MUM Europe 2020
drupol
Beginners quest: 2 routers, 2 subnets.
Sat Mar 26, 2016 4:40 pm
Hi all,
I bought my first two MikroTik routers(RB951Ui-2HnD) this morning. Before buying them, I was using some Ciscos with DDWRT on them.
I'm impressed with the web interface, there's no need to install ddwrt on openwrt, it's slick, fast and beautiful. I'm quite happy !
My message here is to get a bit of help on how to do something. I have an IT background but not in networking, it's too far away and I'm unable to do what I want at home.
Here's the current situation:
I have a modem (from VOO in Belgium), connected to the first MikroTik on the first port (WAN).
This first router (MT1) has a local IP: 192.168.1.1 and the wireless is configured with DHCP range: 192.168.1.50~150
The address acquisition for Internet is set to Automatic and it currently has 109.89.6.XX and gateway: 109.89.6.1
The second router (MT2) is connected to the first router(Port 2) using its first port (WAN).
Its local ip is: 192.168.3.1 and the wireless is configured with DHCP range: 192.168.3.50~150
The address acquisition for Internet is set to Automatic and it currently has 192.168.1.50 and gateway: 192.168.1.1
Here's what I'm trying to do:
I would like to have two proper networks.
MT1 with subnet 192.168.1.0/24
MT2 with subnet 192.168.3.0/24
The big question is how to configure the port on each router. How to let the two routers detect each other and communicate properly ?
Those two networks should have Internet and also let devices communicate between each others, from a subnet to another.
I think it's the tenth time that I try to do something, but I always end up not having internet and forced to reset the router to get my network back.
Thanks in advance for any help you might give.
kiaunel
Sat Mar 26, 2016 5:27 pm
You have two options.
1. Make a setup like You described but is the worst situation. I can not know where you are loosing internet conectivity without you describing what did you do . you can use the quick setup feature configure both routers. But in this setup you will have double nat and possible to have problems with some internet aplications.
2. Best way is to setup the first mikrotik as router with two dhcp servers one for ports 3-5 and one for port2 who is connected with second mikrotik . That will be setup as a bridge. This way you can have two separate networks and the routing and nat will be done only by the first mikrotik.
If are in trouble to setup devices I can prepare a config for you later in a lab.
Sent from my Lenovo K50a40 using Tapatalk
drupol
Re: Beginners quest: 2 Routers, 2 subnets.
Sat Mar 26, 2016 5:34 pm
Thanks for replying!
I don't want double nat for sure, this is why I would like a separate router for each subnet.
Is it possible to do ?
kiaunel
Sat Mar 26, 2016 8:17 pm
Yes. Solution 2 i gave to you
drupol
Sun Mar 27, 2016 10:07 am
Yeah the solution you gave is one solution but it's not really what I want.
I want MT2 to have it's own DHCP. I don't want to rely on MT1 for that.
I really want to differents subnets, one on each router.
ShayanFiroozi
Re: Beginners quest: 2 routers, 2 subnets.
Sun Mar 27, 2016 12:36 pm
Hi ,
1-Unplug your second router !!
2-first you have to setup you first router , if your first router has internet ( you can test it by ping 8.8.8.8 from Tools/Ping) then setup DHCP on first router and be sure it's working,since your modem , first router and first router's hosts are in a same subnet no routing will be required.
3-now connect your second router to the first router and setup your addressing :
192.168.1.1 should be set to the first router port2(which connected to the second router)
192.168.1.2(or any free ip address in 192.168.1 subnet) should be set to the wan port of second router(which connected to the first router)
default router will be add automatically when you are adding IP's.
4-in Tool/Ping you should be able to ping 192.168.1.1 from second router and ping 192.168.1.2(or any IP you given to the second router) from first router , if they are done go on next.....
5-in second router go to IP/Route and add this route :
add check-gateway=ping comment="Gateway To Internet" distance=1 gateway=192.168.1.1
6- no if you ping 8.8.8.8 from second router everything should be ok !
7-after that setup your second router DHCP on your second router.
*** pay attention here : your gateway of second router's users should be 192.168.1.1(actually your first router , then first router will route it to your modem ;) )
The price of your knowledge which you have to pay is to share it with others !!
drupol
Sun Mar 27, 2016 12:45 pm
Hi ,
That's working perfectly.
192.168.1.1 is already set to be the IP of MT1. Should I also assign the same IP to the port 2 of MT1 ?
Could you please describe a bit more ?
Thanks!
ShayanFiroozi
Sun Mar 27, 2016 12:49 pm
no , use another subnet it's not important but 2 IP's should be on same subnet , set 192.168.250.1 to first router port 2 and 192.168.250.2 to second router wan(or any port which connected to the first router)
kiaunel
Sun Mar 27, 2016 1:03 pm
Hi ,
That will be double nat setup and I don't recommend it and he said also he does not want double nat. Again, setup first router, when everything works in the first router, remove ether5 from switch, you can do it by removing ether2 from master switch option and adding an IP and a dhcp server to ether5. Next setup the second mikrotik as a bridge and connect it to ether5 to the first one. That's it.
ShayanFiroozi
Sun Mar 27, 2016 1:08 pm
Hi ,
It's not double nat , masquerade nat on first router will be enough. also bridging will cause broadcast and collision domain also ARP poisoning and many other issues.......
routed network works more reliable and in future firewalling and controlling over hosts will be much more easier
kiaunel
Sun Mar 27, 2016 1:11 pm
Yeah, I've missed last part, sorry.
ShayanFiroozi
Sun Mar 27, 2016 1:15 pm
NP ,it seams drupol is working hard and no result yet ;)
Sob
Sun Mar 27, 2016 4:05 pm
Sorry if I misunderstood you, but users in second 192.168.3.0/24 subnet can't have 192.168.1.1 as gateway (unless you play with proxy arp, but that's completely unnecessary). What is needed is the last missing step:
8-tell first router, where to find second subnet
add distance=1 dst-address=192.168.3.0/24 gateway=192.168.1.2
People who quote full posts should be spanked with ethernet cable. Some exceptions for multi-topic threads may apply. Not intended as incentive for masochists.
drupol
Sun Mar 27, 2016 4:11 pm
Indeed, had to reset once both routers because I messed up once again... but the good news is that I got everything working now thanks to your advice :-)
IP Configuration on MT1:
[admin@MT1] /ip> export
# mar/27/2016 15:07:43 by RouterOS 6.34.3
# software id = JT0P-F8WA
add name=dhcp ranges=192.168.1.50-192.168.1.150
add address=192.168.1.1/24 interface=ether2-master network=192.168.1.0
add address=192.168.250.1/24 interface=bridge-home3 network=192.168.250.0
/ip dhcp-client
add comment=defconf dhcp-options=hostname,clientid disabled=no interface=ether1-gateway
add address-pool=dhcp disabled=no interface=bridge-home1 name=defconf
add address=192.168.1.0/24 comment=defconf gateway=192.168.1.1 netmask=24
add address=192.168.3.0/24 gateway=192.168.3.1 netmask=24
set allow-remote-requests=yes
/ip dns static
add address=192.168.1.1 name=router
add chain=forward comment="defconf: accept established,related" connection-state=established,related
add action=drop chain=forward comment="defconf:  drop all from WAN not DSTNATed" connection-nat-state=!dstnat connection-state=new in-interface=ether1-gateway
add chain=input protocol=icmp
add chain=input connection-state=established
add chain=input connection-state=related
add action=drop chain=input in-interface=ether1-gateway
add action=masquerade chain=srcnat comment="defconf: masquerade" out-interface=ether1-gateway
add check-gateway=ping distance=1 dst-address=192.168.3.0/24 gateway=192.168.250.2
[admin@MT1] /ip>
IP Configuration on MT2:
[admin@MT2] /ip> export
# mar/27/2016 15:09:19 by RouterOS 6.34.3
# software id = R657-I42S
/ip hotspot profile
add hotspot-address=192.168.5.1 name=hsprof1
add hotspot-address=192.168.5.1 name=hsprof2
add name=dhcp ranges=192.168.3.50-192.168.3.150
add name=hs-pool-10 ranges=192.168.5.2-192.168.5.254
add address=192.168.3.1/24 comment="default configuration" interface=ether2-master-local network=192.168.3.0
add address=192.168.5.1/24 comment="hotspot network" interface=wlan2 network=192.168.5.0
add address=192.168.250.2/24 interface=ether1-gateway network=192.168.250.0
/ip dhcp-client
add comment="default configuration" dhcp-options=hostname,clientid interface=ether1-gateway
add address-pool=dhcp disabled=no interface=bridge-local name=default
add address-pool=dhcp disabled=no interface=wlan2 name=hotspot src-address=192.168.66.1
/ip dhcp-server lease
add address=192.168.3.5 client-id=1:0:11:32:34:81:b2 mac-address=00:11:32:34:81:B2 server=default
add address=192.168.3.0/24 comment="default configuration" gateway=192.168.3.1 netmask=24
add address=192.168.5.0/24 comment="hotspot network" gateway=192.168.5.1
set allow-remote-requests=yes servers=192.168.250.1
/ip dns static
add address=192.168.3.1 name=router
add action=passthrough chain=unused-hs-chain comment="place hotspot rules here" disabled=yes
add chain=input comment="default configuration" protocol=icmp
add chain=input comment="default configuration" connection-state=established,related
add action=drop chain=input comment="default configuration" in-interface=ether1-gateway
add action=fasttrack-connection chain=forward comment="default configuration" connection-state=established,related
add chain=forward comment="default configuration" connection-state=established,related
add action=drop chain=forward comment="default configuration" connection-state=invalid
add chain=forward comment="default configuration" connection-nat-state=!dstnat connection-state=new in-interface=ether1-gateway
add action=masquerade chain=srcnat comment="default configuration" out-interface=ether1-gateway
add action=masquerade chain=srcnat comment="masquerade hotspot network" src-address=192.168.5.0/24
/ip hotspot
add address-pool=hs-pool-10 disabled=no interface=wlan2 name=hotspot1 profile=hsprof2
/ip hotspot user
add name=admin
add check-gateway=ping distance=1 gateway=192.168.250.1
[admin@MT2] /ip>
Now that this is in place and working, is there something particular that I have to do to do NAT properly ? (without double nat)
Sob
Sun Mar 27, 2016 4:50 pm
Remove this rule from second router, that's the unnecessary second NAT:
ShayanFiroozi
Sun Mar 27, 2016 5:00 pm
Yeah thank you for correction , that because i just imagined situation and didn't draw it as diagram also working with not real IP's was confusing;)
ShayanFiroozi
Sun Mar 27, 2016 5:07 pm
@drupol :
your first router working as NAT router for you , packets route from router #2 to #1 because you have default route in your #2 router : add check-gateway=ping distance=1 gateway=192.168.250.1
it will be route all packets which their subnet is not exists in router #2's routing table t the 192.168.250.1(router #1)
drupol
[Fixed] Re: Beginners quest: 2 routers, 2 subnets.
Wed Mar 30, 2016 4:06 pm
Hi all,
Everything is working fine, thanks for your warm help.
Here's the network diagram of my home network.
Users browsing this forum: No registered users and 38 guests
