MUM Europe 2020
irghost
TP-Link TL-WN722N and mikrotik does it work?
Mon Mar 28, 2016 9:38 am
hi all
TP-link WN722N has Atheros AR9271 Chipset
mikrotik RB951Ui must support it
MTCNA MTCRE MTCTCE MTCUME MTCWE MTCIPv6E MTCINE
irghost
Re: TP-Link TL-WN722N and mikrotik does it work?
Mon Mar 28, 2016 4:04 pm
UP
Is there any Admin here?
answer me plz
djape
Tue Jun 07, 2016 11:18 pm
Same problem.
I read on Wiki and Forum here, bought TP-Link TL-WN722N and RB751U-2HnD, spent money for something that is not working for me now.
As and old and faithful Mikrotik user I would appreciate if someone can answer.
Idea was to have small soho route which I can use to extend signal in hotels when I go to vacation with my family.
If you can't do this, please make RN with 2 wifi interfaces, 1 stronger, 1 weaker/cheaper, I am sure many will buy it.
Anyway, till then, can someone be precise and write here what is the version on which will 722N works ( I read on forum it works on 5.26, but for me it doesn't (I tried 5.16, 6.0, 6.0rc6, 6.0rc9 and of course latest stable 6.35.2)
Thank you.
I drink like a pirate and smoke like a hippie...
kristaps
Wed Jun 08, 2016 2:12 am
We are sorry but we removed usb wifi support in RouterOS v6 because of instability issue.
You can use wireless-rep and repeater function now http://wiki.mikrotik.com/wiki/Manual:In ... s#Repeater
djape
Thu Jun 09, 2016 2:19 pm
Thank you for prompt reply.
Please update WIKI.
Thanks.
p3rad0x
Long time Member
Long time Member
Fri Jun 10, 2016 11:31 am
Why would you want to connect the TL-WN722N? for increased range?
There you go then you touched something ;-) : it only takes a change in wind direction to screw with your nat :-)
flips
Wed Jun 29, 2016 12:03 am
The repeater function should work with WLAN's/master's that's non-Mikrotik/RouterBoard?
flips 8)
JHOELIT
Sat Jun 16, 2018 3:06 am
I have the same problem, the tp-link repeater does not work for mikrotik ...
(OmniTik in AP bridge mode) ---> (Repeater Tp-Link) ---> (Laptop Client)
Normal dhcp enters the ip addresses in the laptop, but it does not give me internet and it does not ping the mikrotik ...
it may not be compatible, all are of 2.4GHz frequency.
Users browsing this forum: Majestic-12 [Bot] and 28 guests
