MUM Europe 2020
josu
Cryptographic accelerator for IPSec
Thu May 26, 2016 9:54 pm
I want to join 2 office with IPSec, each one have symmetric 300Mbps internet connection.
I want to use RB 850Gx2 devices. Could this RB handle a 300Mbps IPSec connection?
Anyone have similar installation?
Thanks for you help.
mrz
Re: Cryptographic accelerator for IPSec
Fri May 27, 2016 1:01 pm
Maximum throughput on this device is ~500Mbps UDP traffic with 1400byte packets.
josu
Fri May 27, 2016 1:05 pm
Thanks!
This value is on IPSec?
Regards.
mrz
Fri May 27, 2016 1:53 pm
Yes, you asked about ipsec.
josu
Fri May 27, 2016 2:09 pm
Thanks!
And what about RB450G? I have one of them, could I use in my installation?
Thank you for your help.
Kind regards.
mrz
Fri May 27, 2016 2:11 pm
No, that one has weak CPU and no HW acceleration, max ipsec throughput is around 25Mbps.
josu
Fri May 27, 2016 2:23 pm
Thanks!
So, which device is the cheaper for 300mbps symmetric IPSec connection?
Thank you.
mrz
Fri May 27, 2016 2:31 pm
You already picked cheapest one, RB850x2. Other routers more expensive are RB1100AHx2 and CCR series rotuers.
josu
Sun May 29, 2016 1:53 am
Thanks!
josu
Wed Jun 15, 2016 6:59 pm
And what about RB3011?
It looks great and it is not so expensive. Could it handle a IPSec 300mbps?
Best regards.
mrz
Wed Jun 15, 2016 8:51 pm
Currently RB3011 can handle around 150Mbps ipsec traffic. Router has hardware acceleration, but the driver is not ready (for RouterOS v6).
Users browsing this forum: kos and 33 guests
