MUM Europe 2020
Soli98
How to set my Huawei E3372 LTE Dongle to work?
Fri Jun 10, 2016 6:35 am
Let me say this first: I'm thoroughly noob.
I've gone through a lot of topics that are related to problems with 3G of 4G modems; but they're just "Problems".
I just need a complete walkthrough to help me set this LTE modem up and use it.
My dongle is a Huawei E3372 4G modem and I'm using an RB951Ui.
Thanks for your replies.
pe1chl
Re: How to set my Huawei E3372 LTE Dongle to work?
Fri Jun 10, 2016 10:14 am
Have you updated the RouterOS to 6.35.2 ?
Do you see the lte1 interface in the interfaces list?
irghost
Fri Jun 10, 2016 1:33 pm
update your modem firmware to hilink mode and just plug it you will see lte1 interface (if not reboot ur rb951) then u just need to add dhcp-client for lte1 interface and NAT your network
MTCNA MTCRE MTCTCE MTCUME MTCWE MTCIPv6E MTCINE
pe1chl
Fri Jun 10, 2016 2:11 pm
When the modem has no hilink firmware I would recommend not to change that, as the other
firmware has the advantage that you will not be behind another NAT.
I have hilink firmware but I would prefer the other, however it is too complicated to change it.
Soli98
Fri Jun 10, 2016 8:20 pm
Yes, the version is 6.35.2.
Yes again. The lte1 appears in the interfaces list.
What's next?
Soli98
Fri Jun 10, 2016 8:24 pm
I have tried this method and it works; but seems not to be a proper solution.
I just feel that there is a lot of unstability in terms of connection speed rather than connecting the dongle directly to my pc/laptop. Any ideas?
pe1chl
Mon Jun 13, 2016 2:12 pm
When you have the lte1 interface you should add a DHCP client to that interface.
Then it should all work.
irghost
Tue Jun 14, 2016 7:21 pm
Cuz RB951 USB does not have enough Power for this modem ( i have same problem  that lte1 interface disappear when i start download ) so you must use USB Powered HUB  or use RB2011
Soli98
Sun Jul 24, 2016 3:12 pm
Yes! That's exactly my problem. The modem seems to disconnect after some time and it won't reconnect again until I replug it in or reboot the routerboard.
What usb hub model do you suggest? The problem is WAY annoying :(
Users browsing this forum: No registered users and 37 guests
