MUM Europe 2020
irghost
VPN Over IPv6 ? How?
Mon Jul 04, 2016 1:07 am
hi guys
i want to create VPN server on mikrotik Over ipv6
so help me with this case
MTCNA MTCRE MTCTCE MTCUME MTCWE MTCIPv6E MTCINE
irghost
Re: VPN Over IPv6 ? How?
Mon Jul 04, 2016 10:42 pm
Up Up Up
mpreissner
Mon Jul 04, 2016 10:51 pm
Your question has little meaning without more detail.  What kind of environment is this?  What is the purpose...are you trying to tunnel your internal network to an IPV6 broker because your ISP only provides IPv4 at this time?  Or just trying to set up a VPN server to listen on an IPv6 address?  Nobody is going to respond unless you give us more details.
Michael Preissner
CISSP, CCSP, CEH, PMP
irghost
Tue Jul 05, 2016 12:20 am
why  the sky is blue? why Elephant cant fly?
i have public /56 ipv6 and i wanna run vpn server
barkas
Re: RE: Re: VPN Over IPv6 ? How?
Tue Jul 05, 2016 12:30 am
Good luck then.
Cha0s
Forum Veteran
Forum Veteran
Tue Jul 05, 2016 12:31 am
Is there an elephant in your room that prevents you from doing that?
Or do you wish us to come to your place and set it up for you?
Do you also need some ice cream while you wait?
Seriously, if you don't describe your problem properly, why should anyone try to help you?
Making jokes like you are entitled to an answer does not give anyone the motive to help you.
What have you tried so far, what results did you expect and what were the results you got? Post your configuration.
You know, the ABCs of asking technical help...
irghost
Tue Jul 05, 2016 1:00 am
question is clear
How to Run VPN Server Over ipv6??
what is your problem bro?
all of people can run vpn server over ipv4( private - public ) its too easy
Cha0s
Forum Veteran
Forum Veteran
Tue Jul 05, 2016 1:06 am
question is clear
No problem here "bro". Since you are MTCNA MTCRE MTCTCE, I am sure you will figure it out on your own ;)
Good luck with your problem.
Users browsing this forum: No registered users and 61 guests
