MUM Europe 2020
rastod
How to configure OSPF routing?
Fri Sep 08, 2006 2:13 pm
Hi all, I need to configure a tool that enable keep my network working even some links are dropped. I have routed netowork with 6 main routers that are connected in a circle. There is /28 network between each two routers in order. 1-2 2-3 3-4 4-5 5-6 6-1
I suppose that OSPF is the tool.
I have read the mikrotik manual but when I configure OSFP network nothing happen, only one new route is in the routing table, it is red with flag "DI O".
Can anyone help me?
Equis
Forum Veteran
Forum Veteran
Fri Sep 08, 2006 3:36 pm
I use winbox
add interface
add networks of each router
so if ip address of router is 192.168.0.1 add network 192.168.0.0/24
Only add networks your router can directly see
rastod
Fri Sep 08, 2006 4:10 pm
my configuration is:
[admin@mikrotik_apnam] routing ospf> print
router-id: xx.xx.208.22
distribute-default: never
redistribute-connected: as-type-1
redistribute-static: as-type-1
redistribute-rip: no
redistribute-bgp: no
metric-default: 1
metric-connected: 20
metric-static: 20
metric-rip: 20
metric-bgp: 20
[admin@mikrotik_apnam] routing ospf> network print
# NETWORK AREA
0 xx.xx.208.192/28 local_1
1 xx.xx.208.16/28 local_1
[admin@mikrotik_apnam] routing ospf> area print
# NAME AREA-ID STUB DEFAULT-COST AUTHENTICATION
0 backbone 0.0.0.0 none
1 local_1 0.0.0.1 no 1 none
[admin@mikrotik_apnam] routing ospf> neighbor print
router-id=xx.xx.208.22 address=xx.xx.208.22 priority=1 state="2-Way" state-changes=0 ls-retransmits=0 ls-requests=0 db-summaries=0 dr-id=xx.xx.208.22
backup-dr-id=0.0.0.0
Users browsing this forum: MSN [Bot] and 76 guests
