robertEIT
RB951Ui-2Hnd - Wireless configuration - best practices
Wed Mar 16, 2016 6:51 pm
I just received my 951Ui-2Hnd, after playing with several hAP-lites and couldn't wait to see how much the better wireless in the 2Hnd will perform (range) but....I just set it up and honestly it is not noticeable better than my hAP lites as range. I guess either I didn't set it up right or my knowledge is wrong.
I would like to know from you guys what are the "best practices" when configuring the wireless on these devices as wireless APs, multi-user, for home and office.
Could you post your configurations please?
gabrielpike
Re: RB951Ui-2Hnd - Wireless configuration - best practices
Wed Mar 16, 2016 7:17 pm
Just remember that more power is not always better. One way to increase range may be to set you power level. In winbox under the wireless tables tab, open the wireless interface dialog box. Under Tx Power set the mode to "all rates fixed" then adjust tx power to what you want. I think the max is 30dBm. In some cases depending on configuration performance can increase at lower power levels however. Do some testing to see what configuration works best for you.
Gabriel Pike
MTCNA
darkprocess
Thu Mar 17, 2016 4:21 pm
May be your laptop wifi sensibility
nxs02
Fri Mar 18, 2016 1:56 am
but be careful, AFAIK setting up TX power to big will damaging the mikrotik wireless chip
jarda
Fri Mar 18, 2016 7:11 pm
Any values set to integrated device will damage the amplifier. It could happen only when antenna is not connected at all.
robertEIT
Sat Mar 19, 2016 10:27 pm
This is what I have on my hAP lite, a standard ap bridge wifi private + a guest one. What settings do you guys think I can tweak?
[admin@MikroTik] > interface wireless print
 0    ;;; Guest Wireless
      name="ap-guest" mtu=1500 mac-address=E5:8D:8C:9E:D8:AD arp=enabled
      interface-type=virtual-AP master-interface=wlan1 ssid="Guests"
      vlan-mode=no-tag vlan-id=1 wds-mode=disabled wds-default-bridge=none
      wds-ignore-ssid=no bridge-mode=enabled default-authentication=yes
      default-forwarding=yes default-ap-tx-limit=0 default-client-tx-limit=0
      hide-ssid=no security-profile=default
 1    ;;; WiFi
      name="wlan1" mtu=1500 mac-address=E4:8D:8C:5E:D8:AD arp=enabled
      interface-type=Atheros AR9300 mode=ap-bridge ssid="MikroTik"
      frequency=2427 band=2ghz-b/g/n channel-width=20mhz scan-list=default
      wireless-protocol=802.11 vlan-mode=no-tag vlan-id=1 wds-mode=disabled
      wds-default-bridge=none wds-ignore-ssid=no bridge-mode=enabled
      default-authentication=yes default-forwarding=yes default-ap-tx-limit=0
      default-client-tx-limit=0 hide-ssid=no security-profile=profile1
      compression=no
gabrielpike
Mon Mar 21, 2016 3:39 pm
Like below:
Gabriel Pike
MTCNA
Users browsing this forum: miltont, sichinavaks and 92 guests
