Multik
API -> get Routing Tables
Tue Apr 05, 2016 4:08 pm
How to get all available routing tables?
for example - /ping a have routing-table parameter... how i can get it all from API?
thanks!
boen_robot
Re: API -> get Routing Tables
Tue Apr 05, 2016 6:44 pm
Question is how would you get them from the command line...
I'm guessing "/ip route print", and then loop over that to find all distinct occurrences of "table".
PEAR2_Net_RouterOS(1.0.0b6) - My API client in PHP
(Rate my posts? If you want... no pressure...)
docmarius
Tue Apr 05, 2016 9:48 pm
Routing tables may exist even if no route is associated with them. e.g. a VRF with no assigned IP address on its interface. Or a mangle rule setting a routing mark.
But there must be an direct method, since they appear in the dropdown lists in winbox.
If not, this is the moment of a feature request :-)
Torturing CCR1009-7G-1C-1S+, RB450G, RB750GL, RB951G-2HnD, RB960PGS, RB260GSP, OmniTIK 5HnD and NetMetal 922UAGS-5HPacD + R11e-5HnD in my home network.
Users browsing this forum: No registered users and 9 guests
