MUM Europe 2020
hi4ibb
problem: authorization login page opening always when user connect to network
Tue Feb 09, 2016 12:42 am
hi all,
how i can make login page opening for once time, cause when user disconnect to my network and comeback it have to enter password always , and i don't want that.
anyone can help me ?
ZeroByte
Re: problem: authorization login page opening always when user connect to network
Tue Feb 09, 2016 12:45 am
enable http cookies login in the hotspot's profile.
When given a spoon,
you should not cling to your fork.
The soup will get cold.
hi4ibb
Tue Feb 09, 2016 1:19 am
i made that friend, but same problem.
well, i mean i want user comback to my network without login page if it is authorization.
is this problem has relation with timeout idle or keepalive timeout
kiaunel
Tue Feb 09, 2016 1:32 am
Like as @Zerobyte said... As long the cookie is valid user get no login screen. Tested in my config also. Make sure cookie validity time is set equal to user authorization time.
Sent from my Lenovo K50-t5 using Tapatalk
ZeroByte
Tue Feb 09, 2016 1:34 am
Yes - if the host's authorization times out,then they're going to get a login screen again.
If you don't have idle timeouts or at the very least, maximum session durations, then you're going to run out of host IP addresses.
You could also enable MAC authentication if you want to have completely transparent logins - but self-service adding those to RADIUS might be tricky.
When given a spoon,
hi4ibb
Tue Feb 09, 2016 4:20 pm
well i will explain more, i mean i use user manager , and i want person login in my network once time per day, i mean login and when disconnect and comeback no need to open login page , i want server know that person authorization and when person reach limit of hours or validity, then i want page open automatically agian .
okay friend, could you give me best settings for timeout idle and keepalive for my wireless network
my settings are :
hotspot idle timeout = 00:30:00
hotspot keepalive timeout = none
hotspot login timeout = 00:05:00
user profile idle timeout = 00:05:00
user profile keepalive timout= none
user profile session timeout = none
is it okay settings ?
ZeroByte
Tue Feb 09, 2016 6:05 pm
I'm not normally a fan of doing things with scripts, but perhaps you would be happiest if you had a script that runs at, say, 4:00am and disconnects all active sessions, and then set the timeouts to zero in the hotspot/user profiles.
As for the timers you posted, the user profile values will override the hotspot profile values, so while the hotspot's idle timeout is 30 minutes, the users' profile will time them out in just 5 minutes, with the values you posted. I don't think that's what you want.
When given a spoon,
hi4ibb
Tue Feb 09, 2016 6:30 pm
thank you friend , you maybe helped me in last point you comment
i have to increase timeout of hotspot and set hotspot keepalive , i think that is mean they will seen long time in ip hosts , that is good for authorization clients . is that right ?
ZeroByte
Tue Feb 09, 2016 8:51 pm
As long as they stay active in the hosts list, then yes, they're not going to be forced to login again.
When given a spoon,
macotel
Wed Feb 10, 2016 3:05 pm
Im having a similar problem. My hotspot has multiple login pages 1 for paid wifi 1 for free wifi and 1 for home. The login.html is the home page. The loginfree.html is the free low speed login and the loginpaid.html is the paid wifi. When connected to the wifi network we get directed to the login.html page (home). when I click the link to either paid or free and press the submit button it brings me back to the login.html page (home). When I rename the loginfree or loginpaid html to login.html it works. Any ideas?
osasmike
I CANNOT LOGIN TO USER MANAGER
Wed Feb 17, 2016 4:51 pm
I try to log into user manager but it says your section been reset due to inactivity. i need help
Users browsing this forum: Calvinfuete, dmitris, Matta, mccowboy and 44 guests
