theotang
Dude 4.0beta3 database fixed
Wed Mar 30, 2016 8:43 pm
I’ve had a problem Dude 4.0beta3 database for a year now. dude.db was 419259 KB in size.
Trying the dump to .sql solution caused all my maps to disappear.
Instead, I did the following:
1. Shutdown dude.exe
2. Make a backup of dude.db
3. Use sqlite3 dude.db
4. sqlite> DELETE FROM outages;
5. sqlite> DELETE FROM chart_values_raw;
6. sqlite> DELETE FROM chart_values_10min;
7. sqlite> DELETE FROM chart_values_2hour;
8. sqlite> DELETE FROM chart_values_1day;
9. sqlite> pragma integrity_check;
10. sqlite> vacuum;
11. sqlite> reindex;
12. sqlite> .quit
13. Start dude.exe again
My dude.db is now 46662 with all maps minus all historic outages and charts. It runs fast.
jarda
Thu Mar 31, 2016 1:46 am
Great. But it should be running fast with all historic data...
lebowski
Re: Dude 4.0beta3 database fixed
Fri Apr 01, 2016 10:55 pm
Nice to know how to clear out the database!
navidrasi
Sat Apr 30, 2016 8:13 pm
I have a problem with my dude , it stop working now when i check the this command here is the result:
/dude print
action timed out - try again, if error continues contact MikroTik support and send a supout file (13)
so i download the database and delete all historic data it reduce the database size from 260MB to 20 MB
but still when i enable the dude and run the /dude print it shows it is loading the record and then it hangs again(check the attachment)
it seems there is a line in database which crashes the dude
when i dump the database i have 43427 records in obj table
anyway thoughts about how i can fix this?
Thank you
theotang
Tue May 03, 2016 2:50 am
Sorry to hear that you are having trouble with your Dude install.
Did you try the vacuum command?
Users browsing this forum: Bing [Bot], YaCy [Bot] and 10 guests
