flameproof
Script or method to update dynamic DNS on failover interface
Fri Apr 15, 2016 11:54 am
I have a CCR1016 sitting in a remote location, connected via AirFiber to the internet backhaul. Since we get the occasional failure of the primary backhaul, I connected a 4G router to the CCR, so it can use this connection when the primary goes down.
What I now need is for a way to find out the public IP the 4G router has - the router itself doesn't offer any dynamic DNS methods built-in.
Since the setup is [CCR 10.100.0.10] -> [4G Router 10.100.0.1] -> [4G Router public x.x.x.x] the normal scripts don't work, as the public IP will never be assigned to one of the interfaces of the CCR.
I cannot also see a way to use /tool fetch as it will always try to go out of the default gateway, which is fine during failover, but I want it to run always, so I can have a way to remote into the CCR at any time over the 4G link.
Any ideas?
Sob
Re: Script or method to update dynamic DNS on failover interface
Fri Apr 15, 2016 1:24 pm
I use IP->Cloud and simply add static route to cloud.mikrotik.com (81.198.87.240, 91.188.51.139) via backup connection's gateway. It's not perfect, because addresses can change, but you could create a script that would resolve the hostname periodically and update addresses.
The same idea could be applied to /tool fetch method, and it would be even easier if you used it with your server with static address.
People who quote full posts should be spanked with ethernet cable. Some exceptions for multi-topic threads may apply. Not intended as incentive for masochists.
flameproof
Fri Apr 15, 2016 2:28 pm
Thanks for the idea - have tested it and it works, it's fine for what I need. Awesome!
Users browsing this forum: Raouf, Znevna and 156 guests
