satish143
Block DDoS on Prerouting chain on firewall
Fri Feb 26, 2016 9:01 pm
We are getting lots of IP Fragmentation style DDoS, Packets are marked with MF (more fragment flag) and Mikrotik is super busy in assemble packets. CPU is 100% that time.
Is there a way i can block or stop IP Fragmented packet with MF bit on Prerouting chain? But prerouting chain doesn't support "DROP" action. Why prerouting doesn't have "DROP"?
Or any other solution to stop this kind of attack??
ZeroByte
Re: Block DDoS on Prerouting chain on firewall
Fri Feb 26, 2016 9:11 pm
You could make action=mark-packet new-packet-mark=dropme
and then in filter table:
chain=input packet-mark=dropme action=drop
chain=forward packet-mark=dropme action=drop
Do be aware that this could break other things that are legitimately having packet fragmentation along the path.
When given a spoon,
you should not cling to your fork.
The soup will get cold.
satish143
Fri Feb 26, 2016 9:49 pm
Is there a way i can mark only "MF" flag in prerouting? How do i filter fragmented packet in Prerouting chain?
satish143
Sat Feb 27, 2016 9:08 pm
Anybody who can help?
satish143
Mon Feb 29, 2016 4:24 pm
Any solution?
dada
Mon Feb 29, 2016 5:59 pm
new mangle rule/extra/[x] ip fragment
as mentioned before - fragmented traffic is perfectly legal. By dropping subsequent fragments you will probably make more problems than you solve
chechito
Mon Feb 29, 2016 8:34 pm
is important to establish if offending traffic is toward the router itself or is in transit traffic
satish143
Tue Mar 01, 2016 3:56 pm
are application is voice base RTP packet which data size is less than 512 bytes. We did all kind of study and finally decided we don't need fragmented packet. We run sniffer for 1 month to detect fragmented packet and we didn't find single fragmented packet. We have dual home network so i want to restrict fragment on public facing interface.
I was reading doc and its saying following for "IP Fragment" option in firewall
Matches fragmented packets. First (starting) fragment does not count. If connection tracking is enabled there will be no fragments as system automatically assembles every packet.
We have connection tracking enabled, do you think your option will help?
satish143
Tue Mar 01, 2016 3:57 pm
Its transit traffic toward my servers.
chechito
Tue Mar 01, 2016 4:09 pm
maybe limiting specific application destination port to a max size of packet?? looks like ip firewall has the option of match ip fragments
satish143
Tue Mar 01, 2016 7:02 pm
Here is the problem, even if i identify my packet is IP Fragmented but i want to drop then in PREROUTING chain itself. because if i block them in INPUT or FORWARD chain my CPU get 100%.
I want to stop them in PREROUTING so it won't touch routing table and get drop on door before getting in.
What do you suggest?
ZeroByte
Tue Mar 01, 2016 7:13 pm
This won't improve your performance.
Only the forward or input chain can actually block packets. Mangle is like a paint sprayer - it can mark packets and change some interesting values on them, but it doesn't do any discarding.
Even if it did, this would not improve the performance, because the same basic actions must be taken: receive packet, identify it as a fragment, discard it. Routing table lookups are a very very very fast operation and don't take much CPU, especially when a destination is cached.
When given a spoon,
satish143
Tue Mar 01, 2016 8:11 pm
Okay! Enable IP Fragment option in "Prerouting" chain to mark fragmented packet but its not matching any single packet. If i disable check mark "IP fragment" it start matching packet..
I am sending "IP Fragmented" packet using following command to test,
-x option will set "MF" bit in packet. I have tired other option ot like -f and -g but its not matching anyone. I think its different purpose for IP fragment.
hping3 -V --icmp --data 100 -x 192.168.200.2
chechito
Tue Mar 01, 2016 8:45 pm
maybe you need a powerfull routerboard than actual??
satish143
Tue Mar 01, 2016 9:29 pm
I have CCR1036-8G-2S+ 16GB memory 32 CPUs, Does it enough?
chechito
Tue Mar 01, 2016 9:54 pm
ccr1036 has 36 cpu tile cores not 32
bandwidth an pps of legitimate traffic??
bandwidth and pps of offending traffic when attacked??
dada
Tue Mar 01, 2016 9:55 pm
As you already mentioned the problem is probably that ROS does the fragment reassembly automatically when connection tracking is enabled (i.e. when filter rules used). So you will see no packet fragment - the packet will enter the rules after it was reassembled.
So I see no solution for you here.
Note: in the past we had another type of problems with fragmented packets. On CPE stations we configure a firewall (allowing only configured SRC IPs from client, etc) and disabled connection tracking (there is no NAT and no statefull firewall). Sometimes it happened that the customer was not able to run VPNs/tunnels through the CPE. It showed that fragmented traffic was not forwarded. Explanation from MT support was that when there is any filter rule fragmented packets are dropped (it is expected that connection tracking is enabled and thus thare are no real fragments goints though rules). The problem was a little bit fuzzy because without changing the config all was working most time. After CPE restart the problem could appear or disappear. Enabling the connection tracking solved it. Later ROS versions enable the tracking automatically if filter rules are present and default settings is used.
satish143
Tue Mar 01, 2016 11:40 pm
You are right, its 36 core. 100kpps and total bandwidth is 1G internet link
satish143
Tue Mar 01, 2016 11:41 pm
You are right, if connection tracking is enabled then you will never be able to find fragmented packet because it get assembly at door.
How other company handling this kind of attack?
dada
Wed Mar 02, 2016 7:48 am
I hope the fragments you want to eliminate are part of some DDoS attack. For example if the attack is made by DNS protocol you could try to filter all packes which have SRC port UDP/53. If you are lucky enough you can made exceptions for legal DNS traffic (i.e. if your customers use known set of DNS servers).
Maybe when the first packet id dropped the fragments will be dropped silently too. But maybe the logic of packet reassembly will be behaving badly inthis case too. I would ask MT support if they have solution for you.
We are not using MT for nothing else than CPE, AP. You are a proof that even 36 CPUs is not enough (if they are not effectivelly used and are not too powerful alone). You could replace the box with x86 and run ROS or Linux on it. Than you can use some accelerated NIC (which allows to distribute packets to more cores) and be able much more traffic
satish143
Wed Mar 02, 2016 11:51 pm
attacker sending traffic on RTP ports (12000-13000 UDP Port), and they mark packet with "MF" flag set with ~1500 around packet size.
In my lab i am trying to reproduce this attack using hping3 command and if i set "MF" flag and sending hell load of traffic Mikrotik CPU hitting 100%
But if i run same test on simple Linux firewall (iptables) CPU is under 1% and system is happy.. Something weird going on with Mikrotik, or its not able to use 36 CPU properly... i don't know but result is very diff
jarda
Sat Mar 05, 2016 8:26 am
Have you informed support? What did they reply?
bajodel
Long time Member
Long time Member
Thu Mar 17, 2016 9:50 am
any news on this?
chechito
Mon Feb 26, 2018 6:44 pm
sebastia
Mon Feb 26, 2018 9:33 pm
Was about to say same thing: drop in RAW...
Users browsing this forum: No registered users and 93 guests
