =)
normis
Thu Mar 17, 2016 11:27 am
If you find any hardware related issue with our products, please contact the seller to arrange a replacement via Warranty repair services.
3bs
Sun Mar 20, 2016 4:56 am
Noise when wifi work - hardware issue, or feature (all work fine except small noise)?
And ethernet that stop work after attach to mettal surface.
Maybe it's all hardware features? :)
WBR, 3bs =)
Sob
Sun Mar 20, 2016 6:04 am
It's MWAAF, MikroTik Wireless Activity Audio Feedback™. Patent pending. And for no extra charge!
DmitryAVET
Sun Mar 20, 2016 8:54 pm
+1
Confirm noise on high load
Maybe power system?
kiler129
Sun Mar 20, 2016 10:20 pm
It could be piezeoelectric effect of capacitors.
Details: https://www.youtube.com/watch?v=F2gX-R1k7MM
fragtion
Mon Apr 18, 2016 7:45 pm
I've got the same problem with my mAP Lite. I noticed a problem with ethernet connectivity immediately after unboxing on first use, but didn't realize that it was caused by a design flaw with the magnet until reading this thread
Update: Mine's working perfectly since removing the magnets.
juanvi
Wed May 11, 2016 11:56 am
Broken Eth in one of my 3 map lite. Interface shows intermitent disconnections of few seconds. Faulty device? Magnets?Anyone else? Some news from MT side? I love this device, please MT give him some love too. :D
¡vʞvdnX puv ···SOɹǝʇnoɹ ʞıʇoɹʞıW oʇ sʞuvHʇ
SolarW
Wed May 11, 2016 4:48 pm
Can confirm this issue - my 3 mAP Light have this problem.
1. Install to magnetic surface
2. Reboot or power cycle
3. Ethernet port not work
Temporarily solution (tnx to this post writers)
Solution 1 (without warranty void)
- install on NOT magnetic surface (on double-sided adhesive tape for example)
Solution 2 (with warranty lost)
- remove magnets from mAP Light cover
SolarW
Wed May 11, 2016 4:49 pm
Realy?
You have solution for this problem?
normis
Wed May 11, 2016 4:59 pm
Well yes, we are able to fix most problems, I wrote about this in March already, so you would have received the repaired unit by now. Our RMA department needs to see your unit before we can make a definite conclusion what exactly was wrong.
SolarW
Wed May 11, 2016 5:07 pm
Sounds like good :)
I'm buy my mAP Light only two week ago - in March you write not for me :)
littlebill
Tue May 24, 2016 6:29 am
so what is the link to the fix? apparently everyone has this problem
normis
Tue May 24, 2016 8:24 am
Like I said, with any device that has any kind of problem, submit it to RMA for repair, so we can fix it.
littlebill
Tue May 24, 2016 3:59 pm
ok let me ask this a different way, is there anyone on this thread or who owns one, who DOESN"T have this problem?
normis
Tue May 24, 2016 4:16 pm
Not sure about this thread, but just let me remind you, that nobody goes into the forum for posting something that works. People come to the forum to post about their problems. This thread has 31 posts.
Sob
Tue May 24, 2016 6:47 pm
To help fellow user with interrogation ;), are you saying that these troubled mAP Lites are only few bad units? The ones you have available for yourself to play with work fine, there's no trouble with ethernet speed negotiation even if you stick them on big metal rack using the magnet, and no noticeable noice even when you push 100Mbit through wireless. And if people go and buy new one, they have >99% chance to get trouble free unit? Is that so? Out of curiosity, any hints what's wrong with those units that don't work fine?
Zorro
Long time Member
Long time Member
Thu May 26, 2016 7:08 am
cable itself is more EMI-vulnerable(or become part of pollution itself, which is even more important, sadly :/) than connector.
but if you deploy STP or CAT7 cable(or one of those "improved 6a" cables with one-two-multiple screens(but weaker than on Cat7 somewhat and with weaker cable itself and skin effect/bandwidth)) you HAD TO ENSURE that also connectors are - Properly Shielded and grounded, connected to screen, not just routers and for thus - have sockets with screen/grounding 360'/around clock.
sup5
Thu May 26, 2016 11:00 am
One thing looks suspicious.
Since approx. two to three weeks no online shop I could find has MAPlite on stock.
But I remember they were available before this timeframe.
So I assume they all sent back their MAPs to Mikrotik for inspection.
Mazutti
Fri Jul 08, 2016 11:49 am
Sounds possible, since mAP Lite have never been available here in Brazil, and no distributor has any forecast as to when it will be. Hope it´s for the best.
Mazutti
solelunauno
Mon Jul 11, 2016 5:55 pm
I noticed the same problem using mAP lite with its iron plate with adhesive: mAP will stuck @ 10Mbps and it will not work. If it's installed far from iron surfaces, it works well.
SL1 Systems srl MTCNA MTCRE
darkprocess
Mon Jul 11, 2016 6:52 pm
I removed one magnet and now it works as it has to be.
Envoyé de mon SM-G925F en utilisant Tapatalk
ecylcje
Tue Apr 24, 2018 5:01 pm
Is this magnetic interference issue still happening with mAP Lites. I bought my mAP lite 17/04/2018 and it has issues where the eth1 port goes down every so often (seemingly random).
I have removed the 'metal backing' plate for now and attached using 'blue tack', but I was just wondering whether I should still need to be doing this, or even considering opening up the mAP lite to removal the internal magnet. (Is opening it up easy to do - I know it breaks the warranty).
Thanks,
Chris
ecylcje
Tue Apr 24, 2018 7:37 pm
Update:
It has been running now for several hours without being attached to anything metallic, only via blue tack. The connection has been rock sold, whereas previously it was 'link' bouncing at least 2 to 3 times ever hour (or more).
I suspect either the issue is back or my MAP lite came from a supplier which had 2 year old stock (unlikely).
Thanks,
Chris
bazzer
Trainer
Trainer
Tue Apr 24, 2018 8:06 pm
Pop the lid and see if it has any metal shield plates over the magnets. if it hasn't, its an original MK 1 with the ether interference problem. I'll see if i can find a comparison picture i took when the MK2 came out to help.
Barry Higgins
bazzer
Trainer
Trainer
Tue Apr 24, 2018 9:22 pm
MK1 on the left (bottom), MK 2 on the right (top)
Barry Higgins
ecylcje
Wed Apr 25, 2018 7:07 pm
Just as a reply to this. I contacted the seller and the stock is a maximum of 3 months old. So it should definitely be a MK2 version. I guess there are still issues.
I'm now just deciding whether to open it up and void the warranty or live with the 'blue-tack'. I suspect the blue-tack will win.
Note: There have been no issues since using the blue-tack.
Thanks to everyone,
Chris
juliokato
Wed Apr 25, 2018 8:02 pm
Again mikrotik adjusts the product without at least providing some indication visible in part number or serial number. (like RevA or RevB)
We have to open the equipment to do a visual inspection of the product. (sad thing)
How much it costs to make a change on the labels?
I apologize my grammatical errors, my english not so good, I am not a native speaker.
Wiki is maintained in English. I use Google translator. 8)
bazzer
Trainer
Trainer
Wed Apr 25, 2018 9:41 pm
If I recall I don't think there are any warranty labels by MT, unless your supplier sticks anything on
Barry Higgins
Users browsing this forum: Slavuntm and 31 guests
