negge
Port flapping (ether6 link down/up) on RB3011UiAS-RM
Mon Feb 08, 2016 11:21 am
I recently convinced a friend to purchase an RB3011UiAS-RM for his office since he needed something reliable and powerful enough. The router has been installed and in use for about a week now and everything's been solid, but recently the switch which is connected to ether6 on the router has started to drop for a few seconds at a time.
The log is filled with entries like "ether6 link down" followed by "ether6 link up (speed 1G, full duplex)". I've attached a fresh supout.rif file.
The router is running the stock firmware since there were no newer packages available for download on mikrotik.com at the time of the setup.
Any help here would be appreciated, even just an acknowledgement of the issue.
ScottReed
Re: Port flapping (ether6 link down/up) on RB3011UiAS-RM
Mon Feb 08, 2016 5:16 pm
You've checked the obvious like the patch cord from ETHER6 to your switch? You've tried another port on your switch/RB?
I took a look at your configuration and one thing I did notice is your switch configuration.
I'm assuming you want all the ports (except ETHER1 and the SFP) in a switch configuration?
If so, you need to make ETHER2 the master-port for ETHER3,4,5. Then make ETHER6 the master-port for ETHER7,8,9,10.
/interface ethernet set ether3 master-port=ether2
/interface ethernet set ether4 master-port=ether2
/interface ethernet set ether5 master-port=ether2
/interface ethernet set ether7 master-port=ether6
/interface ethernet set ether8 master-port=ether6
/interface ethernet set ether9 master-port=ether6
/interface ethernet set ether10 master-port=ether6
In your bridge configuration, for br2-lan, remove all the ports and only add ETHER2 and ETHER6. That will bridge the two switch groups.
/interface bridge port add interface=ether2 bridge=br2-lan
/interface bridge port add interface=ether6 bridge=br2-lan
negge
Tue Feb 09, 2016 4:19 pm
Thanks for your reply!
The router only has two ports connected, ether1 goes to WAN and ether6 goes to a switch. Both are on different switch groups so I didn't bother setting up any master/slave relationship between ports.
I haven't tried another port yet, I guess I could ask the tenants to move the cable.
I just remembered that when I got an RB2011 a year ago or so the ether6 port was completely dead so I'm wondering if that's just a coincidence or if this port is about to fail soon as well.
lambert
Long time Member
Long time Member
Tue Feb 09, 2016 10:46 pm
I've seen things like this on three x86 boxes. I only have three x86 MikroTiks. I have not seen it on any of my RouterBoard devices. I have more than 100 multi-ethernet RouterBoards.
It seems to happen to my units most often after what I assume was a power brownout. I have always seen it after a storm rolled through the area. One or more of the NICs will show link, no link, link, no link .... until I reboot. I've been seeing that 6.x from 6.5 through 6.27, so far.
The other night I saw it when I tried to move a function from a 100Mbps port, ether7, to a Gigabit port, ether3, with both ports in a bridge. Ether3 had been operating a 1Gbps to a Mimosa radio for several weeks until 5 minutes before I tried to use it in place of ether7. A reboot lined it out. I suspect it's something to do with the ethernet driver and Intel brand NICs in these network appliances. I haven't dug into very much. I don't know if my appliances have any parts in common with the RB3011. This could all be a red herring.
negge
Wed Feb 10, 2016 2:31 pm
Interesting, I'll let you know how it goes once I get the guy on site to actually move the cables arond a little bit.
negge
Thu Feb 18, 2016 4:31 pm
Seems I'm not alone, someone else seems to have the exact same issue: http://forum.mikrotik.com/viewtopic.php ... 34#p522134
negge
Wed Mar 02, 2016 11:32 am
I can confirm that this only affects the second switch (ports 6-10). Is there any way to fix this? I've looked through the release notes for the newer RouterOS versions that have been released but haven't seen this issue mentioned anywhere. There is also no newer Routerboot version available
lambert
Long time Member
Long time Member
Wed Mar 02, 2016 1:25 pm
Sometimes MikroTik notices issues posted on the forums. Usually not. It would be best to email support@mikrotik.com about this issue and be sure to include a supout file collected while the port is flapping.
infused
Tue Apr 12, 2016 3:37 am
Just bumping this as we are seeing this on a couple of RB2011UAS
Port 6 wan (1gbit) drops and reconnects @ 100mbit when new devices connect via DHCP in the morning. Blocking the first device's mac doesn't seem to fix it, indicating there is something else going on here...
wnet
Tue May 31, 2016 9:41 am
Hi guys,
on our last days same experience "port flapping on ports 6-10" (from ROS 6.36.rc20 renamed switch 2, finally) you can see topic here http://forum.mikrotik.com/viewtopic.php?f=3&t=108603
We solved only through a new official OS by Netinstall http://wiki.mikrotik.com/wiki/Manual:Netinstall and after updating (as e-mail received from support) to last RC version. Only now there are residual re-login of customers group, but it appear without a specific cluster. But since we use UBNT Rocket at moment (https://www.ubnt.com/airmax/rocketm/) we need to investigate if that is caused by them or what other.
wnet
Wed Jun 01, 2016 10:16 am
Sorry, guys. I think...it was solved, because after last setup of previous post, RB3011 was about 8h without problems.
But...now about 1 down every 4 hours, but there is. With identical configuration on RB1100 on the same place, no problems.
Attached screens.
infused
Tue Jun 07, 2016 4:23 am
Can anyone confirm this is fixed? Getting really sick of these port issues.
wnet
Sun Jun 12, 2016 7:22 pm
After many days, RB1100 continue to logout and re-login immediately groups of users, some from a specific Ubiquiqi Rocket M (as described here http://tinyurl.com/zt7bja5). More strange is that we have different values A) CPE (XM and/or XW, with 5.6.2 or 5.6.5 FW) Uptime B) Connection time to AP (value under AP information) and C) Uptime (on RB under PPP/Uptime, on UBNT CPE under PPPoE information) as a summary of problems...
PaulsMT
Sun Jun 12, 2016 10:04 pm
Please try to install the latest RouterOS bugfix version, there are several improvements for RB3011, including port flapping fix.
wnet
Sun Jun 12, 2016 10:37 pm
Thanks. Just made without real fix for us (6.36.rc27).
okoun
Tue Sep 27, 2016 11:53 pm
Unfortunately, there is still the problem in version 6.36. flapping all ports 6-10
https://ctrlv.cz/koYO
Takv
Fri Oct 28, 2016 11:49 pm
Exact same problem still happening, but another equipment, RB450G.
Ros v6.37
See atached image
carbonita
Wed Dec 14, 2016 7:27 pm
Similar symptoms on HAP ac running 6.37.3. Resolved by lowering link to 100M full duplex.
carbonita
Sat Dec 17, 2016 3:26 am
Posted too soon. Flapping is back. Attempted the below with no resultant joy:
.ether5 PoE (unpowered) flapping port cable changed to ether4 rj45
.10Mbps full and half duplex
.new cat5 unshielded cables (~1m in length)
BastiaanN
Wed Jan 04, 2017 8:42 am
I have the same problems on a RB3011UiAS-RM (running ROS 6.38 and Firmware 3.35). With a configuration that used to work fine on a RB2011UiAS-2HnD-IN.
I tried to make the configuration from scratch yesterday, but that does not help.
For me the ports that flap are always on switch 1, i haven't seen the issue on switch 2 yet.
Router log:
03:29:18 interface,info ether2-master link up (speed 1G, full duplex)
03:29:19 interface,info ether3 link up (speed 1G, full duplex)
03:29:19 interface,info ether4 link up (speed 1G, full duplex)
03:29:19 igmp-proxy,info starting IGMP proxy forwarding
03:29:19 pppoe,ppp,info KPN: authenticated
03:29:19 pppoe,ppp,info KPN: connected
03:29:29 interface,info WAN link down
03:29:29 interface,info ether2-master link down
03:29:29 interface,info ether3 link down
03:29:29 interface,info ether4 link down
03:29:29 pppoe,ppp,info KPN: terminating... - disconnected
03:29:29 pppoe,ppp,info KPN: disconnected
03:29:29 pppoe,ppp,info KPN: initializing...
03:29:29 pppoe,ppp,info KPN: connecting...
03:29:30 igmp-proxy,error Leave multicast group failed on WAN.4 group=224.0.0.2:
03:29:30 igmp-proxy,error Cannot assign requested address
03:29:30 igmp-proxy,info stopping IGMP proxy forwarding
03:29:32 interface,info WAN link up (speed 1G, full duplex)
03:29:32 interface,info ether2-master link up (speed 1G, full duplex)
03:29:32 interface,info ether3 link up (speed 1G, full duplex)
03:29:33 pppoe,ppp,info KPN: authenticated
03:29:33 pppoe,ppp,info KPN: connected
03:29:33 igmp-proxy,info starting IGMP proxy forwarding
03:29:33 interface,info ether4 link up (speed 1G, full duplex)
03:30:33 pppoe,ppp,info KPN: terminating...
03:30:33 pppoe,ppp,info KPN: disconnected
03:30:33 pppoe,ppp,info KPN: initializing...
03:30:33 pppoe,ppp,info KPN: connecting...
03:30:33 pppoe,ppp,info KPN: authenticated
03:30:33 pppoe,ppp,info KPN: connected
03:31:33 pppoe,ppp,info KPN: terminating...
03:31:33 pppoe,ppp,info KPN: disconnected
03:31:33 pppoe,ppp,info KPN: initializing...
03:31:33 pppoe,ppp,info KPN: connecting...
03:31:33 pppoe,ppp,info KPN: authenticated
03:31:33 pppoe,ppp,info KPN: connected
03:31:33 system,info item added
03:51:34 system,info item removed
03:51:35 system,info item added
03:52:18 interface,info WAN link down
03:52:18 interface,info ether2-master link down
03:52:18 interface,info ether3 link down
03:52:18 interface,info ether4 link down
03:52:18 pppoe,ppp,info KPN: terminating... - disconnected
03:52:18 pppoe,ppp,info KPN: disconnected
03:52:18 pppoe,ppp,info KPN: initializing...
03:52:18 pppoe,ppp,info KPN: connecting...
03:52:18 system,info item removed
03:52:19 igmp-proxy,error Leave multicast group failed on WAN.4 group=224.0.0.2:
03:52:19 igmp-proxy,error Cannot assign requested address
03:52:19 igmp-proxy,info stopping IGMP proxy forwarding
03:52:21 interface,info WAN link up (speed 1G, full duplex)
03:52:21 interface,info ether2-master link up (speed 1G, full duplex)
03:52:21 interface,info ether3 link up (speed 1G, full duplex)
03:52:22 pppoe,ppp,info KPN: terminating...
03:52:22 pppoe,ppp,info KPN: disconnected
03:52:22 pppoe,ppp,info KPN: initializing...
03:52:22 pppoe,ppp,info KPN: connecting...
03:52:22 interface,info ether4 link up (speed 1G, full duplex)
03:52:22 igmp-proxy,info starting IGMP proxy forwarding
03:52:23 pppoe,ppp,info KPN: terminating...
03:52:23 pppoe,ppp,info KPN: disconnected
03:52:23 pppoe,ppp,info KPN: initializing...
03:52:23 pppoe,ppp,info KPN: connecting...
03:52:25 pppoe,ppp,info KPN: initializing...
03:52:25 pppoe,ppp,info KPN: connecting...
03:52:25 pppoe,ppp,info KPN: terminating...
03:52:25 pppoe,ppp,info KPN: disconnected
03:52:28 pppoe,ppp,info KPN: initializing...
03:52:28 pppoe,ppp,info KPN: connecting...
03:52:28 pppoe,ppp,info KPN: terminating...
03:52:28 pppoe,ppp,info KPN: disconnected
03:52:35 pppoe,ppp,info KPN: initializing...
03:52:35 pppoe,ppp,info KPN: connecting...
03:52:35 pppoe,ppp,info KPN: terminating...
03:52:35 pppoe,ppp,info KPN: disconnected
03:52:45 pppoe,ppp,info KPN: initializing...
03:52:45 pppoe,ppp,info KPN: connecting...
03:52:45 pppoe,ppp,info KPN: terminating...
03:52:45 pppoe,ppp,info KPN: disconnected
03:52:55 pppoe,ppp,info KPN: initializing...
03:52:55 pppoe,ppp,info KPN: connecting...
03:52:55 pppoe,ppp,info KPN: terminating...
03:52:55 pppoe,ppp,info KPN: disconnected
03:53:05 pppoe,ppp,info KPN: initializing...
03:53:05 pppoe,ppp,info KPN: connecting...
03:53:05 pppoe,ppp,info KPN: terminating...
03:53:05 pppoe,ppp,info KPN: disconnected
03:53:15 pppoe,ppp,info KPN: initializing...
03:53:15 pppoe,ppp,info KPN: connecting...
03:53:16 pppoe,ppp,info KPN: terminating...
03:53:16 pppoe,ppp,info KPN: disconnected
03:53:26 pppoe,ppp,info KPN: initializing...
03:53:26 pppoe,ppp,info KPN: connecting...
03:53:26 pppoe,ppp,info KPN: terminating...
03:53:26 pppoe,ppp,info KPN: disconnected
03:53:36 pppoe,ppp,info KPN: initializing...
03:53:36 pppoe,ppp,info KPN: connecting...
03:53:36 pppoe,ppp,info KPN: terminating...
03:53:36 pppoe,ppp,info KPN: disconnected
03:53:46 pppoe,ppp,info KPN: initializing...
03:53:46 pppoe,ppp,info KPN: connecting...
03:53:46 pppoe,ppp,info KPN: terminating...
03:53:46 pppoe,ppp,info KPN: disconnected
03:53:56 pppoe,ppp,info KPN: initializing...
03:53:56 pppoe,ppp,info KPN: connecting...
03:53:56 pppoe,ppp,info KPN: terminating...
03:53:56 pppoe,ppp,info KPN: disconnected
03:54:06 pppoe,ppp,info KPN: initializing...
03:54:06 pppoe,ppp,info KPN: connecting...
03:54:06 pppoe,ppp,info KPN: authenticated
03:54:06 pppoe,ppp,info KPN: connected
03:54:06 system,info item added
03:54:34 interface,info WAN link down
03:54:34 interface,info ether2-master link down
03:54:34 interface,info ether3 link down
03:54:34 interface,info ether4 link down
03:54:34 pppoe,ppp,info KPN: terminating... - disconnected
03:54:34 pppoe,ppp,info KPN: disconnected
03:54:34 pppoe,ppp,info KPN: initializing...
03:54:34 pppoe,ppp,info KPN: connecting...
03:54:34 system,info item removed
03:54:35 igmp-proxy,error Leave multicast group failed on WAN.4 group=224.0.0.2:
03:54:35 igmp-proxy,error Cannot assign requested address
03:54:35 igmp-proxy,info stopping IGMP proxy forwarding
03:54:37 interface,info WAN link up (speed 1G, full duplex)
03:54:37 interface,info ether2-master link up (speed 1G, full duplex)
03:54:37 interface,info ether3 link up (speed 1G, full duplex)
03:54:38 pppoe,ppp,info KPN: authenticated
03:54:38 pppoe,ppp,info KPN: connected
03:54:38 interface,info ether4 link up (speed 1G, full duplex)
03:54:38 igmp-proxy,info starting IGMP proxy forwarding
03:55:38 pppoe,ppp,info KPN: terminating...
03:55:38 pppoe,ppp,info KPN: disconnected
03:55:38 pppoe,ppp,info KPN: initializing...
03:55:38 pppoe,ppp,info KPN: connecting...
03:55:38 pppoe,ppp,info KPN: authenticated
03:55:38 pppoe,ppp,info KPN: connected
03:56:38 pppoe,ppp,info KPN: terminating...
03:56:38 pppoe,ppp,info KPN: disconnected
03:56:38 pppoe,ppp,info KPN: initializing...
03:56:38 pppoe,ppp,info KPN: connecting...
03:56:38 pppoe,ppp,info KPN: authenticated
03:56:38 pppoe,ppp,info KPN: connected
03:56:38 system,info item added
04:09:16 interface,info WAN link down
04:09:16 interface,info ether2-master link down
04:09:16 interface,info ether3 link down
04:09:16 interface,info ether4 link down
04:09:16 pppoe,ppp,info KPN: terminating... - disconnected
04:09:16 pppoe,ppp,info KPN: disconnected
04:09:16 pppoe,ppp,info KPN: initializing...
04:09:16 pppoe,ppp,info KPN: connecting...
04:09:16 system,info item removed
04:09:17 igmp-proxy,error Leave multicast group failed on WAN.4 group=224.0.0.2:
04:09:17 igmp-proxy,error Cannot assign requested address
04:09:17 igmp-proxy,info stopping IGMP proxy forwarding
04:09:19 interface,info WAN link up (speed 1G, full duplex)
04:09:19 interface,info ether2-master link up (speed 1G, full duplex)
04:09:20 pppoe,ppp,info KPN: authenticated
04:09:20 pppoe,ppp,info KPN: connected
04:09:20 igmp-proxy,info starting IGMP proxy forwarding
04:09:20 interface,info ether3 link up (speed 1G, full duplex)
04:09:20 interface,info ether4 link up (speed 1G, full duplex)
04:10:20 pppoe,ppp,info KPN: terminating...
04:10:20 pppoe,ppp,info KPN: disconnected
04:10:20 pppoe,ppp,info KPN: initializing...
04:10:20 pppoe,ppp,info KPN: connecting...
04:10:21 pppoe,ppp,info KPN: authenticated
04:10:21 pppoe,ppp,info KPN: connected
04:11:21 pppoe,ppp,info KPN: terminating...
04:11:21 pppoe,ppp,info KPN: disconnected
04:11:21 pppoe,ppp,info KPN: initializing...
04:11:21 pppoe,ppp,info KPN: connecting...
04:11:21 pppoe,ppp,info KPN: authenticated
04:11:21 pppoe,ppp,info KPN: connected
04:11:21 system,info item added
04:31:22 system,info item removed
04:31:23 system,info item added
04:34:09 interface,info WAN link down
04:34:09 pppoe,ppp,info KPN: terminating... - disconnected
04:34:09 interface,info ether2-master link down
04:34:09 interface,info ether3 link down
04:34:09 interface,info ether4 link down
04:34:09 pppoe,ppp,info KPN: disconnected
04:34:09 pppoe,ppp,info KPN: initializing...
04:34:09 pppoe,ppp,info KPN: connecting...
04:34:09 system,info item removed
04:34:10 igmp-proxy,error Leave multicast group failed on WAN.4 group=224.0.0.2:
04:34:10 igmp-proxy,error Cannot assign requested address
04:34:10 igmp-proxy,info stopping IGMP proxy forwarding
04:34:12 interface,info WAN link up (speed 1G, full duplex)
04:34:12 interface,info ether2-master link up (speed 1G, full duplex)
04:34:13 interface,info ether3 link up (speed 1G, full duplex)
04:34:13 interface,info ether4 link up (speed 1G, full duplex)
04:34:13 igmp-proxy,info starting IGMP proxy forwarding
04:34:13 pppoe,ppp,info KPN: terminating...
04:34:13 pppoe,ppp,info KPN: disconnected
04:34:13 pppoe,ppp,info KPN: initializing...
04:34:13 pppoe,ppp,info KPN: connecting...
04:34:14 pppoe,ppp,info KPN: terminating...
04:34:14 pppoe,ppp,info KPN: disconnected
04:34:14 pppoe,ppp,info KPN: initializing...
04:34:14 pppoe,ppp,info KPN: connecting...
04:34:15 pppoe,ppp,info KPN: initializing...
04:34:15 pppoe,ppp,info KPN: connecting...
04:34:15 pppoe,ppp,info KPN: terminating...
04:34:15 pppoe,ppp,info KPN: disconnected
04:34:16 pppoe,ppp,info KPN: initializing...
04:34:16 pppoe,ppp,info KPN: connecting...
04:34:16 pppoe,ppp,info KPN: terminating...
04:34:16 pppoe,ppp,info KPN: disconnected
04:34:20 pppoe,ppp,info KPN: initializing...
04:34:20 pppoe,ppp,info KPN: connecting...
04:34:20 pppoe,ppp,info KPN: terminating...
04:34:20 pppoe,ppp,info KPN: disconnected
04:34:26 pppoe,ppp,info KPN: initializing...
04:34:26 pppoe,ppp,info KPN: connecting...
04:34:26 pppoe,ppp,info KPN: terminating...
04:34:26 pppoe,ppp,info KPN: disconnected
04:34:36 pppoe,ppp,info KPN: initializing...
04:34:36 pppoe,ppp,info KPN: connecting...
04:34:37 pppoe,ppp,info KPN: terminating...
04:34:37 pppoe,ppp,info KPN: disconnected
04:34:47 pppoe,ppp,info KPN: initializing...
04:34:47 pppoe,ppp,info KPN: connecting...
04:34:47 pppoe,ppp,info KPN: terminating...
04:34:47 pppoe,ppp,info KPN: disconnected
04:34:57 pppoe,ppp,info KPN: initializing...
04:34:57 pppoe,ppp,info KPN: connecting...
04:34:57 pppoe,ppp,info KPN: terminating...
04:34:57 pppoe,ppp,info KPN: disconnected
04:35:07 pppoe,ppp,info KPN: initializing...
04:35:07 pppoe,ppp,info KPN: connecting...
04:35:07 pppoe,ppp,info KPN: terminating...
04:35:07 pppoe,ppp,info KPN: disconnected
04:35:17 pppoe,ppp,info KPN: initializing...
04:35:17 pppoe,ppp,info KPN: connecting...
04:35:17 pppoe,ppp,info KPN: terminating...
04:35:17 pppoe,ppp,info KPN: disconnected
04:35:27 pppoe,ppp,info KPN: initializing...
04:35:27 pppoe,ppp,info KPN: connecting...
04:35:27 pppoe,ppp,info KPN: terminating...
04:35:27 pppoe,ppp,info KPN: disconnected
04:35:37 pppoe,ppp,info KPN: initializing...
04:35:37 pppoe,ppp,info KPN: connecting...
04:35:38 pppoe,ppp,info KPN: terminating...
04:35:38 pppoe,ppp,info KPN: disconnected
04:35:48 pppoe,ppp,info KPN: initializing...
04:35:48 pppoe,ppp,info KPN: connecting...
04:35:48 pppoe,ppp,info KPN: terminating...
04:35:48 pppoe,ppp,info KPN: disconnected
04:35:58 pppoe,ppp,info KPN: initializing...
04:35:58 pppoe,ppp,info KPN: connecting...
04:35:58 pppoe,ppp,info KPN: authenticated
04:35:58 pppoe,ppp,info KPN: connected
04:35:58 system,info item added
04:37:22 interface,info WAN link down
04:37:22 pppoe,ppp,info KPN: terminating... - disconnected
04:37:22 pppoe,ppp,info KPN: disconnected
04:37:22 pppoe,ppp,info KPN: initializing...
04:37:22 pppoe,ppp,info KPN: connecting...
04:37:22 interface,info ether2-master link down
04:37:22 interface,info ether3 link down
04:37:22 interface,info ether4 link down
04:37:22 system,info item removed
04:37:23 igmp-proxy,error Leave multicast group failed on WAN.4 group=224.0.0.2:
04:37:23 igmp-proxy,error Cannot assign requested address
04:37:23 igmp-proxy,info stopping IGMP proxy forwarding
04:37:25 interface,info WAN link up (speed 1G, full duplex)
04:37:25 interface,info ether2-master link up (speed 1G, full duplex)
04:37:25 interface,info ether3 link up (speed 1G, full duplex)
04:37:26 pppoe,ppp,info KPN: authenticated
04:37:26 pppoe,ppp,info KPN: connected
04:37:26 interface,info ether4 link up (speed 1G, full duplex)
04:37:26 igmp-proxy,info starting IGMP proxy forwarding
04:38:26 pppoe,ppp,info KPN: terminating...
04:38:26 pppoe,ppp,info KPN: disconnected
04:38:26 pppoe,ppp,info KPN: initializing...
04:38:26 pppoe,ppp,info KPN: connecting...
04:38:26 pppoe,ppp,info KPN: authenticated
04:38:26 pppoe,ppp,info KPN: connected
04:39:26 pppoe,ppp,info KPN: terminating...
04:39:26 pppoe,ppp,info KPN: disconnected
04:39:26 pppoe,ppp,info KPN: initializing...
04:39:26 pppoe,ppp,info KPN: connecting...
04:39:26 pppoe,ppp,info KPN: authenticated
04:39:26 pppoe,ppp,info KPN: connected
04:39:26 system,info item added
04:59:27 system,info item removed
04:59:28 system,info item added
05:02:57 interface,info WAN link down
05:02:57 pppoe,ppp,info KPN: terminating... - disconnected
05:02:57 pppoe,ppp,info KPN: disconnected
05:02:57 pppoe,ppp,info KPN: initializing...
05:02:57 pppoe,ppp,info KPN: connecting...
05:02:57 interface,info ether2-master link down
05:02:57 interface,info ether3 link down
05:02:57 interface,info ether4 link down
05:02:57 system,info item removed
05:02:58 igmp-proxy,error Leave multicast group failed on WAN.4 group=224.0.0.2:
05:02:58 igmp-proxy,error Cannot assign requested address
05:02:58 igmp-proxy,info stopping IGMP proxy forwarding
05:03:00 interface,info WAN link up (speed 1G, full duplex)
05:03:00 interface,info ether2-master link up (speed 1G, full duplex)
05:03:00 interface,info ether3 link up (speed 1G, full duplex)
05:03:01 pppoe,ppp,info KPN: terminating...
05:03:01 pppoe,ppp,info KPN: disconnected
05:03:01 pppoe,ppp,info KPN: initializing...
05:03:01 pppoe,ppp,info KPN: connecting...
05:03:01 interface,info ether4 link up (speed 1G, full duplex)
05:03:01 igmp-proxy,info starting IGMP proxy forwarding
05:03:02 pppoe,ppp,info KPN: initializing...
05:03:02 pppoe,ppp,info KPN: connecting...
05:03:02 pppoe,ppp,info KPN: terminating...
05:03:02 pppoe,ppp,info KPN: disconnected
05:03:03 pppoe,ppp,info KPN: initializing...
05:03:03 pppoe,ppp,info KPN: connecting...
05:03:03 pppoe,ppp,info KPN: terminating...
05:03:03 pppoe,ppp,info KPN: disconnected
05:03:07 pppoe,ppp,info KPN: initializing...
05:03:07 pppoe,ppp,info KPN: connecting...
05:03:07 pppoe,ppp,info KPN: terminating...
05:03:07 pppoe,ppp,info KPN: disconnected
05:03:13 pppoe,ppp,info KPN: initializing...
05:03:13 pppoe,ppp,info KPN: connecting...
05:03:14 pppoe,ppp,info KPN: terminating...
05:03:14 pppoe,ppp,info KPN: disconnected
05:03:24 pppoe,ppp,info KPN: initializing...
05:03:24 pppoe,ppp,info KPN: connecting...
05:03:24 pppoe,ppp,info KPN: terminating...
05:03:24 pppoe,ppp,info KPN: disconnected
05:03:34 pppoe,ppp,info KPN: initializing...
05:03:34 pppoe,ppp,info KPN: connecting...
05:03:34 pppoe,ppp,info KPN: terminating...
05:03:34 pppoe,ppp,info KPN: disconnected
05:03:44 pppoe,ppp,info KPN: initializing...
05:03:44 pppoe,ppp,info KPN: connecting...
05:03:44 pppoe,ppp,info KPN: terminating...
05:03:44 pppoe,ppp,info KPN: disconnected
05:03:54 pppoe,ppp,info KPN: initializing...
05:03:54 pppoe,ppp,info KPN: connecting...
05:03:54 pppoe,ppp,info KPN: terminating...
05:03:54 pppoe,ppp,info KPN: disconnected
05:04:04 pppoe,ppp,info KPN: initializing...
05:04:04 pppoe,ppp,info KPN: connecting...
05:04:05 pppoe,ppp,info KPN: terminating...
05:04:05 pppoe,ppp,info KPN: disconnected
05:04:15 pppoe,ppp,info KPN: initializing...
05:04:15 pppoe,ppp,info KPN: connecting...
05:04:15 pppoe,ppp,info KPN: terminating...
05:04:15 pppoe,ppp,info KPN: disconnected
05:04:25 pppoe,ppp,info KPN: initializing...
05:04:25 pppoe,ppp,info KPN: connecting...
05:04:25 pppoe,ppp,info KPN: terminating...
05:04:25 pppoe,ppp,info KPN: disconnected
05:04:35 pppoe,ppp,info KPN: initializing...
05:04:35 pppoe,ppp,info KPN: connecting...
05:04:35 pppoe,ppp,info KPN: authenticated
05:04:35 pppoe,ppp,info KPN: connected
05:04:35 system,info item added
05:04:55 interface,info WAN link down
05:04:55 interface,info ether2-master link down
05:04:55 interface,info ether3 link down
05:04:55 interface,info ether4 link down
05:04:55 pppoe,ppp,info KPN: terminating... - disconnected
05:04:55 pppoe,ppp,info KPN: disconnected
05:04:55 pppoe,ppp,info KPN: initializing...
05:04:55 pppoe,ppp,info KPN: connecting...
05:04:55 system,info item removed
05:04:56 igmp-proxy,error Leave multicast group failed on WAN.4 group=224.0.0.2:
05:04:56 igmp-proxy,error Cannot assign requested address
05:04:56 igmp-proxy,info stopping IGMP proxy forwarding
05:04:58 interface,info WAN link up (speed 1G, full duplex)
05:04:58 interface,info ether2-master link up (speed 1G, full duplex)
05:04:59 pppoe,ppp,info KPN: authenticated
05:04:59 pppoe,ppp,info KPN: connected
05:04:59 igmp-proxy,info starting IGMP proxy forwarding
05:04:59 interface,info ether3 link up (speed 1G, full duplex)
05:04:59 interface,info ether4 link up (speed 1G, full duplex)
05:05:59 pppoe,ppp,info KPN: terminating...
05:05:59 pppoe,ppp,info KPN: disconnected
05:05:59 pppoe,ppp,info KPN: initializing...
05:05:59 pppoe,ppp,info KPN: connecting...
05:05:59 pppoe,ppp,info KPN: authenticated
05:05:59 pppoe,ppp,info KPN: connected
05:06:59 pppoe,ppp,info KPN: terminating...
05:06:59 pppoe,ppp,info KPN: disconnected
05:06:59 pppoe,ppp,info KPN: initializing...
05:06:59 pppoe,ppp,info KPN: connecting...
05:06:59 pppoe,ppp,info KPN: authenticated
05:06:59 pppoe,ppp,info KPN: connected
05:06:59 system,info item added
05:19:55 interface,info WAN link down
05:19:55 pppoe,ppp,info KPN: terminating... - disconnected
05:19:55 interface,info ether2-master link down
05:19:55 interface,info ether3 link down
05:19:55 interface,info ether4 link down
05:19:55 pppoe,ppp,info KPN: disconnected
05:19:55 pppoe,ppp,info KPN: initializing...
05:19:55 pppoe,ppp,info KPN: connecting...
05:19:55 system,info item removed
05:19:56 igmp-proxy,error Leave multicast group failed on WAN.4 group=224.0.0.2:
05:19:56 igmp-proxy,error Cannot assign requested address
05:19:56 igmp-proxy,info stopping IGMP proxy forwarding
05:19:58 interface,info WAN link up (speed 1G, full duplex)
05:19:58 interface,info ether2-master link up (speed 1G, full duplex)
05:19:58 interface,info ether3 link up (speed 1G, full duplex)
05:19:59 pppoe,ppp,info KPN: authenticated
05:19:59 pppoe,ppp,info KPN: connected
05:19:59 interface,info ether4 link up (speed 1G, full duplex)
05:19:59 igmp-proxy,info starting IGMP proxy forwarding
05:20:59 pppoe,ppp,info KPN: terminating...
05:20:59 pppoe,ppp,info KPN: disconnected
05:20:59 pppoe,ppp,info KPN: initializing...
05:20:59 pppoe,ppp,info KPN: connecting...
05:20:59 pppoe,ppp,info KPN: authenticated
05:20:59 pppoe,ppp,info KPN: connected
05:21:59 pppoe,ppp,info KPN: terminating...
05:21:59 pppoe,ppp,info KPN: disconnected
05:21:59 pppoe,ppp,info KPN: initializing...
05:21:59 pppoe,ppp,info KPN: connecting...
05:21:59 pppoe,ppp,info KPN: authenticated
05:21:59 pppoe,ppp,info KPN: connected
05:21:59 system,info item added
05:41:59 system,info item removed
05:42:00 system,info item added
05:44:28 interface,info WAN link down
05:44:28 interface,info ether2-master link down
05:44:28 interface,info ether3 link down
05:44:28 interface,info ether4 link down
05:44:28 pppoe,ppp,info KPN: terminating... - disconnected
05:44:28 pppoe,ppp,info KPN: disconnected
05:44:28 pppoe,ppp,info KPN: initializing...
05:44:28 pppoe,ppp,info KPN: connecting...
05:44:28 system,info item removed
05:44:29 igmp-proxy,error Leave multicast group failed on WAN.4 group=224.0.0.2:
05:44:29 igmp-proxy,error Cannot assign requested address
05:44:29 igmp-proxy,info stopping IGMP proxy forwarding
05:44:31 interface,info WAN link up (speed 1G, full duplex)
05:44:31 interface,info ether2-master link up (speed 1G, full duplex)
05:44:32 pppoe,ppp,info KPN: terminating...
05:44:32 pppoe,ppp,info KPN: disconnected
05:44:32 pppoe,ppp,info KPN: initializing...
05:44:32 pppoe,ppp,info KPN: connecting...
05:44:32 igmp-proxy,info starting IGMP proxy forwarding
05:44:32 interface,info ether3 link up (speed 1G, full duplex)
05:44:32 interface,info ether4 link up (speed 1G, full duplex)
05:44:33 pppoe,ppp,info KPN: initializing...
05:44:33 pppoe,ppp,info KPN: connecting...
05:44:33 pppoe,ppp,info KPN: terminating...
05:44:33 pppoe,ppp,info KPN: disconnected
05:44:35 pppoe,ppp,info KPN: initializing...
05:44:35 pppoe,ppp,info KPN: connecting...
05:44:35 pppoe,ppp,info KPN: terminating...
05:44:35 pppoe,ppp,info KPN: disconnected
05:44:38 pppoe,ppp,info KPN: initializing...
05:44:38 pppoe,ppp,info KPN: connecting...
05:44:38 pppoe,ppp,info KPN: terminating...
05:44:38 pppoe,ppp,info KPN: disconnected
05:44:45 pppoe,ppp,info KPN: initializing...
05:44:45 pppoe,ppp,info KPN: connecting...
05:44:45 pppoe,ppp,info KPN: terminating...
05:44:45 pppoe,ppp,info KPN: disconnected
05:44:55 pppoe,ppp,info KPN: initializing...
05:44:55 pppoe,ppp,info KPN: connecting...
05:44:55 pppoe,ppp,info KPN: terminating...
05:44:55 pppoe,ppp,info KPN: disconnected
05:45:05 pppoe,ppp,info KPN: initializing...
05:45:05 pppoe,ppp,info KPN: connecting...
05:45:05 pppoe,ppp,info KPN: terminating...
05:45:05 pppoe,ppp,info KPN: disconnected
05:45:15 pppoe,ppp,info KPN: initializing...
05:45:15 pppoe,ppp,info KPN: connecting...
05:45:15 pppoe,ppp,info KPN: terminating...
05:45:15 pppoe,ppp,info KPN: disconnected
05:45:25 pppoe,ppp,info KPN: initializing...
05:45:25 pppoe,ppp,info KPN: connecting...
05:45:26 pppoe,ppp,info KPN: terminating...
05:45:26 pppoe,ppp,info KPN: disconnected
05:45:36 pppoe,ppp,info KPN: initializing...
05:45:36 pppoe,ppp,info KPN: connecting...
05:45:36 pppoe,ppp,info KPN: terminating...
05:45:36 pppoe,ppp,info KPN: disconnected
05:45:46 pppoe,ppp,info KPN: initializing...
05:45:46 pppoe,ppp,info KPN: connecting...
05:45:46 pppoe,ppp,info KPN: terminating...
05:45:46 pppoe,ppp,info KPN: disconnected
05:45:56 pppoe,ppp,info KPN: initializing...
05:45:56 pppoe,ppp,info KPN: connecting...
05:45:56 pppoe,ppp,info KPN: terminating...
05:45:56 pppoe,ppp,info KPN: disconnected
05:46:06 pppoe,ppp,info KPN: initializing...
05:46:06 pppoe,ppp,info KPN: connecting...
05:46:06 pppoe,ppp,info KPN: authenticated
05:46:06 pppoe,ppp,info KPN: connected
05:46:06 system,info item added
05:47:20 interface,info WAN link down
05:47:20 interface,info ether2-master link down
05:47:20 interface,info ether3 link down
05:47:20 interface,info ether4 link down
05:47:20 pppoe,ppp,info KPN: terminating... - disconnected
05:47:20 pppoe,ppp,info KPN: disconnected
05:47:20 pppoe,ppp,info KPN: initializing...
05:47:20 pppoe,ppp,info KPN: connecting...
05:47:20 system,info item removed
05:47:21 igmp-proxy,error Leave multicast group failed on WAN.4 group=224.0.0.2:
05:47:21 igmp-proxy,error Cannot assign requested address
05:47:21 igmp-proxy,info stopping IGMP proxy forwarding
05:47:23 interface,info WAN link up (speed 1G, full duplex)
05:47:23 interface,info ether2-master link up (speed 1G, full duplex)
05:47:23 interface,info ether3 link up (speed 1G, full duplex)
05:47:24 igmp-proxy,info starting IGMP proxy forwarding
05:47:24 interface,info ether4 link up (speed 1G, full duplex)
05:47:24 pppoe,ppp,info KPN: authenticated
05:47:24 pppoe,ppp,info KPN: connected
05:48:24 pppoe,ppp,info KPN: terminating...
05:48:24 pppoe,ppp,info KPN: disconnected
05:48:24 pppoe,ppp,info KPN: initializing...
05:48:24 pppoe,ppp,info KPN: connecting...
05:48:25 pppoe,ppp,info KPN: authenticated
05:48:25 pppoe,ppp,info KPN: connected
05:49:25 pppoe,ppp,info KPN: terminating...
05:49:25 pppoe,ppp,info KPN: disconnected
05:49:25 pppoe,ppp,info KPN: initializing...
05:49:25 pppoe,ppp,info KPN: connecting...
05:49:25 pppoe,ppp,info KPN: authenticated
05:49:25 pppoe,ppp,info KPN: connected
05:49:25 system,info item added
06:09:25 system,info item removed
06:09:26 system,info item added
06:22:47 interface,info WAN link down
06:22:47 pppoe,ppp,info KPN: terminating... - disconnected
06:22:47 interface,info ether2-master link down
06:22:47 pppoe,ppp,info KPN: disconnected
06:22:47 pppoe,ppp,info KPN: initializing...
06:22:47 interface,info ether3 link down
06:22:47 pppoe,ppp,info KPN: connecting...
06:22:47 interface,info ether4 link down
06:22:47 system,info item removed
06:22:48 igmp-proxy,error Leave multicast group failed on WAN.4 group=224.0.0.2:
06:22:48 igmp-proxy,error Cannot assign requested address
06:22:48 igmp-proxy,info stopping IGMP proxy forwarding
06:22:50 interface,info WAN link up (speed 1G, full duplex)
06:22:50 interface,info ether2-master link up (speed 1G, full duplex)
06:22:50 interface,info ether3 link up (speed 1G, full duplex)
06:22:51 pppoe,ppp,info KPN: terminating...
06:22:51 pppoe,ppp,info KPN: disconnected
06:22:51 pppoe,ppp,info KPN: initializing...
06:22:51 pppoe,ppp,info KPN: connecting...
06:22:51 interface,info ether4 link up (speed 1G, full duplex)
06:22:51 igmp-proxy,info starting IGMP proxy forwarding
06:22:52 pppoe,ppp,info KPN: initializing...
06:22:52 pppoe,ppp,info KPN: connecting...
06:22:52 pppoe,ppp,info KPN: terminating...
06:22:52 pppoe,ppp,info KPN: disconnected
06:22:54 pppoe,ppp,info KPN: initializing...
06:22:54 pppoe,ppp,info KPN: connecting...
06:22:54 pppoe,ppp,info KPN: terminating...
06:22:54 pppoe,ppp,info KPN: disconnected
06:22:57 pppoe,ppp,info KPN: initializing...
06:22:57 pppoe,ppp,info KPN: connecting...
06:22:57 pppoe,ppp,info KPN: terminating...
06:22:57 pppoe,ppp,info KPN: disconnected
06:23:04 pppoe,ppp,info KPN: initializing...
06:23:04 pppoe,ppp,info KPN: connecting...
06:23:04 pppoe,ppp,info KPN: terminating...
06:23:04 pppoe,ppp,info KPN: disconnected
06:23:14 pppoe,ppp,info KPN: initializing...
06:23:14 pppoe,ppp,info KPN: connecting...
06:23:14 pppoe,ppp,info KPN: terminating...
06:23:14 pppoe,ppp,info KPN: disconnected
06:23:24 pppoe,ppp,info KPN: initializing...
06:23:24 pppoe,ppp,info KPN: connecting...
06:23:24 pppoe,ppp,info KPN: terminating...
06:23:24 pppoe,ppp,info KPN: disconnected
06:23:34 pppoe,ppp,info KPN: initializing...
06:23:34 pppoe,ppp,info KPN: connecting...
06:23:34 pppoe,ppp,info KPN: terminating...
06:23:34 pppoe,ppp,info KPN: disconnected
06:23:44 pppoe,ppp,info KPN: initializing...
06:23:44 pppoe,ppp,info KPN: connecting...
06:23:44 pppoe,ppp,info KPN: terminating...
06:23:44 pppoe,ppp,info KPN: disconnected
06:23:54 pppoe,ppp,info KPN: initializing...
06:23:54 pppoe,ppp,info KPN: connecting...
06:23:55 pppoe,ppp,info KPN: terminating...
06:23:55 pppoe,ppp,info KPN: disconnected
06:24:05 pppoe,ppp,info KPN: initializing...
06:24:05 pppoe,ppp,info KPN: connecting...
06:24:05 pppoe,ppp,info KPN: terminating...
06:24:05 pppoe,ppp,info KPN: disconnected
06:24:15 pppoe,ppp,info KPN: initializing...
06:24:15 pppoe,ppp,info KPN: connecting...
06:24:15 pppoe,ppp,info KPN: terminating...
06:24:15 pppoe,ppp,info KPN: disconnected
06:24:25 pppoe,ppp,info KPN: initializing...
06:24:25 pppoe,ppp,info KPN: connecting...
06:24:25 pppoe,ppp,info KPN: authenticated
06:24:25 pppoe,ppp,info KPN: connected
06:24:25 system,info item added
06:26:05 interface,info WAN link down
06:26:05 pppoe,ppp,info KPN: terminating... - disconnected
06:26:05 pppoe,ppp,info KPN: disconnected
06:26:05 pppoe,ppp,info KPN: initializing...
06:26:05 pppoe,ppp,info KPN: connecting...
06:26:05 interface,info ether2-master link down
06:26:05 interface,info ether3 link down
06:26:05 interface,info ether4 link down
06:26:05 system,info item removed
06:26:06 igmp-proxy,error Leave multicast group failed on WAN.4 group=224.0.0.2:
06:26:06 igmp-proxy,error Cannot assign requested address
06:26:06 igmp-proxy,info stopping IGMP proxy forwarding
06:26:08 interface,info WAN link up (speed 1G, full duplex)
06:26:08 interface,info ether2-master link up (speed 1G, full duplex)
06:26:09 pppoe,ppp,info KPN: authenticated
06:26:09 pppoe,ppp,info KPN: connected
06:26:09 interface,info ether4 link up (speed 1G, full duplex)
06:26:09 igmp-proxy,info starting IGMP proxy forwarding
06:26:10 interface,info ether3 link up (speed 1G, full duplex)
06:27:09 pppoe,ppp,info KPN: terminating...
06:27:09 pppoe,ppp,info KPN: disconnected
06:27:09 pppoe,ppp,info KPN: initializing...
06:27:09 pppoe,ppp,info KPN: connecting...
06:27:09 pppoe,ppp,info KPN: authenticated
06:27:09 pppoe,ppp,info KPN: connected
06:28:09 pppoe,ppp,info KPN: terminating...
06:28:09 pppoe,ppp,info KPN: disconnected
06:28:09 pppoe,ppp,info KPN: initializing...
06:28:09 pppoe,ppp,info KPN: connecting...
06:28:09 pppoe,ppp,info KPN: authenticated
06:28:09 pppoe,ppp,info KPN: connected
06:28:09 system,info item added
06:48:10 system,info item removed
06:48:11 system,info item added
06:49:59 interface,info WAN link down
06:49:59 interface,info ether2-master link down
06:49:59 interface,info ether3 link down
06:49:59 interface,info ether4 link down
06:49:59 pppoe,ppp,info KPN: terminating... - disconnected
06:49:59 pppoe,ppp,info KPN: disconnected
06:49:59 pppoe,ppp,info KPN: initializing...
06:49:59 pppoe,ppp,info KPN: connecting...
06:49:59 system,info item removed
06:50:00 igmp-proxy,error Leave multicast group failed on WAN.4 group=224.0.0.2:
06:50:00 igmp-proxy,error Cannot assign requested address
06:50:00 igmp-proxy,info stopping IGMP proxy forwarding
06:50:02 interface,info WAN link up (speed 1G, full duplex)
06:50:02 interface,info ether2-master link up (speed 1G, full duplex)
06:50:02 interface,info ether3 link up (speed 1G, full duplex)
06:50:03 pppoe,ppp,info KPN: terminating...
06:50:03 pppoe,ppp,info KPN: disconnected
06:50:03 pppoe,ppp,info KPN: initializing...
06:50:03 pppoe,ppp,info KPN: connecting...
06:50:03 interface,info ether4 link up (speed 1G, full duplex)
06:50:03 igmp-proxy,info starting IGMP proxy forwarding
06:50:04 pppoe,ppp,info KPN: initializing...
06:50:04 pppoe,ppp,info KPN: connecting...
06:50:04 pppoe,ppp,info KPN: terminating...
06:50:04 pppoe,ppp,info KPN: disconnected
06:50:06 pppoe,ppp,info KPN: initializing...
06:50:06 pppoe,ppp,info KPN: connecting...
06:50:06 pppoe,ppp,info KPN: terminating...
06:50:06 pppoe,ppp,info KPN: disconnected
06:50:09 pppoe,ppp,info KPN: initializing...
06:50:09 pppoe,ppp,info KPN: connecting...
06:50:09 pppoe,ppp,info KPN: terminating...
06:50:09 pppoe,ppp,info KPN: disconnected
06:50:16 pppoe,ppp,info KPN: initializing...
06:50:16 pppoe,ppp,info KPN: connecting...
06:50:16 pppoe,ppp,info KPN: terminating...
06:50:16 pppoe,ppp,info KPN: disconnected
06:50:26 pppoe,ppp,info KPN: initializing...
06:50:26 pppoe,ppp,info KPN: connecting...
06:50:26 pppoe,ppp,info KPN: terminating...
06:50:26 pppoe,ppp,info KPN: disconnected
06:50:36 pppoe,ppp,info KPN: initializing...
06:50:36 pppoe,ppp,info KPN: connecting...
06:50:36 pppoe,ppp,info KPN: terminating...
06:50:36 pppoe,ppp,info KPN: disconnected
06:50:46 pppoe,ppp,info KPN: initializing...
06:50:46 pppoe,ppp,info KPN: connecting...
06:50:47 pppoe,ppp,info KPN: terminating...
06:50:47 pppoe,ppp,info KPN: disconnected
06:50:57 pppoe,ppp,info KPN: initializing...
06:50:57 pppoe,ppp,info KPN: connecting...
06:50:57 pppoe,ppp,info KPN: terminating...
06:50:57 pppoe,ppp,info KPN: disconnected
06:51:07 pppoe,ppp,info KPN: initializing...
06:51:07 pppoe,ppp,info KPN: connecting...
06:51:07 pppoe,ppp,info KPN: terminating...
06:51:07 pppoe,ppp,info KPN: disconnected
06:51:17 pppoe,ppp,info KPN: initializing...
06:51:17 pppoe,ppp,info KPN: connecting...
06:51:17 pppoe,ppp,info KPN: terminating...
06:51:17 pppoe,ppp,info KPN: disconnected
06:51:27 pppoe,ppp,info KPN: initializing...
06:51:27 pppoe,ppp,info KPN: connecting...
06:51:27 pppoe,ppp,info KPN: terminating...
06:51:27 pppoe,ppp,info KPN: disconnected
06:51:37 pppoe,ppp,info KPN: initializing...
06:51:37 pppoe,ppp,info KPN: connecting...
06:51:37 pppoe,ppp,info KPN: terminating...
06:51:37 pppoe,ppp,info KPN: disconnected
06:51:47 pppoe,ppp,info KPN: initializing...
06:51:47 pppoe,ppp,info KPN: connecting...
06:51:48 pppoe,ppp,info KPN: authenticated
06:51:48 pppoe,ppp,info KPN: connected
06:51:48 system,info item added
06:57:31 interface,info WAN link down
06:57:31 pppoe,ppp,info KPN: terminating... - disconnected
06:57:31 interface,info ether2-master link down
06:57:31 pppoe,ppp,info KPN: disconnected
06:57:31 pppoe,ppp,info KPN: initializing...
06:57:31 interface,info ether3 link down
06:57:31 pppoe,ppp,info KPN: connecting...
06:57:31 interface,info ether4 link down
06:57:31 system,info item removed
06:57:32 igmp-proxy,error Leave multicast group failed on WAN.4 group=224.0.0.2:
06:57:32 igmp-proxy,error Cannot assign requested address
06:57:32 igmp-proxy,info stopping IGMP proxy forwarding
06:57:34 interface,info WAN link up (speed 1G, full duplex)
06:57:34 interface,info ether2-master link up (speed 1G, full duplex)
06:57:34 interface,info ether3 link up (speed 1G, full duplex)
06:57:35 pppoe,ppp,info KPN: authenticated
06:57:35 pppoe,ppp,info KPN: connected
06:57:35 interface,info ether4 link up (speed 1G, full duplex)
06:57:35 igmp-proxy,info starting IGMP proxy forwarding
06:58:35 pppoe,ppp,info KPN: terminating...
06:58:35 pppoe,ppp,info KPN: disconnected
06:58:35 pppoe,ppp,info KPN: initializing...
06:58:35 pppoe,ppp,info KPN: connecting...
06:58:35 pppoe,ppp,info KPN: authenticated
06:58:35 pppoe,ppp,info KPN: connected
06:59:35 pppoe,ppp,info KPN: terminating...
06:59:35 pppoe,ppp,info KPN: disconnected
06:59:35 pppoe,ppp,info KPN: initializing...
06:59:35 pppoe,ppp,info KPN: connecting...
06:59:35 pppoe,ppp,info KPN: authenticated
06:59:35 pppoe,ppp,info KPN: connected
06:59:35 system,info item added
07:19:35 system,info item removed
07:19:36 system,info item added
I created an issue with Mikrotik support.
verbovet
Sun Feb 19, 2017 2:11 am
I had this problem on CCR1009-8G-1S-1S+PC with 6.38.1.
Flapping stopped when I disabled the loop protect feature.
iperezandres
Mon Feb 20, 2017 12:07 pm
Same issue here. My model is a 2011UiAS-2HnD, firmware 3.33 and v6.38.1.
Only see the flapping in the second switch (eth 6-10).
I have tried many things without success. I have just disabled loop protection, let's see how it goes...
Thanks!
iperezandres
Mon Feb 20, 2017 12:11 pm
Sorry, didn't work setting the loop protection to "off", same link down / link up situation.
The frequency is not constant, sometimes it happens every minute, every 2 minutes, 5 minutes...
UPDATE: it happens in both switches, 1 and 2. What I have in that port is a Sony Bravia TV with Android TV.
fr4nk
Wed Feb 22, 2017 6:41 pm
i have the same problem with a RB3011UiAS-RM. Ether1 and Ether4 flapping. Ether1 is WAN and Ether4 is switch (cisco WS-C3750G-24TS). No other ports are connected to RB3011UiAS-RM. Flapping occurs when there is no wan traffic (eg. over night). If i do remove the Ether1 flapping occurs, if i remove ether4 (cisco switch WS-C3750G-24TS) flapping do not occur. EtherStats from Mikrotik Router OS and EtherStats from Cisco do not show any errors or collisions. Cisco C3750G-24TS works with no problems, no other device connected to the switch do have any problems.
i tried to reboot RB3011UiAS-RM as last device on the network, but flapping still occurs.
i tried to turn off loop protection, but flapping still occurs.
i tried to change the uplink cables to ether1 and ether2, but flapping still occurs.
i changed port on Cisco switch from port1 to port2 connected to RB3011UiAS-RM and i changed port on RB3011UiAS-RM from ether4 to ether5 connected to cisco switch, both with no success.
The port flapping frequency is not constant. same like "ipereandres" in thread post #23
Basically there is no issue with that. As soon as there is traffic flapping stops. But logs are horrible to read and it feels like something is wrong.
Is there any way to get a detailed report why RB3011UiAS-RM puts the ports down and up again. The log only states "07:52:14 interface,info ether1 link down". What are the circumstances to take this ether ports down?
Firmware and ROS is the newest.
Takv
Mon Apr 17, 2017 4:34 pm
Using latest current release 6.38.5 and port flaping still happens in rb450g, and x86 using intel pro 1000 4 port gigabit cards.
Indeed, its more common with the last update.
Whats going on? The reports of this problem started from year 2011 as I read the forums, and begining with the 6.38.x routeros version it increased a lot.
Some fixes around? Any help to make routers stop flapping each 1, 2, 5, 10, 30 minutes or a workaround will be appreciated.
iperezandres
Wed Dec 05, 2018 10:21 am
The same here, a long time has passed and we already have v6.43.4 and nothing has changed. I think it might be related to the device connected to the port that flaps. In my case it is an smart TV, so I suspect that when it is in standby mode, it connects and disconnects from time to time.
BastiaanN
Wed Dec 05, 2018 10:40 am
In my case it stopped when i replaced the original power supply, haven't had an issue since.
Users browsing this forum: No registered users and 31 guests
