MUM Europe 2020
kiaunel
Export configuration to another diferent device
Fri Feb 12, 2016 6:54 am
I think I already know the answer but if I try to export the whole config from a 433ah to a 750g it will work?
Sent from my Lenovo K50-t5 using Tapatalk
jarda
Fri Feb 12, 2016 9:03 am
Sure the export will work. But before the import you will have to rewrite the script to be acceptable by totally different device.
kiaunel
Fri Feb 12, 2016 9:20 am
I just tried... Worked.... somehow
But ETH interfaces were switched... I mean plunged cable in ether1 but in ros the link came up to ether3 I think because the two wireless interfaces from 433 are missing in 750g.
Users browsing this forum: Google [Bot] and 27 guests
