th0massin0
Feature Request: Ed25519 SSH keys
Tue Jun 07, 2016 1:20 pm
As in subject, everybody will sleep better if the support of Ed25519 keys will be available in ROS7 (or 6!)
azol
Re: Feature Request: Ed25519 SSH keys
Tue Oct 03, 2017 6:18 pm
agree, +1
WzL
Thu Nov 16, 2017 10:24 pm
+1, this feature is much missed here!
Anastasia
Mon Jan 28, 2019 3:06 pm
+1 add support Ed25519.
cypa
Mon Mar 23, 2020 1:34 pm
+1 we need this!!!
msatter
Mon Mar 23, 2020 1:47 pm
cypa
Mon Mar 23, 2020 1:58 pm
OK could you please hint what do I do wrong?
[cypa@hAP.k16] > user ssh-keys import public-key-file=id_ed25519.pub
unable to load key file (wrong format?) !
[cypa@hAP.k16] > system resource print
                   uptime: 56m26s
                  version: 6.46.4 (stable)
               build-time: Feb/21/2020 11:26:37
         factory-software: 6.34.2
              free-memory: 6.4MiB
             total-memory: 32.0MiB
                      cpu: MIPS 24Kc V7.4
                cpu-count: 1
            cpu-frequency: 650MHz
                 cpu-load: 7%
           free-hdd-space: 7.7MiB
          total-hdd-space: 16.0MiB
  write-sect-since-reboot: 115
         write-sect-total: 30299
               bad-blocks: 0%
        architecture-name: smips
               board-name: hAP lite
                 platform: MikroTik
[cypa@hAP.k16] >
eworm
Mon Mar 23, 2020 3:24 pm
Nothing wrong, ed25519 is not supported.
VVL
Thu Sep 03, 2020 1:53 am
In 7.1beta2 wireguard protocol was added. It use ed25519 as one of algorithm. Maybe it possible to add ssh support of this algo too?
Markg23
Tue Dec 08, 2020 1:39 pm
+1 It would be great if RouterOS support ssh Ed25519 keys
mkx
Tue Dec 08, 2020 9:05 pm
wireguard and ssh don't necessarily share encryption libraries so support for certain key types in one of these services doesn't mean support for same key type in the other service. However the trend in IT is to re-use things and hopefully wireguard and ssh will share encryption library ... not only to provide same level of support for key types but to reduce size of install as well.
akschu
Tue Jun 22, 2021 9:55 pm
Please! I'm deploying cert based auth and this is needed.
Paradox
Fri Oct 15, 2021 3:53 pm
I'd like to use Ed25519 SSH keys, too. I do not use any other key formats anymore.
Please add it!
yottabit
Thu Nov 25, 2021 5:51 pm
6.49.1 here and still no support for ed25519 keys. As I can no longer use sha-1 RSA keys, I would like to use the currently most secure format and not manage so many different keys just because a vendor refuses to update security to the best practices.
Can we get ed25519 support in v6 please??
Edit: I can't even get ecdsa to import, sigh.
Edit 2: workaround for now is to use rsa-sha2-256, which is still not as secure as ed25519 but it's the best that RouterOS v6 currently supports. To generate this key using openssh:
$ ssh-keygen -t rsa-sha2-256
I'm still going to be maintaining this weaker key for RouterOS only, and an ed25519 key for everything else.
eworm
Thu Nov 25, 2021 5:54 pm
I have a support/feature ticket on that topic (SUP-61929). Answer from MikroTik:
Thank you for your feedback. We will consider adding this feature in the future.
That's better than 'No' I guess... So go and place your own issue...
yottabit
Thu Nov 25, 2021 6:15 pm
Done, SUP-67007.
guipoletto
Thu Nov 25, 2021 11:20 pm
Done, SUP-67007.
did they offer a timeline?
msatter
Thu Nov 25, 2021 11:49 pm
I only know the start of the first request and that was more than 5 years ago.
eworm
Fri Nov 26, 2021 12:35 am
Timeline? Currently we do not know whether or not we will see this any time soon or at all.
So if you want this... Open your own issue to make Mikrotik aware of the interest.
osc86
Tue Apr 12, 2022 6:00 pm
It seems we first need support for modern signature algorithms (rsa-sha2-256/512, ssh-ed25519, ecdsa-sha2-nistp256/384/521).
With the release of OpenSSH 9.0, ssh-rsa is officially deprecated and disabled by default, which seems to be the only supported algorithm in RouterOS 6+7 (next to ssh-dss, also deprecated).
Connecting to the router using a rsa key now fails, and adding an exception to allow ssh-rsa again on every machine running openssh 9.0+ is not an option.
yottabit
Tue Apr 12, 2022 9:17 pm
Done, SUP-67007.
No. They didn't commit to v6 at all, and just said "shortly" for v7. That was on 2021-12-28. No updates since.
CarlitoxxPro
Mon Jun 20, 2022 1:55 pm
+1, this should be a must
@strods, please could you ping internally to the security team and let us know if is in the roadmap and what is the ETA.
Thanks in advance.
mikrotip
Sat Sep 10, 2022 5:01 pm
What is the problem? 6 years passed. Is there some update about the feature?
foorschtbar
Wed Sep 21, 2022 4:01 pm
I switched to ed25519 and my Mikrotik devices are the only ones that don't support it yet :(
rextended
Wed Sep 21, 2022 4:05 pm
Patience, you don't have to protect the "Deutsche Bank" anyway, right?
tangent
Thu Sep 22, 2022 1:15 am
Six years stretches the word “patience” all out of shape.
This in a world where RouterOS has dropped DSA (as it should) leaving only the semi-obsolescent RSA, a tech older than most of the board’s participants, I’d warrant.
It’s past time for this lack to be filled. The option to DIY a fix for ourselves with containers is either unavailable or unpalatable: most devices aren’t ARM, and even with those that are, a scripted bounce thru an OpenSSH container sucks.
Get it done, MikroTik!
foorschtbar
Thu Sep 22, 2022 2:13 pm
When u today create a new Keypair, why not use ED25519? There more improvements, like the shorter keys, and not only MoRE SEcuRe!!!11elf
yottabit
Thu Sep 22, 2022 4:38 pm
Most of my ssh hosts won't even accept rsa keys anymore. So I have to maintain ed25519 for them, and a separate rsa key just for the RouterOS hosts. It's very annoying.
gazmirb
Sun Jan 22, 2023 1:45 pm
either with update 7.7 my mikrotik doesnt support Ed25519 key :?
shalak
Sun Jan 22, 2023 9:05 pm
As of the most recent macOS update (Ventura, 13.1), by default it no longer allows RSA to be used for SSH client.
You have to explicitly allow it in SSH config:
Host *
    PubkeyAcceptedKeyTypes=+ssh-rsa
    HostKeyAlgorithms=+ssh-rsa
Any updates on implementing ed25519?
yottabit
Sun Jan 22, 2023 9:10 pm
6.5 years since original post. 2 years since they said "shortly" in my ticket. We need a reference for what "shortly" means in this case? Software dev cycles? Human lifespan? Galactic time scale? 😅
fmikker
Tue Jan 31, 2023 5:04 pm
I'm still waiting too..
seb13
Thu Feb 02, 2023 5:10 pm
+1!
Naoy
Wed Mar 08, 2023 12:17 am
We're in 2023 and Ed25519, the most used ECDH protocol, is still not supported...
eworm
Wed Mar 08, 2023 10:13 pm
Perhaps in 7.9beta? *holding thumbs*
majestic
Wed Mar 08, 2023 10:46 pm
+1 this should really of been added in many years ago. This should not be too hard to implment.
rextended
Wed Mar 08, 2023 11:22 pm
Like count on BGP routes?
Sob
Thu Mar 09, 2023 12:09 am
Reinventing the wheel properly takes time. ;) And they like to do it a lot, example: viewtopic.php?p=965896#p965896
JohnConnett
Fri Mar 10, 2023 1:10 pm
+1. Really surprised this still isn't supported in 2023!
Paradox
Mon Mar 20, 2023 5:39 pm
Also did a feature request...
laca77
Fri Mar 31, 2023 2:57 pm
What's new in 7.9beta4 (2023-Mar-23 15:01):
*) ssh - added Ed25519 host key support;
tangent
Fri Mar 31, 2023 5:34 pm
That's only the host key part. It doesn't let you set up pre-shared ed25519 keys per user.
One hopes the latter piece is coming later in the 7.9 beta process.
theprojectgroup
Sat Apr 01, 2023 9:11 pm
+1. Please, still unsupported in 2023?
laca77
Thu Apr 06, 2023 12:35 pm
7.9rc2 changelog:
Changes in this release:
*) ssh - added support for Ed25519 key export and import in PKCS8 format;
eworm
Thu Apr 06, 2023 5:37 pm
This is still just host key support, not public key authentication.
rotor
Wed May 03, 2023 12:58 pm
Confirmed it still doesn't import on 7.9.
[admin@MikroTik] > /user/ssh-keys/import public-key-file=id_ed25519.pub user=admin
unable to load key file (wrong format or bad passphrase)!
[admin@MikroTik] > /system/resource/print
                   uptime: 13h5m31s
                  version: 7.9 (stable)
               build-time: May/02/2023 05:35:06
         factory-software: 6.46.3
              free-memory: 201.8MiB
             total-memory: 256.0MiB
                      cpu: MIPS 1004Kc V2.15
                cpu-count: 4
            cpu-frequency: 880MHz
                 cpu-load: 4%
           free-hdd-space: 4208.0KiB
  write-sect-since-reboot: 2563
         write-sect-total: 375345
        architecture-name: mmips
               board-name: hEX
                 platform: MikroTik
[admin@MikroTik] >
infabo
Wed May 10, 2023 2:41 pm
And now I'd like to use my ED25519-SK token for public key authentication. That's still not possible in ROS 7.9
mantouboji
Mon May 29, 2023 11:22 am
how long should we wait ?
rextended
Mon May 29, 2023 11:26 am
Until it's finished.
lucidnx
Sat Jun 10, 2023 4:59 pm
I would love ed25519-sk support as well since I am using yubikeys.
mantouboji
Wed Jul 19, 2023 12:04 pm
How about the progress ?
eworm
Thu Aug 17, 2023 1:02 pm
Available now in 7.12beta1! 🥳
lucidnx
Wed Oct 18, 2023 2:19 pm
what about ED25519-SK? is this planned?
alexunderboots
Mon Dec 04, 2023 4:12 pm
7.12.2 steel not work (((((
alexdelprete
Mon Dec 04, 2023 6:11 pm
user ed25519 keys are in 7.12?
mkx
Mon Dec 04, 2023 7:19 pm
Yes.
alexdelprete
Mon Dec 04, 2023 10:11 pm
Yes.
Thank you. I must have missed it in the changelog.
Users browsing this forum: froggi, giguard, sch and 25 guests
