MUM Europe 2020
Think7
[ CHR ] FATAL ERROR: No harddrives found
Wed Feb 17, 2016 5:10 pm
I have been trying to install the CHR image on an OVH VPS but continually get the "No harddrives found" error.
Someone has had a similar issue: http://forum.mikrotik.com/viewtopic.php?t=99793 however they were using the standard ISO rather than the CHR image.
Very much am using the chr-6.34.1.img and the VM boots into the installer, but then throws the "FATAL ERROR: no hard drives found".
The exact procedure i have taken is:
- Created a Win2012R2 VM.
- Attach a 10GB HDD to it.
- Download the CHR image file listed above.
- Used this tool: http://hddguru.com/software/HDD-Raw-Copy-Tool/ to write the image to the drive.
- Rebooted the VM to the newly written drive.
- Installer starts, then throws No harddrives found error.
EDIT:
I just tried again using CentOS and DD to write the raw image to the disk. Same issue:
Below is a hwinfo printout of that same VM booted into CentOS 7.
server-2
    description: Computer
    product: OpenStack Nova
    vendor: OpenStack Foundation
    version: 2014.2.3
    serial: c7fb1b80-d3c8-11e4-8000-001e67caded6
    width: 64 bits
    capabilities: smbios-2.4 dmi-2.4 vsyscall32
    configuration: boot=normal uuid=0D08F27A-D5C4-4330-B7E7-C8AF5F0B95CE
  *-core
       description: Motherboard
       physical id: 0
     *-firmware
          description: BIOS
          vendor: Bochs
          physical id: 0
          version: Bochs
          date: 01/01/2011
     *-cpu
          description: CPU
          product: Intel Xeon E312xx (Sandy Bridge)
          vendor: Intel Corp.
          physical id: 401
          bus info: cpu@0
          slot: CPU 1
          capacity: 2GHz
          width: 64 bits
          capabilities: fpu fpu_exception wp vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush mmx fxsr sse sse2 ss syscall nx pdpe1gb rdtscp x86-64 constant_tsc rep_good nopl eagerfpu pni pclmulqdq vmx ssse3 fma cx16 pcid sse4_1 sse4_2 x2apic movbe popcnt tsc_deadline_timer aes xsave avx f16c rdrand hypervisor lahf_lm abm xsaveopt vnmi ept fsgsbase bmi1 avx2 smep bmi2 erms invpcid
     *-memory
          description: System Memory
          physical id: 1000
          capacity: 4000MiB
        *-bank
             description: DIMM RAM
             physical id: 0
             slot: DIMM 0
             width: 64 bits
     *-generic:0 UNCLAIMED
          physical id: 1
          bus info: parisc@1
     *-generic:1 UNCLAIMED
          physical id: 10
          bus info: parisc@10
     *-generic:2 UNCLAIMED
          physical id: 108
          bus info: parisc@108
     *-generic:3 UNCLAIMED
          physical id: 11
          bus info: parisc@11
     *-generic:4 UNCLAIMED
          physical id: 112
          bus info: parisc@112
     *-generic:5 UNCLAIMED
          physical id: 113
          bus info: parisc@113
     *-generic:6 UNCLAIMED
          physical id: 115
          bus info: parisc@115
     *-generic:7 UNCLAIMED
          physical id: 116
          bus info: parisc@116
     *-generic:8 UNCLAIMED
          physical id: 12
          bus info: parisc@12
     *-generic:9 UNCLAIMED
          physical id: 13
          bus info: parisc@13
     *-generic:10 UNCLAIMED
          physical id: 136
          bus info: parisc@136
     *-generic:11 UNCLAIMED
          physical id: 14
          bus info: parisc@14
     *-generic:12 UNCLAIMED
          physical id: 142
          bus info: parisc@142
     *-generic:13 UNCLAIMED
          physical id: 143
          bus info: parisc@143
     *-generic:14 UNCLAIMED
          physical id: 144
          bus info: parisc@144
     *-generic:15 UNCLAIMED
          physical id: 15
          bus info: parisc@15
     *-generic:16 UNCLAIMED
          physical id: 16
          bus info: parisc@16
     *-generic:17 UNCLAIMED
          physical id: 17
          bus info: parisc@17
     *-generic:18 UNCLAIMED
          physical id: 18
          bus info: parisc@18
     *-generic:19 UNCLAIMED
          physical id: 19
          bus info: parisc@19
     *-generic:20 UNCLAIMED
          physical id: 2
          bus info: parisc@2
     *-generic:21 UNCLAIMED
          physical id: 20
          bus info: parisc@20
     *-generic:22 UNCLAIMED
          physical id: 205
          bus info: parisc@205
     *-generic:23 UNCLAIMED
          physical id: 21
          bus info: parisc@21
     *-generic:24 UNCLAIMED
          physical id: 210
          bus info: parisc@210
     *-generic:25 UNCLAIMED
          physical id: 214
          bus info: parisc@214
     *-generic:26 UNCLAIMED
          physical id: 22
          bus info: parisc@22
     *-generic:27 UNCLAIMED
          physical id: 227
          bus info: parisc@227
     *-generic:28 UNCLAIMED
          physical id: 234
          bus info: parisc@234
     *-generic:29 UNCLAIMED
          physical id: 24
          bus info: parisc@24
     *-generic:30 UNCLAIMED
          physical id: 25
          bus info: parisc@25
     *-generic:31 UNCLAIMED
          physical id: 26
          bus info: parisc@26
     *-generic:32 UNCLAIMED
          physical id: 27
          bus info: parisc@27
     *-generic:33 UNCLAIMED
          physical id: 273
          bus info: parisc@273
     *-generic:34 UNCLAIMED
          physical id: 28
          bus info: parisc@28
     *-generic:35 UNCLAIMED
          physical id: 286
          bus info: parisc@286
     *-generic:36 UNCLAIMED
          physical id: 29
          bus info: parisc@29
     *-generic:37 UNCLAIMED
          physical id: 3
          bus info: parisc@3
     *-generic:38 UNCLAIMED
          physical id: 302
          bus info: parisc@302
     *-generic:39 UNCLAIMED
          physical id: 303
          bus info: parisc@303
     *-generic:40 UNCLAIMED
          physical id: 306
          bus info: parisc@306
     *-generic:41 UNCLAIMED
          physical id: 308
          bus info: parisc@308
     *-generic:42 UNCLAIMED
          physical id: 313
          bus info: parisc@313
     *-generic:43 UNCLAIMED
          physical id: 319
          bus info: parisc@319
     *-generic:44 UNCLAIMED
          physical id: 320
          bus info: parisc@320
     *-generic:45 UNCLAIMED
          physical id: 321
          bus info: parisc@321
     *-generic:46 UNCLAIMED
          physical id: 38
          bus info: parisc@38
     *-generic:47 UNCLAIMED
          physical id: 39
          bus info: parisc@39
     *-generic:48 UNCLAIMED
          physical id: 40
          bus info: parisc@40
     *-generic:49 UNCLAIMED
          physical id: 41
          bus info: parisc@41
     *-generic:50 UNCLAIMED
          physical id: 5
          bus info: parisc@5
     *-generic:51 UNCLAIMED
          physical id: 550
          bus info: parisc@550
     *-generic:52 UNCLAIMED
          physical id: 6
          bus info: parisc@6
     *-generic:53 UNCLAIMED
          physical id: 60
          bus info: parisc@60
     *-generic:54 UNCLAIMED
          physical id: 61
          bus info: parisc@61
     *-generic:55 UNCLAIMED
          physical id: 7
          bus info: parisc@7
     *-generic:56 UNCLAIMED
          physical id: 713
          bus info: parisc@713
     *-generic:57 UNCLAIMED
          physical id: 739
          bus info: parisc@739
     *-generic:58 UNCLAIMED
          physical id: 741
          bus info: parisc@741
     *-generic:59 UNCLAIMED
          physical id: 742
          bus info: parisc@742
     *-generic:60 UNCLAIMED
          physical id: 8
          bus info: parisc@8
     *-generic:61 UNCLAIMED
          physical id: 84
          bus info: parisc@84
     *-generic:62 UNCLAIMED
          physical id: 851
          bus info: parisc@851
     *-generic:63 UNCLAIMED
          physical id: 852
          bus info: parisc@852
     *-generic:64 UNCLAIMED
          physical id: 9
          bus info: parisc@9
     *-pci
          description: Host bridge
          product: 440FX - 82441FX PMC [Natoma]
          vendor: Intel Corporation
          physical id: 100
          bus info: pci@0000:00:00.0
          version: 02
          width: 32 bits
          clock: 33MHz
        *-isa
             description: ISA bridge
             product: 82371SB PIIX3 ISA [Natoma/Triton II]
             physical id: 1
             bus info: pci@0000:00:01.0
             version: 00
             width: 32 bits
             clock: 33MHz
             capabilities: isa
             configuration: latency=0
        *-ide
             description: IDE interface
             product: 82371SB PIIX3 IDE [Natoma/Triton II]
             physical id: 1.1
             bus info: pci@0000:00:01.1
             version: 00
             width: 32 bits
             clock: 33MHz
             capabilities: ide bus_master
             configuration: driver=ata_piix latency=0
             resources: irq:0 ioport:1f0(size=8) ioport:3f6 ioport:170(size=8) ioport:376 ioport:c0a0(size=16)
        *-usb
             description: USB controller
             product: 82371SB PIIX3 USB [Natoma/Triton II]
             physical id: 1.2
             bus info: pci@0000:00:01.2
             version: 01
             width: 32 bits
             clock: 33MHz
             capabilities: uhci bus_master
             configuration: driver=uhci_hcd latency=0
             resources: irq:11 ioport:c040(size=32)
           *-usbhost
                product: UHCI Host Controller
                vendor: Linux 3.10.0-229.1.2.el7.x86_64 uhci_hcd
                physical id: 1
                bus info: usb@1
                logical name: usb1
                version: 3.10
                capabilities: usb-1.10
                configuration: driver=hub slots=2 speed=12Mbit/s
              *-usb
                   description: Mouse
                   product: QEMU USB Tablet
                   vendor: QEMU
                   physical id: 1
                   bus info: usb@1:1
                   version: 0.00
                   serial: 42
                   capabilities: usb-2.00
                   configuration: driver=usbhid maxpower=100mA speed=12Mbit/s
        *-bridge
             description: Bridge
             product: 82371AB/EB/MB PIIX4 ACPI
             physical id: 1.3
             bus info: pci@0000:00:01.3
             version: 03
             width: 32 bits
             clock: 33MHz
             capabilities: bridge
             configuration: driver=piix4_smbus latency=0
             resources: irq:9
        *-display
             description: VGA compatible controller
             product: GD 5446
             vendor: Cirrus Logic
             physical id: 2
             bus info: pci@0000:00:02.0
             version: 00
             width: 32 bits
             clock: 33MHz
             capabilities: vga_controller rom
             configuration: driver=cirrus latency=0
             resources: irq:0 memory:fc000000-fdffffff memory:febd0000-febd0fff memory:febc0000-febcffff
        *-network
             description: Ethernet interface
             product: Virtio network device
             vendor: Red Hat, Inc
             physical id: 3
             bus info: pci@0000:00:03.0
             logical name: eth0
             version: 00
             serial: fa:16:3e:fa:b5:8c
             width: 32 bits
             clock: 33MHz
             capabilities: msix bus_master cap_list rom ethernet physical
             configuration: broadcast=yes driver=virtio_net driverversion=1.0.0 ip=167.114.242.1 latency=0 link=yes multicast=yes
             resources: irq:10 ioport:c060(size=32) memory:febd1000-febd1fff memory:feb80000-febbffff
        *-scsi
             description: SCSI storage controller
             product: Virtio block device
             physical id: 4
             bus info: pci@0000:00:04.0
             version: 00
             width: 32 bits
             clock: 33MHz
             capabilities: scsi msix bus_master cap_list
             configuration: driver=virtio-pci latency=0
             resources: irq:11 ioport:c000(size=64) memory:febd2000-febd2fff
        *-generic
             description: Unclassified device
             product: Virtio memory balloon
             physical id: 5
             bus info: pci@0000:00:05.0
             version: 00
             width: 32 bits
             clock: 33MHz
             capabilities: bus_master
             resources: irq:10 ioport:c080(size=32)
Think7
Re: [ CHR ] FATAL ERROR: No harddrives found
Sun Feb 21, 2016 11:40 am
Update!
Turns out that while the RAW image does not detect a suitable drive, both the VHDX and VDI versions do!
I'm not sure if this is intentional by MTK or not. My (possibly incorrect) understanding was that every variant of the CHR would have every supported driver.
Either way, it works! :D :D :D
janisk
Tue May 03, 2016 2:04 pm
just checked, and CHR loads normally using
$ qemu-system-x86_64 --version
QEMU emulator version 2.5.0 (Debian 1:2.5+dfsg-5ubuntu10), Copyright (c) 2003-2008 Fabrice Bellard
or
$ kvm --version
Users browsing this forum: No registered users and 2 guests
