MUM Europe 2020
Ahmed1989
Public IP for each pppoe server
Wed Mar 30, 2016 1:57 pm
Hello
I have a pppoe server as shown in the picture
how can I configure NAT to specify Public IP for each pppoe clients in one pppoe server ?
pukkita
Trainer
Trainer
Re: Public IP for each pppoe server
Wed Mar 30, 2016 5:21 pm
That diagram isn't clear, does the Mikrotik run a PPPoE server itself, and if so, why eth1,2,3 connect to more pppoe servers? or those are the interfaces connected to sectors, or network segments from where PPPoE clients reach the Mikrotik?
Simplicity is the Ultimate Sophistication - Da Vinci
Getting the most out of this forum
Ahmed1989
Wed Mar 30, 2016 10:41 pm
each interface of mikrotik RB is pppoe server ... and these interfaces connected to pppoe clients ( such as sectors )
I need to specify public IP for pppoe clients in one sector
pukkita
Trainer
Trainer
Wed Mar 30, 2016 11:35 pm
Cannot you use src-address as criteria? Do you use different pools for each PPPoE server?
Ahmed1989
Wed Mar 30, 2016 11:44 pm
No I cannot use src-address , I use the same pools for different pppoe servers ... I tried to use in interface for matching ... but it doesnt working
lambert
Long time Member
Long time Member
Fri Apr 01, 2016 1:28 am
Use different pools for each PPPoE server. They can be in the same overall supernet if you like, as long as the ranges don't overlap.
In-interface matching won't work because each client is on his own PPP interface.
You might be able to assign a MikroTik-Address-List via RADIUS based on which PPPoE server the connection came in via. Then you could use the address list in the src-nat rule. I would leave that as a last resort since it is going to be complicated and require some work.
Someone else may have a better idea. Different ip pools is where I would go if I wanted to do what you are trying to do.
pukkita
Trainer
Trainer
Fri Apr 01, 2016 1:29 pm
Your post is lacking proper details, are public IPs all on the same WAN interface?
Ahmed1989
Tue Apr 05, 2016 1:15 pm
the public IP s are loopback interfaces
ZeroByte
Tue Apr 05, 2016 5:07 pm
Break the problem down logically:
pppoe clients in group 1 should all have some easily-matched criteria that identifies them as group 1
Then a srcnat rule matches criteria1 and uses to-address=ip1
replicate this for group 2 and group 3 ... etc...
That's it in a nutshell. Now- what criteria to use?
A) Use a different IP pool for each group of users - this is easily matched by a srcnat rule:
src-address=172.16.0.0/16 action=src-nat to-address=ip1
src-address=172.17.0.0/16 action=src-nat to-address=ip2
etc...
B) Use the "address list" option on the ppp profiles to specify an address list for the user's IP to be placed in,
and then NAT based on the address list:
PPP Profile "group 1" -> address-list=Group1
PPP Profile "group 2" -> address-list=Group2
etc...
/ip firewall nat ->
chain=srcnat src-address-list=Group1 action=src-nat to-address=ip1
chain=srcnat src-address-list=Group2 action=src-nat to-address=ip2
etc...
When given a spoon,
you should not cling to your fork.
The soup will get cold.
Users browsing this forum: No registered users and 68 guests
