KennyPowers
RB3011 & 3 RB951G VLANS
Tue Apr 12, 2016 11:27 pm
Hi Guys,
Can anyone help me here I have my RB3011 set up as CAPSMAN (All working fine) with 3 RB951G's I wan't to set up 2 WiFi networks Public and Private and also set the switch ports on each RB951G to Public and Private so Port3 - Private Port4 - Public Port 5 - Trunk
On the RB3011 I also need switch ports Public Private and also Office 1 and Office 2 + Trunk
Is all this possible can anyone point me in the right direction?
KennyPowers
Re: RB3011 & 3 RB951G VLANS
Mon Apr 18, 2016 12:46 pm
Planned diagram attached can anyone help with the config for this or point me in the right direction.
slv
Mon Apr 18, 2016 3:25 pm
Hello
I'm using 3011 too and would like to get VLANs working on it
Problem is that since more over 1 months Mikrotik support couldnt figure it out what is wrong with port based VLANs on 3011.
My config You will find http://forum.mikrotik.com/viewtopic.php ... ead#unread
VLANs on trunked port working properly but computer conected directly to ethernet port of 3011 couldn't act properly
Ping local gateway drops 40-80% and so on
Has any one similar problems with VLANs on 3011?
Regards
SLawek
KennyPowers
Thu Jun 02, 2016 9:40 am
I have this working now, I have one issue I hope someone can help with.
VLANS are all set up on master port 2
Bridge-local contains ether2 & ether6
All CAPs register and connect and the vlans get the correct ip when connected on ports 2-5
CAPs connected 6-10 register but the don't don't get an ip.
If I move the vlans from ether2 to bridge-local interface everything seems to work ok.
But when I do this winbox won't connect with the MAC address anymore I have to use the ip?
Users browsing this forum: No registered users and 90 guests
