UsernameMT
Re: v6.37rc [release candidate] is released, only one wireless package!
Mon Aug 08, 2016 10:13 am
http://forum.mikrotik.com/viewtopic.php ... 50#p550398
I can not use the 10 devices, because waiting the working firmware. WHEN?
sorry for my English
andriys
Mon Aug 08, 2016 1:34 pm
It's a bit weird to see complains like this in a topic dedicated to a test version of software. And yes, I followed your other links, and all of them appear to be talking about 6.37rc. The RC versions are only made available for testing purposes, you are NOT supposed to be using these in production, so what 10 devices that you cannot use you are talking about?
strods
Mon Aug 08, 2016 2:19 pm
What's new in 6.37rc13 (2016-Aug-08 07:39):
>>> IMPORTANT! WIRELESS PACKAGE CHANGES:
If you are not using "routeros" bundle package and have two wireless packages installed,
uninstall one wireless package before upgrade to 6.37. For other cases simply upgrade to
6.37 version.
There will be only one "wireless" package in RouterOS v6.37. If using bundle package to
upgrade, click "Check for updates" in your RouterOS configuration interface, or head to
our download page: http://www.mikrotik.com/download.
>>> IMPORTANT! DFS MODE CHANGES:
DFS mode setting is removed, and by default becomes forced to "dfs=radar-detect" for all
devices that use radar frequencies. If your client devices use a scan list with a few
specific frequencies that could conflict with radar frequencies, you could lose the
connection. It is recommended to widen the scan list range, use default scan list, or
change the AP frequency
Changes since 6.37rc12:
*) disk - do not do unnecessary sector writes;
*) lte - added initial deregistration only for bandrich modems;
*) partitions - added ability to add comments;
*) partitions - fixed crash on repartition when there is not enough free space;
*) usb - added support for SMSC95XX USB Ethernet dongle on mipsbe;
*) webfig - allowed user password changing (broken in v6.36);
UsernameMT
Mon Aug 08, 2016 4:16 pm
in my post:
http://forum.mikrotik.com/viewtopic.php ... 57#p549357
i write - "in version 6.36"
version 6.36 - "6.36 (Current)"
please tell me, what topic to write bugs version 6.36 Current, I duplicates my posts in this topic. :evil:
PS: for MTteam: if I did write in the wrong topic, you just ignored me, could not say where i need write about the problem?!!
PPS: I had never imagined that the topic "[current] is released" can continue the discussion of bugs! :shock:
notToNew
Mon Aug 08, 2016 4:55 pm
And just because of this you think you can not run your devices?
You can check in the script itself to see it the domain is already in the list....
CCR1036-12G-4S, several 952Ui-5ac2nD, ...
BartoszP
Mon Aug 08, 2016 5:27 pm
Is your router unusable with working old configuration applied when it uses IP not domain names ?
If yes then you have 10 unusable devices.
You have switched to new funcionalities and you are complaining about it.
Yes, it could be irritating that configuration with DNSes does not work same way as with IP but it does not make your router unusable despite fact that DNS names lists seem to work different that IP ones.
Real admins use real keyboards.
Chupaka
Mon Aug 08, 2016 5:40 pm
by the way, in current RC you cannot add duplicate domain names too :)
Russian-speaking forum: https://forum.mikrotik.by/. Welcome!
For every complex problem, there is a solution that is simple, neat, and wrong.
MikroTik. Your life. Your routing.
EDinATL
Mon Aug 08, 2016 7:26 pm
I had some trouble accessing the rc13 just now via the winbox system packages, so I just downloaded it from the site and all is fine so far. Other than that, I just wanted to say thanks for all the work and time you guys are putting in! Much love from Atlanta, GA, USA!
John39
Mon Aug 08, 2016 11:24 pm
I have a few in stock mikrotik rb 2011, only one of them when you install any version 6,37 rc wireless interface disappear, what would that do to avoid it. Removing packages, endless flashing does not help, at 6.36 on the site interface.
IntrusDave
Tue Aug 09, 2016 7:07 am
Bug: MIKROTIK-MIB-mtxrHlProcessorFrequency (SNMP Processor Frequency) reads 0 on the RB3011
David Joyce
Network & Security Engineer
Intrus Technologies, LLC.
Rancho Cucamonga, CA, USA
andriys
Tue Aug 09, 2016 9:26 am
support@mikrotik.com
UsernameMT
Tue Aug 09, 2016 11:36 am
Thank you so much!
Why then created it ?:
http://forum.mikrotik.com/viewtopic.php?f=21&t=110425
http://forum.mikrotik.com/viewtopic.php?f=21&t=110419
PS: замечательно, начерта темы форума созданы тогда? я описал явный БАГ прошивки, который стыдно допускать даже (просто по невнимательности его сделали). И ппц исправлять его еще месяц мля (сначала ждал пока релизнеться сама прошивка, теперь жди пока они исправят элементарнейший баг в ней). Попробуй создай дублированных сотню тысяч записей, а потом ручками и глазками выбирай их и удаляй. Вообще до сего момента, не понимал почему ВЕЗДЕ (от слова ВООБЩЕ ВЕЗДЕ) хаят техподдержку микротика, ... теперь понял...
dash
Hi guys, I want to report an issue with the capsman upgrade policy. I am currently running a ROS 6.37rc12 but this bug exists since the cap upgrade setting was introduced.
Bug description: When using 'require same version ' then caps act like having the 'suggest same version ' setting set,- and vice versa...
Example: With require same version i get a log entry: "upgrade failed, Provision as same version only suggested."
But It should be the other way around. Thanks for your great work. Keep it going...
John39
Tue Aug 09, 2016 12:27 pm
Смотрю тут пишут по русски, поэтому рискну и я.
Есть у меня несколько микротиков rb2011, с прошивкой 6.36 проблем нет, однако при прошивке его прошивкой 6.37 пропадает беспроводной интерфейс, пакет установлен, интерфейса нет. Проблема только на одном, с остальными проблем нет.
Откатываешь на 6.36, все в порядке. Как побороть?
UsernameMT
Tue Aug 09, 2016 12:34 pm
по русски тут пишут, когда в гневе, :D и не хватает английских слов, чтобы культурно изложить свои мысли, вопросу на русском навряд ли тут помогут, только англоязычное написание применяй. по поводу беспроводки, смотри выше, тут вроде в этой теме с первой страницы, озвучивают проблему и её решение
http://forum.mikrotik.com/viewtopic.php ... 99#p551539
сам не вникал, у меня Девайс3011, по этому не сталкивался, да и вообще тут один совет, не юзай RC используй только стабильные выпуски. Попробуй пользоваться форумом "форум наг ру", если решение существует, то там помогут.
BartoszP
Tue Aug 09, 2016 1:17 pm
Please DO use English ... not all understand what you are writing. Both of you.
If you do not know enough words in English to curse as you write then ... "speech is silver and silence is golden"
andriys
Tue Aug 09, 2016 1:32 pm
Check you firmware (bootloader) version. Try upgrading in case current-firmware and upgrade-firmware versions differ.
/system routerboard print
/system routerboard upgrade
Chupaka
Tue Aug 09, 2016 2:24 pm
because it's just an announcements and there's a note on the bottom? "If you experience version related issues, then please send supout file from your router to support@mikrotik.com"
я уже не говорю, что с таким "багом" address-lists существовали далеко не одну мажорную версию (с 2.9 по 6.??) - и всё было хорошо ;)
не исправлять, а дорабатывать новую функциональность, разве нет? ;) а то, что кто-то её начал использовать, самостоятельно допридумывав желаемое поведение и не проверив его на практике - ну так это у этого человека проблема с программированием, не надо его допускать к написанию скриптов, если его никто не контролирует
вот вы месяц ждёте доработки - вы ведь правда уже давно подправили свой скрипт, чтобы он корректно работал в текущих условиях?
вы такой смешной. почему создавали записи скриптом, а удаляли вручную? клин клином вышибать надо. т.е. скриптом :)
потому что люди не умеют читать, но имеют богатую фантазию и преувеличенные надежды на форум сообщества пользователей? хотя вопросительный знак, пожалуй, лишний
BartoszP
Tue Aug 09, 2016 2:33 pm
Chupaka's post at a glance .... "do not complain, do your work" :-)
Chupaka .... молодец !!! :)
John39
Tue Aug 09, 2016 3:04 pm
Version 3.33
diablothebest
Tue Aug 09, 2016 3:12 pm
Нифга тут коры начались!
Use script to remove all old entries!
UsernameMT
Tue Aug 09, 2016 4:51 pm
не с одним предложением твоим не поспорю :) всё верно пишешь... но блин я могу переписать свои скрипты, добавив предварительную проверку уже имеющейся записи, но сотня тысяч таких записей будет идти ещё дольше, а она и так долго происходит и без этого :)
Кстати, использование возврата ошибки, это нормальная функциональность, которая и присутствует во всем остальном в том же микротике...
ну и опять мы приходим всё к тому же :lol: , приделай костыли, так как это микротик....
по поводу удалять скриптом, я всё ещё придерживаюсь, что "производителю" проще/правильнее исправить свой косяк, чем мне костЫлить стандартный скрипт - к сожалению тут меня не переубедить.
Опять же, сейчас настроишь приспособившись к этой проблеме, а потом исправят, надумаешь перепрошить, и ппц, всё слетит и начнешь заного... нет уж ....
...писал конечно же, потому что, как обычно - наболело...
Мужик, с уважением к тебе.
PS: i stop talking. :)
mrz
Tue Aug 09, 2016 5:10 pm
@UsernameMT: Problem is already fixed in v6.37rc
nescafe2002
Long time Member
Long time Member
Tue Aug 09, 2016 5:31 pm
Issue in auto update.. affected versions are 6.37rc12 and 6.37rc13.
[admin@MikroTik] /system package update> set channel=release-candidate
[admin@MikroTik] /system package update> print
error - contact MikroTik support and send a supout file (10)
[admin@MikroTik] /system package update> export
# aug/09/2016 16:30:15 by RouterOS 6.37rc13
#error exporting /system package update
Edit:
Issue gone after reboot.. thanks raffav
Edit 2:
However, after opening 'System', 'Packages', 'Check For Updates' the issue is reintroduced:
Edit 3:
Without Winbox, the issue occurs after setting (and changing) channel:
[admin@MikroTik] > /system package update
            channel: release-candidate
  installed-version: 6.37rc13
[admin@MikroTik] /system package update> set channel=current
            channel: current
     latest-version: 6.36
             status: New version is available
Edit 4:
Issue is fixed within rc13 (external cause?)
raffav
Tue Aug 09, 2016 6:00 pm
i get the same error but, after a while the system reboot and the new version show up
tested on on RB433, BASEBOX2 and CRS125
strods
Thu Aug 11, 2016 2:14 pm
--- IMPORTANT! WIRELESS PACKAGE CHANGES:
6.37 version.
--- IMPORTANT! DFS MODE CHANGES:
Changes since 6.37rc13:
*) capsman - fixed upgrade policy;
*) capsman - report radio-name in registration table;
*) dns - allow to set query-server-timeout and query-total-timeout only greater than 0s;
*) dns - fixed lockup when dynamic dns server address 0.0.0.0 was received;
*) dude - (changes discussed here: http://forum.mikrotik.com/viewtopic.php?f=8&t=110424);
*) firewall - added additional matchers for firewall raw rules;
*) health - do not show psu and fan information for passive cooling devices;
*) sstp - allow to specify proxy by dns name;
*) sstp - fixed disconnects on transmit for multicore systems;
*) traffic-flow - allow ipv6 src address to be optional;
*) webfig - do not crash if radius server does not give out encryption keys;
*) winbox - added src-address field for traffic-flow target;
*) winbox - fixed disconnect when no windows were opened for a while in unsecure mode;
*) winbox - hide ethernet flow control settings for interfaces which does not support them;
*) winbox - make queue tree default queue type default-small;
John39
Thu Aug 11, 2016 5:08 pm
Today, I installed a new version of the firmware , but my problem with the wireless interface is lost it does not solve .
Сегодня установил новую версию прошивки, однако моей проблемы с пропадающим беспроводным интерфейсом это не решает.
diablothebest
Thu Aug 11, 2016 5:47 pm
Так он у тебя вообще исчез?
Пробовал делать полный сброс без конфы?
John39
Thu Aug 11, 2016 5:56 pm
Да, совсем исчез, сброс делал без конфы, шил голый, все равно интерфейса нет.
Yes, absolutely disappeared , dumping did not confit, sewed naked, still no interface .
raffav
Thu Aug 11, 2016 5:58 pm
i think is not fair to post using a non english language :idea:
Zorro
Long time Member
Long time Member
Thu Aug 11, 2016 6:13 pm
"not make easier to communicate" maybe, "not fair" - definitely no.
having thousands of languages on Earth have nothing with "fairness". and "fairness" have nothing with "making sense".
its not sport or trade to care much about "fairness".
and if he/person was not fluent in English - its somewhat simpler to let them native language, than trying to understand them thru prism of google translate or whatever they tend to use.
after all - there was several ppl who still remember Russian language over there, even in Latvia.
patrick7
Thu Aug 11, 2016 6:32 pm
Just ignore them, or they will continue posting in russian.
diablothebest
Thu Aug 11, 2016 8:56 pm
Can you try reflash your device with NetInstall tool?
Прошивал через НетИнсталл роутер?
John39
Thu Aug 11, 2016 10:44 pm
No.
John39
Thu Aug 11, 2016 11:23 pm
Попробовал netinstall, интерфейса нет.
Tried netinstall, interface no.
Zorro
Long time Member
Long time Member
Fri Aug 12, 2016 1:12 am
try to downgrade ROS to say ROS 6.35, restart, install all "wireless, disable, all but "wireless-cm2", restart router, remove all but wireless-cm2 package. install ROS 6.36, install ensure that "wireless-rep was operational and enabled. if so - remove other packages, restart.
and now - try to upgrade to 637rc15, perhaps.
jondavy
Fri Aug 12, 2016 1:20 am
please add CCQ to CapsMan registration-table
John39
Fri Aug 12, 2016 7:54 am
Спасибо, но где я могу скачать ROS 6.35?
Thank you, but where I can download the ROS 6.35?
UsernameMT
Fri Aug 12, 2016 9:14 am
http://www.mikrotik.com/download/archive
If reflash on older version will not help, write to technical support.
And write in "english language" only, otherwise all offended (ignore) if you do not use international "english language". :wink:
John39
Fri Aug 12, 2016 10:08 am
Попробовал сделать как вы сказали. Установил 6.35.4, беспроводных пакетов стало 2, один отключил, cm оставил, второй пакет не удаляется. Установил 6.36, все работает, установил 6.37.15, беспроводной интерфейс пропал.
I tried to do as you say. Installed 6.35.4, wireless packet was 2, one disabled, cm left, the second package is not removed. Installed 6.36 , it works , installed 6.37.15 , the wireless interface is missing.
BartoszP
Fri Aug 12, 2016 10:52 am
John39
I have already asked you to not use Russian. Please consider your behavior.
John39
Fri Aug 12, 2016 12:47 pm
John39
Я уверен что форум создан для помощи, о которой я и прошу и язык не должен являться препятствием для этого. Я вижу здесь много русскоязычных пользователей, более того, если вы не в курсе, то в Латвии большинство жителей разговаривает на русском языке, уверен, что русскоговорящим удобнее читать на русском языке, нежели читать кривой гугл перевод. Именно по этой причине я пишу по русски, но учитывая ваши требования я дублирую на английском языке, который в отличии от русского вы должны понимать. И еще, что б делать замечания другим, нужно быть идеальным самому, но как я вижу и вы тоже пишите на польском http://forum.mikrotik.com/viewtopic.php ... 85#p544985 .
I am sure that the forum is designed to help, which I ask, and the language should not be an obstacle to this. I see there are a lot of Russian-speaking users, moreover, if you do not know, the majority of residents in Latvia speaks in Russian, I am sure that Russian-speaking easier to read in Russian, rather than read the Google translation of the curve. It is for this reason that I am writing in Russian, but considering your demands I duplicate in the English language, which is in contrast to Russian, you need to understand. And yet, what would make remarks to others, you need to be perfect, but as I see you, too, write in Polish http://forum.mikrotik.com/viewtopic.php ... 85#p544985 .
BartoszP
Fri Aug 12, 2016 1:09 pm
A. I do read and understand Russian and it is not a problem for me.
B. I am using English on this forum.
C. Nobody is perfect but please translate my Polish text and you will see that I have written in Polish: This forum is in English language so please use it.
D. We have most of users not from Eastern Europe so please do not dazzle them with cyrillic alphabet ... what if Chinese users choose to use they iconic language or Middle East choose to write Arabic right to left ?
E. Please follow rules.
normis
Fri Aug 12, 2016 1:14 pm
This is not a latvian forum. Only around 0,001% of the users here are from Latvia
nescafe2002
Long time Member
Long time Member
Fri Aug 12, 2016 4:03 pm
@John39, could you try installing the wireless package from the "Extra packages" bundle manually?
John39
Fri Aug 12, 2016 8:50 pm
I've done it , it does not solve the problem .
IntrusDave
Sun Aug 14, 2016 12:31 pm
hAP AC (internation) goes into a reboot loop when 6.37rc15 is installed.
Net install with 6.37rc15 continues the loop.
Net install with 6.36 boots stable.
David Joyce
Zorro
Long time Member
Long time Member
Sun Aug 14, 2016 2:08 pm
weird. then its must be something in router config, relate to wi-fi interface, preventing from properly exporting/upgrading it and transitioning to newer version.
and thus i presume it may be very interesting to MT to take a look into, considering possible impact on other customers.
downgrading bootloader to actual 3.31(where hell he get 3.33 ?)make sense or even trying to 3.22/3.23(depend platform).
nastitek
Re: The Dude, v6.37rc test builds.
Mon Aug 15, 2016 2:28 am
HAP AC LITE
CPU 100% constant utilization
Winbox 3.4 cannot connect after a few hours - this may be due to high utilization
HotSpot settings keeps breaking - disabling dhcp for this interface until allowing LAN dhcp as its dhcp source/pool
LAN IP changes (under quickset) using recently added dhcp pool.
strods
Mon Aug 15, 2016 11:39 am
What's new in 6.37rc16 (2016-Aug-15 07:48):
6.37 version.
Changes since 6.37rc15:
*) l2tp - fixed kernel failure when fastpath handles l2tp packets;
*) switch - added comment field for CRS switch VLANs;
*) switch - fixed configuration reload on CRS switches;
palhaland
Tue Aug 16, 2016 8:41 am
issues found on v6.27rc16 (running on mAP lite)
Love the new version with only one wireless package!
However I found some issues :)
Wireless interface
/interface wireless connect-list does not work on virtual station. (on mAP2nd) When running with logging the network is listed (correct frequency), but the wireless interface claim that there is no network that satisfy the connect list.
Scripting
This code works in command line but not in script;
:local $scanList "scanList.csv"
:local wlanInterface "wlan1"
:local j [:execute {/interface wireless scan [find name=$wlanInterface] background=yes duration=5 rounds=1 save-file=$scanList;}]
Where as this code works in both command line and script:
:local wlanInterface [/interface wireless find name="wlan1"]
:local j [:execute {/interface wireless scan $wlanInterface background=yes duration=5 rounds=1 save-file=$scanList;}]
update 17.08.2016: there are no issues with scripting, the reason why it did not work was because the variables used was only in the local scope, it has to be in the global scope
TonyJr
Tue Aug 16, 2016 6:20 pm
Thank you for this fix - site-to-site VPN is now stable between a CCR1009-8G-1S-1S+-PC and a CRS109-8G-1S-2HnD with 6.37rc16. I had thought the problem was with my configuration, until I saw the changelog. The connection would previously disconnect every few minutes if under any load - Link Downs would often have numbers in the thousands, now it is 0.
TonyJr
Ulypka
Wed Aug 17, 2016 2:22 pm
After upgrade from v6.37rc10 to v6.37rc16 openvpn server dosn't work.
emils
Wed Aug 17, 2016 2:38 pm
Ulypka, please send supout.rif file to support@mikrotik.com
Ulypka
Wed Aug 17, 2016 9:19 pm
emils, I'm so sorry it was my mistake unrelated to ovpn.
strods
Thu Aug 18, 2016 2:11 pm
What's new in 6.37rc19 (2016-Aug-18 06:46):
6.37 version.
Changes since 6.37rc16:
*) arm - show cpu frequency under resources menu;
*) arp - fixed crash that caused Ethernet frames to go out via wrong interface;
*) pppoe - fixed kernel crash caused by dial-on-demand when used with fastpath;
uldis
Thu Aug 18, 2016 3:41 pm
Wireless interface
I was unable to reproduce this problem.
Please provide us more information on that and also the wireless debug logs. Also make sure you select the correct security-profile in the connect-list.
jarda
Thu Aug 18, 2016 3:46 pm
Is the [Ticket#2016081022001387] solved already in this rc?
Ciambot
Thu Aug 18, 2016 3:50 pm
Oh my God!
normis
Thu Aug 18, 2016 3:52 pm
Oh my God!
If you are in some place where you can use the radar frequencies ... Use Superchannel mode and it won't matter
pe1chl
Thu Aug 18, 2016 3:59 pm
The problem is not using the radar frequencies, the problem is the (mis?)detection of radar on other frequencies when
at a high site near to radar. Do you mean that when switching from "regulatory - domain" to "superchannel" you can
still turn off the DFS? And will this remain in place or will it be the next feature to go?
Fortunately we use separate routers and APs that are only bridge, so we can still update routers and keep APs on old firmware
until there is a good solution. As it is now, DFS does not work for us on SXT, Metal5 etc.
napismizpravu
Thu Aug 18, 2016 5:02 pm
6.37rc19 Do not use RB433UAH hide all interfaces wireless (winbox, web) ethernet random refresh, wireless no configuration (remembers previous settings, broadcasts), ....downgrade previous build 6.37rc15
normis
Thu Aug 18, 2016 5:04 pm
Most likely your wireless package got disabled, this can sometimes happen if you have installed multiple wireless packages. No need to downgrade, just need to re-enable correct wireless npk.
napismizpravu
Thu Aug 18, 2016 5:21 pm
It's not this way
wireless packages activate build 6.37rc19 ( wireless AP view air)
build 6.37rc15 upgrade to 6.37rc19 > downgrade 6.37rc15 (works)
macgaiver
Thu Aug 18, 2016 5:30 pm
It's not this way
You most definately need to send supout.rif file from rc19 to support@mikrotik.com
With great knowledge comes great responsibility, because of ability to recognize id... incompetent people much faster.
napismizpravu
Thu Aug 18, 2016 5:55 pm
macgaiver: why he wrote it? post+1? your is spamer
palhaland
Thu Aug 18, 2016 6:03 pm
Wireless interface
This is with frequency set to auto on the ap-bridge
831	Aug/18/2016 16:38:04	memory	wireless, debug	wlan2: no network that satisfies connect-list, by default choose with strongest signal
832	Aug/18/2016 16:38:04	memory	wireless, debug	wlan2: failed to select network
833	Aug/18/2016 16:38:04	memory	wireless, debug	wlan2: must select network
834	Aug/18/2016 16:38:04	memory	wireless, debug	empty
This is with frequency set to the correct frequency:
985	Aug/18/2016 16:41:21	memory	wireless, debug	<mac address>: on 2462 AP: yes SSID <correct network name> caps 0x1431 rates 0xCCK:11 OFDM:12-54 BW:1x SGI:1x HT:0-23 basic 0xCCK:11 MT: no
986	Aug/18/2016 16:41:21	memory	wireless, debug	<mac address>: on 2462 AP: yes SSID <correct network name> caps 0x1431 rates 0xCCK:11 OFDM:12-54 BW:1x SGI:1x HT:0-23 basic 0xCCK:11 MT: no
987	Aug/18/2016 16:41:21	memory	wireless, debug	<mac address>: on 2462 AP: yes SSID <different network name> caps 0x1431 rates 0xCCK:11 OFDM:12-54 BW:1x SGI:1x HT:0-23 basic 0xCCK:11 MT: no
988	Aug/18/2016 16:41:21	memory	wireless, debug	<mac address>: on 2462 AP: yes SSID caps 0x1431 rates 0xCCK:11 OFDM:12-54 BW:1x SGI:1x HT:0-23 basic 0xCCK:11 MT: no
989	Aug/18/2016 16:41:21	memory	wireless, debug	<mac address>: on 2462 AP: yes SSID caps 0x1431 rates 0xCCK:11 OFDM:12-54 BW:1x SGI:1x HT:0-23 basic 0xCCK:11 MT: no
990	Aug/18/2016 16:41:21	memory	wireless, debug	wlan2: no network that satisfies connect-list, by default choose with strongest signal
991	Aug/18/2016 16:41:21	memory	wireless, debug	wlan2: failed to select network
992	Aug/18/2016 16:41:22	memory	wireless, debug	wlan2: must select network
# aug/18/2016 16:46:13 by RouterOS 6.37rc16
# software id = G2LP-VRHH
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-eC \
    disabled=no distance=indoors frequency=2462 mode=ap-bridge ssid=\
    MikroTik-149006 wireless-protocol=802.11
add disabled=no mac-address=<mac-address> master-interface=wlan1 mode=\
    station-pseudobridge name=wlan2
/ip neighbor discovery
set ether1 discover=no
add authentication-types=wpa-psk,wpa2-psk management-protection=allowed mode=\
    dynamic-keys name=profile1 wpa-pre-shared-key=<password> \
    wpa2-pre-shared-key=<password>
add address-pool=default-dhcp disabled=no interface=wlan1 name=defconf
add interface=wlan2 security-profile=profile1 ssid=<network name>
add address=192.168.88.1/24 comment=defconf interface=wlan1 network=\
    192.168.88.0
/ip dhcp-client
add comment=defconf dhcp-options=hostname,clientid disabled=no interface=ether1
add default-route-distance=0 dhcp-options=hostname,clientid disabled=no \
    interface=wlan2
set allow-remote-requests=yes
/ip dns static
add address=192.168.88.1 name=router
add action=accept chain=input comment="defconf: accept established,related" \
add action=drop chain=input comment="defconf: drop all from WAN" in-interface=\
    ether1
add action=accept chain=forward comment="defconf: accept established,related" \
add action=drop chain=forward comment="defconf: drop invalid" connection-state=\
    invalid
    "defconf:  drop all from WAN not DSTNATed" connection-nat-state=!dstnat \
    connection-state=new in-interface=ether1
add action=masquerade chain=srcnat comment="defconf: masquerade" out-interface=\
    ether1
/system clock
set time-zone-name=Europe/Oslo
/system logging
add topics=wireless,debug
/system routerboard settings
set cpu-frequency=650MHz protected-routerboot=disabled
/tool mac-server
add interface=wlan1
/tool mac-server mac-winbox
add interface=wlan1
By only adding the SSID to connect to and the security profile, it connects immediately
/interface wireless wlan2 set ssid=<wireless network> security-profile=profile1
voody77
Thu Aug 18, 2016 6:23 pm
At start hap ac wireless interfaces is work. run 2-5 minuts - result: hide all wireless interfaces in inbox menu on 6.37rc19 and networks not working!
raffav
Thu Aug 18, 2016 6:36 pm
for me is ok
[raffaello@RJ-AT-MK02 - CAP1] > interface wireless print without-paging
 0 X  ;;; COMERCIAL --- wireless
      name="Wap45_comercial" mtu=1500 l2mtu=1600 mac-address=02:15:6D:68:40:71 arp=enabled interface-type=virtual master-interface=wlan1 mode=ap-bridge ssid="comercial_answer" vlan-mode=no-tag vlan-id=1
      wds-mode=disabled wds-default-bridge=none wds-ignore-ssid=no bridge-mode=enabled default-authentication=no default-forwarding=no default-ap-tx-limit=0 default-client-tx-limit=0 hide-ssid=no
      security-profile=comercial_answer
 1 X  ;;; DIRETORIA --- wireless
      name="Wap75_diretoria" mtu=1500 l2mtu=1600 mac-address=02:15:6D:68:40:74 arp=enabled interface-type=virtual master-interface=wlan1 mode=ap-bridge ssid="diretoria_answer" vlan-mode=no-tag vlan-id=1
      wds-mode=disabled wds-default-bridge=none wds-ignore-ssid=no bridge-mode=enabled default-authentication=yes default-forwarding=yes default-ap-tx-limit=0 default-client-tx-limit=0 hide-ssid=no
      security-profile=diretoria_answer
 2 X  ;;; LOGISTICA --- wireless
      name="Wap85_logistica" mtu=1500 l2mtu=1600 mac-address=02:15:6D:68:40:70 arp=enabled interface-type=virtual master-interface=wlan1 mode=ap-bridge ssid="logistica_answer" vlan-mode=no-tag vlan-id=1
      security-profile=logistica_answer
 3 X  ;;; VISITANTE --- wireless
      name="Wap145_visitante" mtu=1500 l2mtu=1600 mac-address=02:15:6D:68:40:6F arp=enabled interface-type=virtual master-interface=wlan1 mode=ap-bridge ssid="visitante_answer" vlan-mode=no-tag vlan-id=1
      security-profile=visitante_answer
 4 X  ;;; MOBILE-RJ --- wireless
      name="Wap146_mobile-rj" mtu=1500 l2mtu=1600 mac-address=02:15:6D:69:38:B0 arp=enabled interface-type=virtual master-interface=wlan1 mode=ap-bridge ssid="answer_mobile" vlan-mode=no-tag vlan-id=146
      security-profile=mobile_answer
 5 X  ;;; TI --- Wireless
      name="Wap155_TI" mtu=1500 l2mtu=1600 mac-address=02:15:6D:68:40:75 arp=enabled interface-type=virtual master-interface=wlan1 mode=ap-bridge ssid="TI_answer" vlan-mode=no-tag vlan-id=155 wds-mode=disabled
      wds-default-bridge=none wds-ignore-ssid=no bridge-mode=enabled default-authentication=yes default-forwarding=yes default-ap-tx-limit=0 default-client-tx-limit=0 hide-ssid=no security-profile=TI_answer
 6 X  ;;; TI --- Wireless Mobile
      name="Wap156_MOBILE" mtu=1500 l2mtu=1600 mac-address=02:15:6D:69:38:AF arp=enabled interface-type=virtual master-interface=wlan1 mode=ap-bridge ssid="W_TI" vlan-mode=no-tag vlan-id=1 wds-mode=disabled
      wds-default-bridge=none wds-ignore-ssid=no bridge-mode=enabled default-authentication=no default-forwarding=no default-ap-tx-limit=0 default-client-tx-limit=0 hide-ssid=yes security-profile=TI_Mobile
 7 X  ;;; managed by CAPsMAN
      ;;; channel: 2412/20/g(21dBm), SSID: diretoria_answer, CAPsMAN forwarding
      name="wlan1" mtu=1500 l2mtu=1600 mac-address=D4:CA:6D:14:01:F3 arp=enabled interface-type=Atheros AR5413 mode=ap-bridge ssid="answer_wireless" frequency=auto band=2ghz-b/g channel-width=20mhz
      scan-list=default wireless-protocol=802.11 antenna-mode=ant-a vlan-mode=no-tag vlan-id=97 wds-mode=disabled wds-default-bridge=none wds-ignore-ssid=no bridge-mode=disabled default-authentication=no
      default-forwarding=no default-ap-tx-limit=0 default-client-tx-limit=0 hide-ssid=yes security-profile=TI_answer compression=no
[raffaello@RJ-AT-MK02 - CAP1] > system package print
Flags: X - disabled
 #   NAME        VERSION        SCHEDULED
 0   routeros-mipsbe        6.37rc19
 1   system        6.37rc19
 2   ipv6        6.37rc19
 3   wireless        6.37rc19
 4   hotspot        6.37rc19
 5   dhcp        6.37rc19
 6   mpls        6.37rc19
 7   routing        6.37rc19
 8   ppp        6.37rc19
 9   security        6.37rc19
10   advanced-tools        6.37rc19
raffaello@RJ-AT-MK02 - CAP1] > system resource print
                   uptime: 6m35s
                  version: 6.37rc19 (testing)
               build-time: Aug/18/2016 06:45:52
              free-memory: 104.7MiB
             total-memory: 128.0MiB
                      cpu: MIPS 24Kc V7.4
                cpu-count: 1
            cpu-frequency: 680MHz
                 cpu-load: 4%
           free-hdd-space: 492.1MiB
          total-hdd-space: 512.0MiB
  write-sect-since-reboot: 237
         write-sect-total: 45367767
               bad-blocks: 0.2%
        architecture-name: mipsbe
               board-name: RB433UAH
                 platform: MikroTik
napismizpravu
Thu Aug 18, 2016 6:53 pm
raffav I use „Extra packages” (all_packages...) the terminal I was not looking, important WinBox
raffav
Thu Aug 18, 2016 7:03 pm
ok
so maybe the problem is on the extra packages, my winbox is ok too
I don't lost any wifi configuration or interfaces
macgaiver
Fri Aug 19, 2016 10:26 am
Cause only ones that can help you are reachable via that mail, to make sure that RC20 doesn't have this problem.
strods
Fri Aug 19, 2016 11:18 am
What's new in 6.37rc20 (2016-Aug-19 06:35):
6.37 version.
Changes since 6.37rc19:
*) address-list - fixed crash (introduced in 6.37rc17);
*) export - updated default values in /system routerboard settings menu;
*) sfp - enabled eeprom printout in /interface ethernet monitor;
*) sfp - removed "sfp-rate-select" as command was not relevant to currently supported hardware;
*) trafficgen - fixed crash (introduced in 6.37rc17);
pe1chl
Fri Aug 19, 2016 10:22 pm
*) snmp - added script table which executes script and returns it's output on get request;
Please explain how to use this feature, because I cannot find it in the user interface...
raffav
Fri Aug 19, 2016 11:06 pm
Very strange thing on a RB450G when I do a port knock using tcp the RB reset all interface and lost connection
using rc19 version
port knock is 2 top sequencie 2468 and 55027
can any one using rc19 tray to se if the rb crash
Zorro
Long time Member
Long time Member
Sun Aug 21, 2016 11:23 pm
there was presumed some changes in 3.34 bootloader ?
strods
Thu Aug 25, 2016 10:18 am
What's new in 6.37rc21 (2016-Aug-25 06:15):
6.37 version.
--- IMPORTANT! DFS CHANGES:
DFS configuration in RouterOS has been redesigned, now device looks at specified country
settings (/interface wireless info country-info <country> ), and apply corresponding
DFS mode for each frequency range automatically, making dfs-mode setting unnecessary.
Please, check that your frequencies work with correcponding DFS settings before upgrade.
Changes since 6.37rc20:
*) hotspot - show comments from user menu also in active menu;
*) tunnel - ipv6 link-local address is now generated from tunnel local-address;
*) vlan - do not allow to add new vlan interface with mtu higher than l2mtu;
*) wireless - updated brazil country settings;
heaven
Thu Aug 25, 2016 12:17 pm
Hi Guys, I have 2 Mikrotik in my network (RB2011 & hAP AC Lite). All my routers have release candidate firmware. The RB2011 is a capsman controller and hap ac is a cap with 2 more virtual cap.
When RB2011 was restart after upgrade or another cause the cap in hap ac has registered new/dynamic wlan number in cap. It's very uncomfortably because I have some bridges and all each networks (wlans) uses different bridges.
For example.
on the hAP AC
Bridge -> Ports:
br1 - wlan0
br2 - wlan2
br3 - wlan3
Wireless by controller capsman:
wlan0 - general cap
wlan2 - 1st virtual cap
wlan3 - 2nd virtual cap
after restart of capsman controller (RB2011), cap (hAP AC) registered new wlans:
Wireless capsmann controlled:
wlan0 - general cap
wlan25 - 1st virtual cap
wlan26 - 2nd virtual cap.
in Bridge -> Ports
br1 - wlan0
br2 - unknown
br3 - unknown
how to solve this problem or maybe developer have a liitle time to do a static virtual caps wlans number?) Thanks.
raffav
Thu Aug 25, 2016 12:52 pm
Don't use dynamic enable
Use enable only
Enviado de meu XT1580 usando Tapatalk
heaven
Thu Aug 25, 2016 12:59 pm
Use enable only
wrong(. every time cap have a new number of virtual cap wlan on reconnect. if it's was be so easy i'm not write here. but thank you for your answer).
raffav
Thu Aug 25, 2016 1:22 pm
Use enable only
Sorry, but sometimes is wrong there,
My cap number don't change when devices is rebooted
Edit:
Now I got it
I understand another Dynamic number Image
The caps number on the cap device it Is normal to increase ( Why need to be like that I don't know)
The trick is to use data path settings so the caps interface go to the correct bridge
napismizpravu
Thu Aug 25, 2016 1:52 pm
info: RB433UAH this works build 6.37rc21 (all_packages...)
upgrade 6.37rc15 :>>> 6.37rc21
6.37rc19 no works
strods
Thu Aug 25, 2016 1:56 pm
What's new in 6.37rc22 (2016-Aug-25 09:01):
6.37 version.
settings (/interface wireless info country-info), and applies corresponding
Please, check that your frequencies work with corresponding DFS settings before upgrade.
Changes since 6.37rc21:
*) ethernet - fixed rare kernel failure on non-switch ethernet reset;
*) simple queues - fixed issue which caused additional/unnecessary CPU load;
macgaiver
Thu Aug 25, 2016 2:03 pm
Can you be more specific? What simple queue configurations are affected? how much?
heaven
Thu Aug 25, 2016 2:06 pm
Use enable only
Edit:
Now I got it
I try fistly write br number in datapath but nothing(.
patrick7
Thu Aug 25, 2016 2:12 pm
Feature request:
Allow unset at every place where it's possible to set an empty value (example: bgp update source, unset update-source does not work, set update-source=none is needed. firewall log prefix, set log-prefix="" works, but unset log-prefix does not work.).
strods
Thu Aug 25, 2016 2:13 pm
macgaiver - Simple Queue hashing algorithm had an issue which caused hash rebuilds. This caused additional CPU load. This fix affects all Simple Queue configurations but improvement depends on queue count and complexity.
This issue was found on Intel based x86 installation with ~6500 Simple Queues. Load after upgrade went down from 70-80% to 20-30%.
pe1chl
Thu Aug 25, 2016 2:36 pm
Feature request:
unset something is not the same as setting an empty value for it. it may work out the same in some cases, but be different in others.
maybe you would want a "reset" function that sets it to its default value, which may be unset, empty or none.
mrz
Thu Aug 25, 2016 2:44 pm
unset is available only for parameters that can be unset, log-prefix is not one of them.
Type in the terminal "unset 0 <tab>" and see all acceptable parameters that can be unset.
patrick7
Thu Aug 25, 2016 2:45 pm
Don't agree.
[admin@cr1.zrh1] /routing bgp peer> :put [get 6 update-source ]
As you can see, update-source is nothing (=empty). In WebFig, it's possible to click an arrow to make this field disappearing (like unset).
[admin@cr1.zrh1] /routing bgp peer> set 6 update-source=1.2.3.4
1.2.3.4
Now we have the update source "1.2.3.4". I want to do the same as in the GUI, unset this value:
[admin@cr1.zrh1] /routing bgp peer> unset 6 update-source
input does not match any value of value-name
So why should I use
[admin@cr1.zrh1] /routing bgp peer> set 6 update-source=none
? In my oppinion, "none" is not correct. Every BGP update message NEEDS a source address. None means "no source address". Unset would just be right for that (= tell the router to not use a specific address, like "unspecified").
If I say that a configuration value should be "none", I expect this "none" to be in the configuration, which is not. It's also not possible to clear this value with set update-source="".
mrz
Thu Aug 25, 2016 2:54 pm
Parameter is for custom update-source. What custom update-source to use? None. So perfectly valid option. And as I mentioned in previous post, unset works on specific parameters which can be seen by typing unset 0 <tab>, update-source is also not one of them.
patrick7
Thu Aug 25, 2016 2:59 pm
Don't really see the sense behind that, but ok......
In my opinion, it should also be possible to unset (make empty) "custom" values. Because in the configuration you don't see the "none" so it's like "empty" or "not set".
alexjhart
Fri Aug 26, 2016 1:27 am
I too am looking for more information. Don't see anything in the wiki yet?
Alex Hart
The Brothers WISP
Motorbreath
Fri Aug 26, 2016 1:27 pm
I get a pretty different signal strenght between 6.36.2 and 6.37rc22, all the settings are the same...can someone please explain?
Edit: It's a pretty significant drop in Signal Strenght on 6.37rc22, was the same with previous 6.37rc's. As soon as I get back to 6.36.2 everything is back to normal.
pukkita
Trainer
Trainer
Fri Aug 26, 2016 2:21 pm
Have you tried resetting the wireless config and redoing it? Is your RB firmware up to date?
Simplicity is the Ultimate Sophistication - Da Vinci
Getting the most out of this forum
Motorbreath
Fri Aug 26, 2016 3:24 pm
Yes, tried resetting config, and the RB fw is up to date. Mikrotik responded that it could be a new way signal strenght is calculated...
pukkita
Trainer
Trainer
Fri Aug 26, 2016 11:59 pm
I think I noticed that, but related to chain numbers... maybe the case as you have only one chain. Have you tested the link to see if there are actual performance differences?
Motorbreath
Sat Aug 27, 2016 12:27 am
performance seems to be the same, all signal led lights are still on my Groove...
Noise floor goes to -92 dBm, signal to noise 37 dB on 6.37rc22 and on the current 6.36.2 it's -97 dBm and 48 dB signal noise... I am back on stable version for now
Kevo
Sat Aug 27, 2016 6:19 am
48db signal to noise sounds just about impossible in the real world on unlicensed freq. We have licensed links running under -50 that don't see 48db SNR. I would guess the first set of numbers are more accurate.
Motorbreath
Sat Aug 27, 2016 9:51 am
So we (using Groove) had false info for wireless signal strenght this whole time? MikroTik, what did you change for the RC versions so it shows different signal quality? A bug, or?
pukkita
Trainer
Trainer
Sat Aug 27, 2016 12:01 pm
To enhance those wireless values precision. They're crucial in order to tune and troubleshoot wireless links.
Remember a 3dB diference is actually a double increase or a half decrease...
Motorbreath
Sat Aug 27, 2016 2:41 pm
OK, but what I need is someone from MikroTik to confirm that it isn't just a bug that will come into the next stable version.
vikibhai
Sat Aug 27, 2016 3:01 pm
i have 2 basebox and both have latest packages 6.37 rc22.....problem with TX RX CHAIN...i test multipal combination chains.....
chain 1 not working..check its if its have a firmware bug
vikibhai
Sat Aug 27, 2016 4:44 pm
raffav
Re: RE: Re: v6.37rc [release candidate] is released, only one wireless package!
Sat Aug 27, 2016 5:01 pm
Just a silly question
It not to check TX and RX on both chain?
vikibhai
Sat Aug 27, 2016 5:16 pm
what silly i have click on tx chain 1 and u see on my image there my registered client not having a chain1 sgnal...zoom it see clearly
raffav
Re: RE: Re: RE: Re: v6.37rc [release candidate] is released, only one wireless package!
Sat Aug 27, 2016 5:30 pm
No
On your 1 print
You check chain 0 TX and RX
chain 1 only Rx is checked
On 2 print on chain 1 only TX is checked
My silly question was
the correct way is not to check both TX and RX on both chain 01
Zorro
Long time Member
Long time Member
Sat Aug 27, 2016 5:56 pm
can there be some detail "unnecessary CPU usage in simple queues", eg not sources code of course but explanations a bit ?
eg that not Break things, that several recent "improvements"/hacks did with netstack in many vendors starting from intel itself?
(so in result despite being CPU-savvy queues that Heavily rely on hashing, say sfq/hfq(and derivatives), pcq, retro-forks of stochastic blue and several other - start behaving erratic, unreliable or at-least less efficient than before. at-least potentially - they can).
vikibhai
Sat Aug 27, 2016 6:31 pm
No
On your 1 print
dear brother .... i did not post here what is corect way to check..my basicaly point to show chain 1 not working...here i tel u why.....i have mostly speed issue through that...so i test it deeply why it happen ,mostly only with these devcies....so i decide to check chains....
device have tx and rx wht ever i select on chain..but should have click on tx and rx for receiving and sending data...
1)when i checked on "TX AND RX ON CHAIN 0" my system connect with my accesspoint and i use my internet and shering services...device working on single chain..
2)and when i checked on "TX AND RX ON CHAIN 1" then my system not connected with my accesspoint....thats show chain 1 not working....
3)in images i show the behaviour of chain 1 .... when i click on TX "CHAIN 1" with tx and rx chain0 ..my system connected with it and show the chain0 and chain 1 sgnal on registered client properties..giving sgnal its not the sign that device transfer the data through chain 1...and anotherway when i checked on tx and rx chain 0 and rx only chain 1 ..then also my system conet with my accesspoint..and regitered client properties not show the chain 1 signal....i hope some admin note it ....if i am rong then correct me...
raffav
Re: RE: Re: RE: Re: RE: Re: v6.37rc [release candidate] is released, only one wireless package!
Sat Aug 27, 2016 11:10 pm
No
On your 1 print
Ok
Now I understand the point, I also have a base 2 but it is controlled by capsman so I don't see that information
To see if that happens to I am using the last rc version
vikibhai
Sun Aug 28, 2016 10:00 pm
1)have 2 basebox2 with 6.37 rc22
2)i downgradge my basebox2 to 5.26....... both basebox downgrde successfulyy.but one of them having a licence issue...on every reboot..device changing the software id.....now i upgrade it to back 6.37rc22..got lisence back..why it happend one of my basebox2 device on 5.26...even 2nd basebox2 device working good with lisence
Chupaka
Mon Aug 29, 2016 2:30 am
uldis
Mon Aug 29, 2016 10:59 am
vikibhai, please contact support@mikrotik.com about your TX/RX chain0/chain1 signal reading problem. The problem of the signal not reading started with v6.37rc22?
Also please note that chain0 RX should always be enabled as chain0 is considered the main chain.
vikibhai
Mon Aug 29, 2016 7:10 pm
I already mail to support mikrotik...and i dnt think so it startex with 6.37rc22..i have speed issue from 1st day...mostly people said wirless giving bad reception...so i test deeply it and discover that issue...u saw img that i post link http://imgur.com/a/bJptd...i click on tx rx chain 0 and tx on chain 1....but in registerd client sgnl status client not have chain 1 sgnal...i downgradge to v5.26 both chain working good...but problem is here oly one basebox2 working ..2nd basebox giving license issue ..on erery reboot software id chage randomly...so i upgrate it back to 6.37rc22...is there any solution i downgradge it to 5.26 without licence error
emils
Wed Aug 31, 2016 10:15 am
Version 6.37rc24 has been released.
Changes since 6.37rc22:
*) dhcpv6 - update DUID when system-id changes (solves problem when cloned VM retains the same DUID);
*) ipsec - don't log authtype mismatch as critical;
*) ipsec - fixed kernel crash when sha512 was used;
*) ipsec - fixed xauth parameter printing in terminal;
*) lte - added support for more dlink dwm-222 configurations;
*) lte - added zte K5008-Z back;
*) lte - fixed default channels for dlink dwm-157;
*) pppoe - fixed master interface l2mtu check, could result in assumption that master interface can handle 14 byte bigger packet than it actually can (broken in 6.36);
*) snmp - skip forbidden oids on getnext completion;
*) supout - fixed bug that could cause enormous size supout.rif files;
*) usb - fixed usb port reset on ether1 link changes on mAP 2n;
If you experience version related issues, then please send supout file from your router to support@mikrotik.com. File must be generated while router is not working as suspected or after crash.
Motorbreath
Wed Aug 31, 2016 10:27 am
The issue I had with lower signal on than on current version on Groove is fixed in rc24... well done 8)
nz_monkey
Wed Aug 31, 2016 12:19 pm
What problems does this fix ?
I ask as we have had some issues with SNMP polling of RouterBoards causing stability issues.
http://thebrotherswisp.com/ | Mikrotik MTCNA, MTCRE, MTCINE | Fortinet FTCNA, FCNSP, FCT | Extreme Networks ENA
emils
Wed Aug 31, 2016 12:50 pm
SNMP would crash when accessing these oids. This particular issue was introduced in 6.37rc10.
nz_monkey
Wed Aug 31, 2016 2:00 pm
Thanks Emils,
Its not the SNMP + Routing issue we have.
Zorro
Long time Member
Long time Member
Wed Aug 31, 2016 2:23 pm
also if there wasn't "standart" radar-detection sources-code/algorythm, mandatory/enforced to use - there was some possibility to slightly tune-down radar-detection in ROS to considerably reduce amount of complains/whine about, because erratic behavior, making it kinda unusuable in several cases(with dense EMI/side-bands/harmonics, usual for ubran area)
emils
Wed Aug 31, 2016 4:00 pm
Version 6.37rc26 has been released.
Changes since 6.37rc24:
!) ethernet - added new loop-protect feature for ethernet,vlan,eoip,eoipv6 interfaces (http://wiki.mikrotik.com/wiki/Manual:Loop_Protect);
*) fastpath - fixed kernel crash on interface disable/remove;
*) fetch - fixed bug with incomplete files in https mode;
*) routing - improved kernel performance in setups with large routing tables;
*) snmp - require write permitions for script run table access;
*) sstp - now supports TLS_ECDHE algorithms;
BartoszP
Wed Aug 31, 2016 4:16 pm
Does not work for RB411
[admin@RB411_102] > interface ethernet
[admin@RB411_102] /interface ethernet>
.. -- go up to interface
blink -- Generate traffic to blink leds
cable-test --
comment -- Set comment for items
disable -- Disable items
edit --
enable -- Enable items
export -- Print or save an export script that can be used to restore configuration
find -- Find items by value
get -- Gets value of item's property
monitor -- Monitor interface status
print -- Print values of item properties
reset-counters --
reset-mac-address --
set -- Change item properties
switch --
patrick7
Wed Aug 31, 2016 4:17 pm
About loop protect: How is that handled if interface is in a bridge / switch group?
How is routing performance improved?
bajodel
Long time Member
Long time Member
Fri Sep 02, 2016 2:41 am
Seems like ipip tunnels not working if fastpath is enabled (if I disable fastpath locally on ipip interface or globally tunnels works)
alexjhart
Fri Sep 02, 2016 2:49 am
Yeah, I'm wondering if this can help with the CRS shortcoming (no STP for switch group ports). I haven't purchased CRS yet because of this.
Alex Hart
The Brothers WISP
alexjhart
Fri Sep 02, 2016 2:55 am
@emils maybe?
Alex Hart
The Brothers WISP
irghost
Fri Sep 02, 2016 7:17 am
where?
I cant find it ! (/interface ethernet)
MTCNA MTCRE MTCTCE MTCUME MTCWE MTCIPv6E MTCINE
emils
Fri Sep 02, 2016 9:37 am
This is just the initial release for this new feature. We are still polishing it, writing documentation and fixing some bugs. Until it is done, you will have to explore it by yourselves.
irghost, are you sure you have the latest release candidate version installed? On what RouterBOARD you can not find this function?
pe1chl
Fri Sep 02, 2016 10:52 am
(I presume this is about the snmp script table)
Can you at least indicate where this feature can be found in the command structure?
I have been looking in /system script and in /snmp but I have been unable to find any command or option referring to a script table.
Zorro
Long time Member
Long time Member
Fri Sep 02, 2016 10:55 am
not sure in which of latest RC's, but port scans detection - working again. (most stealth scans ~ reliably detected now as before).
that good/essential, IMHO.
emils
Fri Sep 02, 2016 2:44 pm
Version 6.37rc27 has been released.
Changes since 6.37rc26:
*) ethernet - allow to force mtu value when actual-mtu is already the same;
*) ethernet - rb44ge now have disabled-running-check=no by default;
*) ipsec - fixed dynamic policy not deleted on disconnect for nat-t peers;
*) kvm - fix add/remove of disabled interfaces;
*) lte - added rndis for ZTE MF8xx;
*) lte - adjusted usb config for dlink dwm-157 D;
*) mpls - fixed vpls throughput issues caused by out-of-order packets;
*) usermanager - fixed rare crash on paypal payment;
macgaiver
Fri Sep 02, 2016 2:45 pm
under interfaces.
/interface ethernet set <tab><tab>
pe1chl
Fri Sep 02, 2016 3:00 pm
under interfaces.
I am taliking about this:
Not this:
paulct
Fri Sep 02, 2016 3:12 pm
Interesting, where will the performance be felt? Loading of bgp peer routes? or?
rpingar
Long time Member
Long time Member
Mon Sep 05, 2016 10:27 am
to have it fixed (*) mpls - fixed vpls throughput issues caused by out-of-order packets;) do I have to upgrade only the termination tunnel or all the mpls chain????
regards
Ros
emils
Mon Sep 05, 2016 10:43 am
rpingar, should be enough to upgrade only routers with VPLS endpoints.
pe1chl, you can download the latest Mikrotik.mib file and look for differences between the previous version. Mikrotik.mib.
paulct, any action with routing table should be faster now.
pe1chl
Mon Sep 05, 2016 12:35 pm
Thanks, I see the entries now.
I would have expected some command to add a OID and script name (or literal script) binding that OID to the script.
It now appears that all scripts in the existing script table fulfilling some criteria are callable via SNMP. Not sure if that is a good idea.
irghost
Mon Sep 05, 2016 12:57 pm
yes last RC version ( RB2011)
emils
Mon Sep 05, 2016 1:13 pm
irghost, Winbox support is not yet added, it is only available from terminal:
/interface ethernet set etherX loop-protect<tab>
emils
Tue Sep 06, 2016 3:31 pm
Version 6.37rc30 has been released.
Changes since 6.37rc27:
*) dns - fixed crash when using regexp static dns entries;
*) ethernet - fixed loop-protect on bridged ports;
*) ethernet - fixed neverending loop in CDP packet processing;
*) ipv6 - show multiple neighbors with the same address;
*) kvm - fixed guest crashing when using MTU bigger than 1504;
*) leds - added option to disable all leds on RBcAP2n;
*) lte - added switch for Huawei K5160;
*) lte - fixed band unsetting;
*) pppoe - fixed disconnects by idle timeout when fastpath is used;
*) rb3011 - fixed rare occasions when router would hang while loading kernel;
*) sfp - fixed initial eeprom reading on CCR1036-8G-2S+ and CCR1072-1G-8S+;
*) trafficgen - add per stream packet count setting;
*) tunnel - fixed link status flapping when remote end is not responding (introduced in 6.37rc);
*) tunnel - increased minimal MRRU to 1500 for PPP interfaces;
*) webfig - fixed certificate signing;
*) winbox - added auto refresh for BFD neighbors;
*) winbox - added comment field support for switch vlan menu;
*) winbox - adjusted allowed values for http-proxy field;
*) winbox - disabled MRRU by default for PPP interfaces;
*) winbox - removed L2MTU field for PPP interfaces;
*) winbox - removed unset button for L2MTU field;
All known wireless package issues after system upgrade should be fixed now.
macgaiver
Tue Sep 06, 2016 3:36 pm
Just upgraded board from 6.35.4, with 4 wireless packages on it -fp and -cm2 (in bundle) -cm2 and -rep separately, enabled -rep.
Upgrade went without issues have one "wireless" in the bundle, enabled, with configuration intact. Good Job!
MartijnVdS
Tue Sep 06, 2016 4:25 pm
How does the new automatic DFS setting work in relation to CAPsMANv2?
As far as I know, DFS did not work when using CAPsMANv2. Has this changed? Do CAPs now run DFS checks if you use a frequency on which DFS is required?
Beone
Tue Sep 06, 2016 8:07 pm
We've noticed that multicast forwarding isn't working anymore since v6.37rc27 previous RCs where working. Rollback to v6.34.6 works perfect
notToNew
Wed Sep 07, 2016 3:57 pm
Feature request for wireless-package:
As we have the mode "aligment only", I'd like to have a mode "Virtual only".
I often use the new combination of the wireless-rep package and configure one device as a station, and a virtual-device as a bridge-ap.
Now, wenn the station doesn't get a connection, it also disables the virtual bridge-ap-device.
As a workaround, I configure 2 virtual devices, the station AND the bridge. Now, what should I do with the master-device?
As solution I suggest 2 things:
1. Don't disable virtual devices if the master device (as station) doesn't get a connection.
2. Add the mode "Virtual only" for the master-device.
emils
Wed Sep 07, 2016 5:08 pm
Version 6.37rc32 has been released.
Changes since 6.37rc30:
*) dude - (changes discussed here: viewtopic.php?f=8&t=110424);
*) ipv6 - improved system responsiveness when ipv6 routes are frequently modified;
*) ppp - use default-route-distance when adding ipv6 default route;
*) quickset - added 2GHz-g/n band support;
*) quickset - fixed guest reporting in "home ap dual" mode;
*) quickset - fixed wireless frequency fields in "home ap dual" mode;
*) trafficgen - show out-of-order packet counters in stats printouts;
*) tunnel - fixed ipv6 link-local address adding for gre;
*) users - fixed script policy checking against user policies when running scripts;
*) winbox - added default-authentication parameter for wireless station modes;
*) winbox - adjust on-event field dynamically depending on window size;
*) winbox - display actual-mtu for tunnels in interfaces window;
*) winbox - fixed multiline read only fields not displaying new line characters;
*) winbox - fixed raw firewall showing jump targets from filter chains;
*) winbox - removed health menu from devices that do not support it;
*) winbox - removed L2MTU field from PPP server binding settings;
*) winbox - show firmware-type in routerboard window;
pe1chl
Wed Sep 07, 2016 5:13 pm
I agree with this! I use wireless-rep without a direct bridge as setup when using it as a repeater.
The station should connect to a WiFi AP, then I setup a VPN over that link, and the VPN network is offered on the bridge-ap configured using wireless-rep.
It is very inconvenient that the bridge-ap does not work when the station is not connected, e.g. you want to set the password on the station
by logging in to the MikroTik. That is now only possible using a cable.
(of course I understand the trouble beneath this: when the station is not connected it will be scanning the frequencies to find an AP,
and the bridge-ap is using the same hardware so the same frequency, which is not stable then. however, with dual-chain devices
or some clever timeouts this can probably be solved?)
notToNew
Wed Sep 07, 2016 6:32 pm
Another finding:
It is somehow unclear if you set the master-wifi-device to bridge and the virtual-device to bridge-ap,
the limitation of the master-device to allow only 1 connected device wins.
Changing the master-device to bridge-ap solved my problem.
So please add in the documentation (or fix that limitation)
I wondered for several hours why it is not possible to connect more than 1 wireless device at the same time while not getting any error-logs...
jarda
Wed Sep 07, 2016 10:07 pm
I would like to have it too. Very useful.
tnakir
Fri Sep 09, 2016 1:02 pm
I am having a problem with wireless-rep package on RB2011UiAS-2HnD-IN when using 2.4 band (I tried all the channel widths) on my laptop.
When my Logitech Unifying receiver (mouse) is connected to my laptop's USB, my CCQ drops to 20%. When I unplug it, i get 90+%.
When I use older packages, I don't get interference. In both cases I am using auto frequency (I also tried to change channels manually and it didn't help).
Any ideas?
RyperX
Sat Sep 10, 2016 10:18 pm
Latest RC is working fine on rb2011
jondavy
Sun Sep 11, 2016 1:45 am
Romon neighbor bug:
when the identity is too long it appears as mikrotik into romon neighbor
and also the option to port forbid not working
hedele
Mon Sep 12, 2016 5:43 pm
Wow... greatly reduced CPU load over previous versions on devices with large routing tables! Also a CCR1016 does no longer produce packet loss in general packet forwarding when a single CPU core is stuck at 100%
sergejs
Tue Sep 13, 2016 1:33 pm
Version 6.37rc34 has been released,
Changes since 6.37rc32:
*) capsman - fixed kernel crash on cap while changing client-to-client forwarding;
*) dhcpv6 - improved interface status tracking;
*) gps - always check NMEA checksum if available;
*) ipv6 - fixed RA and RS processing on new interfaces after many interfaces have lost link during prolonged operation;
*) mpls - fixed memory leak;
*) packages - fixed situation when it was impossible to disable ipv6 package (introduced in v6.37rc3x);
*) ppp,lte - pin is now converted to string argument;
*) supout - improved crash report generation for tile architecture;
If you experience version related issues, then please contact MikroTik support (support@mikrotik.com) and send supout file from your router. File must be generated while router is not working as suspected or after crash
nz_monkey
Tue Sep 13, 2016 2:09 pm
Hi Sergejs + Team,
Can you please provide more detail on this fix. Specifically what the triggers for the memory leak were, this way we can know exactly what problems it will solve.
Thanks!
macgaiver
Tue Sep 13, 2016 4:02 pm
Hi Sergejs + Team,
Thanks!
Lately changelog is as precise as they are willing/allowed to answer. for example - you wouldn't like them to reveal information that can potentially be used to trigger this on purpose. Especially while the fix is only in RC versions. Questions like this are dangerous.
Question here is simple, have you noticed or not some memory leaks in your mpls setups? If yes - upgrade.
sergejs
Tue Sep 13, 2016 4:16 pm
nz_monkey,
We had ticket with MPLS configuration, that produced memory leak. This is fixed, however it is actual for very specific configurations. And I do not have to add more that previous poster replied.
amokkatmt
Tue Sep 13, 2016 5:38 pm
I can't disable wireless package on RB750GL since some of rc's.
17:24:09 system,info package wireless@ is scheduled for disable by ***
17:24:18 system,info disabled wireless@-6.37rc34
17:24:21 system,info router rebooted
And after this reboot:
/system package print terse where disabled=no name=wireless
 0   name=wireless version=6.37rc34 build-time=sep/12/2016 13:06:07 scheduled="" bundle=routeros-mipsbe
jarda
Tue Sep 13, 2016 5:47 pm
Using package bundle by default is very bad approach of mikrotik for years. Better to install separate packages instead of bundle. Never mind it should be possible to disable bundled packages too.
Tonda
Tue Sep 13, 2016 6:11 pm
I have the same problem with disabling wireless package at RB750UP. To be honest - I do not understand, why it is even possible to install or enable/disable wireless package on device, which never had and will never have any kind of WiFi device inside? I think more examples can be found among Routerboard devices.
jarda
Tue Sep 13, 2016 10:13 pm
because you can use such device as capsman - so you need the wireless package.
nz_monkey
Wed Sep 14, 2016 8:10 am
nz_monkey,
Thanks Sergejs, macgaiver perfectly explained with a context I had not thought about.
JHV
Wed Sep 14, 2016 9:53 pm
DHCPv6 still does not work like before v 6.33.6.
If a disconnect occurs, DHCPv6 stays for 10 minutes in state renewing and for another 10 minutes in state rebinding. It takes exactly 20 minutes until a new prefix could be obtained.
Please see also this thread.
juhos
Sat Sep 17, 2016 3:03 pm
Hi guys!
*) modem - added d-link dwm-222 support;
Can anyone help me with this? I have one dwm-222 modem but it not seems like work. The router only see the "Mobile connect"(cd drive for progs on pc).
Im trying on HAP lite.
wispwest
Sun Sep 18, 2016 10:28 pm
We had a few catostrophic wireless failures recently due to upgrading firmwares When it would come back, WLAN is disabled and lost all of its configuration as if ts a brand-new WLAN interface. Some of them didn't even show it, and needed the new wireless package enabled. Granted it wasn't clear enough what to do "prior" to the upgrade to the tech that was upgrading them.
It is understood now, but does still post some risks, would definitely be nice if the upgrade was full-automatic, which I understand is now happening the newest firmware? Aside from if you have multiple packages enabled, just make sure you disable one of them?
mistry7
Mon Sep 19, 2016 10:06 am
How to solve this?
How to remove the old used Wireless Pack?
notToNew
Mon Sep 19, 2016 11:54 am
Is it possible to use the wireless-connect-list to connect to HIDDEN ssid's? Am I blind, or is there no possibility?
CCR1036-12G-4S, several 952Ui-5ac2nD, ...
strods
Mon Sep 19, 2016 1:28 pm
Version 6.37rc38 has been released,
Changes since 6.37rc36:
!) ethernet - added new loop-protect feature for ethernet,vlan,eoip,eoipv6 interfaces, http://wiki.mikrotik.com/wiki/Manual:Loop_Protect ;
w0lt
Mon Sep 19, 2016 4:22 pm
Package list (Check For Updates) doesn't seem to grab the latest RC version.
MTCNA - 2011
" The Bitterness of Poor Quality Remains Long After the Sweetness of Low Price is Forgotten "
barracuda
Mon Sep 19, 2016 11:59 pm
Same here!
qiet72
Tue Sep 20, 2016 12:31 am
Currently running 6.37rc38 on a hAP ac. I noticed that my laptop with an Intel 7250 wireless card cannot seem to receive mimo (dual chain) at the higher rates of 802.11ac but works perfectly when connected to my Asus RT-AC68U router. The issue seems to only happen on receive (to laptop), not transmit (from laptop). Transmit works as expected with dual chain mimo. I have used the registration page in winbox and the "iw wlan0 station dump" linux command to get the info.
Have tried 6.34.6, 6.36.3 and this latest rc - all exibit the same issue. The Asus RT-AC68U router seems to use the Broadcom BCM4360 chipset.
Qiet72
BartoszP
Tue Sep 20, 2016 9:13 am
6.37rc36 @ RB433 does not see rc38 for download.
Real admins use real keyboards.
qiet72
Tue Sep 20, 2016 9:45 am
I stand corrected. Thank you. I will re-check the version and try again with latest.
Sent from my iPhone using Tapatalk
kristaps
Tue Sep 20, 2016 10:44 am
How to solve this?
Please use the Netinstall utility to reinstall the device:
http://wiki.mikrotik.com/wiki/Manual:Netinstall
andywright
Tue Sep 20, 2016 12:00 pm
6.37rc38 on hAP AC
Trying to use QuickSet from Winbox in Home AP Dual mode - unable to save config as 'Band' always stays red whatever settings for 2GHz and 5GHz are chosen. Works ok from Web config page though.
macgaiver
Tue Sep 20, 2016 2:59 pm
6.37rc38 on hAP AC
what winbox loader version are you using?
andywright
Tue Sep 20, 2016 3:03 pm
Winbox 3.5
strods
Tue Sep 20, 2016 3:34 pm
Version 6.37rc40 has been released,
Changes since 6.37rc38:
*) dhcpv6 - reworked DHCP-PD server interface and route management;
*) tunnel - fixed communication via tunnel to router itself if fastpath was active;
*) wireless - fixed interface disappearance on upgrade to 6.37 (introduced in v6.37rc);
strods
Tue Sep 20, 2016 3:35 pm
andywright - This is an Winbox issue and will be fixed in next Winbox release.
andywright
Tue Sep 20, 2016 3:39 pm
strods - many thanks :D
John39
Tue Sep 20, 2016 4:42 pm
After upgrading to 6.37 RC 40 on the router where the wireless interface disappeared , he returned , although in support of said preparing to replace the router as the problem in the router .
rajo
Tue Sep 20, 2016 5:16 pm
Is there any reason why NTP client still does not support DNS? It would be great if I could finally get rid of my script for this.
uldis
Tue Sep 20, 2016 5:24 pm
It is supported for a while already or you are looking some other setting:
/system ntp client set server-dns-names=NTP_SERVER_NAME
rajo
Tue Sep 20, 2016 5:51 pm
I don't have server-dns-names as a configuration parameter. These are the options I have on MikroTik hardware:
[admin@MikroTik] > system ntp client set
enabled  mode  primary-ntp  secondary-ntp
Both primary-ntp and secondary-ntp require an IP address.
npero
Tue Sep 20, 2016 6:52 pm
Do you maybe using ntp package ?
With ntp package
without
enabled primary-ntp secondary-ntp server-dns-names
if you don't need ntp server don't have any reason to use ntp package.
rajo
Tue Sep 20, 2016 7:17 pm
Thanks! That was the issue.
@MikroTik, please fix the inconsistency. It doesn't make sense to me that the server-dns-names option should not be available with the NTP package installed.
pe1chl
Tue Sep 20, 2016 7:37 pm
It does make sense. The NTP package provides an NTP server and it works with fixed server addresses. Sure it would be
nice if there was the possibility to use DNS names there, but you should understand that in that case the DNS names would
be resolved only one time after router reboot. And there may even be dependency problems in that the router wants to set
the clock correctly before it has started the DNS resolver.
When running the router without NTP package, an SNTP implementation is used that can (when server-dns-names is used)
do an NTP lookup every time it requests the time, and the DNS name can return a different IP address every time. When that
is what you want (e.g. because you want to use the NTP pool), please use the SNTP implementation. Unfortunately, in that
case you cannot serve the time from the router.
I don't know which NTP server sourcecode MikroTik uses for the NTP server, and when it is the ntpd reference implementation,
if they will update to the latest version in RouterOS version 7. When they do, it would be possible to add a "pool-dns-name"
option to have both DNS resolution and server functionality.
rajo
Tue Sep 20, 2016 8:16 pm
I really don't buy this argument. What you describe is really an implementation rather than technical (or even best-practices) issue.
rzirzi
Tue Sep 20, 2016 8:18 pm
Still the same problems... now the same with RC40...
pe1chl
Tue Sep 20, 2016 9:57 pm
It is the same in all NTP server implementations. NTP servers lock onto reference servers, and would not work OK when the actual
server changes for subsequent polls. So NTP server implementations lookup the DNS name only when started. SNTP is different.
qiet72
Tue Sep 20, 2016 10:55 pm
OK, I have now updated to the latest rc (6.37rc40) by downloading from mikrotik.com/download and updating routeros manually.
I did the same test: Do a download via the 5Ghz 802.11ac. My hardware is an Intel 7260 a/b/g/n/ac adapter. When I download via my Asus RT-AC68U router which uses a Broadcom BCM4360 chipset, I get full mimo transfers at up to 866 Mb/s (actual transfer speed is about 320Mb/s). Unfortunately, when the Intel card is connected to the 5 Ghz hAP ac MikroTik router, then I only get a bitrate of 433Mb/s max (1 chain) on receiving or around 210Mb/s and 866 Mb/s (2 chains) on transmitting. Again, this issue happens also on 6.36.3 and 6.34.6 versions. Interestingly, the bug only happens when the receive signal is negotiate above 195 Mb/s.
Qiet72
Sob
Wed Sep 21, 2016 1:14 am
Let it work the same way as other ntp servers do, that's fine. No one asks for hostname being resolved again and again for each poll.
Current problem is that you have to put in numeric address instead of proper hostname, and if server moves somewhere else, RouterOS is stuck with old address. So you have to update config of all RouterOS clients, instead of updating only server's hostname. It's not right, since dns was invented to solve exactly this kind of problems.
People who quote full posts should be spanked with ethernet cable. Some exceptions for multi-topic threads may apply.
pe1chl
Wed Sep 21, 2016 11:44 am
I understand what you mean, but note that MikroTik routers do not usually have a hardware real time clock, so they need
to get their system time from an external source as soon as possible during startup. It might be that the NTP server is
started before the DNS resolver, I don't know details about that.
The problem is worsened by the fact that MikroTik allow only 2 NTP servers to be configured. This should IMHO be
extended to at least 4, better an "arbitrary" number as seen in other places (where you can just expand the value list).
Maybe the issue could be solved by adding the capability for at least 2 DNS names in addition to the existing 2 fixed
addresses, and the NTP server could delay the resolving of DNS names until it has DNS available.
Having some method of updating certain settings of a large number of MikroTik routers is a topic I am going to investigate
anyway, as I get more and more routers and require this as well. Probably some solutions exist using either the API
or an automated login to the ssh/telnet service.
RyperX
Wed Sep 21, 2016 1:44 pm
I updated to latest rc40 and i lost my complete interface configuration. (As i know i came from rc38)
All interfaces was resettet and every setting that had an interface applied was set to unknown.
Any idea what happen? Device rb2011
qiet72
Wed Sep 21, 2016 1:50 pm
Qiet72
I am considering adding screenshots to give a better idea of what I mean in case someone does not understand the problem. Unfortunately, I haven't figured out how to upload screenshots. If I try to insert an image, then it looks like it expects the image to exist already on the internet, but I would like upload the image from my computer - how do I do that on this forum?
Qiet72
qiet72
Wed Sep 21, 2016 2:12 pm
I seem to remember that you have to use the mac address of the ap you want to connect to instead of the ssid when you want to connect to a hidden access point.
Qiet72
notToNew
Wed Sep 21, 2016 6:05 pm
Qiet72
Thanks for your answer, I tried it without success. My Ap has several hidden wifi with the same mac, so how can the microtik connection-list determine which
wifi to choose, when it has no information about the ssid? Maybe that's the reason why it didn't work in my test?
pe1chl
Wed Sep 21, 2016 7:14 pm
Ohh boy... that is not good! Did the AP allow you to configure it that way? Did you have to force it somehow?
Sob
Wed Sep 21, 2016 7:53 pm
You may be overthinking it. DNS resolver in RouterOS is simple service, it must start up in no time. Making it a dependency for NTP client should not be a problem. And even if not, and NTP client was not able to resolve hostname, it would succeed a second later. No big deal to most users.
You can come up with some setup where hostnames wouldn't work. E.g. if your upstream DNS resolver would be only accessible using IPSec tunnel, which would have trouble starting with wrong system time. But it would be a special case and user/admin's responsibility to use the right configuration (i.e. in this case NTP client with numeric addresses only).
Mikhail73
Wed Sep 21, 2016 8:43 pm
Does anyone have problems with recursive routing? I used this manual (Multiple host checking per Uplink), and everything works fine on first router. But exactly the same configuration (except gateways, of course) doesn't work on another two routers. When i add default route via virtual host 10.1.1.1, this route becomes active for several seconds, then becomes inactive. When i checked 10.1.1.1 (terminal-ip route check 10.1.1.1) - everything is ok. It seems to me, it's a bug. Tested on 6.36.2/6.36.3/6.47rc40.
qiet72
Wed Sep 21, 2016 8:59 pm
Qiet72
You say: "My Ap has several hidden wifi with the same mac" - do you mean you have multiple Virtual AP's with the same mac address beside the one physical AP?
Qiet72
notToNew
Thu Sep 22, 2016 9:56 am
Qiet72
No, I have ONE AP(not mikrotik) with several hidden SSIDs. each of this ssids have a name, like private-net and guestnet.
Every hidden ssid has the same mac-adresss.
So when i want to connect to the "private-net", how can i be shure that i'm connected to this net when i use ssid=MAC instead of ssid=private-net?
MartijnVdS
Thu Sep 22, 2016 10:08 am
Qiet72
Every virtual AP should, by default, get its own unique mac address. Otherwise, clients will get confused even when the network is visible.
pe1chl
Thu Sep 22, 2016 10:36 am
Please verify that again. I don't think it is true, and if it is true I don't think it can work.
uldis
Thu Sep 22, 2016 11:10 am
This will be fixed/added in the RouterOS v7 only as current implementation doesn't allow that to add in v6 for the NTP package.
paoloaga
Thu Sep 22, 2016 1:13 pm
There are so many things that will be available in v7 only, the most important (for me) are IPv6 routing enhancements (like the recursive lookup of BGP routes), I hope that we will be able to see it soon enough!
patrick7
Thu Sep 22, 2016 1:49 pm
If it ever will be available...
strods
Thu Sep 22, 2016 3:15 pm
Version 6.37rc42 has been released,
Changes since 6.37rc40:
!) dude - (changes discussed here: viewtopic.php?f=8&t=110424);
*) certificate - do not allow to remove certificate template while signing certificate;
*) dhcpv6 - fixed interface status update on client add (introduced in v6.37rc);
*) firewall - fixed time based rules on time/timezone changes (again);
*) ipsec - fixed crash with enabled fragmentation;
*) ipsec - fixed fragmentation use negotiation;
*) lte - added hauwei me909s variant;
*) lte - fixed setting correct lte band for sxt lte;
*) traffic-flow - fixed IPFIX packet timestamp;
*) traffic-flow - fixed IPFIX wrong flow sequence;
notToNew
Thu Sep 22, 2016 4:26 pm
2 year old sony-tv does not work with wireless-rep package. wireless-cm2 works as expected.
BartoszP
Thu Sep 22, 2016 9:45 pm
RB741TC @ RC36 or RC40
Cannot set it as CAP as "Certicate" field is in error state and there is no way to resolve this problem from GUI.
This RB741 have been removed from CAPSMAN some RC's back and I want to connect it again to CAPSMAN.
FezzFest
Thu Sep 22, 2016 11:42 pm
Upgraded OmniTIK U-5HnD from 6.34.6 (bugfix) to 6.37rc40 and I'm stuck without wireless. It is in the package list two times, once with version 6.37rc40, once with version 6.27 (I have no idea where this comes from), both disabled. Uninstalling wireless package does not work, neither does enabling any of the packages.
Edit: downgraded to 6.36.3 and upgraded to 6.37rc42 again, issue persists. Device is in a remote location, so netinstall is not a possibility.
mistry7
Fri Sep 23, 2016 6:43 am
@fezzfest
Known Unfixed issue......
Downgrade to 6.35.4
This bring you back with Wireless, After This you can Upgrade to 6.36 and the old Wireless-FP will be removed!
Mistry7
Mikhail73
Fri Sep 23, 2016 6:47 pm
Does anyone have problems with recursive routing? I used this manual (Multiple host checking per Uplink), and everything works fine on first router. But exactly the same configuration (except gateways, of course) doesn't work on another two routers. When i add default route via virtual host 10.1.1.1, this route becomes active for several seconds, then becomes inactive. When i checked 10.1.1.1 (terminal-ip route check 10.1.1.1) - everything is ok. It seems to me, it's a bug. Tested on 6.36.2/6.36.3/6.36rc40/6.37
Excuse my persistence, but can anyone answer me, why double recursive route is inactive while it's gateway is active?..
samsung172
Sat Sep 24, 2016 1:23 am
 with "radar-detect" enabled will end in endless frequency search loop, even when there is realy no radar
That is not true. All countries in the EU, and the USA should have already been using this setting for a long time, and there are no problems like you describe.
I hope taht there will be country "other"
RouterOS already has a superchannel mode that does exactly this.
this is not true.
If you have to much power, noise and gain - you WILL have DFS to detect radar at all freq. DFS is NOT working as expected in ros. You should also implement TPC.
Chupaka
Sat Sep 24, 2016 3:35 am
please make a new topic and post some details of actual config and state ("/ip route print detail", etc). as you can see, your question is not about 6.37rc exactly
Russian-speaking forum: https://forum.mikrotik.by/. Welcome!
For every complex problem, there is a solution that is simple, neat, and wrong.
MikroTik. Your life. Your routing.
vlatko
Sat Sep 24, 2016 12:47 pm
I'm not sure where mikrotik going, concerning wireless and radio side
I am aware of the limitations imposed by regulatory agencies in terms of DFS and other
now is the fact that with the current DFS mode, wireless becomes completely unusable in dense areas
DFS just constantly shifting frequency even if there is no radar in the vicinity and that's a fact
ITS TOTALY UNUSABLE
as far as I can see, there are two possible solutions
or they will be left some backdoor possibillity to go without DFS
or they will have to do something drastic to change
I think we need the following
spectrum scan should be carried out continuously in the background, independently of the work of operating clients radio
selection of free channels should be carried in background also, without disrupting client connections
probably would have to be a separate radio for it, like at ubiquiti
also, on mandatory, should be introduced synchronous switching customers to new frequency from ap radio side
after DFS establishing new free frequencies, ap should task a control signal for simultaneously switching to a new frequency to all clients from reg table
This could probably be introduced on proprietary protocols
without this i dont see how to use DFS
notToNew
Mon Sep 26, 2016 10:48 am
thanks BartoszP for answering, i know that 6.37 only has one wireless-package.
Anyway, the problem still exists:
Connecting with 3.36.3 and wireless-cm2 works,
3.36.3 wireless-rep and 3.37.42 wireless does not work.
Another device which does not work: "Samsung UE22H5670"
pe1chl
Mon Sep 26, 2016 11:49 am
It could depend on some settings, e.g. aes/tkip for group ciphers.
notToNew
Mon Sep 26, 2016 12:07 pm
Thanks for answering.
I posted a more in-dept message in the new 6.37 thread and think we should continoue there...?
My settings are the same on every MT-AP-device: WPA2-PSK and aes-ccm, no tkip.
I have different OS'ses on the client side (linux, windows, BSD, ...)
The MT support already contacted me some weeks ago, without any prograss until today. I offered them so donate
such a device for testing, but they bought one on theire own.
As wireless-cm2 is discontinued in the current branch, I'm somehow worried about the future...
My settings are the same on every device: WPA2-PSK and aes-ccm, no tkip.
pe1chl
Mon Sep 26, 2016 12:09 pm
Try to enable tkip for group cipher.
notToNew
Mon Sep 26, 2016 2:33 pm
No difference. Here is the Debuglog from 3.26.3 with enables TKIP
02:02:31 wireless,debug wlan1: 00:12:F0:6E:DD:XX attempts to associate
02:02:31 wireless,debug wlan1: reject 00:12:F0:6E:DD:XX, banned (last failure - extensive data loss)
02:02:34 wireless,debug wlan1: 00:12:F0:6E:DD:XX attempts to associate
02:02:34 wireless,debug wlan1: reject 00:12:F0:6E:DD:XX, banned (last failure - extensive data loss)
02:02:37 wireless,debug wlan1: 00:12:F0:6E:DD:XX attempts to associate
02:02:37 wireless,debug wlan1: reject 00:12:F0:6E:DD:XX, banned (last failure - extensive data loss)
02:02:40 wireless,debug wlan1: 00:12:F0:6E:DD:XX attempts to associate
02:02:40 wireless,debug wlan1: 00:12:F0:6E:DD:XX not in local ACL, by default accept
02:02:40 wireless,info 00:12:F0:6E:DD:XX@wlan1: connected
02:02:43 wireless,debug wlan1: 00:12:F0:6E:DD:XX attempts to associate
02:02:43 wireless,info 00:12:F0:6E:DD:XX@wlan1: reassociating
02:02:43 wireless,info 00:12:F0:6E:DD:XX@wlan1: disconnected, ok
02:02:43 wireless,debug wlan1: 00:12:F0:6E:DD:XX not in local ACL, by default accept
02:02:43 wireless,info 00:12:F0:6E:DD:XX@wlan1: connected
02:02:46 wireless,debug wlan1: 00:12:F0:6E:DD:XX attempts to associate
02:02:46 wireless,info 00:12:F0:6E:DD:XX@wlan1: reassociating
Log wir 6.36.3 wireless-cm2
02:07:15 wireless,debug wlan1: 00:12:F0:6E:DD:XX attempts to associate
02:07:15 wireless,debug wlan1: 00:12:F0:6E:DD:XX not in local ACL, by default accept
02:07:15 wireless,info 00:12:F0:6E:DD:XX@wlan1: connected
Edit: Added log for wireless-cm2
pe1chl
Mon Sep 26, 2016 4:05 pm
Ok it helped for me for another ancient device...
normis
Mon Sep 26, 2016 4:15 pm
6.37 is out. Please start separate topics about specific issues or questions
Users browsing this forum: No registered users and 6 guests
