MUM Europe 2020
moly
SFP DDM not working
Fri Jul 08, 2016 1:17 pm
Hi, I have problem with SFP DDM monitoring.
I try on CRS112-8G-4S and in version 6.35.4 and 6.34.6 not report data ( TX power, RX power, ... )
In version 6.30.4 work good.
Thanx for fix
Martin Cerny
Martin Cerny
chairman of Oslavany.NET
pukkita
Trainer
Trainer
Re: SFP DDM not working
Sat Jul 09, 2016 2:36 pm
Please post
/system routerboard print
Simplicity is the Ultimate Sophistication - Da Vinci
Getting the most out of this forum
Maggiore81
Fri Feb 10, 2017 2:11 pm
I am the very same situation: CRS212-1G-10S-1S+ with 6.37.4 bugfix
[admin@MikroTik] > /system routerboard print
routerboard: yes
model: CRS212-1G-10S-1S+
serial-number: 64DD05F55160
firmware-type: qca8719L
factory-firmware: 3.29
current-firmware: 3.29
upgrade-firmware:
Dott. Elia Spadoni
Network Administrator,
MTCNA, MTCRE, MTCTCE, MTCINE, MTCWE
Spadhausen Internet Provider
Ravenna, ITALY
http://www.spadhausen.com
gorec2005
Thu Aug 01, 2019 2:34 pm
I have similar situation...
[admin@MT46] > /system routerboard print
routerboard: yes
serial-number: 813F0799D322
factory-firmware: 3.41
current-firmware: 6.42.7
upgrade-firmware: 6.42.7
[admin@MT24] > /system routerboard print
routerboard: yes
serial-number: A62C092D4789
factory-firmware: 6.42.10
current-firmware: 6.45.1
upgrade-firmware: 6.45.1
[admin@MT30] > /system routerboard print
routerboard: yes
serial-number: 813F07ED4E21
current-firmware: 6.42.6
upgrade-firmware: 6.43.2
... more over when use sfp without ddm - all work ok, but when used one-two with ddm - random port have trouble...
byko
Wed Dec 18, 2019 12:42 pm
same here
any firmware
CRS 212-1G-10S-1S+IN
ports randomly flapping when more then one in sfp port
monitor shows problems with eeprom.
sfp module in sfp+ port is OK
[login@TMP-crs] > interface ethernet monitor 8
status: no-link
auto-negotiation: disabled
sfp-module-present: yes
sfp-rx-loss: yes
eeprom-checksum: bad
eeprom: 0000: 03 04 01 00 00 00 00 12 00 00 00 00 00 00 00 00 ........ ........
0010: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ........ ........
0020: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ........ ........
0030: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ........ ........
0040: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ........ ........
0050: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ........ ........
0060: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ........ ........
0070: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ........ ........
0080: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ........ ........
0090: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ........ ........
00a0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ........ ........
00b0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ........ ........
00c0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ........ ........
00d0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ........ ........
00e0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ........ ........
00f0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ........ ........
status: no-link
sfp-rx-loss: yes
sfp-type: (unknown)
eeprom-checksum: good
eeprom: 0000: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ........ ........
gorec2005
Wed Dec 18, 2019 1:57 pm
Hi!
With help from Mikrotik support problem have been solved - just use other sfp module... ( for 212 use sfp from fs.com... )
Users browsing this forum: No registered users and 18 guests
