infospa
Visual C++ Runtime Error! Windows 10 Help!!!
Sat Mar 05, 2016 7:54 pm
Helllo!
I have this problem in three PC on windows 10, the Dude client not work
do you have any solution? I used 6.34 and 6.35
ShayanFiroozi
Re: Visual C++ Runtime Error! Windows 10 Help!!!
Sat Mar 05, 2016 11:01 pm
try to uninstall/install MS VC++ runtime 2010 or 2013 , see what happens
The price of your knowledge which you have to pay is to share it with others !!
infospa
Sun Mar 06, 2016 11:56 am
I tried but not good! Do you have another soutions? Thank You!
ShayanFiroozi
Sun Mar 06, 2016 2:05 pm
it could be be a bug or incompatibility with your OS , contact support
callumbrieske
Sun Mar 13, 2016 7:41 am
I am having this same issue. Two of my PC's will now not run the dude client. All machines are window 10 pro.
I just did a clean install on my main desktop, and I am still getting this error. Only with the dude, no other programs are causing this issue.
I have downloaded and installed all the runtime libs to no avail. This is a very frustrating issue.
UPDATE: It appears that this issue may have something to do with windows update KB3140743 or KB3139907. Unfortunately KB3139907 cannot be uninstalled to confirm this. However, only my machines that do not have KB3139907 installed will run the client.
callumbrieske
Wed Mar 16, 2016 6:48 am
Well this error seems to have been caused by windows update. After a recent windows update, all my dude clients have started working again.
Very odd.
Spawny
Wed Apr 06, 2016 4:58 pm
I had the same problem.
Solved by disabling all non windows services.
msconfig/services - Hide all Microsoft services and disable all left.
infospa
Mon May 16, 2016 9:27 am
I always have the same problem on 8 pcs different operating systems .
I disabled the services
And uninstalled packages
without solving
krisjanis
Tue May 24, 2016 1:18 pm
Looks like in at least one case the problem was solved by setting dude.exe to run in win8 compatibility mode.
Basdno
Wed Jun 15, 2016 8:28 pm
Didnt work for me atleast! :'(
Basdno
Fri Jun 17, 2016 3:56 pm
And now a second PC has succumbed to this annoying problem! Grrr
This is my office backup PC with Windows7, has worked like a charm on this PC for years!
This PC basically is running 24/7, BECAUSE it is supposed to make DUDE accessible from my phone when I am out working.
Did DUDE Client code change recently in any way that could do this,
Or is it just Microsoft Windows pushing out shit breaking updates again?
This PC might have autoupdated, cause I had to log in to it today when I came to the office, so I still suspect Windows update!
Cheers
tberg
Tue Jun 21, 2016 9:19 pm
We are also having this problem on Windows 8.1 & 10.  One WIn8 machine works fine and the other doesn't.  Tried on 4 different Win10 machines.  None worked initially, but I was able to get one of them to work after removing a few other programs.  I thought the problem program was Wireshark, but one of the other laptops that doesn't work has never had Wireshark installed.  Haven't had time to troubleshoot in depth yet.
Todd
Basdno
Wed Jun 22, 2016 11:55 am
I guess Windows update is messing something up!
On my second PC The DUDE stopped working after an automatic update.
I have no auto update on the PCs still working!
Has any1 asked / posted anything on Windows/Microsoft support yet?
krisjanis
Wed Jun 22, 2016 1:00 pm
We will also look into this as soon as we actually catch one of our windows workstations doing this. So far no luck.
Basdno
Fri Jul 29, 2016 11:10 am
Does 6.36 release solve the Runtime C++ problem discussed here?
It is really annoying, and I havent dared to upgrade my 2 last Windows PCs in fear I will loose all my DUDE Clients. Then I will be "Blind"!
I am also really unsure if I gonna dare upgrade my main dude client PC to Win10 before the offer expires end of July, cause I really can not afford loosing my DUDE client just because of a free Win10 Update! ;D lol
krisjanis
Fri Jul 29, 2016 1:36 pm
Basdno
Wed Nov 23, 2016 4:13 pm
I Still have this problem on PCs that I installed updates on before I upgraded to Win10.
I have now tried Dude v 6.35.4.
Have also tried uninstalling all Runtime C++ on PC, and Uninstalling DUDE,
Downloaded latest Runtime C++ and installed it, reinstalled DUDE 6.35.4 , but still get the same annoying error message!
HELP! I need dude-client to work on ALL my work PCs!
PS.
I have also upgraded some PCs to Win10 where I for a long time didnt install updates, cause I was afraid of this problem.
On these PCs Dude client works perfectly fine!
jackadision
Mon Nov 06, 2017 1:01 pm
In order to fix Visual C++ Runtime Error you should apply the below-given steps:
Press the Windows key and the R key at the same time to open the Run prompt.
Type into the Run prompt: appwiz.cpl.
Press Enter.
Find all installations relating to the Microsoft Visual C++ Runtime and uninstall them one by one.
Download and re-install the previously removed runtime libraries.
Source: http://www.pcerror-fix.com/windows-8-c- ... tuprestart
Users browsing this forum: MasteRTriX and 10 guests
