p4rv33n
UBNT AP monitoring using Dude
Sun Jul 03, 2016 6:36 pm
Hi all,
I monitoring cisco switch that is directly connected to Dude server installed on CCR1009. But an UBNT wireless device connected to eth-10 of Cisco switch.
Dude client showing only Cisco switch details but not showing anything for UBNT wireless device. From some forum help I am able add Ethernet port monitoring using probe.
After long try I am not able to monitor anything for UBNT AP.
Kindly help me how can I do for UBNT (SNMP agent is enabled)
p4rv33n
Re: UBNT AP monitoring using Dude
Mon Jul 04, 2016 12:37 pm
Please help, I really need this as maximum devices is behind that Cisco switch so which i need to monitor.
kmok1
Wed Jul 06, 2016 12:29 am
Under the Settings option of your Ubnt device, under its Services tab, use ping and/or http.  There is nothing in Dude to monitor my Airfiber's wlan or lan port.
krisjanis
Wed Jul 06, 2016 11:49 am
Did you upload UBNT mib to your dude server?
p4rv33n
Wed Jul 06, 2016 7:09 pm
How can I do this , I am new to this?
kmok1
Wed Jul 06, 2016 10:08 pm
The UBNT-MIB file is at the bottom of this page.
https://help.ubnt.com/hc/en-us/articles ... -Test-SNMP
I added those ubnt files to Files/mibs folder.
Afterward, in my ubnt object, I am able to pull info via snmp walk, but it is in table form.  Do you have instructions on how to present this in Dude's Network Maps?
p4rv33n
Thu Jul 07, 2016 1:21 am
If you share this also, that would be more helpful...Thanks
SimonK
Wed Jul 13, 2016 9:41 am
we are also running Thedude, we are montering UBNT AP's.
In the network map i can see how clients which are connected to the AP's
also pulling AP name, IP, AP model, location and so on
please let me know if this is what you guys want
p4rv33n
Wed Aug 03, 2016 3:08 pm
Yes , yes that's what I am looking for but in addition AP signal strength need to be monitor.
I am giving AP's different subnet mask and IP other then dude IP series. Is that the problem?
Please share your implementation as it will help me so much.
SimonK
Sun Aug 28, 2016 11:52 am
this is what i use in TheDUDE on UBNT AirMAX APS
[oid("1.3.6.1.2.1.1.5.0")]
[Device.FirstAddress]
[oid("1.2.840.10036.3.1.2.1.3.5")]
[oid("1.3.6.1.2.1.1.6.0")]
Users Online:[oid("1.3.6.1.4.1.41112.1.4.5.1.15.1")]
insert in apperance
Users browsing this forum: No registered users and 28 guests
