geras5834
Log Screen
Sun Mar 20, 2016 5:30 pm
Good Morning!
Do anyone knows what does this means?
Am I getting spam to my Router?
Am I being hacked?
Who are all theses users?
Thank you
Best Regards
tr00g33k
Re: Log Screen
Sun Mar 20, 2016 7:23 pm
Looks like somebody is bruteforcing your SSH service. If you dont need it disable it under
/ip service disable ssh
If you use it, limit the access with firewall rules (example if you need access to ssh only from 192.168.1.10):
/ip firewall filter add chain=input src-address=192.168.10.1 protocol=tcp dst-port=22 action=accept place-before=0
/ip firewall filter add chain=input protocol=tcp dst-port=22 action=drop place-before=1
Just example, with firewall filter you limit access to SSH for your needs.
plisken
Re: Log Screen
Mon Mar 21, 2016 9:42 pm
You can also change the ssh port 22 to 20022 ore something
Greatings
Users browsing this forum: No registered users and 25 guests
