MUM Europe 2020
pbaumgartner
PtMP: SXT2 -> 2x SXT2 Lite not working (Bridge -> 2xStation Bridge)
Mon Apr 25, 2016 2:22 pm
I'm trying to configure a transparent point-to-multi-Point Configuration with one SXT2 and two SXT2-Lite.
The connection between the master and ONE SXT2-Lite is working perfect. But I can't connect the second client. The only error I'm seeing is a Wireless Timeout in the LOG window. Nothing else. It just can't connect.
If I shutdown client number 1, client nr.2 connects immediately. After the reboot now client1 can't connect.
As far as I understand, I needed only one Device with Mikrotik License Level 4 - the master. The client devices, where only a point-to-point (1client, 1master) connection is needed, level 3 should be enough.
Here are the details of hardware and configuration:
Hardware:
1x SXT2 (Server); License Level 4
2x SXT2 Lite (Client); License Level 3
Software:
RouterOS: 6.35
Configuration:
Quick-Set: PTP Bridge with manual correction (nv2 passwords missing on Client Side) or manual with this guide: Bridging Networks with SXT
Frequency: fixed; Protocol: nv2; Band: 2GHz-BGN, Channel width 20/40MHz CE
Thank you in advance, Peter
kiaunel
Mon Apr 25, 2016 2:54 pm
Use ap bridge mode on sxt2
Sent from my Lenovo K50a40 using Tapatalk
pbaumgartner
Re: PtMP: SXT2 -> 2x SXT2 Lite not working (Bridge -> 2xStation Bridge)
Wed Apr 27, 2016 12:24 pm
wow, that worked! Thank you!
pbaumgartner
Wed Apr 27, 2016 1:45 pm
Who is able to edit the MikroTik Wiki? this little hint could help others.
jarda
Wed Apr 27, 2016 2:52 pm
I think that wireless modes are quite well described in manual. Unfortunately people are very often repetitively asking the questions that they could had answered if they were using Google or at least read relevant threads of the forum. And I don't speak about the documentation...
Writing more things there will not make more people to read it.
pbaumgartner
Wed Apr 27, 2016 3:25 pm
A lot of configuration manuals I found when searching for point-to-point and point-to-multipoint with or without SXT talked about configuring the "master" in "bridge" mode. None mentioned the AP bridge. as obvious as it is AFTER reading the hint, I didn't even think about it, when trying to find my mistake before. And I DID read the manual.
Users browsing this forum: barracuda, klaus007 and 32 guests
