navidrasi
Powershell Module
Wed Jun 01, 2016 8:48 pm
Hi everyone ,
I am not an experienced programmer but i love Mikrotik and Powershell , so here is my simple mikrotik powershell cmdlet module
i hope you like it , Please let me know if you think we can improve it
it supports API and API-SSL , for more information about Filters and Attributes please check http://wiki.mikrotik.com/wiki/Manual:API
Thank you
Exmaples:
PS C:\>Import-Module Mikrotik.dll
PS C:\> Get-Command -Module Mikrotik
CommandType Name Version Source
Cmdlet Connect-Mikrotik 1.0.0.0 Mikrotik
Cmdlet Disconnect-Mikrotik 1.0.0.0 Mikrotik
Cmdlet Send-Mikrotik 1.0.0.0 Mikrotik
#Connecting using API default port and save the connection object in C$ then we can use C$ to send commands
PS C:\> $C=Connect-Mikrotik -IPaddress 192.168.3.1 -UserName admin -Password password
Connected to 192.168.3.1 , Identity=TEST1
#Connecting using API-SSL default port
PS C:\> $C=Connect-Mikrotik -IPaddress 192.168.3.1 -UserName admin -Password password -UseSSL
#Connecting using API-SSL on diffrenet port that 8729
PS C:\> $C=Connect-Mikrotik -IPaddress 192.168.3.1 -UserName admin -Password svgafara -UseSSL -Port 3323
#get all ethernet interface which is not disabled
PS C:\> Send-Mikrotik -Connection $C -Command "/interface/getall" -Filters "type=ether","disabled=false"
#add ip to ether 1
PS C:\> Send-Mikrotik -Connection $C -Command "/ip/address/add" -Attributes "interface=ether1","address=192.168.201.1/24"
#get ether1 ip addres
PS C:\> Send-Mikrotik -Connection $C -Command "/ip/address/getall" -Filters "interface=ether1"
#Close the connection
PS C:\> Disconnect-Mikrotik -Connection $C
bitplumber
Re: Powershell Module
Tue Jun 14, 2016 12:58 pm
Thanks mate, I was just thinking about something like this myself.  :)
janisk
Tue Jun 14, 2016 4:00 pm
thanks, added link in the API page to your creation.
fsbl
Thu Sep 01, 2016 2:40 pm
Hello! I want to say thank you for your module.
And I ask how I can use the commands "set" and "remove" with this module?
milan63
Sun Jan 08, 2017 10:08 pm
Windows Server 2012 PS:
import-module d:\mikrotik.dll
error: HRESULT: 0x80131515
What can i do with it?
Can you help me please?
mitchellmnr
Tue Mar 07, 2017 8:53 pm
@milan63 -
Try right click and say unblock.
* That should do the job
@navidrasi -
Would you consider open-sourcing and posting the code on GitHub?
milan63
Wed May 24, 2017 7:20 pm
@mitchellmnr-
Perfect
Thank You !!!
nateingalls
Thu Nov 09, 2017 6:16 pm
Sorry to bump an old thread but I'm wondering how to run Torch through this module. I just need the first result Torch gives me and then end the command. I tried running the following:
Import-Module –Name "C:\location\of\Mikrotik.dll" -Verbose
$C=Connect-Mikrotik -IPaddress ip.of.mikrotik -UserName admin -Password ******
Send-Mikrotik -Connection $C -Command "/tool/torch" -Attributes "interface=bridge1" >torchresults.txt
It returns
Connected to ip.of.mikrotik , Identity=MikrotikIdentity
then locks up. I am unable to even Ctrl+Break out of the code. I've verified this command works in the CLI of the Mikrotik.
Any help would be greatly appreciated!
vedodedo
Sun Sep 30, 2018 3:16 pm
hello there
i have problem with this powershell script
cant gave count-only to the script !
i just want to have the number.
many thanks for your attention
kareem
gbudny
Sun Jan 27, 2019 9:55 pm
Hello !
Module is great and helped me a lot :) works like a charm !
But I have the same issue while trying to get count only to the script :(
By the way, have you considered putting the source of module on GitHub and allow e.g us to contribute with issue, bugs resolving and improving it ? ;) - would be great for me.
Thanks !
Best Regards
Grzegorz Budny
flydvorkin
Thu Jul 04, 2019 1:18 pm
After 6.45.1 update previous API authorization method is deprecated and dll is not working :-(
Can you update dll with new auth method?
flydvorkin
Thu Jul 04, 2019 4:24 pm
In accordance with the API manual change source code in this function to:
Code: Select all
public bool Login(string username, string password)
Send("/login");
Send("=name=" + username);
Send("=password=" + password, true);
if (Read()[0] == "!done")
return true;
else
return false;
In attach - source and dll
gbudny
Fri Jul 05, 2019 6:13 pm
Hey,
flydvorkin thanks a lot ! Have you planned to add it on git as a fork to let us work on this or report issues/bugs etc ?
I use API quite lot and would appreciate it ;)
Best Regards
Grzegorz Budny
flydvorkin
Tue Jul 23, 2019 4:55 pm
Hi.
I don't know, i'm not C-programmer, just only find and fix auth procedure in accordance with official API manual.
KareemAlKhayat
Mon Jun 22, 2020 5:16 pm
Hello everyone
Mr. Navidrasi
I have modified the module you created to match the new login method in Mikrotik Router-OS (post-v6.43).
NOTE: I live in Syria and i don't know if this Modification is legal or not
In case that the modification is illegal please email me to remove it.
my mail is: kareem.kh95@outlook.com
ronuron
Tue Aug 11, 2020 10:48 am
thanks you all for this Mikrotik powershell module.
I need one advice from you - I need to control routerboard without password.
But how can I do it from powershell??
PS C:\Temp\Mikrotik\moduly\new> $Login=Connect-Mikrotik -IPaddress 192.168.30.1 -UserName admin
cmdlet Connect-Mikrotik at command pipeline position 1
Supply values for the following parameters:
Password:
Connect-Mikrotik : Cannot bind argument to parameter 'Password' because it is an empty string.
At line:1 char:8
+ $Login=Connect-Mikrotik -IPaddress 192.168.30.1 -UserName admin
+ CategoryInfo : InvalidData: (:) [Connect-Mikrotik], ParameterBindingValidationException
+ FullyQualifiedErrorId : ParameterArgumentValidationErrorEmptyStringNotAllowed,Mikrotik.Connect_Mikrotik
Thank you a lot,
Rostislav
tecnidom
Fri Aug 21, 2020 9:39 am
I have the same problem as ronuron.
I need to configure the factory routers, which come without a password and give me the same error
"Connect-Mikrotik : No se puede enlazar el argumento con el parámetro 'Password' porque es una cadena vacía. En C:\Mikrotik\script.ps1: 8 Carácter: 71 + ... krotik -IPaddress 192.168.88.1 -UserName $Usuario -Password $Password + ~~~~~~~~~ + CategoryInfo : InvalidData: (:) [Connect-Mikrotik], ParameterBindingValidationException + FullyQualifiedErrorId : ParameterArgumentValidationErrorEmptyStringNotAllowed,Mikrotik.Connect_Mikrotik" I need the configuration to be for clumsy as I will not be the person who will do it, but it will be done by unqualified personnel and I need it to be done with just a couple of clicks, it does not serve me to use winbox and restore a backup as it can be 800 routers in total.
Thanks in advance
dima1002
Wed Sep 02, 2020 7:05 pm
Hello all,
how can i disable a IP from address-list? or enable?
Users browsing this forum: No registered users and 29 guests
