ik3umt
Navigation issue with Fasttrack in conjunction with pcc
Mon Jul 25, 2016 7:59 pm
I'm experiencing some navigation issues (website latency or hung, timeout during web bandwidth tests etc.) that disappear once fasttrack rules are disabled on ip firewall filter.
I'm using two wan PCC as per http://mum.mikrotik.com/presentations/US12/steve.pdf instructions.
What can I check and what could be the cause ?
Thank you
OKNET
Re: Navigation issue with Fasttrack in conjunction with pcc
Tue Jul 26, 2016 12:15 pm
Fasttrack rule is the one included in basic firewall settings:
add comment="accept ICMP" chain=input action=accept protocol=icmp
add comment="accept establieshed,related" chain=input action=accept connection-state=established,related
add comment="drop all from WAN" chain=input action=drop in-interface=ether9
add comment="drop all from WAN" chain=input action=drop in-interface=ether10
add comment="fasttrack" chain=forward action=fasttrack-connection connection-state=established,related
add comment="accept established,related" chain=forward action=accept connection-state=established,related
add comment="drop invalid" chain=forward action=drop connection-state=invalid
add comment="drop all from WAN not DSTNATed" chain=forward action=drop connection-state=new connection-nat-state=!dstnat in-interface=ether9
add comment="drop all from WAN not DSTNATed" chain=forward action=drop connection-state=new connection-nat-state=!dstnat in-interface=ether10
I have two other machines with similar configurations both with issue gone once fasttrack rule was disabled
Should perhaps fasttrack to be avoided with PCC ??
Any idea ?
soonwai
Sat Mar 04, 2017 6:41 pm
Did you all managed to solve this problem? I'm also load balancing 2 WANs with PCC and having the same problems with browser stalling when FastTrack is on. I've managed to solve it but not sure if this is the right way.
What I've done is to exclude WAN2 connections from FastTrack.
add action=fasttrack-connection chain=forward connection-mark=!WAN2_conn connection-state=established,related
That's all I did and it seems to be working. FastTrack is back on and everything is ok so far. CPU usage on my RB2011 is down from 80% to 50% when routing at 60mbps. The WANs are 30mbps each.
j528
Sun Oct 29, 2017 12:24 am
I'm experiencing exactly the same problem.
Confirmed that soonwai's workaround also seems to work for me.
vanderleiromera
Fri Jul 27, 2018 1:35 am
Thank you!
stackflow
Fri Feb 08, 2019 5:14 pm
Same issue here.
Never found the best solution.
sebastia
Fri Feb 08, 2019 6:53 pm
This CAN'T be solved!
PCC needs mangling to work BUT Fast-track bypasses mangling
What you can do, is fast-track your default route (choose one), the other route needs to do the full processing, as done by @soonwai
Users browsing this forum: No registered users and 37 guests
