kgoodyer
DHCP's all being allocated to 00:00:00:00:00:00
Wed Jul 27, 2016 12:16 am
I have 3 x VLAN's with associated DHCP pools.   VLAN2 =  10.1.2.0  VLAN4 = 10.1.4.0  VLAN5 = 10.1.5.0.
For some reason my 10.1.2.X network seem to be allocating the entire DHCP range to an unknown device with mac address 00:00:00:00:00:00  t other two VLAN's are configure exactly the same, and no such issues - not even sure where to start to look.
As soon as I release any of the leases, it gets immediatly populated with another 00:00:00:00:00:00
Cheers
Keith
pe1chl
Re: DHCP's all being allocated to 00:00:00:00:00:00
Wed Jul 27, 2016 10:36 am
Did you do a Packet Sniff to see what may be going on?
reidavidinho
Wed Jul 27, 2016 10:41 am
U can block access to the MAC address. Just go to IP DHCP-SERVER LEASES, add manually and then block access to the suspect MAC address.
Mikrotik Certified Consultant
[ MTCNA , MTCRE ]
cutedrummerboy
Wed Jul 27, 2016 3:42 pm
is vlan2 connected to wireless access point which is open?? may be a dhcp attack or some device in vlan2 have bad configuration.
Device: RB2011UIAS-RM, RB750GL, CISCO SG300-28, UNIFI UAP-LR
kgoodyer
Wed Jul 27, 2016 3:58 pm
Nope Wireless - Its a VERY closed and secure network - there are about 100 hosts on it, all with Static IP's.  Just wanted to set up a pool of 10 DHCP addresses, that can be used by new equipment that defaults to DHCP, so we can then configure them to their Static IP's.  It was only when I set up the DHCP server on that VLAN we discoverd the 'Issue'.
pe1chl
Wed Jul 27, 2016 4:08 pm
It may be a defective or badly configured piece of equipment. Try to locate it e.g. by segmenting the network,
sniffing the traffic and look in the request, etc.
trace323
Fri Jul 29, 2016 4:05 am
What firmware are you running on? If so anything above 6.33.3 firmware causes that issue. it's a bug..
trace323
Fri Jul 29, 2016 4:06 am
tsouzar
Sat Jul 30, 2016 1:32 am
I had this problem on my home's RB951Ui after changing network netmask on interface and DHCP server. I could't solve it until when rebooted my RB and everything came to work properly. What a crappy bug, MikroTik!
Users browsing this forum: eworm, saulllynas, Znevna and 138 guests
