Bishop
ipv6 and PPtP
Thu Mar 24, 2016 10:05 am
Hello , help solve the problem . Not binding ipv6 addr on pptp client.
My Example:
(PPtP Server) [Mikrotik] <------- PPtP --------- [Windows 7 Host ] (PPtP Client)
Task: Bind real ipv6 address for the client from pool.
My config:
Pool:
/ipv6 pool add name=IPv6-Pool prefix=2002:c311:11bb:2::/64 prefix-length=80
Profile:
/ppp profile add dhcpv6-pd-pool=IPv6-Pool local-address=10.100.100.1 name=MyProfile-ipv6 remote-ipv6-prefix-pool=IPv6-Pool use-encryption=yes
/ppp secret add name=tester password=test profile=MyProfile-ipv6 service=pptp
After connection:
/ipv6 dhcp-server  print
Flags: D - dynamic, X - disabled, I - invalid
 #    NAME                        INTERFACE                        ADDRESS-POOL                        PREFERENCE LEASE-TIME
 0 D  <pptp-tester>               <pptp-tester>                    IPv6-Pool                                  255 3d
 /ipv6 pool used print
POOL                              PREFIX                                      OWNER                              INFO
IPv6-Pool                         2002:c311:11bb:2::/80                       PPTP<195.19.1.207>               tester
But:
 ipv6 dhcp-server binding print
Flags: X - disabled, D - dynamic
 #   ADDRESS                                                               DUID                           SERVER                           STATUS
Windows Client settings.
janisk
Re: ipv6 and PPtP
Thu Mar 24, 2016 10:52 am
first, if your clients are end user hosts, you do not need to set up pool for PD.
Bishop
Re: ipv6 and PPtP
Thu Mar 24, 2016 11:09 am
Sorry, i will correct scheme.
(PPtP Server) [Mikrotik] <-------( Internet )--------- [Windows 7 Host ] (PPtP Client)
If "not need to set up pool for PD" as client will then get the address ?
Such a scheme will work?
janisk
Re: ipv6 and PPtP
Thu Mar 24, 2016 12:36 pm
also, what you see in the logs?
Bishop
Re: ipv6 and PPtP
Thu Mar 24, 2016 3:04 pm
No Error!
15:49:19 pptp,info TCP connection established from 19.19.16.207
15:49:19 pptp,info PPP: TCP connection established from 19.19.16.207
15:49:19 pptp,debug,packet PPP: rcvd Start-Control-Connection-Request from 19.19.16.207
15:49:19 pptp,debug,packet PPP:     protocol-version=0x0100
15:49:19 pptp,debug,packet PPP:     framing-capabilities=1
15:49:19 pptp,debug,packet PPP:     bearer-capabilities=1
15:49:19 pptp,debug,packet PPP:     maximum-channels=0
15:49:19 pptp,debug,packet PPP:     firmware-revision=0
15:49:19 pptp,debug,packet PPP:     host-name=
15:49:19 pptp,debug,packet PPP:     vendor-name=Microsoft
15:49:19 pptp,debug,packet PPP: sent Start-Control-Connection-Reply to 19.19.16.207
15:49:19 pptp,debug,packet PPP:     result-code=1
15:49:19 pptp,debug,packet PPP:     error-code=0
15:49:19 pptp,debug,packet PPP:     framing-capabilities=2
15:49:19 pptp,debug,packet PPP:     bearer-capabilities=0
15:49:19 pptp,debug,packet PPP:     firmware-revision=1
15:49:19 pptp,debug,packet PPP:     host-name=MikroTik
15:49:19 pptp,debug,packet PPP:     vendor-name=MikroTik
15:49:19 pptp,debug,packet PPP: rcvd Outgoing-Call-Request from 19.19.16.207
15:49:19 pptp,debug,packet PPP:     call-id=39186
15:49:19 pptp,debug,packet PPP:     call-serial-number=30
15:49:19 pptp,debug,packet PPP:     minimum-bps=300
15:49:19 pptp,debug,packet PPP:     maximum-bps=100000000
15:49:19 pptp,debug,packet PPP:     bearer-type=3
15:49:19 pptp,debug,packet PPP:     framing-type=3
15:49:19 pptp,debug,packet PPP:     packet-recv-window-size=64
15:49:19 pptp,debug,packet PPP:     packet-processing-delay=0
15:49:19 pptp,debug,packet PPP:     phone-number-length=0
15:49:19 pptp,debug,packet PPP:     phone-number=
15:49:19 pptp,debug,packet PPP:     subaddress=
15:49:19 pptp,ppp,debug PPP: <48>: LCP lowerup
15:49:19 pptp,ppp,debug PPP: <48>: LCP open
15:49:19 pptp,debug,packet PPP: sent Outgoing-Call-Reply to 19.19.16.207
15:49:19 pptp,debug,packet PPP:     call-id=48
15:49:19 pptp,debug,packet PPP:     peers-call-id=39186
15:49:19 pptp,debug,packet PPP:     cause-code=0
15:49:19 pptp,debug,packet PPP:     connect-speed=100000
15:49:19 pptp,debug,packet PPP:     packet-recv-window-size=100
15:49:19 pptp,debug,packet PPP:     physical-channel-id=0
15:49:19 pptp,debug,packet PPP: rcvd Set-Link-Info from 19.19.16.207
15:49:19 pptp,debug,packet PPP:     peers-call-id=48
15:49:19 pptp,debug,packet PPP:     send-accm=0xffffffff
15:49:19 pptp,debug,packet PPP:     receive-accm=0xffffffff
15:49:19 pptp,debug,packet PPP: sent Set-Link-Info to 19.19.16.207
15:49:19 pptp,ppp,debug,packet PPP:  <48>: rcvd LCP ConfReq id=0x0
15:49:19 pptp,ppp,debug,packet PPP:    <mru 1400>
15:49:19 pptp,ppp,debug,packet PPP:    <magic 0x5afd0118>
15:49:19 pptp,ppp,debug,packet PPP:    <pcomp>
15:49:19 pptp,ppp,debug,packet PPP:    <accomp>
15:49:19 pptp,ppp,debug,packet PPP:    <callback 0x06>
15:49:19 pptp,ppp,debug,packet PPP:  <48>: sent LCP ConfReq id=0x1
15:49:19 pptp,ppp,debug,packet PPP:    <mru 1280>
15:49:19 pptp,ppp,debug,packet PPP:    <magic 0x68f3ca83>
15:49:19 pptp,ppp,debug,packet PPP:    <auth  mschap2>
15:49:19 pptp,ppp,debug,packet PPP:    <mrru 1600>
15:49:19 pptp,ppp,debug,packet PPP:  <48>: sent LCP ConfRej id=0x0
15:49:19 pptp,ppp,debug,packet PPP:  <48>: rcvd LCP ConfRej id=0x1
15:49:19 pptp,ppp,debug,packet PPP:  <48>: sent LCP ConfReq id=0x2
15:49:19 pptp,ppp,debug,packet PPP:  <48>: rcvd LCP ConfReq id=0x1
15:49:19 pptp,ppp,debug,packet PPP:  <48>: sent LCP ConfAck id=0x1
15:49:19 pptp,ppp,debug,packet PPP:  <48>: rcvd LCP ConfAck id=0x2
15:49:19 pptp,ppp,debug PPP: <48>: LCP opened
15:49:19 pptp,ppp,debug,packet PPP:  <48>: sent CHAP Challenge id=0x1
15:49:19 pptp,ppp,debug,packet PPP:     <challenge len=16>
15:49:19 pptp,ppp,debug,packet PPP:     <name MikroTik>
15:49:19 pptp,ppp,debug,packet PPP:  <48>: rcvd LCP Ident id=0x2
15:49:19 pptp,ppp,debug,packet PPP:     MSRASV5.20
15:49:19 pptp,ppp,debug,packet PPP:  <48>: rcvd LCP Ident id=0x3
15:49:19 pptp,ppp,debug,packet PPP:     MSRAS-0-BISHOP-\8F\8A
15:49:19 pptp,ppp,debug,packet PPP:  <48>: rcvd LCP Ident id=0x4
15:49:19 pptp,ppp,debug,packet PPP:     \C3\A8\F85\C6\82\E6I\AA\0B\E9hZ.\B4w
15:49:19 pptp,ppp,debug,packet PPP:  <48>: rcvd CHAP Response id=0x1
15:49:19 pptp,ppp,debug,packet PPP:     <response len=49>
15:49:19 pptp,ppp,debug,packet PPP:     <name tester>
15:49:19 pptp,ppp,info,account tester logged in, 0.0.0.0
15:49:19 pptp,ppp,info,account PPP: tester logged in, 0.0.0.0
15:49:19 pptp,ppp,debug,packet PPP:  <48>: sent CHAP Success id=0x1
15:49:19 pptp,ppp,debug,packet PPP:     S=F3A3FFAF50D205E4B2618CA5E7234BF8C67DA9F1
15:49:19 pptp,ppp,debug,packet PPP:  <48>: sent CBCP CallbackReq id=0x0
15:49:19 pptp,ppp,debug,packet PPP:      01 02
15:49:19 pptp,ppp,debug,packet PPP:  <48>: rcvd CBCP CallbackResp id=0x0
15:49:19 pptp,ppp,debug,packet PPP:  <48>: sent CBCP CallbackAck id=0x1
15:49:19 pptp,ppp,info <pptp-tester>: authenticated
15:49:19 pptp,ppp,info PPP: <pptp-tester>: authenticated
15:49:19 pptp,ppp,debug PPP: <48>: IPCP lowerup
15:49:19 pptp,ppp,debug PPP: <48>: IPCP open
15:49:19 pptp,ppp,debug,packet PPP:  <48>: sent IPCP ConfReq id=0x1
15:49:19 pptp,ppp,debug,packet PPP:     <addr 10.100.100.1>
15:49:19 pptp,ppp,debug PPP: <48>: IPV6CP lowerup
15:49:19 pptp,ppp,debug PPP: <48>: IPV6CP open
15:49:19 pptp,ppp,debug,packet PPP:  <48>: sent IPV6CP ConfReq id=0x1
15:49:19 pptp,ppp,debug,packet PPP:     <interface-identifier 0:0:f0:30>
15:49:19 pptp,ppp,debug PPP: <48>: MPLSCP lowerup
15:49:19 pptp,ppp,debug PPP: <48>: MPLSCP open
15:49:19 pptp,ppp,debug,packet PPP:  <48>: sent MPLSCP ConfReq id=0x1
15:49:19 pptp,ppp,debug PPP: <48>: BCP open
15:49:19 pptp,ppp,debug PPP: <48>: CCP lowerup
15:49:19 pptp,ppp,debug PPP: <48>: CCP open
15:49:19 pptp,ppp,debug,packet PPP:  <48>: sent CCP ConfReq id=0x1
15:49:19 pptp,ppp,debug,packet PPP:     <mppe 1000040>
15:49:19 pptp,ppp,debug,packet PPP:  <48>: rcvd IPV6CP ConfReq id=0x5
15:49:19 pptp,ppp,debug,packet PPP:     <interface-identifier dc18:5864:d56c:64c7>
15:49:19 pptp,ppp,debug,packet PPP:  <48>: sent IPV6CP ConfAck id=0x5
15:49:19 pptp,ppp,debug,packet PPP:  <48>: rcvd CCP ConfReq id=0x6
15:49:19 pptp,ppp,debug,packet PPP:  <48>: sent CCP ConfAck id=0x6
15:49:19 pptp,ppp,debug,packet PPP:  <48>: rcvd LCP ProtRej id=0x7
15:49:19 pptp,ppp,debug,packet PPP:      80 21 01 01 00 0a 03 06 0a 64 64 01
15:49:19 pptp,ppp,debug PPP: <48>: IPCP lowerdown
15:49:19 pptp,ppp,debug,packet PPP:  <48>: rcvd IPV6CP ConfAck id=0x1
15:49:19 pptp,ppp,debug PPP: <48>: IPV6CP opened
15:49:19 pptp,ppp,info <pptp-tester>: connected
15:49:19 pptp,ppp,info PPP: <pptp-tester>: connected
15:49:19 pptp,ppp,debug,packet PPP:  <48>: rcvd LCP ProtRej id=0x8
15:49:19 pptp,ppp,debug,packet PPP:      82 81 01 01 00 04
15:49:19 pptp,ppp,debug,packet PPP:  <48>: rcvd CCP ConfAck id=0x1
15:49:19 pptp,ppp,debug PPP: <48>: CCP opened
15:49:19 pptp,ppp,info <pptp-tester>: using encoding - MPPE128 stateless
15:49:19 pptp,ppp,info PPP: <pptp-tester>: using encoding - MPPE128 stateless
15:49:39 pptp,debug,packet PPP: rcvd Set-Link-Info from 19.19.16.207
15:49:39 pptp,debug,packet PPP:     peers-call-id=48
15:49:39 pptp,debug,packet PPP:     send-accm=0xffffffff
15:49:39 pptp,debug,packet PPP:     receive-accm=0xffffffff
15:49:39 pptp,debug,packet PPP: sent Set-Link-Info to 19.19.16.207
15:49:39 pptp,debug,packet PPP:     peers-call-id=39186
15:49:39 pptp,ppp,debug,packet PPP:  <48>: rcvd LCP TermReq id=0x9
15:49:39 pptp,ppp,debug,packet PPP:     Z\FD\01\18\00<\CDt\00\00\00\00
15:49:39 pptp,ppp,debug PPP: <48>: LCP closed
15:49:39 pptp,ppp,debug PPP: <48>: CCP lowerdown
15:49:39 pptp,ppp,debug PPP: <48>: CCP closed
15:49:39 pptp,ppp,debug PPP: <48>: BCP lowerdown
15:49:39 pptp,ppp,debug PPP: <48>: BCP down event in starting state
15:49:39 pptp,ppp,debug PPP: <48>: IPCP lowerdown
15:49:39 pptp,ppp,debug PPP: <48>: IPCP down event in starting state
15:49:39 pptp,ppp,debug PPP: <48>: IPV6CP lowerdown
15:49:39 pptp,ppp,debug PPP: <48>: IPV6CP closed
15:49:39 pptp,ppp,debug PPP: <48>: MPLSCP lowerdown
15:49:39 pptp,ppp,debug,packet PPP:  <48>: sent LCP TermAck id=0x9
15:49:39 pptp,ppp,debug PPP: <48>: LCP lowerdown
15:49:39 pptp,ppp,info <pptp-tester>: terminating...
15:49:39 pptp,ppp,info PPP: <pptp-tester>: terminating...
15:49:39 pptp,ppp,debug PPP: <48>: LCP down event in starting state
15:49:39 pptp,ppp,info,account tester logged out, 20 5791 682 30 12
15:49:39 pptp,ppp,info,account PPP: tester logged out, 20 5791 682 30 12
15:49:39 pptp,ppp,info <pptp-tester>: disconnected
15:49:39 pptp,ppp,info PPP: <pptp-tester>: disconnected
Users browsing this forum: Bing [Bot] and 74 guests
