EbeltoftsNet
Security problems
Fri Sep 15, 2006 2:08 am
HI
I will heard if is possibly to to use web-key on stastic ip adrress And no cryp on DHCP (hotspot)
on the same AP
Hope I can or there is a way in the hotspot modul
THANKS 8)
jo2jo
Forum Veteran
Forum Veteran
Fri Sep 15, 2006 4:41 am
what is question?
normis
Fri Sep 15, 2006 1:48 pm
what exactly you want to do?
EbeltoftsNet
Fri Sep 15, 2006 11:32 pm
I am sorry, I :oops: try again
I use static ip address with web security, that’s ok
I use the Hotspot with DHCP, is that possibly to use that without security?
Or can you do that the DHCP clients get security automatic? The same as my clients
Both is using the same ap card b/g or it is the hard way to set up ap for both dhcp / static client
spire2z
Long time Member
Long time Member
Wed Sep 20, 2006 1:09 pm
I think he means is it possible to run a HotSpot with WEP running?
EbeltoftsNet
Wed Sep 20, 2006 1:31 pm
yes, thats rigth, because now I have to set Web security before getting the dhcp adr. that have to be automatic
sergejs
Wed Sep 20, 2006 2:29 pm
If you want to use wireless encryption between AP and client, anyway client's wireless interface preconfiguration will be required to accomplish it.
Wireless security is intended to secure communication between AP and clients, to decrease possibility of unauthorized access to the AP.
ofasa
Wed Sep 20, 2006 8:42 pm
You should be able to achive this using two virtual AP interfaces with the hotspot running on the inerface that's unencrypted.
EbeltoftsNet
Thu Sep 21, 2006 1:11 am
Sound like a god ide, but can't the client get the encryption automatic when they get the dhcp adress
Have try to look in the manual ??
sergejs
Thu Sep 21, 2006 10:15 am
No, if you want to use encryption over wireless link, you will not set it without any preconfiguration on the client interface.
Users browsing this forum: Bing [Bot] and 36 guests
