cendrawasih
mikrotik openvpn server - Mac osx and windows 7 client
Sat Jun 11, 2016 7:43 am
Dear Mikrotik,
After read http://wiki.mikrotik.com/wiki/Manual:Cr ... rtificates,
Mikrotik has a tutorial, how to access openvpn from macbook osx and windows 7 as a client ??
in many tutorials , macbook using tunnelblick applications and windows 7 using the application of openvpn.net
best regards
olkitu
Re: mikrotik openvpn server - Mac osx and windows 7 client
Sun Jun 12, 2016 1:36 am
http://wiki.mikrotik.com/wiki/OpenVPN#C ... figuration
Here is manual how to connect Windows and Linux to OpenVPN. You must create .ovpn config file where have connection settings. That setting use to connect to your OpenVPN Server (Mikrotik)
Network Specialist
Need know where is cellular tower? Try CellMapper to get know where is cellular tower:
https://www.cellmapper.net/map
cendrawasih
Wed Jun 15, 2016 12:11 am
@olkitu
do you have sample user config for mac or windows ?
al least successfully test.
regards
olkitu
Wed Jun 15, 2016 7:18 pm
client
dev tun
proto tcp
resolv-retry infinite
nobind
remote vpn.example.org 1194 #
#Root CA
<ca>
-----BEGIN CERTIFICATE-----
-----END CERTIFICATE-----
</ca>
# Client certificate
<cert>
</cert>
#Private Key
<key>
-----BEGIN PRIVATE KEY-----
-----END PRIVATE KEY-----
</key>
tls-client
port 1194
user nobody
group nogroup
#comp-lzo # Do not use compression. It doesn't work with RouterOS (at least up to RouterOS 3.0rc9)
# More reliable detection when a system loses its connection.
ping 15
ping-restart 10
ping-timer-rem
persist-tun
persist-key
# Silence  the output of replay warnings, which are a common false
# alarm on WiFi networks.  This option preserves the  security  of
# the replay protection code without the verbosity associated with
# warnings about duplicate packets.
mute-replay-warnings
# Verbosity level.
# 0 = quiet, 1 = mostly quiet, 3 = medium output, 9 = verbose
verb 3
cipher AES-256-CBC
auth SHA1
pull
route-nopull
route 192.168.1.0 255.255.255.0
push "dhcp-option DNS 8.8.8.8
auth-user-pass
Here is sample config. It work Windows, Android and iOS on OpenVPN software. I think it work OS X too.
Network Specialist
Users browsing this forum: Bing [Bot], sindy and 120 guests
