MUM Europe 2020
tricer
SXT Lite 5ac using 2.4 as AP
Fri Jun 10, 2016 2:27 am
I was wondering if you upgraded the license level to 4 from 3 if you could do the following
1. use the 5GHz radio as an AP
2. use the 2.4GHz radio as an AP for more then 1 connection, I am assume the 1.5db antenna is omni
3. if 2 can happen, management the 2.4GHz radio with CAPsMan
The reason I am using is that I have a setup where I really could use the 5GHz as a backhaul and the 2.4GHz to serve wireless client access to laptops and or smart devices all it would be outdoors and all the the devices will be without 100 feet or so from the sxt lite5 ac
if the SXT lite5 ac will not do this, what product do you recommend? I would like 1 device with 2 radios in it, if there is no such product this would be a great idea to look into.
thanks in advance
uldis
Re: SXT Lite 5ac using 2.4 as AP
Fri Jun 10, 2016 5:27 pm
you can go for wAP ac board as well.
chechito
Fri Jun 10, 2016 6:55 pm
i think he needs the 5ghz directional radio of sxt
tricer
Fri Jun 10, 2016 10:07 pm
Correct I need a somewhat powerful directional antenna granted the backhaul hauls won't be far under 1 mile for sure, but may have a tree of building here or there
tricer
Fri Jun 17, 2016 11:42 pm
so nobody knows?
I guess I will just order 1 and upgrade the license to test
jnygard
Sat Jun 18, 2016 9:53 pm
I tested that and it works just as I hoped it would:
http://forum.mikrotik.com/viewtopic.php ... 60#p518660
tricer
Sun Jun 19, 2016 4:16 pm
perfect thank you, any clue on the power of the 2.4GHz radio? assuming around 20db with a 1.5dbi antenna should work pretty well for serving laptops and smart devices
jarda
Sun Jun 19, 2016 4:49 pm
Isn't there level 3 license? It will not allow more than 1 client connected at once.
Edit. I see. Will update license, that's right...
andriys
Sun Jun 19, 2016 4:50 pm
It's 13-17 dBm (depending on the rate) with 1.5 dBi antenna gain. http://i.mt.lv/routerboard/files/SXT-Lite5-ac.pdf
Users browsing this forum: No registered users and 13 guests
