WISP-BG
Strange problem with src-nat
Fri Oct 08, 2004 11:54 am
When I use src-nat to hide all my private network 192.168.x.x/24 behind a range of real IP-adresses, say x.x.x.65 - x.x.x.69, strange things happen - some sites with loging/password (mail, bank-services) frequently loses connection and you must reconnect and loging again.
Any suggestion or help?
P.S. Sorry for my bad english :oops:
[ASM]
Sun Oct 10, 2004 8:44 pm
Try using multiple outgoing addresses only for free servers. It help with ICQ too :):)
[ASM]
Sun Oct 10, 2004 8:46 pm
P.S.: this thing happens because of change of client's outgoing address (on connection NAT-ed through 1 IP and another connetion throught different IP address)
WISP-BG
Sun Oct 10, 2004 9:51 pm
Yes, I know that, but I look for some elegant way to solve the problem.
ICQ? A? :)
mag
Re: Strange problem with src-nat
Tue Oct 12, 2004 4:20 pm
if you are going to map ranges of different sizes together, it will not work. the ip-address range size have to match.
regards.
 matthias
WISP-BG
Tue Oct 12, 2004 9:36 pm
:? Hmm... But it basically works, the problem occur only in websites with user/pass, and not in all sites, just a few. It's no sense using src-nat to map, say 254 private adressess to same range real ones.
andrewluck
Forum Veteran
Forum Veteran
Tue Oct 12, 2004 11:04 pm
I would nat all of your client PCs out through one of your public IP addresses using port address translation. Use the other IP addresses for incoming connections only.
Regards
Andrew
mag
Wed Oct 13, 2004 12:22 pm
i would suggest this too. i.e. masquerading for usual clients, src-/dst-NAT pairs for servers.
regards.
 matthias
Users browsing this forum: Google [Bot], martinclaro, snagles, willianwrm and 118 guests
