dennyyellow
Setup GrooveA 52HPn wireless in cable out
Fri Apr 15, 2016 6:00 pm
We just got our Mikrotik device today and it will be used for setup on the boat. The harbour has a wifi-network, so what we basically want to do is put the mikrotik on top of the boat and use the cable to plug in to an AP in the boat.
I was trying to get on internet via the ethernet cable and I try to search on this forum for a solution. I did found a solution which I thought was correct and they linked to the following page http://wiki.mikrotik.com/wiki/Connect_t ... ss_Network. This seemed like the correct solution, but when following all the steps I stumbeled upon some missing lines (like the wlan1 in DHCP Client). I tried several things, but I cannot seem to find the correct solution...
Any help is welcome!
Note: I tried every solution after a factory reset and I am using Winbox to connect to my device.
flynno
Re: Setup GrooveA 52HPn wireless in cable out
Fri Apr 15, 2016 6:38 pm
Do you know the password of the AP on the harbour you want to connect your GrooveA 52HPn to?
If answer is yes, you need to winbox into the GrooveA 52HPn
Reset the GrooveA 52HPn to default again with the reset button or via Winbox,
Use default setup config
Now Select on the left navigation menu
Quick Set > Drop down menu top left change to > CPE > Find the SSID of the AP on Harbour > Select it > Enter Password
You now should be able to connect to the Harbour AP with the GrooveA 52HPn,
IP > DHCP CLIENT
DHCP CLIENT > Interface Wan1 or what ever your wireless network is called
Make 2 Firewall Rules in NAT
General =
chain srcnat
Out. Interface Wlan1
Action =
Masquerade
General =
chain srcnat
Out. Interface ether1
Action =
Masquerade
Check for internet connection by
Tools > Ping
Ping to 8.8.8.8
dennyyellow
Fri Apr 15, 2016 6:53 pm
Thanks for your reply!
I tried as you said, but when selecting DHCP CLIENT, I only see bridge-local.
So I tried to change bridge-local into wlan1.
Then, when adding the firewall rules I got the following:
"--in/out-interface matcher not possible when interface (wlan1) is slave - use master instead (bridge-local)"
and same for ether1
Note: I did again a factory reset and used the default setup config
flynno
Fri Apr 15, 2016 6:58 pm
No problem :D
Ok what you need to do now is go into "Bridge" on left navi bar in winbox
Select "Ports" tab
Remove Wlan1 from the list
Winbox will probably kick you now so reload it again if it does
IP > DHCP CLIENT
dennyyellow
Fri Apr 15, 2016 7:04 pm
Okay, thanks! So far so good. I can ping :D
Now for the second part.. I have to connect the ethernet cable to my AP. So I thought if I can access the internet on my desktop (by connecting the ethernet cable to my desktop), then I can setup my AP. Problem is however.. I cannot access the internet this way.. He can connect to a network, but is not connected..
Any suggestions??
flynno
Fri Apr 15, 2016 7:14 pm
Cool, so if you connect the GrooveA 52HPn via ethernet cable to your desktop you have internet access but if you connect the GrooveA 52HPn to another Router/AP your wireless devices have no internet access?
What is the Router/AP you are using and do you know if its in Bridge mode or Router mode and what is the network address of that Router/AP
dennyyellow
Fri Apr 15, 2016 7:20 pm
No, in both cases I do not have internet access.
flynno
Fri Apr 15, 2016 7:27 pm
Ok can you go into Winbox
Left Navigation Menu
IP > Firewall
Filter Rules Tab
Disable all Rules
Go to Nat Tab and check you have rules
General =
chain srcnat
Action =
Masquerade
General =
chain srcnat
Out. Interface bridge (name of your bridge here)
Action =
Masquerade
dennyyellow
Fri Apr 15, 2016 7:49 pm
Okay... weird stuff happening. I was disconnected and when I restarted the quick set was back to router in stead of bridge. wlan1 port was added to bridge and ip > DHCP Client was back to bridge-local.
When changing everything back to normal, as you described I get the same error message, but only at ether1 ...
Looking at your last message, I changed that rule (ether1) into bridge-local but.. still no internet...
dennyyellow
Fri Apr 15, 2016 7:51 pm
I also get randomly disconnected reverting all settings as described in my previous message...
flynno
Fri Apr 15, 2016 8:05 pm
Ok might be best to ignore Quickset for now
Open Winbox
System > Reset Configuration
Tick "No Default Configuration"
Now press "Reset Configuration"
Winbox back in when GrooveA 52HPn reloads
Select Quickset
CPE > SSID OF HARBOUR AP
Enter Password
Configuration
Tick Router Mode
Internet
Tick Automatic
Local Address
192.168.88.1
255.255.255.0/24
Tick DHCP
192.168.88.10-255.255.255.254
Tick NAT
Click Apply
dennyyellow
Fri Apr 15, 2016 8:12 pm
Done that.. When clicking apply it disconnects, but now it won't connect anymore... error message: "Could not connect to <MAC> (port 20561) - internal error!"
But unfortunately I have to go right now.. So I will check tomorrow morning again, maybe you have some ideas...
Thanks for today! :)
flynno
Fri Apr 15, 2016 8:16 pm
Ok now you should be able to winbox into the GrooveA 52HPn with the address 192.168.88.1
dennyyellow
Fri Apr 15, 2016 8:21 pm
Grwat, should I then also do the settings as before with the dhcp and firewall??
flynno
Fri Apr 15, 2016 8:26 pm
Nope ignore everything I said before, follow below only
Open Winbox
Select Quickset
Enter Password
Configuration
Tick Router Mode
Internet
Tick Automatic
Local Address
192.168.88.1
255.255.255.0/24
Tick DHCP
Tick NAT
Click Apply
dennyyellow
Sat Apr 16, 2016 11:59 am
I tried it again this morning. Using the ip I cannot connect. (Tried 20 times, no success)
When clicking the ... Button I see the Mikrotik after waiting like 10 secs.
When clicking the mac address appears and 1 out of 3 times winbox starts, the other times I get an error that he cannot connect.
When accessing the Mikrotik, is automatically disconnects after 5 seconds or so...
flynno
Sat Apr 16, 2016 12:39 pm
Ok, you need to reset the Groove using the reset button,
When it reboots keep using the default config script,
Go to Wireless on left navigation bar
Find security tab and add a new profile call it harbour,
Add the Harbour wifi password into the profile.
Interface tab
Select the wireless card
Use the security profile you created
Look for scanner, scan for networks and find the ssid of Harbour and select
Press connect
flynno
Sat Apr 16, 2016 1:03 pm
Picture Guide
dennyyellow
Sun Apr 17, 2016 12:35 pm
Thanks for your pictures. I am now on the harbour and am trying to make things work. Unfortenately, with your solution, I do not have any internet via the ethernet cable :?
flynno
Sun Apr 17, 2016 1:26 pm
Ok If you can winbox in and go to terminal and type in
export file= harbour-script
Drag the harbour-script from files in winbox onto you desktop and open it with notepad++ or sublime text editor, copy and paste the content here, hide any passwords and any other private info you want to
dennyyellow
Sun Apr 17, 2016 1:41 pm
Just hided the password and SSID:
# jan/02/1970 00:02:14 by RouterOS 6.30.4
# software id = 10X3-6478
add admin-mac=E4:8D:8C:F7:7A:5C auto-mac=no name=bridge-local
add authentication-types=wpa2-psk eap-methods="" management-protection=\
allowed mode=dynamic-keys name=harbour supplicant-identity="" \
wpa2-pre-shared-key=***PASS HERE***
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n disabled=no frequency=2412 \
l2mtu=1600 security-profile=harbour ssid=***SSID Here***
add bridge=bridge-local interface=ether1
add bridge=bridge-local interface=wlan1
add address=192.168.88.1/24 comment="default configuration" interface=\
bridge-local network=192.168.88.0
/system leds
set 0 interface=wlan1
/system routerboard settings
set cpu-frequency=600MHz protected-routerboot=disabled
/tool romon port
add
flynno
Sun Apr 17, 2016 3:03 pm
Ok there seems to be a few lines missing from the script, like firewall rules and nat
dennyyellow
Sun Apr 17, 2016 3:13 pm
That could be correct, as I did not set those up yet. As they were not included in your last instruction. But which rules should I include then??
flynno
Sun Apr 17, 2016 3:16 pm
Ok now I need you to winbox in and reset device and tick no default configuration
Now edit this script and add in the ssid and password in the slots to match the Harbour
When edits are complete, I need you to copy and paste script back into the new terminal on winbox
/interface wireless
set [ find default-name=ether1 ] name=ether1-local
add address-pool=default-dhcp disabled=no interface=ether1-local name=default
ether1-local network=192.168.88.0
/ip dhcp-client
add comment="default configuration" dhcp-options=hostname,clientid disabled=\
no interface=wlan1-gateway
add address=192.168.88.0/24 comment="default configuration" gateway=\
192.168.88.1
set allow-remote-requests=yes
/ip dhcp-client
add chain=input comment="default configuration" protocol=icmp
add chain=input comment="default configuration" connection-state=\
established,related
add action=drop chain=input comment="default configuration" in-interface=\
wlan1-gateway
add action=fasttrack-connection chain=forward comment="default configuration" \
add chain=forward comment="default configuration" connection-state=\
established,related
add action=drop chain=forward comment="default configuration" \
connection-state=invalid
connection-nat-state=!dstnat connection-state=new in-interface=\
wlan1-gateway
add action=masquerade chain=srcnat comment="default configuration" \
out-interface=wlan1-gateway
/system leds
dennyyellow
Sun Apr 17, 2016 3:29 pm
When doing this, I get the message "input does not match any value of interface" after every "in-interface=wlan1-gateway" or out-interface. Any tips??
flynno
Sun Apr 17, 2016 3:33 pm
paste this instead, I had type mistake
/ip dhcp-client
no interface=wlan1
192.168.88.1
/ip dhcp-client
no interface=wlan1
established,related
wlan1
established,related
wlan1
out-interface=wlan1
dennyyellow
Sun Apr 17, 2016 3:55 pm
I executed all code. Don't have internet via cable, but will now try the router setup. maybe it is my computer that does something weird :?
I will get back to you if I am done ;)
flynno
Sun Apr 17, 2016 4:00 pm
If the interface is called "ether1-local"
out-interface=ether1-local
if you still dont have connection try disable the "drop" firewall rules
Use tools ping to test internet connection
8.8.8.8
also note you may need to disable & enable your NIC
dennyyellow
Sun Apr 17, 2016 5:16 pm
It works!!!
It was my computer who could not cope with the internet cable. Thank you very much for all your help!! :D :D
flynno
Sun Apr 17, 2016 5:38 pm
Ah cool, glad its sorted for you now, enjoy :D
dennyyellow
Sun Apr 17, 2016 8:59 pm
Thanks :) quick question.. Is there also a way to extend my range a bit? I read something about increasing dbm..
flynno
Sun Apr 17, 2016 10:33 pm
You need to make sure your facing your Groove at the Harbour AP, adjust it until you get optimal signal using the scanner on the wireless card to search, maybe buy a mesh dish and stick the Groove onto instead of an Omni for better results
dennyyellow
Sun Apr 17, 2016 10:35 pm
Okay, we will try to do that! Thanks for all your help :D
draknor
Wed Apr 20, 2016 11:03 pm
Way to stick with it! i have a groove setup the same way for my RV, and I also had a lot of trouble getting QuickSet to work - ended up building the config out manually. Not sure why!
Users browsing this forum: anav, andriys, heidarren, maigonis, mszru, solar77 and 63 guests
