question about behavior of IPv6 assignment to interfaces from an pool.
I got a /56 from my provider via DHCPD-PD, assign from the pool on /64 to LAN1 the next to LAN5.
From upstream in pool
2003:xxxx:xxxx:xx00/56
now on the first start, i got
2003:xxxx:xxxx:xx00/64 on LAN1 (set in the Adress list 2003:xxxx:xxxx:xx00::1/64)
2003:xxxx:xxxx:xx01/64 on LAN5 (set in the Adress list 2003:xxxx:xxxx:xx01::1/64)
which is what i want so far, only the 00::/64 prefix is with advertisement and autoconfiguration.
The 01::/64 is for static configuration(server)
After an reboot of the router the addresses flips.
2003:xxxx:xxxx:xx01::1/64 on LAN1
2003:xxxx:xxxx:xx00::1/64 on LAN5
And with this, different settings are now wrong which i set on the interface, so i must change.
Router is an CCR1009 with v6.35rc42
Known behavior, or bug?
