MUM Europe 2020
calvofede
SMB can access by WiFi but not by ethernet
Tue Mar 01, 2016 12:34 am
I have a problem woth access to SMB, i set to all interfaces but I only can access by WiFi (192.168.32.0/24). By ethernet says: "Tha path was not found". Ethernet eth10 is (10.128.0.4-10.128.0.30).
enabled: yes
        domain: WORKGROUP
       comment: CarpetaCompartida
  allow-guests: no
    interfaces: all
 #   ADDRESS            NETWORK         INTERFACE
 0   ;;; Bridge UniFi
     192.168.32.1/24    192.168.32.0    UniFi
 1   ;;; Enlace Mikrotik2
     10.0.0.1/30        10.0.0.0        ether13
 2   ;;; server
     192.168.32.1/24    192.168.32.0    ether2
 3 XI 10.128.8.1/22      10.128.8.0      ether13_vlan400
 4   ;;; Switch oficina
     10.128.0.1/24      10.128.0.0      ether10
 5   10.128.4.1/22      10.128.4.0      ether11
 6   192.168.33.1/24    192.168.33.0    vlan100-UniFi
 7 XI 192.168.34.1/24    192.168.34.0    vlan550
 8   10.128.8.1/22      10.128.8.0      ether12
 9 D 190.11.32.98/29    190.11.32.96    ether1
10 D 10.0.0.1/32        10.0.0.2        <pptp-cfede>
 0 ADS  0.0.0.0/0                          190.11.32.97              0
 1  DC  10.0.0.0/30        10.0.0.1        ether13                 255
 2 ADC  10.0.0.2/32        10.0.0.1        <pptp-cfede>              0
 3 ADC  10.128.0.0/24      10.128.0.1      ether10                   0
 4  DC  10.128.4.0/22      10.128.4.1      ether11                 255
 5  DC  10.128.8.0/22      10.128.8.1      ether12                 255
 6   S  ;;; M2
        10.128.32.0/19                     10.0.0.2                  1
 7 ADC  190.11.32.96/29    190.11.32.98    ether1                    0
 8 ADC  192.168.32.0/24    192.168.32.1    UniFi                     0
                                           UniFi
 9 ADC  192.168.33.0/24    192.168.33.1    vlan100-UniFi             0
With UniFi I can access to that folder but with Eth10 I can't.
What can i do?
Splash
Re: SMB can access by WiFi but not by ethernet
Tue Mar 01, 2016 12:44 pm
Maybe some tests you could perform.
Check IP gateway that is being assigned to the client computer is correct. (subnet etc)
Ping the SMB share IP. (probably the 10.128.0.1 ip)
Traceroute to the SMB share IP.
Torch the interface to see if you are seeing requests.
MTCNA, MTCRE, MTCINE, MTCTCE, MTCIPv6E, MTCUME
calvofede
Mon Mar 07, 2016 5:08 pm
Its rare because sometimes it shows up the login windows but no matter what user and password i put that after login says "The path was not found".
Maybe something with firewall?
Over Wifi works perfect.
Users browsing this forum: MSN [Bot] and 28 guests
