taundertaker773
Mikrotik 6.34.1 Check updates fail
Tue Feb 16, 2016 2:44 pm
Good day this is a new build which i did on my own however i'm receiving this error: Could not resolve dns name when i try to update the server or any packages ?
Also the hotspot i can login on the page but won't connect to internet ?
osquetar
Re: Mikrotik 6.34.1 Check updates fail
Mon Mar 21, 2016 9:58 am
Same here!
macgaiver
Mon Mar 21, 2016 10:35 am
Then you both have issues with your DNS configuration, make sure that you can resolve upgrade.mikrotik.com
With great knowledge comes great responsibility, because of ability to recognize id... incompetent people much faster.
Uqbar
Thu Mar 24, 2016 8:09 pm
How can I test from within the Mikrotik whether I can resolv upgrade.mikrotik.com?
It's clearly not working!
So the real question is how can I troubleshoot it?
I can resolv from lan, but not from the router itself.
There's never a stupid question. But often stupid answers.
And, yes I do used search engines. This is why I am here.
normis
Sat Mar 26, 2016 7:49 pm
ping upgrade.mikrotik.com from RouterOS terminal and from your Windows PC. Compare results and post here
Uqbar
Sat Mar 26, 2016 8:45 pm
From "PC":
support@server:/home/support > ping -c 5 upgrade.mikrotik.com
PING d355q2xs8kb5oj.cloudfront.net (54.192.131.180) 56(84) bytes of data.
64 bytes from server-54-192-131-180.ams50.r.cloudfront.net (54.192.131.180): icmp_req=1 ttl=53 time=44.1 ms
64 bytes from server-54-192-131-180.ams50.r.cloudfront.net (54.192.131.180): icmp_req=2 ttl=53 time=47.3 ms
64 bytes from server-54-192-131-180.ams50.r.cloudfront.net (54.192.131.180): icmp_req=3 ttl=53 time=43.9 ms
64 bytes from server-54-192-131-180.ams50.r.cloudfront.net (54.192.131.180): icmp_req=4 ttl=53 time=47.4 ms
64 bytes from server-54-192-131-180.ams50.r.cloudfront.net (54.192.131.180): icmp_req=5 ttl=53 time=47.3 ms
--- d355q2xs8kb5oj.cloudfront.net ping statistics ---
5 packets transmitted, 5 received, 0% packet loss, time 4006ms
rtt min/avg/max/mdev = 43.948/46.048/47.461/1.658 ms
From Mikrotik:
[admin@NA2] > ping upgrade.mikrotik.com
invalid value for argument address:
    invalid value of mac-address, mac address required
    invalid value for argument ipv6-address
    while resolving ip-address: could not get answer from dns server
The router is the only machine that cannot resolve anything.
Useless to say that:
1. From within the router tools-->traceroute works as expected;
2. The router has proper configuration for DNSes (4: 2xGoogle and 2xOpenDNS);
3. From the LAN everything works fine.
shankuo
Thu Apr 07, 2016 6:08 am
same problem but more error messages. "ERROR: Could not resolve DNS name" and "ERROR: Bad HTTP response"
The Ping test received replies from the host upgrade.mikrotik.com.
After the ERROR: Could not resolve DNS name the next error message "ERROR: Bad HTTP response"
What MikroTik utilities tools do I use to troubleshoot this problem and to upgrade the firmware?
normis
Thu Apr 07, 2016 9:41 am
terminal uses router DNS server, Winbox uses PC OS (Linux / OSX in your case) DNS server. Check if you configured the same DNS server address in "IP DNS" menu, just like you have in your PC OS.
normis
Thu Apr 07, 2016 9:51 am
add "dns,debug" to your log, and make a supout.rif file, email to us, we will check debug logs
shankuo
Sun Apr 10, 2016 7:24 am
I tried update firmware today without any changes to the DNS setting either on the PC and MikroTik router both error message did not appear but new error message appears "ERROR: Missing wireless-6.34.4-mipsebe.npk". I have enclosed the file directory where there is a wireless-6.34.4-mipsebe.npk but zero file length.
File wireless-6.34.4-mipsebe.npk file length is ZERO.
As per your request, the supout.rif was created and send to support via Mikrotik support website.
Update 13th April 2016
Problem solved, error message "wireless-6.34-mipsebe.npk file" did not appear after the router reboot and the "wireless-6.34-mipsebe.npk file size remains as ZERO.
flynno
Sun Apr 10, 2016 8:11 pm
Download package and upload to router solves the problem.
Add google dns 8.8.8.8 & 8.8.4.4
cszolee79
Thu Jun 30, 2016 9:36 pm
Same problem here, tried with only 8.8.8.8 and many different free DNS servers, but the router did not see upgrade.mikrotik.com. ROS 6.33 / 6.35. This is my home router, UPC cable net behind their UBEE cable modem.
Client PC connected to the router, using the same DNS servers can ping the upgrade server. Other Mikrotik routers at other ISPs can upgrade without problem.
Added static entry in IP/DNS for upgrade.mikrotik.com 52.85.184.245 and now works perfectly.
Sometimes things just happen with no explanation :)
One... Hundred... BILLION DOLLARS!
pe1chl
Thu Jun 30, 2016 10:12 pm
I had such problems when there was a link with less than 1500 bytes MTU further down the path.
The server hosting the updates does not process ICMP "must fragment but DF set" replies correctly.
When the router has a mangle rule to clamp the MSS to a lower value, it works OK.
Uqbar
Fri Jul 01, 2016 11:31 am
That indeed works!
But I cannot accept that "it just happened"!
Something in the resover path was wrong, and was wrong only there.
I have 7 of these routers, 6 upgraded gracefully and one resufed to do so until the "DNS trick".
There must be an explaination.
pe1chl
Fri Jul 01, 2016 1:08 pm
I tried updating a RB750 this morning and it took quite some time before it displayed the changelog.
So I guess that part of the update servers are down or otherwise malfunctioning.
taundertaker773
Fri Jul 15, 2016 7:18 pm
I had to Disable "Drop ICMP From Outside" and Bang! It worked Thanks Alot for all your feedbacks
Kincaidc
Thu Aug 25, 2016 11:20 pm
Guys just login into the routerboard with winbox. under quick set at the top left put 192.168.1.1 for your router ip and then open a cmd prompt in windows on your machine and type nslookup dns. Put that DNS address in the DNS address of the router in winbox and click the Static IP setting and apply. this will resolve your DNS issues
hardtik
Wed Sep 13, 2017 12:25 pm
I have disabled firewall rule disabling incoming connection from L2TP (ISP-provider). After that update works... After update I have enabled the rule back.
Den4ik
Thu Oct 26, 2017 11:33 am
Just add static name in your IP->DNS
upgrade.mikrotik.com 13.33.44.253
mikedefieslife
Wed Feb 14, 2018 12:52 pm
Similar issue here.
I added the static DNS line, and can now ping upgrade.mikrotik.com from within the router, but checking for updates times out
Uqbar
Wed Feb 14, 2018 1:08 pm
Maybe I am wrong, but this issue is going too far.
Adding an entry into the /etc/hosts file to fix a DNS issue sounds like childish to me.
I understand this is among the rarest issues with this otherwise marvelous product, but there needs to be a reason and, of course, a solution.
Is there any logging we can enable to the "update check" process so we can provide useful data for debugging?
If not, please, add one in the next release and I'll be happy to apply it on my 8 Mikrotik boxes to help.
pe1chl
Wed Feb 14, 2018 1:49 pm
Please read back further above, it does not have to be a DNS issue but it can be a path MTU issue as well.
What is the error message you get?
DimitriDm
Tue Apr 10, 2018 9:50 pm
Hello, i have the some problem, i have configured my routerboard from default mode and on my pc i have network access with dhcp, i have updated dns to google default, and i have tried to add a static redirect to mikrotik ip dns but On the routerboard still dont have internet.
Can you help?
Dm
Uqbar
Wed Apr 11, 2018 11:27 am
Can you help?
viewtopic.php?p=642434#p624968
Be warned: it's a workaround, not a solution!
jmbrnt
Tue Apr 24, 2018 11:26 am
I had this rather weird issue as well - but mine was self inflicted. Somewhere along the line I must have thought I was clever and added a static DNS entry with a poorly formed regex. It was something like [*esxi*] to point things to my home esxi server.. I don't know what I was trying to achieve - however the troubleshooting suggested in this thread helped me.
Using the web-based terminal, I did
put [resolve google.com]
(shows the internal IP of my esxi box!)
/ip dns static
print
Then saw the static DNS entry I had, so i removed it (using GUI) and things updated as expected.
marmachine
Sat Aug 18, 2018 12:33 am
I've found the cause in the wrong DNS settings.
Using Google's DNS server solved it for me.
Enter the next in your terminal:
/ip dns set allow-remote-requests=yes cache-max-ttl=1d cache-size=2048KiB max-udp-packet-size=4096 servers=8.8.8.8,8.8.4.4
Uqbar
Sat Aug 18, 2018 3:09 pm
Do you think Google DNSes have better answers?
I don't understand how your "fix" is related to the problem.
pe1chl
Sat Nov 10, 2018 3:16 pm
I would not advise setting a static address, especially one not tracable to MikroTik.
As I see that advise mainly/only from 1-time posters, let's assume they have bad intentions and ignore them.
Uqbar
Sat Nov 10, 2018 3:27 pm
I fully agree.
I'd like mikrotik to investigate and fix.
pml
Sun Dec 02, 2018 10:56 am
Hi
I had the following rule in /ip firewall filter
;;; defconf; drop all not coming from LAN
chain=input action=drop in-interface-list=!LAN
Where LAN was defined as my LAN addresses.
Temporarily disabling this rule fixed it, and allowed me to update. I just enabled it again after.
Note that the above rule was as per the wiki for a secure firewall, I think it may also be in the default set.
Uqbar
Sun Dec 02, 2018 2:12 pm
Hi
That's a totally different issue.
In the case this topic is about, the router can access the internet but cannot check against Mikrotik sites for upgrades.
pe1chl
Sun Dec 02, 2018 4:20 pm
Hi
That rule is OK to have, but there should also be a rule above that which allows "established" and "related" traffic.
When you delete that, you will have problems.
terryw
Mon Dec 24, 2018 5:05 am
I have the same issue after I upgraded 6.43.8. None of the recommendations resolved my issue.
balkyny
Fri Jan 11, 2019 6:59 am
Hi
I have the same problem.
The problem was that blocking rules in firewall were at the very top.
I moved it lower without disabling, and everything started to work :)
Uqbar
Fri Jan 11, 2019 4:18 pm
Hi
I think there actually are two different types of problem here.
One is user-created, the other one is (could be?) a bug.
If the user blocks the DNS traffic (UDP:53, TCP:53) or the HTTP traffic to/from the update server (IP:185.53.178.9), then it's clear the update won't work.
There's no solution other that making finer grane firewall rules in order to let the router use the DNS for upgrade.mikrotik.com and let the router pull the needed files from there.
If it was just the DNS to be blocked, adding the entry into the hosts file "just fixed the feature"(tm) by bypassing the DNS altogether.
The "other case" is a different story.
There was no firewall filtering, just the "masquerading NAT" to let the packets reach the internet and the answers come back.
Sometimes adding a hosts file entry solved. Some other times, it didn't.
That's in my opinion a real software bug that needs further investigation.
I admit I have no clue on which one holds true.
My suspicion goes to the latter case.
upperscartlea
Tue Feb 19, 2019 5:43 pm
Hi Normis,
I have this issue with upgrading (following TKS Ja Tutorial #4) using WinBox on Windows 10. Ping on Windows works fine, PING on WinBox terminal issues an IPv6 error invalid arguments for MAC/IPV6 etc.
Any help?
Peter
mikst
Sat Mar 02, 2019 11:09 pm
Adding
chain=input action=accept connection-state=established,related
solved this for me.
Thanks for the suggestion!
pe1chl
Wed Mar 06, 2019 4:11 pm
Adding
solved this for me.
Ok that was the case of the user-created problem then.
(this rule is in the default firewall, you removed it)
adrianTNT
Thu Mar 14, 2019 3:32 pm
I had same problem today could not update because dns didn't find the name.
It was an easy fix:
- go to "ip > dns"
- first box under "servers" (was empty) I entered the DNS from google: 8.8.8.8
- click OK
Now it should find the host name/firmware.
You can add more underneath the same box, I also entered 8.8.4.4 (also from Google) and 1.1.1.1 (from CloudFlare)
anav
Thu Mar 14, 2019 6:00 pm
Quite a long trail of posts.
i was going to respond to the original OP post by stating,
The routerOS has a built-in mechanism whereby if you have left updating your ROS for too long and clearly 6.34.1 is so OLD.........
then the MT update server, rejects the attempt as the user simply doesn't have the IT acument to be privileged enough to use MT routers, without supervision LOL.
We need an MT Bulletin..... ;-p
A letter of apology to MT and proof of apology letter to the business one is employed under (if in IT), same for the university or institution one graduated from (if in IT or computer science or software engineering), same to ones family for such negligence) is required to unlock ones shame and the router. :-)))))
Cause as this post proves......................... operator error!!!
I'd rather manage rats than software. Follow my advice at your own risk! (Sob & mkx forced me to write that!)
Users browsing this forum: No registered users and 10 guests
