lynx649
Radius + Hotspot + MAC Cookie Problem
Fri Jul 15, 2016 2:54 am
I am having a problem getting Mikrotik hotspot to work properly with a radius authentication server.  In short, the main problem I am having is that even when I set the MAC cookie to 5 days, if I reboot the server, I get the login page again.  I have other Mikrotiks in the field (not using radius) where if I reboot the server, the cookies are still there and noone has to log in.  Does anyone have any experience with Hotspot + Radius?  Below are some config details that might help, if you need more info or clarification, please let me know.
Thanks!
Using Radius server with:
HTTP PAP enabled
Mac Cookie enabled
MAC Cookie Timeout set to 5 days.
USER PROFILE:
 1   name="test" address-pool=pool10 status-autorefresh=1m shared-users=200 add-mac-cookie=yes mac-cookie-timeout=5d
     address-list=“" transparent-proxy=no
HOTSPOT PROFILE:
 0 * name="default" hotspot-address=10.0.0.2 dns-name=“local" html-directory=hotspot
     html-directory-override="" rate-limit="2M/10M" http-proxy=0.0.0.0:0 smtp-server=0.0.0.0 login-by=http-pap,mac-cookie
     split-user-domain=no use-radius=yes radius-accounting=yes radius-interim-update=received nas-port-type=ethernet
     radius-default-domain="" radius-location-id="" radius-location-name="" radius-mac-format=XX:XX:XX:XX:XX:XX
Derek
lynx649
Re: Radius + Hotspot + MAC Cookie Problem
Thu Jul 21, 2016 2:15 am
Bump
ropbo
Fri Jul 22, 2016 8:43 pm
Hi, have you found a solution? I'm having exactly the same issue, every time I reboot the server or simply restart the hotspot service, all MAC cookies disappear and people get the login page again. I set the "login by" (under Server Profile) to HTTP-PAP and MAC COOKIE. Also checked "Add Mac Cookie" (under User Profile).
KeamKym
Sun Jul 14, 2019 2:43 pm
Hi, I got the same problem. I'm using http cookie instead, though, Im still getting 'local user not found' at least it is able to log me in.
Anyone with a better solution to help.
Users browsing this forum: eworm, jvanhambelgium, kd2pm2, llag, ofca and 134 guests
