KennyPowers
CAPSMAN with CAP Switch VLANS
Thu May 26, 2016 12:38 am
Hi Guys,
I asked something similar before but I just can't get it to work so I simplified what it was in the hope someone can give me a better understanding diagram attached.
I have CAPSMAN RB3011 and the CAP RG951G all set up I can split the wireless devices by adding them to different bridges in the RB3011 But I can't use the switch ports on the CAP, I need to use VLANS to do this and Ideally the wireless should be the same?
I do want to add more caps and possibly more VLANS but if I can get this much going I should be able to work that out.
andriys
Re: CAPSMAN with CAP Switch VLANS
Thu May 26, 2016 12:58 pm
CAPsMAN is about centrally managing wireless networks, and has nothing to do with switch ports. If you need a tool for centrally managing a bunch of RouterOS devices as a whole you are looking in a wrong direction- CAPsMAN is NOT such tool.
KennyPowers
Thu May 26, 2016 1:55 pm
Yes I can manage the wireless centrally, but can I use Vlans on the ports so I can use the switch along with the wireless.
I don't need to centrally manage the Vlans on the switch (CAP) once they are set and working thats all I need.
andriys
Thu May 26, 2016 2:33 pm
Sure you can use VLANs on the wired ports. Just login into your CAP device and set the required VLANs as usual.
KennyPowers
Thu May 26, 2016 4:02 pm
That's the problem I can't get this to work.
KennyPowers
Thu May 26, 2016 11:49 pm
Ok so I got this working with bridges now to figure out the switch.
One problem all my vlans can see each other is there anyway to block this and stop them reaching the router admin panel?
Users browsing this forum: Bing [Bot], kaeferfreund, tikker and 182 guests
