Attempting to upgrade it via System>>Packages>>Check for Updates>>Download & Install results in the following error:
ERROR: not enough disk space, 7.7MiB is required and only 7.3MiB is free
Too late sorry - my post got stuck in the moderation queue and I gave up waiting for it - ended up doing a netinstall, which worked.please post "/system package print" and "/file print" just to be 100% sure you didn't miss something
There isn't enough space to do that. This is a remote router. Netinstall is not an option.Remove unwanted packages. Remove all removable files. Put newer single system package only and reboot. Then add rest of required packages and reboot again.
That's how I managed to resolve the problem. By only downloading the absolute minimum packages required for the next version and rebooting. You only need system and security for most purposes. Wireless too for non-ethernet connected devices.May be don't include modules disabled by default in RouterOS package for smips?
advanced-tools, hotspot, mpls, routing, security -- that modules can be uploaded separately.
In recent versions security package depends on dhcp packageThat's how I managed to resolve the problem. By only downloading the absolute minimum packages required for the next version and rebooting. You only need system and security for most purposes. Wireless too for non-ethernet connected devices.May be don't include modules disabled by default in RouterOS package for smips?
Meh. It would be nice if they ship the devices with the individual packages installed by default instead of the bundled packages. That way you can "uninstall" what you want and just reboot to free up space.In recent versions security package depends on dhcp packageEven if DHCP package is installed but disabled, upgrade won't proceed ... so DHCP package has to be installed/enabled before performing upgrade.
I had this problem on my hAP mini (MUM freebie) but I solved it by one time doing an upgrade using only the separate packages I require instead of the combined package, and from then it upgrades using the one-click method without problem.My question was, does anyone have issues using "check for updates" with a device with factory installed version?
Because in the examples I either see custom package sets, or 6.48 beta versions.
Hi, fortunately I dont have 100s of device I have 10s of devices.Do your hundreds of devices have custom packages installed? Normally there shouldn't be any custom packages and no problem upgrading.
Yes,My question was, does anyone have issues using "check for updates" with a device with factory installed version?
Yes, the first screenshot on my 10/6/2020 post was a default packages preinstalled on hap lite devices. No extra packages installed, had only ever done a simple NAT quickset config and check for update on that Mikrotik device and starting ~6months ago check for updates has been failing due to low disk space when trying to update.My question was, does anyone have issues using "check for updates" with a device with factory installed version?
This is not about 16M flash. That is not the problem (yet). You cannot see the RouterOS files that occupy the flash.I've got two devices with 16meg flash. Looking at "Files" both report around 12.6 used out of 16, but the actual files listed only amount to less than 100k. How do you see what is actually occupying flash?
Yes of course,mongobongo: Did you ever try to reboot the device just before trying the update? That may solve it for now.
The reason I mention this is that MikroTik claim in many threads that they "always test an upgrade with a device running with default settings" and they claim it works.
But we as the users see it fail. So there must be something different between their testlab and "the field". Apart from maybe some complex configurations, another difference likely is that they just netinstall their device with a test setup, and immediately try to upgrade. That has more chance of succeeding than trying to update a device that had been running for a couple of weeks and has used up or -fragmented RAM.
In 6.47 that capability is actually still there!We get told the CPEs have 7.3MB left and 7.4MB are needed. We need a way to package single .npk files into an upgrade package with just what we need. Would we ever consider MPLS on a hAP Lite? Not in a million years... so why not give us the ability to remove it from the upgrade package?
What's new in 6.47.6 (2020-Oct-21 10:41):
*) cap - fixed L2MTU path discovery;
*) crs3xx - fixed hardware offloaded LACP bonding on Ethernet interfaces for CRS354 devices;
*) radius - added "Service-Type" attribute to Access-Request for IPv4 and IPv6 DHCP servers;
*) smips - reduced RouterOS main package size;
*) switch - fixed Ethernet padding for small packets;
