strods
v6.34.6 [bugfix] is released!
Thu Jun 09, 2016 9:28 am
Version 6.34.6 has been released in bugfix channel.
Changes since previous version:
*) discovery - fixed identity discovery (introduced in 6.34.5);
*) log - fixed time zone adjustment (introduced in 6.34.5);
*) snmp - fixed snmp timeout (introduced in 6.34.5);
*) vrrp - fixed missing vrrp interfaces after upgrade (introduced in 6.34.5).
If you experience version related issues, then please send supout file from your router to support@mikrotik.com. File must be generated while router is not working as suspected or after crash.
dgnevans
Re: v6.34.6 [bugfix] is released!
Thu Jun 09, 2016 11:48 am
Route mark working in this version. CCR1009 All seems stable.
Marino
Thu Jun 09, 2016 12:11 pm
Good to know, I'll update soon too. Thanks, much appreciated.
Fraction
Thu Jun 09, 2016 2:22 pm
hAP lite upgraded 3,5 hrs ago and no issues detected so far.. Timestamps are ok now.
thasser
Thu Jun 09, 2016 8:12 pm
Updated from 6.32.3 on 1x RB3011 and 2x RB951. Went smooth and noticeable improvements. Great job MT team! :D
macgaiver
Fri Jun 10, 2016 11:02 am
Moved ~60 boards (CCRs, hAPs wAPs, CRSes, SXTs mostly) to this version - all solid so far..
P.S. five nice comments in a row about version? - this is WITCHCRAFT!! :)
With great knowledge comes great responsibility, because of ability to recognize id... incompetent people much faster.
dgnevans
Fri Jun 10, 2016 6:59 pm
3 RB1100ahx2 upgrading all working well so far.
nz_monkey
Sat Jun 11, 2016 12:23 pm
6.34.6 is working well on our test CCR's.
Nice work Mikrotik
http://thebrotherswisp.com/ | Mikrotik MTCNA, MTCRE, MTCINE | Fortinet FTCNA, FCNSP, FCT | Extreme Networks ENA
bajodel
Long time Member
Long time Member
Sun Jun 12, 2016 12:16 pm
Upgraded some ipsec endpoints (mostly rb1100) ..all working well.
The new bugfix version seems to have the same quality/stability level of previous.. maybe better.
Well done!
thasser
Mon Jun 13, 2016 5:33 pm
Maybe we found a new LTS release...
webor
Tue Jun 14, 2016 2:20 am
After upgrade to 6.34.6 I encounter some error logs for IPsec when connecting from client machines (Windows 7, Android 6) to Mikrotik L2TP/IPsec server. The IPsec Proposal allows aes-256-cbc, aes-192-cbc, aes-128-cbc, and 3des
If Windows connects (aes-128) there is error
ipsec,error key length mismatched, mine:256 peer:128.
ipsec,error key length mismatched, mine:192 peer:128.
and after that there is a success when MT uses 128 in its 3rd attempt. If I disable aes-256 &192 then Android can not connect
That is my signature
mrz
Tue Jun 14, 2016 9:22 am
that is because more secure algorithms are picked first until supported protocol by client is matched.
webor
Tue Jun 14, 2016 10:37 pm
Thank you on your prompt response, appreciate.
I have solved the problem by choosing the Maximum strength encryption under "Data Encription" in Security Tab of the connection on the Windows client machine.
Now also win client chooses 256 as well as android
CoUL
Wed Jun 15, 2016 3:08 pm
It does not work Simple Queues.Check it out!
hAP, hAP ac lite, LHG, mANTBox, mAP, NetBox, NetMetal, PowerBox, PWR-Line, QRT, RB9xx, SXTsq, cAP, hEX Lite, RB4xx, wAP, BaseBox, DynaDish, RB2011, SXT, Groove, hAP mini, hAP lite, CRS3xx, RB3011, X86
RouterOS 6.46.4 (Stable) | WinBox v3.22
macgaiver
Wed Jun 15, 2016 3:09 pm
Disable Fasttrack
CoUL
Wed Jun 15, 2016 3:14 pm
Thank you so much!
That helped. Yet it is a bug, or tell how it should be?
paoloaga
Wed Jun 15, 2016 3:15 pm
Not a bug, read documentation.
macgaiver
Wed Jun 15, 2016 4:30 pm
Thank you so much!
This is probably good example why Dummy simple queue is necessary (similar to dummy firewall rules)
Abdock
Fri Jun 17, 2016 9:08 am
traffic engineer not working, had to downgrade and links came up.
kristaps
Fri Jun 17, 2016 10:03 am
please send your suppout.rif with your configuration and description to support@mikrotik.com we will test it.
docmarius
Fri Jun 17, 2016 11:48 am
NTP server with GPS only is still broken.
Now there is no more working current/bugfix/RC in the upgrade list, since 6.32.4 was the last one working :(
Torturing CCR1009-7G-1C-1S+, RB450G, RB750GL, RB951G-2HnD, RB960PGS, RB260GSP, OmniTIK 5HnD and NetMetal 922UAGS-5HPacD + R11e-5HnD in my home network.
toxicfusion
Fri Jun 17, 2016 11:22 pm
Just realized this 6.34.6 release.
Great news that another member posted "3 RB1100ahx2 upgrading all working well so far."  This give me a peace of mind
Planning to goto this version on  Tuesday evening.
DrDeft
Sat Jun 18, 2016 9:20 pm
6.34.6 is Bugged on RB2011
Little network with 8 users and low traffic. Today router stucked. Reboot helped in this situation.
Profiling
http://puu.sh/pxmSP/897ba95573.png
CPU Load 100%
http://puu.sh/pxmKq/fab14396e8.png
Reverted to 6.34.3
isolnet
Tue Jun 21, 2016 6:13 pm
All Information not show on SFP
lectrapon
Thu Jun 23, 2016 11:40 am
My script won't work after upgrade to 6.34.6...
 :global offset
 :global today
  :local date [ /system clock get date ]
  :local montharray ( "jan","feb","mar","apr","may","jun","jul","aug","sep","oct","nov","dec" )
  :local monthdays ( 31, 28, 31, 30, 31, 30, 31, 31, 30, 31, 30, 31 )
  :local days [ :pick $date 4 6 ]
  :local monthtxt [ :pick $date 0 3 ]
  :local year [ :pick $date 7 11 ]
  :local months ([ :find $montharray $monthtxt]  )
  :for nodays from=0 to=$months do={
   :set days ( $days + [ :pick $monthdays $nodays ] )
  :set days ($days + $year * 365)
  :set today $days
 :foreach i in [ /ip hotspot user find where disabled=no ] do={
  :if ([ :find [ /ip hotspot user get $i comment ] ] = 0 ) do={
   :local date [ /ip hotspot user get $i comment ]
   :set offset [ :pick $date 14 16 ]
   :local months ( [ :find $montharray $monthtxt ] )
   :if ( ($days + $offset) < $today ) do={
    :local name [/ip hotspot user get $i name]
    :log info "HOTSPOT EXPIRE SCRIPT: Disabling Hotspot user $name first logged in $date"
    [ /ip hotspot user disable $i ]
    [ /ip hotspot active remove [find where user=$user] ]
This script worked in past bug fixes.
I try many tests after editing each line and I found that error is at line 20
:if ([ :find [ /ip hotspot user get $i comment ] ] = 0) do={...
can you tell me how to check null value in comment ?
zBear
Thu Jun 23, 2016 3:56 pm
I have a strange problem with this bugfix.
I noticed this after upgrading to v6.34.6 from v6.32.4 and rebooting my RB2011UiAS-2HnD-IN
http://i35.servimg.com/u/f35/11/95/78/30/clipbo19.jpg
Ethernet ports 8-9-10 are in bridge and receive IPTV signal via VLAN.
This continues 10-15 minutes after router restart and then problem disappears.
I checked this 3 times going back an forward between  v6.34.6 and v6.32.4.
Don't have a problem like this with v6.32.4.
infused
Fri Jun 24, 2016 11:51 am
I have huge issues on RB2011's and don't use them  anymore. I'm sure the second switch group has a firmware bug.
zBear
Fri Jun 24, 2016 3:19 pm
it's possible
my problem (mentioned above) can be reproduced with any second switch group port
can anybody else confirm this?
pas
Mon Jun 27, 2016 11:30 pm
I can confirm flapping and other problems (the port goes up only for one second) on the second switch of RB 2011 (eth 6 to 10).
Please fix this problem asap.
sergejs
Tue Jun 28, 2016 10:09 am
Is it possible to get support output file from 6.34.6 and RB2011, where you can see port flap?
We are not aware of any firmware bug on RB2011, as was suggested here.
pas
Tue Jun 28, 2016 10:38 am
Just sent. Ticket#2016062866000221
zBear
Tue Jun 28, 2016 7:13 pm
my report has the number Ticket#2016062866000114
sport80
Wed Jun 29, 2016 11:24 am
fortunately i don't have the problem that you have described. I have more than one RB2011UiAS-RM that are currently using the eth6 to 10 correctly without problems.
zBear
Thu Jun 30, 2016 4:23 pm
I've got an answer today from support
We have reproduced this particular problem in the test lab and are looking for solution now.
I am happy it wasn't my configuration problem :-)
timk
Fri Jul 01, 2016 10:38 am
Is anyone else having issues with PPPoE (client) in this version?
toxicfusion
Fri Jul 01, 2016 4:14 pm
NOTICE / BUG REPORT!
RB1100Ahx2
Firmware 3.24
RouterOS 6.34.6
Upgrade went very well from 6.20....  However, this morning I've had phone calls of random workstations having issues accessing some remote resources.   We have MANY IPSEC VPN tunnels
issue was people unable to access some mapped network drives, or even failure to RDP.  However, other users, different computers could access those same resources without ANY issue
I turned OFF Fasttrack Filter rules and then it suddently worked again.  Appears Fast Track was fast tracking/skipping some packets required for the connection?
Maybe I should just goto Current release?
andriys
Fri Jul 01, 2016 4:17 pm
This is NOT a bug. You have to make sure inner-tunnel packets are never fasttracked. Fasttracking a packet means bypassing most of the usual processing, including IPsec policy matching.
lectrapon
Tue Jul 05, 2016 3:15 am
 :global offset
 :global today
  :set today $days
I found another problem ... when user is connected and I turn off the Hotspot user logged in, active user who was deactivated are not disconnected from the active hotspot tab. He is still connected until it disconnects itself.
zBear
Tue Jul 12, 2016 3:40 pm
RB2011 problem was fixed today in v6.36rc39
*) rb2011 - fixed ether6-ether10 flapping when two ports from both switch chips are in the same bridge;
rmmccann
Mon Jul 25, 2016 9:16 pm
Would be nice to see this make it to the bugfix channel.
A common mistake that people make when trying to design something completely foolproof is to underestimate the ingenuity of complete fools. --Douglas Adams
zBear
Mon Jul 25, 2016 10:09 pm
unfortunately, only in next one
javar008
Thu Aug 25, 2016 10:15 am
Total Bandwidth = Up to 6 M
8 Clients that I have :
Billing : 192.168.88.2
Client1 : 192.168.88.3
Client2 : 192.168.88.4
Client3 : 192.168.88.5
Client4 : 192.168.88.6
Client5 : 192.168.88.7
Client6 : 192.168.88.8
Master : 192.168.88.9
In-Interface = ether1
Out-Interface = bridge-local
/ip firewall address-list
add address=192.168.88.0/24 disabled=no list=bridge-local comment="default configuration"
/ ip firewall mangle
add action=mark-connection chain=prerouting dst-address="bridge-local" in-interface=ether1 new-connection-mark=All-Inconn disabled=no passthrough=yes comment="CONNECTION-IN"
add action=mark-packet chain=prerouting in-interface=ether1 connection-mark=All-Inconn disabled=no new-packet-mark=All-inpkt passthrough=yes comment="UPSTEAM PACKETS"
add action=mark-connection chain=forward Out-interface=bridge-local new-connection-mark=All-Outconn disabled=no passthrough=yes comment="CONNECTION-OUT"
add action=mark-packet chain=forward connection-mark=All-Outconn new-packet-mark=All-Outpkt disabled=no passthrough=yes comment="DOWNSTEAM-PACKETS"
/queue tree
add name=All-Bandwidth parent=global packet-mark=All-Outpkt queue=default priority=1 max-limit=6M
add action=mark-connection chain=forward comment="Billing" disabled=no dst-address=192.168.88.2 new-connection-mark="Billing-conn" passthrough=yes connection-mark=All-Outconn
add action=mark-connection chain=forward comment="Client1" disabled=no dst-address=192.168.88.3 new-connection-mark="Client1-conn" passthrough=yes connection-mark=All-Outconn
add action=mark-connection chain=forward comment="Client2" disabled=no dst-address=192.168.88.4 new-connection-mark="Client2-conn" passthrough=yes connection-mark=All-Outconn
add action=mark-connection chain=forward comment="Client3" disabled=no dst-address=192.168.88.5 new-connection-mark="Client3-conn" passthrough=yes connection-mark=All-Outconn
add action=mark-connection chain=forward comment="Client4" disabled=no dst-address=192.168.88.6 new-connection-mark="Client4-conn" passthrough=yes connection-mark=All-Outconn
add action=mark-connection chain=forward comment="Client5" disabled=no dst-address=192.168.88.7 new-connection-mark="Client5-conn" passthrough=yes connection-mark=All-Outconn
add action=mark-connection chain=forward comment="Client6" disabled=no dst-address=192.168.88.8 new-connection-mark="Client6-conn" passthrough=yes connection-mark=All-Outconn
add action=mark-connection chain=forward comment="Master" disabled=no dst-address=192.168.88.9 new-connection-mark="Master-conn" passthrough=yes connection-mark=All-Outconn
add action=mark-packet chain=forward new-packet-mark="Billing-pkt" passthrough=yes connection-mark="Billing-conn" comment="BILLING DOWNSTEAM"
add action=mark-packet chain=forward new-packet-mark="Client1-pkt" passthrough=yes connection-mark="Client1-conn" comment="CLIENT1 DOWNSTEAM"
add action=mark-packet chain=forward new-packet-mark="Client2-pkt" passthrough=yes connection-mark="Client2-conn" comment="CLIENT2 DOWNSTEAM"
add action=mark-packet chain=forward new-packet-mark=Client3-pkt passthrough=yes connection-mark=Client3-conn comment="CLIENT3 DOWNSTEAM"
add action=mark-packet chain=forward new-packet-mark=Client4-pkt passthrough=yes connection-mark=Client4-conn comment="CLIENT4 DOWNSTEAM"
add action=mark-packet chain=forward new-packet-mark=Client5-pkt passthrough=yes connection-mark=Client5-conn comment="CLIENT5 DOWNSTEAM"
add action=mark-packet chain=forward new-packet-mark=Client6-pkt passthrough=yes connection-mark=Client6-conn comment="CLIENT6 DOWNSTEAM"
add action=mark-packet chain=forward new-packet-mark=Master-pkt passthrough=yes connection-mark=Master-conn comment="MASTER DOWNSTEAM"
/queue tree
add name="Billing" parent=All-Bandwidth packet-mark="Billing-pkt" queue=default priority=8 limit-at=256k max-limit=256k burst-limit=720k burst-threshold=192k burst-time=2s
add name="Client1" parent=All-Bandwidth packet-mark="Client1-pkt" queue=default priority=8 limit-at=256k max-limit=256k burst-limit=720k burst-threshold=192k burst-time=2s
add name="Client2" parent=All-Bandwidth packet-mark="Client2-pkt" queue=default priority=8 limit-at=256k max-limit=256k burst-limit=720k burst-threshold=192k burst-time=2s
add name=Client3 parent=All-Bandwidth packet-mark=Client3-pkt queue=default priority=8 limit-at=256k max-limit=256k burst-limit=720k burst-threshold=192k burst-time=2s
add name=Client4 parent=All-Bandwidth packet-mark=Client4-pkt queue=default priority=8 limit-at=256k max-limit=256k burst-limit=720k burst-threshold=192k burst-time=2s
add name=Client5 parent=All-Bandwidth packet-mark=Client5-pkt queue=default priority=8 limit-at=256k max-limit=256k burst-limit=720k burst-threshold=192k burst-time=2s
add name=Client6 parent=All-Bandwidth packet-mark=Client6-pkt queue=default priority=8 limit-at=256k max-limit=256k burst-limit=720k burst-threshold=192k burst-time=2s
add name=Master parent=All-Bandwidth packet-mark=Master-pkt queue=default priority=8 limit-at=256k max-limit=256k burst-limit=720k burst-threshold=192k burst-time=2s
Part I: Creating package per client to download and trees queue with priority you want , here the script follows :
/ip firewall layer7-protocol
add comment="" name=download regexp="^.*get.+\\.(exe|rar|iso|zip|7zip|flv|mkv|avi|mp4|3gp|rmvb|mp3|img|dat|mov).*\$"
add chain=forward layer7-protocol=download action=mark-packet new-packet-mark="billing-dpkt" passthrough=no packet-mark=Billing-pkt comment="Billing-Down"
add chain=forward layer7-protocol=download action=mark-packet new-packet-mark="client1-dpkt" passthrough=no packet-mark=Client1-pkt comment="Client1-Down"
add chain=forward layer7-protocol=download action=mark-packet new-packet-mark="client2-dpkt" passthrough=no packet-mark=Client2-pkt comment="Client2-Down"
add chain=forward layer7-protocol=download action=mark-packet new-packet-mark=client3-dpkt passthrough=no packet-mark=Client3-pkt comment="Client3-Down"
add chain=forward layer7-protocol=download action=mark-packet new-packet-mark=client4-dpkt passthrough=no packet-mark=Client4-pkt comment="Client4-Down"
add chain=forward layer7-protocol=download action=mark-packet new-packet-mark=client5-dpkt passthrough=no packet-mark=Client5-pkt comment="Client5-Down"
add chain=forward layer7-protocol=download action=mark-packet new-packet-mark=client6-dpkt passthrough=no packet-mark=Client6-pkt comment="Client6-Down"
add chain=forward layer7-protocol=download action=mark-packet new-packet-mark=master-dpkt passthrough=no packet-mark=Master-pkt comment="Master-Down"
/queue tree
add name=Billing-Down parent=Billing packet-mark=billing-dpkt queue=default priority=6 limit-at=180k max-limit=180k burst-limit=256k burst-threshold=135k burst-time=2s
add name=Client1-Down parent=Client1 packet-mark=client1-dpkt queue=default priority=6 limit-at=180k max-limit=180k burst-limit=256k burst-threshold=135k burst-time=2s
add name=Client2-Down parent=Client2 packet-mark=client2-dpkt queue=default priority=6 limit-at=180k max-limit=180k burst-limit=256k burst-threshold=135k burst-time=2s
add name=Client3-Down parent=Client3 packet-mark=client3-dpkt queue=default priority=6 limit-at=180k max-limit=180k burst-limit=256k burst-threshold=135k burst-time=2s
add name=Client4-Down parent=Client4 packet-mark=client4-dpkt queue=default priority=6 limit-at=180k max-limit=180k burst-limit=256k burst-threshold=135k burst-time=2s
add name=Client5-Down parent=Client5 packet-mark=client5-dpkt queue=default priority=6 limit-at=180k max-limit=180k burst-limit=256k burst-threshold=135k burst-time=2s
add name=Client6-Down parent=Client6 packet-mark=client6-dpkt queue=default priority=6 limit-at=180k max-limit=180k burst-limit=256k burst-threshold=135k burst-time=2s
add name=Master-Down parent=Master packet-mark=master-dpkt queue=default priority=6 limit-at=180k max-limit=180k burst-limit=256k burst-threshold=135k burst-time=2s
Here we take and use a connection per client and differentiate into packet connection downloaded by file extension , so if there is a file extension that you think is important , just add the file extension you want to layer 7 protocol of the script above .
Part II . Creating a connection package videos per client complete with tree queuing and priority as you please . the script follows
add comment="" name=streaming regexp="^.*get.+\\.(c.youtube.com|cdn.dailymotion.com|metacafe.com|mccont.com).*\$"
If the script above does not work , try RegExp both in script below !
add comment="" name=streaming regexp="videoplayback|video"
add comment=Billing-Streams chain=forward layer7-protocol=streaming action=mark-packet new-packet-mark=billing-spkt passthrough=no packet-mark=Billing-pkt
add comment=Client1-Streams chain=forward layer7-protocol=streaming action=mark-packet new-packet-mark=client1-spkt passthrough=no packet-mark=Client1-pkt
add comment=Client2-Streams chain=forward layer7-protocol=streaming action=mark-packet new-packet-mark=client2-spkt passthrough=no packet-mark=Client2-pkt
add comment=Client3-Streams chain=forward layer7-protocol=streaming action=mark-packet new-packet-mark=client3-spkt passthrough=no packet-mark=Client3-pkt
add comment=Client4-Streams chain=forward layer7-protocol=streaming action=mark-packet new-packet-mark=client4-spkt passthrough=no packet-mark=Client4-pkt
add comment=Client5-Streams chain=forward layer7-protocol=streaming action=mark-packet new-packet-mark=client5-spkt passthrough=no packet-mark=Client5-pkt
add comment=Client6-Streams chain=forward layer7-protocol=streaming action=mark-packet new-packet-mark=client6-spkt passthrough=no packet-mark=Client6-pkt
add comment=Master-Streams chain=forward layer7-protocol=streaming action=mark-packet new-packet-mark=master-spkt passthrough=no packet-mark=Master-pkt
/queue tree
add name=Billing-Streams parent=Billing packet-mark=billing-spkt queue=default priority=8 limit-at=220k max-limit=220k burst-limit=256k burst-threshold=165k burst-time=2s
add name=Client1-Streams parent=Client1 packet-mark=client1-spkt queue=default priority=8 limit-at=220k max-limit=220k burst-limit=256k burst-threshold=165k burst-time=2s
add name=Client2-Streams parent=Client2 packet-mark=client2-spkt queue=default priority=8 limit-at=220k max-limit=220k burst-limit=256k burst-threshold=165k burst-time=2s
add name=Client3-Streams parent=Client3 packet-mark=client3-spkt queue=default priority=8 limit-at=220k max-limit=220k burst-limit=256k burst-threshold=165k burst-time=2s
add name=Client4-Streams parent=Client4 packet-mark=client4-spkt queue=default priority=8 limit-at=220k max-limit=220k burst-limit=256k burst-threshold=165k burst-time=2s
add name=Client5-Streams parent=Client5 packet-mark=client5-spkt queue=default priority=8 limit-at=220k max-limit=220k burst-limit=256k burst-threshold=165k burst-time=2s
add name=Client6-Streams parent=Client6 packet-mark=client6-spkt queue=default priority=8 limit-at=220k max-limit=220k burst-limit=256k burst-threshold=165k burst-time=2s
add name=Master-Streams parent=Master packet-mark=master-spkt queue=default priority=8 limit-at=220k max-limit=220k burst-limit=256k burst-threshold=165k burst-time=2s
This is the same method to create a package connection as download package is to use a layer 7 protocol , content streaming video on other sites that have not been defined , you simply add the layer 7 protocol if you think that is important , and adjust the priority and the speed limit in trees queue as you please .
c. Making Online game packets per client complete with queue treenya, the following is scriptsnya:
Part III : Making Online connection package game per client complete with trees and queue priority , here the script follows :
add action=mark-packet chain=forward packet-mark=All-Outpkt new-packet-mark=gpkt passthrough=yes protocol=tcp dst-port=5340-5352,6000-6152,10001-10011,14009-14030,18901-18909 comment="Online Game Portal"
add action=mark-packet chain=forward packet-mark=All-Outpkt new-packet-mark=gpkt passthrough=yes protocol=tcp dst-port=39190,27780,29000,22100,10009,4300,15001,15002,7341,7451
add action=mark-packet chain=forward packet-mark=All-Outpkt new-packet-mark=gpkt passthrough=yes protocol=tcp dst-port=40000,9300,9400,9700,7342,8005-8010,37466,36567,8822
add action=mark-packet chain=forward packet-mark=All-Outpkt new-packet-mark=gpkt passthrough=yes protocol=tcp dst-port=47611,16666,20000,5105,29000,18901-18909,9015
add action=mark-packet chain=forward packet-mark=All-Outpkt new-packet-mark=gpkt passthrough=yes protocol=udp dst-port=27005,27015
add action=mark-packet chain=forward packet-mark=All-Outpkt new-packet-mark=gpkt passthrough=yes protocol=udp dst-port=27005-27020,13055,7800-7900,12060-12070
add action=mark-packet chain=forward packet-mark=All-Outpkt new-packet-mark=gpkt passthrough=yes protocol=udp dst-port=8005-8010,9068,1293,1479,9401,9600,30000
add action=mark-packet chain=forward packet-mark=All-Outpkt new-packet-mark=gpkt passthrough=yes protocol=udp dst-port=14009-14030,42051-42052,40000-40050,13000-13080
add action=mark-packet chain=forward new-packet-mark=billing-gpkt passthrough=no dst-address=192.168.88.2 packet-mark=gpkt comment=Billing-Game
add action=mark-packet chain=forward new-packet-mark=client1-gpkt passthrough=no dst-address=192.168.88.3 packet-mark=gpkt comment=Client1-Game
add action=mark-packet chain=forward new-packet-mark=client2-gpkt passthrough=no dst-address=192.168.88.4 packet-mark=gpkt comment=Client2-Game
add action=mark-packet chain=forward new-packet-mark=client3-gpkt passthrough=no dst-address=192.168.88.5 packet-mark=gpkt comment=Client3-Game
add action=mark-packet chain=forward new-packet-mark=client4-gpkt passthrough=no dst-address=192.168.88.6 packet-mark=gpkt comment=Client4-Game
add action=mark-packet chain=forward new-packet-mark=client5-gpkt passthrough=no dst-address=192.168.88.7 packet-mark=gpkt comment=Client5-Game
add action=mark-packet chain=forward new-packet-mark=client6-gpkt passthrough=no dst-address=192.168.88.8 packet-mark=gpkt comment=Client6-Game
add action=mark-packet chain=forward new-packet-mark=master-gpkt passthrough=no dst-address=192.168.88.9 packet-mark=gpkt comment=Master-Game
/queue tree
add name=Billing-Game parent=Billing packet-mark=billing-gpkt queue=default priority=1 limit-at=220k max-limit=220k burst-limit=256k burst-threshold=165k burst-time=2s
add name=Client1-Game parent=Client1 packet-mark=client1-gpkt queue=default priority=1 limit-at=220k max-limit=220k burst-limit=256k burst-threshold=165k burst-time=2s
add name=Client2-Game parent=Client2 packet-mark=client2-gpkt queue=default priority=1 limit-at=220k max-limit=220k burst-limit=256k burst-threshold=165k burst-time=2s
add name=Client3-Game parent=Client3 packet-mark=client3-gpkt queue=default priority=1 limit-at=220k max-limit=220k burst-limit=256k burst-threshold=165k burst-time=2s
add name=Client4-Game parent=Client4 packet-mark=client4-gpkt queue=default priority=1 limit-at=220k max-limit=220k burst-limit=256k burst-threshold=165k burst-time=2s
add name=Client5-Game parent=Client5 packet-mark=client5-gpkt queue=default priority=1 limit-at=220k max-limit=220k burst-limit=256k burst-threshold=165k burst-time=2s
add name=Client6-Game parent=Client6 packet-mark=client6-gpkt queue=default priority=1 limit-at=220k max-limit=220k burst-limit=256k burst-threshold=165k burst-time=2s
add name=Master-Game parent=Master packet-mark=master-gpkt queue=default priority=1 limit-at=220k max-limit=220k burst-limit=256k burst-threshold=165k burst-time=2s
In this case we make connections - online game initially , based out - interface = wlan1 and tcp and udp many ports used by online gaming . Then make an online package of connection games per address ip client that we finally catch packages online games in tree queues and priority that you want .
Part IV . Make browsing packet connections per client complete with queues of trees and give priority , here the following script :
add action=mark-packet chain=forward connection-bytes=0-1000000 src-port=80,443 passthrough=no packet-mark=Billing-pkt new-packet-mark=billing-bpkt protocol=tcp comment="BILLING BROWSING"
add action=mark-packet chain=forward connection-bytes=0-1000000 src-port=80,443 passthrough=no packet-mark=Client1-pkt new-packet-mark=client1-bpkt protocol=tcp comment="CLIENT1 BROWSING"
add action=mark-packet chain=forward connection-bytes=0-1000000 src-port=80,443 passthrough=no packet-mark=Client2-pkt new-packet-mark=client2-bpkt protocol=tcp comment="CLIENT2 BROWSING"
add action=mark-packet chain=forward connection-bytes=0-1000000 src-port=80,443 passthrough=no packet-mark=Client3-pkt new-packet-mark=client3-bpkt protocol=tcp comment="CLIENT3 BROWSING"
add action=mark-packet chain=forward connection-bytes=0-1000000 src-port=80,443 passthrough=no packet-mark=Client4-pkt new-packet-mark=client4-bpkt protocol=tcp comment="CLIENT4 BROWSING"
add action=mark-packet chain=forward connection-bytes=0-1000000 src-port=80,443 passthrough=no packet-mark=Client5-pkt new-packet-mark=client5-bpkt protocol=tcp comment="CLIENT5 BROWSING"
add action=mark-packet chain=forward connection-bytes=0-1000000 src-port=80,443 passthrough=no packet-mark=Client6-pkt new-packet-mark=client6-bpkt protocol=tcp comment="CLIENT6 BROWSING"
add action=mark-packet chain=forward connection-bytes=0-1000000 src-port=80,443 passthrough=no packet-mark=Master-pkt new-packet-mark=master-bpkt protocol=tcp comment="MASTER BROWSING"
/queue tree
add name="Billing-Browsing" parent=Billing packet-mark=billing-bpkt queue=default priority=2 limit-at=256k max-limit=256k burst-limit=720k burst-threshold=192k burst-time=2s
add name="Client1-Browsing" parent=Client1 packet-mark=client1-bpkt queue=default priority=2 limit-at=256k max-limit=256k burst-limit=720k burst-threshold=192k burst-time=2s
add name="Client2-Browsing" parent=Client2 packet-mark=client2-bpkt queue=default priority=2 limit-at=256k max-limit=256k burst-limit=720k burst-threshold=192k burst-time=2s
add name="Client3-Browsing" parent=Client3 packet-mark=client3-bpkt queue=default priority=2 limit-at=256k max-limit=256k burst-limit=720k burst-threshold=192k burst-time=2s
add name="Client4-Browsing" parent=Client4 packet-mark=client4-bpkt queue=default priority=2 limit-at=256k max-limit=256k burst-limit=720k burst-threshold=192k burst-time=2s
add name="Client5-Browsing" parent=Client5 packet-mark=client5-bpkt queue=default priority=2 limit-at=256k max-limit=256k burst-limit=720k burst-threshold=192k burst-time=2s
add name="Client6-Browsing" parent=Client6 packet-mark=client6-bpkt queue=default priority=2 limit-at=256k max-limit=256k burst-limit=720k burst-threshold=192k burst-time=2s
add name="Master-Browsing" parent=Master packet-mark=master-bpkt queue=default priority=2 limit-at=256k max-limit=256k burst-limit=720k burst-threshold=192k burst-time=2s
guys can you help met to fit this script to may ros rb951g if i run this script cant work properly
javar008
Thu Aug 25, 2016 10:18 am
im using mikrotik rb951g v6 any one can help me pls..
lectrapon
Thu Aug 25, 2016 3:35 pm
Hello Javar008,
I think you might try commands bloc by bloc (copy and paste each command line) in your routerboard terminal to find what's wrong ;)
littlebill
Fri Sep 02, 2016 4:27 am
so i guess the port flapping is not going to get fixed on the 2011? really would like to move up in bug fixes...
zBear
Fri Sep 02, 2016 7:29 am
not in this branch, only in the next one
dgcapel
Tue Sep 06, 2016 11:49 pm
Good nigth,
in the last weeks I'm having problems in some routers of my company (model: CCR1009-8G-1S) after a power failure with IPSec VPN.
The router lost power, reboot and then don't work for some IPSec VPN networks (some yes, some no).
192.168.4.0 <--> 192.168.8.0 work fine
192.168.4.0 <--> 192.168.2.0 don't work
The configuration don't change. Then I do a manual reboot of router and .... work fine. Very strange.
Best Regards
bergonz
Thu Sep 08, 2016 1:41 pm
Upgraded 2 RB1100ahx2 from 6.27 to 6.34.6 with IPsec, GRE, OSPF, BGP, MPLS, VRF, OpenVPN. No issues insofar.
Regards,
Bergonz
DennisOlof
Wed Sep 21, 2016 9:43 pm
Is this the last "bug fix" version or will there be more ?
At what stages is bug fixing frozen for current versions, (just like 5.26 is legacy and frozen).
Not that I use that version but still, would like to know.
infused
Fri Sep 30, 2016 3:24 am
I just went to the next version.
I think the fix on the RB2011 took far too long. I was having that issue way back around 3 years ago (or whenever they came out). I kept moaning and sent a few support files but got nothing. Good to see it fixed now, but I literally threw away a ton of these once the RB3011 came out.
It's an odd bug, and would only flap when certain things happened. For us, we narrowed it down to Ubiquiti devices on the network, like APs. Losing power to them or something initiated a port flap.
Ljubo
Tue Oct 04, 2016 1:19 pm
Occasionally I have a problem with ipsec error that tells me the error.
Any idea what it is
02:12:30 ipsec,error failed to get valid proposal.
02:12:30 ipsec,error failed to pre-process ph1 packet (side: 1, status 1).
02:12:30 ipsec,error phase1 negotiation failed.
02:21:14 ipsec,error failed to get valid proposal.
02:21:14 ipsec,error failed to pre-process ph1 packet (side: 1, status 1).
02:21:14 ipsec,error phase1 negotiation failed.
javar008
Sat Oct 08, 2016 4:49 pm
thanks for those replies!....
i need a legit script for my shop i tried to set up... but stiil now i cant find the working script...
but those who are willing to help ill apreciate for your support and effort:
this is my plan:
ether1 is may isp 192.168.1.45/24
ether 2-to-5 is combined to "brigde-local" 192.168.3.1/24
queue tree priority1-games-online
2-browsing
3-streaming
4-social media
5-p2p
6-torrent
7- unknown
8-downloads
thanks to the mikrotik masters that can give the best script of my plan....
docmarius
Sat Oct 08, 2016 8:07 pm
javar008: sorry to say, but what is the relation of your problem with the announcement of a bugfix version?
Open your own topic in the beginner or general section and discuss there your configuration issues.
javar008
Sun Oct 09, 2016 3:54 am
bugfix version? is the only version what i used in my router. there is no problem about my need?
this is what i need ?
qos- overall-parent=bridge-local
Games-online=parent= qosover-all
Games-updte=parent= qosover-all
browsing=parent=qosover-all
socialmediaFB=parent=browsing
streaming =parent=browsing
download =parent=browsing
p2p-all =parent=browsing
unknown =parent=browsing
note: ether1=wan isp= 192.168.1.2/24
bridge-local= 192.168.3.1/24
thats what i need to find out sir,, if you help me ill apreciate......
Cha0s
Forum Veteran
Forum Veteran
Sun Oct 09, 2016 2:01 pm
You are offtopic.
Create a new thread and ask your questions.
What you say has nothing to do with this thread.
docmarius
Mon Oct 10, 2016 6:58 pm
This is an announcement from Mikrotik about releasing a new firmware. We expect to discuss here issues related to this particular release.
Your needs are not specific problems of this release. If you like to discuss configuration and setup issues, open your own topic in the beginner or general forum. Users will answer your questions there.
This is a forum, not a mailing list. So we have the means to organize discussions in different topics. Please keep these firmware announcements clean.
cesarkallas
Tue Oct 18, 2016 2:20 am
Hi
We are using the latest bugfix versão 6.34.6 + 3.27fw into a CCR 1016, and the pppoe clients are duplicating every 24 hours (+-). We already configured only-one (profile) and one session per host (pppoe server).
The most strange thing is: When we remove the interace (pppoe), the active connection continue activated, and off course, the queue state is "unknow" for the duplicated connection.
Tornike
how i can get my files
Tue Oct 18, 2016 4:33 pm
hi guys . i have upgraded my os system on mikrotik router ccr1036 and i lost my files... hotspot and other files how i can get it back can anyone tell me ?
spindlow2016
Thu Oct 20, 2016 10:34 am
Upgrading with version v6.34.6 is working well. Thanks
Tornike
Thu Oct 20, 2016 4:13 pm
i upgraded version v6.34.6 after this i missed my file
strods
Wed Oct 26, 2016 1:27 pm
Version 6.36.4 has been released in bugfix channel:
http://forum.mikrotik.com/viewtopic.php?f=21&t=113905
Users browsing this forum: No registered users and 14 guests
