strods
Winbox3.3 released!
Mon Mar 14, 2016 2:22 pm
What's new in v3.3:
*) added back 'Exit' button;
*) show all managed entries on Reconnect failure;
*) make mac winbox work more reliably (makes possbile to connect to RB850);
*) make RoMON work with RouterOS older than v6.35.
If you experience version related issues, then please report them to support@mikrotik.com.
Winbox is available here:
http://www.mikrotik.com/download
If you try to upgrade directly from Winbox loader and version is not available, then you might need to wait for a while until cache in path between your device and our servers is refreshed.
jarda
Re: Winbox3.3 released!
Mon Mar 14, 2016 3:08 pm
very fast...
Genkun
Mon Mar 14, 2016 3:58 pm
very fast...
I think that's an understatement :lol:
nxs02
Mon Mar 14, 2016 4:42 pm
nice... keep the good work :D
Pea
Mon Mar 14, 2016 9:02 pm
Just small note: Maybe you can add higher resolution app icon... 8)
pukkita
Trainer
Trainer
Mon Mar 14, 2016 9:55 pm
Real fast!!! kudos!
Simplicity is the Ultimate Sophistication - Da Vinci
Getting the most out of this forum
scampbell
Trainer
Trainer
Mon Mar 14, 2016 11:05 pm
Quick work !! :-)
Windows Smartscreen does not like it though - reports it as an unrecognised app from an unknown publisher on Windows10. You have to force Windows to run anyway.....
MTCNA, MTCWE, MTCRE, MTCTCE, MTCSE, MTCINE, MTCEWE, Trainer
___________________
Mikrotik Distributor - New Zealand
http://www.campbell.co.nz
abis
Tue Mar 15, 2016 12:35 am
If you pin it on taskbar, you will have it with a good resolution ;)
Image Image
freemannnn
Long time Member
Long time Member
Tue Mar 15, 2016 7:31 am
thanx for bringing back romon compatibility with older ros
k3dt
Tue Mar 15, 2016 10:08 am
Thank you guys!
rtlx
Tue Mar 15, 2016 10:21 am
Guys, PLEASE, take one hour study in today's cryptography and SIGN WINBOX EXECUTABLE (Microsoft Authenticode) with AT LEAST SHA-256 function, or dual-sign with SHA-256 and SHA-1 for compatibility (like Windows, WinRAR and other today's software does).
Your software is used in very sensitive environments, so security must be on very high level.
AT LEAST attach checksum on the website, but not with old-fashion, compromised and totally obsolete MD5 function, but with SHA-256 AT LEAST. sha256sum, sha256deep, HashTab, Total Commander and even PowerShell can do this.
THANK YOU SO MUCH
Also see: http://forum.mikrotik.com/viewtopic.php ... 97#p477897
tetecko
Wed Mar 16, 2016 8:40 am
Thank you guys!
+1 :-)))
WirelessRudy
Wed Mar 16, 2016 2:43 pm
ok, now it seems MT is working on the winbox platform again ince years without.... I have one other, very annoying item, I'd like to discuss and see if it is open for improvement.
I seem to remember in the 'early' days, when I changed anything in the 'connect to' list, or the 'access' list of a wireless interface the object (CPE) did not disconnect each time a change or edit was applied....
You just could change a name in the comment field for a unit in the accept list and apply while the unit itself just stayed connected to the AP radio.
Now this was in the days before NV2 and mimo technology....
But in fact it always irritated me that since then units disconnect for every little alteration we make in a list.
For instance, in access lists of AP's we mention an antenna (CPE) number, the clients name, type of antenna, signal of 1st connection (installation) and contract type. So in one eye stroke of the registration table of an AP we have all the most important data and inmediately available.
But to get a nice looking winbox overview we need to align the texts in columns and correct typo's, sometimes change contract, or client name, or type of antenna etc.
Since alterations are only visible in the registration table after the change is made in the access list and both are not visible at the same time to align all date properly you have to flap between windows all the time and each time make a new edit, apply it, go back to the reg. table, see if it is ligned out now, if not, go back to the access list, edit and apply again, etc. etc. etc.
Each time you apply the unit disconnects..... even if def. auth in the AP is enabled!
(Same in the 'connect to' list in the CPE. If an edit is applied to that list, even if def. auth is enable, the unit still disconnects)
Why would a CPE being forced to disconnect (and inmediately re-connects again) if only a text field in a comment label of a listing in the access list is changed?????
I'd remember for sure in the old days this was not the case...
Is this something that can be correct / improved in a new winbox version?
Show your appreciation of this post by giving me Karma! Thanks.
Rudy R. Puister
WISP operator based on MT routerboard & ROS.
macgaiver
Wed Mar 16, 2016 2:57 pm
This sounds like feature request for new wireless-rep package not winbox, now when any card can work in 2 modes at the same time and even scan and snoop without disconnecting clients i think adjustment in connect and access list shouldn't disconnect users also
. i think you need to write this feature request to support
With great knowledge comes great responsibility, because of ability to recognize id... incompetent people much faster.
Awax
Wed Mar 16, 2016 3:13 pm
In model of "hAP lite (smips)" there are no data
strods
Wed Mar 16, 2016 3:53 pm
Awax - Do you use Winbox 3.3? This is problem from older version Winbox.
freemannnn
Long time Member
Long time Member
Wed Mar 16, 2016 4:00 pm
please make winbox (windows) fully portable. something to be like the screenshot below in my external harddisk. why is necesary to search in %appdata% to find files of winbox.
all the files of winbox in current folder!
the problem with current folder is that view files does not be transfered and we have to look at %appdata% folder
easyspot
Wed Mar 16, 2016 4:03 pm
Winbox V3 problem including V3.3:
Look at the picture, at my screen size 1280x800px, in Wireless - Advanced Mode window size too long. How about smaller screen pixel size such as notebook PC 1366x768 or netbook PC 1024x600? How can we set?
Imagine if all buttons and info located at title bar (such as firefox/chrome). Sure we can have more space to work with.
Or if can't do that, please provide scroll bar/button. Thanks.
conrad
Wed Mar 16, 2016 5:53 pm
Hi
Когда появится возможность изменять размеры полей в логе?
When there is an opportunity to change the sizes of fields in the log?
It seems, promised to return in release.
Awax
Wed Mar 16, 2016 6:55 pm
Yes version 3.3
Pea
Wed Mar 16, 2016 11:55 pm
Yes, pinned icon on taskbar looks nice.
But when I click it and Winbox is running it gets pixelated :shock:
WirelessRudy
Thu Mar 17, 2016 1:52 am
Hi
Not only that. We've been asking to select, copy and drag text from log to windows desktop.
When searching in long log files you need to be able to select a certain line, or more.
Better would then be it would be able to copy it and paste it into some txt document...
Rudy R. Puister
acung
Thu Mar 17, 2016 7:00 am
+1
Dealsnprice
Thu Mar 17, 2016 9:17 am
Quick Quick Quick...
Ansy
Thu Mar 17, 2016 10:53 am
Wow... Do you still have Windows Taskbar at bottom of desktop/screen? Guys, move it to the left border!
That modern displays with aspect ratios (16:9, 16:10) are for movies, sad but true... even web browsing is uncomfortable.
P.S. May be tweeking screen control settings (to other than default 100% 96dpi) will help?
normis
Thu Mar 17, 2016 11:08 am
Very sad to see somebody using 1024x600 sceens. I think most phones have more.
WirelessRudy
Thu Mar 17, 2016 2:58 pm
That's unfair to say. There are still a lot of 12" netbooks around that are in fact ideal to bring with you to a client or a tower to trouble shoot. But then indeed, in advanced mode part of the info cannot be displayed.
And the remark of Ansy is also poor. If you use dual screen setup (like many nowadays) then a taskbar on the side is not very handy. And too small too. I never liked it on the side anyway but that can be personal. But if you have two, or even three 22" screens side by side a taskbar on the side makes no sense....
Rudy R. Puister
abis
Thu Mar 17, 2016 3:12 pm
Yes, because of the settings from taskbar.
Try use Taskbar buttons: Always combine, hide labels
Image Image
easyspot
Fri Mar 18, 2016 1:32 pm
Agree with WirelessRudy
Will u guys bring notebook PC with 15.6" FHD 1920*1080px to roof/tower? How big? How heavy? How long the battery will last? Dont u guys think its silly? :lol:
We all go to roof/tower using cheap netbook PC so in case of accident, we wont lose so much money. Netbook PC always have small display size n of course small amount of pixels.
About taskbar location, wherever it is, it wont affect much. :D
SiB
Forum Veteran
Forum Veteran
Sat Mar 19, 2016 2:04 am
1) Please add working 'Ctrl+F' at start of WinBox. I must always click on any managed or neighbors RB first.
2) When I connect to RB then window is always open partial out of my monitor :) Picture
MTCNA + MTCRE + MTCINE | ~600 users at ~150 RouterBoards in EMEA | Telegram: @SiB_PL
WinBox Tip: F6 works as ALT+TAB | Gliffy.com - free network schematic | prnt.sc - free ScreenShot software
I will be at MUMEUROPE Prague on ?? ?? 202?
jarda
Sat Mar 19, 2016 7:03 am
Partially opened window is something I can see in 1/10 occasions. I don't understand why several times everything opens normally according to the saved layout and suddenly not. When this happens it is bad to close such window because the layout gets saved in this shape so it's damaged. The only way is to maximize the window and reload the layout from the file again. Then it is correct. It is very annoying bug.
nashrty
Sat Mar 19, 2016 10:35 am
fantastic
BartoszP
Re:
Sat Mar 19, 2016 12:32 pm
Jarda, do you use doublemonitor setup ?
If yes then Windows remeber that the screen is wider and therefore opens applications' windows in such "strange" way. I suppose ... maybe I 'm wrong :-)
Real admins use real keyboards.
isolnet
Sat Mar 19, 2016 6:33 pm
Nice jobs...
jarda
Sun Mar 20, 2016 2:27 am
No. It's mostly single screen notebook with full hd display, win 7 ultimate 64bit. It does only time to time. In most cases it opens correctly. I have not seen any difference between those cases.
dcone
Sun Mar 20, 2016 2:40 am
where can I download the mac version of this?
jarda
Sun Mar 20, 2016 2:54 am
No mac version. Use emulator.
strods
Wed Mar 23, 2016 4:58 pm
Users browsing this forum: No registered users and 7 guests
