mikruser
Suggestion: Completely virtual router based on two physical routers
Fri Jul 29, 2016 3:20 pm
Currently, with VRRP, we have manual edit config on each physical router.
Suggestion: completely virtual router, visible in Winbox as one router (like RAID1(mirror) volume based on two HDD)
do not ask me why it is necessary.
javajox
Re: Suggestion: Completely virtual router based on two physical routers
Sun Aug 14, 2016 7:34 pm
+1 I'm also interested in having this feature
jspool
Mon Oct 17, 2016 12:18 am
+1 This is needed and would be very useful.
ezanolin
Fri Oct 28, 2016 3:37 pm
Just my 2 cents..
Clustering would indeed be very useful, Mikrotik essentially has no HA mode which makes it difficult to push into the enterprise environment. We have VRRP but its not hitless for anything statefull that you may be doing (firewall or tunnelling). Clustering like Junos does on the J and SRX series should be possible to achieve on the current hardware platform. Either that or start producing redundant chassis hardware designs like Cisco 6500 or Juniper MX series devices.
In either case you need to implement dual routing engines, so you need the ability to synchronise state information between devices and delegate a master routing engine. Just this work would make clustering possible, that same work can then be used to make a redundant chassis.
vmiro
Thu Nov 17, 2016 9:52 am
+1 This is a absolutely necessary for use in enterprise environment.
I got several installation with two CCRs, configured with VRRP and is quite hard to maintain this installation. Every change in configuration has to be done on both routers.
I'm using Fortinet FortiGate in my company which supports HA and two physical devices acts as a single logical device.
mIRO
nathan1
Sun Nov 20, 2016 9:20 pm
Give this a go: https://github.com/svlsResearch/ha-mikrotik
It does exactly what you are asking for, except for stateful connection synchronization. I have been using it to run 6 pairs of CCR1036 for over a year now.
raffav
Mon Nov 21, 2016 9:51 pm
@nathan1 i was testing this on a lab using 2 450g, but for some reason on the first HA cyclce , the "B" became the active and the "A" the standby but the HA work normal only this Letter switch
do you have this problem ?
nathan1
Mon Nov 21, 2016 9:55 pm
There is no affinity for a primary right now. So this works as designed. Did you want to have an affinity for one vs. the other? In my setup - they are equal in terms of choice, at some sites my B is currently the active one just due to order in which I upgraded/cycled.
raffav
Mon Nov 21, 2016 9:57 pm
i know that work
but since A and B i think that when A became online again, in my mind need to be Active again :D
but it work very well
nathan1
Mon Nov 21, 2016 10:06 pm
i know that work
In theory, the VRRP could be adjusted to force A back to the primary when it is around. However, you will probably end up with extraneous reboots/connection breaks due to this. I simply treat them like one logical device in my head and the hostname that is currently active doesn't really come in to play. The A and B simple give me a hint as to which one is currently physically active, if I happen to be on site and dealing with them physically, this is useful. Otherwise, I just ignore it entirely and address the active one with the floating IP/hostname.
If you end up really wanting to see A active, I can add the feature when I have some more time. You can always force A to become active again by rebooting B when A is back. (hint: do an $HASyncStandby until it is GOOD before doing this).
raffav
Re: RE: Re: Suggestion: Completely virtual router based on two physical routers
Mon Nov 21, 2016 10:23 pm
i know that work
Oh
You are the creator of the scripts
Very good work, I like do read codes and try to understand them, but your is very complex for one that don't made it,
Very good work
Enviado de meu XT1580 usando Tapatalk
nathan1
Mon Nov 21, 2016 10:30 pm
i know that work
Oh
Very good work
Yep, created it after years of frustration with maintaining pairs of routers. Happy to see that it might work for you. It has been rock solid for us but let me know if you run into any issues.
ujemvi
Tue Nov 22, 2016 5:38 am
Dude, you should try to include this script you made in the Wiki.
It seems really solid and it solves one major need for enterprise needs.
nathan1
Tue Nov 22, 2016 6:10 am
I don't think the Mikrotik wiki is actually community driven, unless I misunderstand something. Are you aware of a way to add an entry? The edit history also seems to suggest that it may be Mikrotik engineers only :(
jarda
Tue Nov 22, 2016 7:27 am
Send it to support and ask them to put the script on the wiki.
ovidiu
Mon Feb 05, 2018 4:40 pm
Many thanks to Nathan1 for this solution. I tested first on a pair of small RB925ui-5ac2nD. Didn't succeed at first try because lack of instructions, but after 2 hours the pair was working as intended.
Then I installed the script on a pair of RB3011UiAS-RM and looks fine. It is still in my lab but next days will move them into production. The setup have 1 internet static IP Ethernet connection, 2 pppoe internet connections (static IP) one vlan connected to 2 RB925ui-5ac2nD providing guest wifi and separate LAN wifi and one wireless link to a remote connection using ubiquiti antennas.
Now I realized that I can connect antenna only to one router (I don't have redundant switch) so to avoid problems the router A must be always master. (of course I don't need fully redundant link to that ubiquiti since it is used only for nightly remote backups and anytime someone can plug the cable to router B )
Does anybody knows how to make always active the router A ?
nathan1
Mon Feb 05, 2018 6:15 pm
Hey Ovidiu,
This is the first setup I've seen deployed using ha-mikrotik that has a physical reason for choosing A over B. In theory, I can add a feature that would force this but it does feel a little bit odd. You can temporarily "force" it to stay on one vs. the other by rebooting the primary, which will then obviously be sticky until another event occurs. The software is designed to have an exact pair such that they are basically indistinguishable.
Just so I can understand the use case....Are the RB925ui-5ac2nD the ones that you want to force a primary? There is a physical antenna you are connecting to the RB925ui-5ac2nD for which you only have one? I'm not following how a redundant switch would come into play here, if you had it.
PS: You are also the only one that I know of that I can recall that isn't using CCRs with ha-mikrotik. Please let me know if you run into anything that feels odd.
ovidiu
Mon Feb 05, 2018 6:42 pm
Hi Nathan,
No, i used RB925ui-5ac2nD just for lab tests without activating wifi. They will be connected to the redundant RB3011UiAS-RM
Please understand that we are talking about a very small office with only about 15-16 people + some visitors quite often. There is no point to buy CCR. I agree that your script is perfect in a normal situation where everything should be redundant. As I explained, there is a wireless link for offsite copy of backups. To be fully redundant i should connect it through a redundant switch. But hey, I don't care about offsite copy of backups. Of course I can plug it to the normal switch where all computers are connected, but I was thinking to block LAN access to the backup using the router.
I know I can remotely restart the master so the slave will take over and since we have good on-line UPS they won't flip for long time.
So Nathan, if we can change something easy to your script would be excellent, but is not a must. I can live very happy the way it is.
Bty, in case of power fail, I found a solution: in System > Routerboard > Settings there is a menu "boot delay" witch seams that doesn't synchronize. I set higher time for router B and now every time the router A start first as master.
nathan1
Mon Feb 05, 2018 7:02 pm
No problem not using CCRs, they are definitely expensive for many deployments. I just wanted to let you know that you are the first one that I know of to test alternative platforms, so good for all of us. I would like to hear how well it works for you after you run for a while.
The boot delay sounds like a great solution if you just want one to always become primary when they are both booted nearly simultaneously (i.e. after power recovery). This wouldn't force A to become primary again after A was primary and then rebooted but that is the feature I could add if you really wanted it. I think this could work based on a pretty simply change that enables VRRP preemption.
It sounds like you have found a pretty workable solution though. Maybe you run it for a while and then see if you generally find it stable and if you still want this feature after a while of running, I will add it. How does that sound?
ovidiu
Mon Feb 05, 2018 7:25 pm
Yes Nathan, I'm sure will be fine for long time. I will let you know when I will put them into production (now I run them at my home). I have to implement some VPN solution and hope to find a way to allow access only from some countries, geoip. After that I will plug them into the rack.
Some other feature would be great: to receive email in case that one router is out for more than few minutes. Suppose that one of the routers have a problem. I will never know without to manually check the state.
bbs2web
Sun Feb 11, 2018 2:43 am
Many thanks, you've saved me days! I tested this on virtualised routers first and had a problem that all interfaces would get disabled, including the VRRP parent, until I hashed out the following line in the ha_startup script:
/system routerboard settings set silent-boot=yes
It's a virtual x86, so it made sense that it failed. I additionally reduced the subnet in the ha_config from /24 to /29. The ha_switchrole script appears to have hardcoded values, which don't match the settings from ha_config, so I set the HA sync interface and then assume it should ping the slave (169.254.23.2), right?
I see no references to the scripts using telnet or ssh so I additionally stopped it restricting those protocols to the HA addresses:
Edited ha_startup script from:
:foreach service in [:toarray "ftp,telnet,ssh"] do={
to:
:foreach service in [:toarray "ftp"] do={
Excellent work, we typically implement redundancy using OSPF, BGP and/or VRRP but bridging VPLS tunnels and retrofitting redundancy on complicated routers with allot of /30 subnets is very easy using the collection of scripts you're written!
Mikrotik should really incorporate your work as a heartbeat HA function, instead of wasting time on kid control...
nathan1
Sun Feb 11, 2018 3:02 am
Hey bbs2web,
Nice work debugging it for your platform. We can put a an on-error around the silent-boot so it works correctly in both cases.
I assume you changed the VRRP address as well when you changed it to a /29? I'd only be reluctant to switch it to a /29 since it won't cover what I have used for the .10 VRRP address since it was created. I guess we can go with a /28 if you feel that you really want to shrink the /24.
I adjust the rules for all 3 services to make sure that the other device can always be used to manually access all of the services. It is more of a management/debugging tool when something might go wrong vs. part of ha-mikrotik automation.
Good catch on the switchrole, it is actually a script I very rarely use and wasn't intended to be committed. It needs to be changed to use $haOtherAddress and $haInterface rather than the fixed IP and interface.
Is it generally working well for you on x86? How long does it take for an ha_pushbackup to slave to boot back up?
It's a virtual x86, so it made sense that it failed. I additionally reduced the subnet in the ha_config from /24 to /29. The ha_switchrole script appears to have hardcore values which don't match the settings from ha_config so I set the HA sync interface and then assume it should ping the slave (169.254.23.2), right?
to:
bbs2web
Sun Feb 11, 2018 8:46 pm
Hi Nathan,
Booting a x86 virtual takes approximately 40 seconds. I converted a customer's active backup routers that we were maintaining, with about 70 individual vrrp interfaces to your ha system. Entire process took about 30 minutes and the process is elegantly simple.
No longer have to work with /29 subnets everywhere and no longer have to do everything twice.
Yes, I made first master 169.254.23.1/29, the initial slave 169.254.23.2/29 and the floating vrrp ip 169.254.23.3.
I'm implementing this on two pairs of CCR1036 routers, at a financial institution, during their maintenance window tomorrow morning. They already have a spanning tree mess, with their Cisco stack running RPVST+ and their HyperV environment running with switches in MSTP mode. This way they have 10 seconds failover redundancy for bridged vlans using VPLS between their primary and DR site.
The client has PCI DSS and ISO compliance tests scheduled in the next 45 days. Confident that everything works!
Really, really excellent work, well done and thank you!
bbs2web
Sun Feb 18, 2018 9:40 am
Would you please consider accepting the following patch, it does the following:
  • Changes '] > ' to stop rancid (configuration revision management) matching it to the RouterOS prompt.
  • Changes netmask from /24 to /29 and moved VRRP IP from .10 to .3.
  • Set schedulers' start date to Unix Epoch (Jan/01/1970).
  • Set schedulers' intervals and start time to prevent overlapping.
  • Only change FTP service, prevents SSH not being reachable on master or enabling Telnet.
  • Replaces hard coded values with variables.
  • Disables adding default route (makes loopback interfaces reachable).
  • Disables silencing Routerboard boot process by default and handle errors (eg VM)
--- HA_init.rsc 2018-02-18 08:54:22.000000000 +0200
+++ ../../HA_init.rsc   2018-02-18 09:32:25.000000000 +0200
@@ -1,7 +1,7 @@
 :do {
 /system script
 remove [find name=ha_checkchanges_new]
-add name=ha_checkchanges_new owner=admin policy=ftp,reboot,read,write,policy,test,password,sniff,sensitive source=":if ([:len [/system script job find where script=\"ha_checkchanges\"]] > 1) do={:error \"already running checkchanges\"; } \
+add name=ha_checkchanges_new owner=admin policy=ftp,reboot,read,write,policy,test,password,sniff,sensitive source=":if ([:len [/system script job find where script=\"ha_checkchanges\"]]  > 1) do={:error \"already running checkchanges\"; } \
        \n:global isMaster\
        \n:global isStandbyInSync\
        \n:global haPassword\
@@ -39,11 +39,11 @@
 remove [find name=ha_config_new]
 add name=ha_config_new owner=admin policy=ftp,reboot,read,write,policy,test,password,sniff,sensitive source="/system script run [find name=\"ha_config_base\"]\
        \n:global haNetwork \"169.254.23.0\"\
-       \n:global haNetmask \"255.255.255.0\"\
-       \n:global haNetmaskBits \"24\"\
+       \n:global haNetmask \"255.255.255.248\"\
+       \n:global haNetmaskBits \"29\"\
        \n:global haAddressA \"169.254.23.1\"\
        \n:global haAddressB \"169.254.23.2\"\
-       \n:global haAddressVRRP \"169.254.23.10\""
+       \n:global haAddressVRRP \"169.254.23.3\""
 remove [find name=ha_functions_new]
 add name=ha_functions_new owner=admin policy=ftp,reboot,read,write,policy,test,password,sniff,sensitive source=":global HADebug do={\
        \n   :put \$1\
@@ -103,7 +103,7 @@
        \n   :error \"Are you sure the other device is configured properly? I am unable to ping MAC \$pingMac\"\
        \n}\
        \n\
-       \n:if ([:len [/ip address find where interface=\"\$haInterface\" and comment!=\"HA_AUTO\"]] > 0) do {\
+       \n:if ([:len [/ip address find where interface=\"\$haInterface\" and comment!=\"HA_AUTO\"]]  > 0) do {\
        \n   :error \"Interface \$haInterface has IP addresses. HA should completely own the interface and it cannot be used by anything else. Please correct\"\
        \n}\
        \n\
@@ -155,7 +155,7 @@
        \n:execute \"ha_setidentity\"\
        \n:do { :local k [/system script find name=\"on_master\"]; if ([:len \$k] = 1) do={ /system script run \$k } } on-error={ :put \"on_master failed\" }"
 remove [find name=ha_pushbackup_new]
-add name=ha_pushbackup_new owner=admin policy=ftp,reboot,read,write,policy,test,password,sniff,sensitive source=":if ([:len [/system script job find where script=\"ha_pushbackup\"]] > 1) do={:error \"already running pushbackup\"; } \
+add name=ha_pushbackup_new owner=admin policy=ftp,reboot,read,write,policy,test,password,sniff,sensitive source=":if ([:len [/system script job find where script=\"ha_pushbackup\"]]  > 1) do={:error \"already running pushbackup\"; } \
        \n:global isMaster\
        \n:global haAddressOther\
@@ -247,7 +247,7 @@
        \n}\
        \n/log warning \"ha_startup: 0.3\"\
        \n/interface ethernet disable [find]\
-       \n:global haStartupHAVersion \"0.2alpha - ea961767e45b63b81aac87eed37301d8b70bedf7\"\
+       \n:global haStartupHAVersion \"0.2alpha - 858dc62b5a9e215a5e5896137a053d01d16695c6\"\
        \n:global isStandbyInSync false\
        \n:global isMaster false\
@@ -268,7 +268,7 @@
        \n/system scheduler remove [find comment=\"HA_AUTO\"]\
        \n\
        \n#Pause on-error just in case we error out before the spin loop - hope 5 seconds is enough.\
-       \n/system scheduler add comment=HA_AUTO name=ha_startup on-event=\":do {:global haInterface; /system script run [find name=ha_startup]; } on-error={ :delay 5; /interface ethernet disable [find default-name!=\\\"\\\$haInterface\\\"]; /log error \\\"ha_startup: FAILED - DISABLED ALL INTERFACES\\\" }\" policy=ftp,reboot,read,write,policy,test,password,sniff,sensitive start-time=startup \
+       \n/system scheduler add comment=HA_AUTO name=ha_startup on-event=\":do {:global haInterface; /system script run [find name=ha_startup]; } on-error={ :delay 5; /interface ethernet disable [find default-name!=\\\"\\\$haInterface\\\"]; /log error \\\"ha_startup: FAILED - DISABLED ALL INTERFACES\\\" }\" policy=ftp,reboot,read,write,policy,test,password,sniff,sensitive start-date=Jan/01/1970 start-time=startup \
        \n\
        \n#/interface ethernet reset-mac-address\
        \n/ip address remove [find interface=\"\$haInterface\"]\
@@ -315,8 +315,8 @@
        \n   }\
        \n}\
        \n\
-       \n/ip route remove [find comment=\"HA_AUTO\"]   \
-       \n/ip route add gateway=\$haAddressOther distance=250 comment=HA_AUTO\
+       \n#/ip route remove [find comment=\"HA_AUTO\"]   \
+       \n#/ip route add gateway=\$haAddressOther distance=250 comment=HA_AUTO\
        \n\
        \n/log warning \"ha_startup: 4\"\
        \n\
@@ -337,10 +337,10 @@
        \n/ip address add address=\$haAddressVRRP netmask=255.255.255.255 interface=HA_VRRP comment=\"HA_AUTO\"\
        \n\
        \n/log warning \"ha_startup: 6\"\
-       \n/system scheduler add comment=HA_AUTO interval=30m name=ha_exportcurrent on-event=\"/export file=\\\"HA_current.rsc\\\"\" policy=ftp,reboot,read,write,policy,test,password,sniff,sensitive start-date=jan/20/2000 start-time=22:37:10\
-       \n/system scheduler add interval=10m name=ha_checkchanges on-event=ha_checkchanges policy=ftp,reboot,read,write,policy,test,password,sniff,sensitive start-date=jan/1/2000 start-time=18:00:30 comment=HA_AUTO\
+       \n/system scheduler add comment=HA_AUTO interval=10m name=ha_exportcurrent on-event=\"/export file=\\\"HA_current.rsc\\\"\" policy=ftp,reboot,read,write,policy,test,password,sniff,sensitive start-date=Jan/01/1970 start-time=00:05:00\
+       \n/system scheduler add interval=10m name=ha_checkchanges on-event=ha_checkchanges policy=ftp,reboot,read,write,policy,test,password,sniff,sensitive start-date=Jan/01/1970 start-time=00:10:00 comment=HA_AUTO\
        \n#Still need this - things like DHCP leases dont cause a system config change, we want to backup periodically.\
-       \n/system scheduler add comment=HA_AUTO interval=24h name=ha_auto_pushbackup on-event=ha_pushbackup policy=ftp,reboot,read,write,policy,test,password,sniff,sensitive start-date=jan/20/2000 start-time=05:00:00\
+       \n/system scheduler add comment=HA_AUTO interval=24h name=ha_auto_pushbackup on-event=ha_pushbackup policy=ftp,reboot,read,write,policy,test,password,sniff,sensitive start-date=Jan/01/1970 start-time=05:00:00\
        \n/log warning \"ha_startup: 7\"\
        \n:if ([:len [/file find name=\"HA_dsa\"]] = 1) do={\
        \n   /ip ssh import-host-key private-key-file=HA_rsa\
@@ -352,9 +352,9 @@
        \n/user add address=\"\$haNetwork/\$haNetmaskBits\" comment=HA_AUTO group=full name=ha password=\"\$haPassword\"\
        \n/log warning \"ha_startup: 8\"\
        \n#So you dont get annoyed with constant beeping\
-       \n/system routerboard settings set silent-boot=yes\
+       \n#:do {/system routerboard settings set silent-boot=yes} on-error={};\
        \n\
-       \n:foreach service in [:toarray \"ftp,telnet,ssh\"] do={\
+       \n:foreach service in [:toarray \"ftp\"] do={\
        \n   :local serviceAddresses \"\"\
        \n   :foreach k in=[/ip service get [find name=\$service] address] do={\
        \n      :if (\$k != \"\$haAddressA/32\" and \$k != \"\$haAddressB/32\" and \$k != \"\$haAddressVRRP/32\") do {\
@@ -365,7 +365,7 @@
        \n   /ip service set [find name=\$service] address=[:toarray \$serviceAddresses]\
        \n}\
        \n\
-       \n:if ([:len [/file find where name=\"HA_run-after-hastartup.rsc\"]] > 0) do {\
+       \n:if ([:len [/file find where name=\"HA_run-after-hastartup.rsc\"]]  > 0) do {\
        \n   /import HA_run-after-hastartup.rsc\
        \n}\
        \n/delay 5\
@@ -388,7 +388,7 @@
        \n   /system script run [find name=\"ha_pushbackup\"]\
        \n   :put \"delaying 60\"\
        \n   /delay 60\
-       \n   :if (\$isMaster && [/ping 169.254.23.3 count=1 interface=ether1 ttl=1] >= 1) do {\
+       \n   :if (\$isMaster && [/ping \$haAddressOther count=1 interface=\$haInterface ttl=1]  >= 1) do {\
        \n      :put \"REBOOTING MYSELF\"\
        \n      :execute \"/system reboot\"\
        \n   } else {\
diff -uNr scripts/ha_checkchanges.script ../../scripts/ha_checkchanges.script
--- scripts/ha_checkchanges.script      2018-02-17 11:58:46.000000000 +0200
+++ ../../scripts/ha_checkchanges.script        2018-02-17 12:35:29.000000000 +0200
@@ -1,4 +1,4 @@
-:if ([:len [/system script job find where script="ha_checkchanges"]] > 1) do={:error "already running checkchanges"; }
+:if ([:len [/system script job find where script="ha_checkchanges"]]  > 1) do={:error "already running checkchanges"; }
 :global isMaster
 :global haPassword
diff -uNr scripts/ha_config.script ../../scripts/ha_config.script
--- scripts/ha_config.script    2018-02-18 08:54:28.000000000 +0200
+++ ../../scripts/ha_config.script      2018-02-18 08:54:06.000000000 +0200
@@ -1,7 +1,7 @@
 /system script run [find name="ha_config_base"]
 :global haNetwork "169.254.23.0"
-:global haNetmask "255.255.255.0"
-:global haNetmaskBits "24"
+:global haNetmask "255.255.255.248"
+:global haNetmaskBits "29"
 :global haAddressA "169.254.23.1"
 :global haAddressB "169.254.23.2"
-:global haAddressVRRP "169.254.23.10"
\ No newline at end of file
+:global haAddressVRRP "169.254.23.3"
diff -uNr scripts/ha_install.script ../../scripts/ha_install.script
--- scripts/ha_install.script   2018-02-17 12:13:18.000000000 +0200
+++ ../../scripts/ha_install.script     2018-02-17 12:37:49.000000000 +0200
@@ -29,7 +29,7 @@
    :error "Are you sure the other device is configured properly? I am unable to ping MAC $pingMac"
-:if ([:len [/ip address find where interface="$haInterface" and comment!="HA_AUTO"]] > 0) do {
+:if ([:len [/ip address find where interface="$haInterface" and comment!="HA_AUTO"]]  > 0) do {
    :error "Interface $haInterface has IP addresses. HA should completely own the interface and it cannot be used by anything else. Please correct"
diff -uNr scripts/ha_pushbackup.script ../../scripts/ha_pushbackup.script
--- scripts/ha_pushbackup.script        2018-02-17 12:13:47.000000000 +0200
+++ ../../scripts/ha_pushbackup.script  2018-02-17 12:38:25.000000000 +0200
@@ -1,4 +1,4 @@
-:if ([:len [/system script job find where script="ha_pushbackup"]] > 1) do={:error "already running pushbackup"; }
+:if ([:len [/system script job find where script="ha_pushbackup"]]  > 1) do={:error "already running pushbackup"; }
 :global haPassword
 :global isMaster
diff -uNr scripts/ha_startup.script ../../scripts/ha_startup.script
--- scripts/ha_startup.script   2018-02-17 12:39:39.000000000 +0200
+++ ../../scripts/ha_startup.script     2018-02-18 09:32:33.000000000 +0200
@@ -35,7 +35,7 @@
 /system scheduler remove [find comment="HA_AUTO"]
-/system scheduler add comment=HA_AUTO name=ha_startup on-event=":do {:global haInterface; /system script run [find name=ha_startup]; } on-error={ :delay 5; /interface ethernet disable [find default-name!=\"\$haInterface\"]; /log error \"ha_startup: FAILED - DISABLED ALL INTERFACES\" }" policy=ftp,reboot,read,write,policy,test,password,sniff,sensitive start-time=startup
+/system scheduler add comment=HA_AUTO name=ha_startup on-event=":do {:global haInterface; /system script run [find name=ha_startup]; } on-error={ :delay 5; /interface ethernet disable [find default-name!=\"\$haInterface\"]; /log error \"ha_startup: FAILED - DISABLED ALL INTERFACES\" }" policy=ftp,reboot,read,write,policy,test,password,sniff,sensitive start-date=Jan/01/1970 start-time=startup
 /ip address remove [find interface="$haInterface"]
@@ -82,8 +82,8 @@
-/ip route remove [find comment="HA_AUTO"]
-/ip route add gateway=$haAddressOther distance=250 comment=HA_AUTO
+#/ip route remove [find comment="HA_AUTO"]
+#/ip route add gateway=$haAddressOther distance=250 comment=HA_AUTO
 /log warning "ha_startup: 4"
@@ -104,10 +104,10 @@
 /ip address add address=$haAddressVRRP netmask=255.255.255.255 interface=HA_VRRP comment="HA_AUTO"
 /log warning "ha_startup: 6"
-/system scheduler add comment=HA_AUTO interval=30m name=ha_exportcurrent on-event="/export file=\"HA_current.rsc\"" policy=ftp,reboot,read,write,policy,test,password,sniff,sensitive start-date=jan/20/2000 start-time=22:37:10
-/system scheduler add interval=10m name=ha_checkchanges on-event=ha_checkchanges policy=ftp,reboot,read,write,policy,test,password,sniff,sensitive start-date=jan/1/2000 start-time=18:00:30 comment=HA_AUTO
+/system scheduler add comment=HA_AUTO interval=10m name=ha_exportcurrent on-event="/export file=\"HA_current.rsc\"" policy=ftp,reboot,read,write,policy,test,password,sniff,sensitive start-date=Jan/01/1970 start-time=00:05:00
+/system scheduler add interval=10m name=ha_checkchanges on-event=ha_checkchanges policy=ftp,reboot,read,write,policy,test,password,sniff,sensitive start-date=Jan/01/1970 start-time=00:10:00 comment=HA_AUTO
-/system scheduler add comment=HA_AUTO interval=24h name=ha_auto_pushbackup on-event=ha_pushbackup policy=ftp,reboot,read,write,policy,test,password,sniff,sensitive start-date=jan/20/2000 start-time=05:00:00
+/system scheduler add comment=HA_AUTO interval=24h name=ha_auto_pushbackup on-event=ha_pushbackup policy=ftp,reboot,read,write,policy,test,password,sniff,sensitive start-date=Jan/01/1970 start-time=05:00:00
 /log warning "ha_startup: 7"
 :if ([:len [/file find name="HA_dsa"]] = 1) do={
@@ -119,9 +119,9 @@
 /user add address="$haNetwork/$haNetmaskBits" comment=HA_AUTO group=full name=ha password="$haPassword"
 /log warning "ha_startup: 8"
-/system routerboard settings set silent-boot=yes
+#:do {/system routerboard settings set silent-boot=yes} on-error={};
-:foreach service in [:toarray "ftp,telnet,ssh"] do={
+:foreach service in [:toarray "ftp"] do={
    :local serviceAddresses ""
    :foreach k in=[/ip service get [find name=$service] address] do={
       :if ($k != "$haAddressA/32" and $k != "$haAddressB/32" and $k != "$haAddressVRRP/32") do {
@@ -132,7 +132,7 @@
    /ip service set [find name=$service] address=[:toarray $serviceAddresses]
-:if ([:len [/file find where name="HA_run-after-hastartup.rsc"]] > 0) do {
+:if ([:len [/file find where name="HA_run-after-hastartup.rsc"]]  > 0) do {
 /delay 5
diff -uNr scripts/ha_switchrole.script ../../scripts/ha_switchrole.script
--- scripts/ha_switchrole.script        2018-02-17 12:14:19.000000000 +0200
+++ ../../scripts/ha_switchrole.script  2018-02-18 09:17:57.000000000 +0200
@@ -4,7 +4,7 @@
    /system script run [find name="ha_pushbackup"]
    :put "delaying 60"
    /delay 60
-   :if ($isMaster && [/ping 169.254.23.3 count=1 interface=ether1 ttl=1] >= 1) do {
+   :if ($isMaster && [/ping $haAddressOther count=1 interface=$haInterface ttl=1]  >= 1) do {
       :put "REBOOTING MYSELF"
       :execute "/system reboot"
    } else {
bbs2web
Sun Feb 18, 2018 3:10 pm
The following patch keeps the HA heartbeat and configuration synchronisation interface's original MAC address on both routers. Not necessary on hardware routers with a direct point-to-point network cable but necessary when working with virtual guests or where HA interfaces connect via switch:
+++ ../../scripts/ha_startup.script     2018-02-18 15:01:54.000000000 +0200
@@ -37,9 +37,9 @@
-#/interface ethernet reset-mac-address
+/interface ethernet reset-mac-address [find default-name="$haInterface"]
 /ip address remove [find comment="HA_AUTO"]
 /interface vrrp remove [find name="HA_VRRP"]
nathan1
All sound good and I will integrate them but two questions:
Nice catch on rancid, it actually impacts me as well. I think we need to fix rancid and give it a stricter prompt for export. Even if we escape ha-mikrotik, it will still break rancid if there is any other script on the devices that use ] >.
Can you try the below patch to rancid and see how it works for you?
Can you help me understand the "Disables adding default route" and how it interacts with the loopbacks for you?
I actually use the default because I have a MASQUERADE rule in my setup that allows the ha-mikrotik network to get out to the internet. I do this to test RouterOS upgrades: I login to the standby, do a RouterOS upgrade, then do a push from the primary, check if the standby looks right, then switch roles and repeat on the new secondary (old master).
Additionally, I've been thinking about giving the secondary a stable known address in addition to the floating ones (ie: .3 is always master, .4 is always secondary). If I do this, it would allow for a NAT setup to allow easier external access to the secondary for monitoring. Additionally, maybe an simple that can be used with the Mikrotik SNMP script GET to monitor the state of the pair. Any thoughts on how you might want to monitor the secondary in general?
--- mtrancid.orig	2018-02-18 07:55:03.199828386 -0500
+++ mtrancid	2018-02-18 07:55:20.856371114 -0500
@@ -235,9 +235,13 @@
 	print STDERR "    In Export: $_" if ($debug);
 	my $buffer = "";
+    #Be much stricter on the quit prompt when exporting. If scripts contain ] > then it is incorrectly terminated early.
+    my $prompt_quit = "${prompt}quit\$";
+	print STDERR "    Quit prompt for export: $prompt_quit\n" if ($debug);
 	while (<INPUT>) {
 		tr/\015//d;
-		if (/$prompt/) { $found_end=1; $clean_run=1; return 0};
+		if (/$prompt_quit/) { $found_end=1; $clean_run=1; return 0};
 		next if(/^(\s*|\s*$cmd\s*)$/);
 		next if(/^#/);
 		return(1) if /(bad command name )/;
nathan1
Sun Feb 18, 2018 4:50 pm
With regard to changing to a /29...we are going to need a better upgrade procedure. Upgrades (rather undocumented) have always consisted of basically just doing an /import HA_init.rsc, pushing, switch roles, push, done. If we change the default VRRP addressing and then use this method then this will break all existing users that use the /24. The secondary ends up taking over and they never reconcile their differences and end up in a reboot loop.
I agree that the user should be able to select their own network but I think I'd rather do it with the existence of an alternate configuration that overrides the standard configuration.
It can also be done as extra parameters to $HAInstall to make it easier to deploy clusters that are similar.
Would this work for you?
PS: Any interest in taking this to the github project so we can track the features/issues a little cleaner?
bbs2web
Sun Feb 18, 2018 4:56 pm
I centralise logging and was receiving SMS messages indicating loss of BGP peers. This was due to me originating syslog messages from the loopback IPs, which would then route out:
/system logging action
set 3 remote=54.119.65.26 src-address=54.79.22.1
I prefer having the standby router exclusively accessible via the acting master, PuTTY's tunneling features really help with this...
I hear your point about having predictable master/slave IPs, but currently handle standby router monitoring by getting notified if the HA interface on the acting master is down two checks in a row (we run Zabbix and have automated discovery which notifies us of any interface which is down when it was ever up). This way I simply need to know that the HA interface is operational and it will not send notifications if it happens to get checked whilst rebooting).
I understand your more conservative approach to RouterOS updates. I had:
  • Upgraded acting master, which switches it to standby mode
  • Connected to new standby router, upgraded firmware to complete the process and rebooted
  • Validated configuration via mac telnet
  • Repeated the steps above on the current master
bbs2web
Sun Feb 18, 2018 5:01 pm
Perfect, I'll have some time tomorrow to fiddle with Rancid and agree that discussing this on Github is probably better. Perhaps I should break up the patch in to separate ones, where each one handles a specific point?
nathan1
Sun Feb 18, 2018 5:20 pm
Let's pick it up from here on github.
I have integrated your changes into a test branch for us: https://github.com/svlsResearch/ha-mikr ... bs2webtest
Issues created for the exclusions: https://github.com/svlsResearch/ha-mikrotik/issues
Excluded for now:
  • No rancid escape fix here. If you still want to do this escaping, let's do it with the generate script. The rancid fix appears to be working OK for me though.
  • Kept the default gateway for now. I understand your use case though, you don't want your secondary getting out.
  • Keeps original /24 addressing until we can sort out the ha-mikrotik upgrade path.
ovidiu
Tue Mar 06, 2018 8:54 am
2 week passed without any problem, the delayed startup ensure the desired router to be the active one.
So this script is working fine on smaller routers as well.
millenium7
Thu Aug 30, 2018 2:57 am
Anyone tested and confirmed this works exactly as expected on 6.42.x ?
We're running this on a couple of routers in a data center and it seems to work fine. However 2 problems i've noticed and I don't know if they are an issue with the later firmware or something going on with the script
1) I can't seem to make either of them a preemptive Master. I've tried adjusting VRRP priorities but if I reboot A and then B takes over, A will never be master until B reboots. We would rather have A always be the active master if it's online
2) I noticed the VRRP instance flaps a lot. I currently have B totally disconnected because it was flapping every few hours. We've tried changing ethernet cables and the same problem still happens. This is a big problem because these routers run BGP as well as PPPoE connections, resulting in extended downtime during a change over. Fine if we have an actual router failure, but not fine during normal day to day operation. There doesn't appear to be a physical interface issue, i'm not sure if its VRRP or the script. Can I just increase the VRRP timers to start with? (Won't break anything on the script or pairs?)
I also have another question regarding firmware updates. Is there any special care that must be taken? i.e. do I need to update both routers at same time or can I do 1, bring it online, reboot the other so the one with latest firmware becomes active, check everything is working fine and then update the backup?
nathan1
Thu Aug 30, 2018 3:42 am
I have not been able to test it on 6.42.x just yet, you may be the first. It is on my todo list. VRRP should not be flapping at all - are they directly connected or are you going via a switch? anything interesting in the logs? Were you running 6.38.x before going to 6.42.x? Did you have any of this VRRP flapping before or is this new? What does the CPU load look like? My units are not very heavy on CPU load, I wonder if your timers are slipping from other loads (BGP? high PPPoE count?)
Regarding preempting, this is by design. Since ha-mikrotik is not stateful, it is rather expensive to keep switching masters (ie: VPN users disconnected 2x), so I made it this way intentionally. Others have asked about preemption but nobody seemed bothered by it enough to warrant it being implemented. See my note below on the VRRP interval on why your change may not have stuck.
As far as firmware upgrades go, I have always done it by upgrading the standby and then checking if it looks right and then doing the master, sometimes forcing sync and then doing another reboot before letting the upgraded guy takeover. Since ha-mikrotik is not supported by Mikrotik themselves, it is somewhat of a crapshoot but I have had general good success. I have many pairs running this code so I generally pick the pair that won't be catastrophic if something goes wrong for the upgrade test.
For changing the VRRP interval, you would want to edit the ha_startup script on the master (look for line after "ha_startup: 5") and then sync the standby and then reboot the master after the standby reboots. If you get the timers out of sync, I believe they will ignore each other and both become master. You can't do this via the VRRP interfaces, as they will be removed and rebuilt on every boot.
I hope this helps.
hamster
Wed Oct 03, 2018 5:44 am
I've just installed this on two x86, version 6.42.9... So far, so good. Thanks for this!
Quick question, if I may: why is it neccessary to reboot the standby router once it receives new configuration?
nathan1
Wed Oct 03, 2018 3:07 pm
"/system backup load" is used to keep the general configuration in sync, which requires a reboot.
millenium7
Thu Feb 21, 2019 9:22 am
So we have had a hardware failure on one of the routers and this script saved us a lot of downtime
However now comes the time to replace with another router. I have an identical model here
There are no instructions on what to do to bring a new standby router back into the mix (preferably without any downtime). Do I simply install the new backup router, connect the 2 via ether8 then run the ha_init script on the existing router once again and do through the same procedure?
Or is there something else I need to do only on the new backup to bring it in
Will it know to keep the existing primary config, and not override the primary with the backup?
Can this be done with little to no downtime?
nathan1
Thu Feb 21, 2019 12:00 pm
Correct, basically replace it and connect it physically like the old one. The replacement should be running the same RouterOS and reset-configuration per original docs. You will then $HAInstall like you originally did, changing the MAC of B (or A) and then following the on screen instructions for bootstrapping.
This can done live and with no downtime, the script should not do anything on the master when it discovers it is already master.
Do you have A or B alive right now? Assuming it is A, you can do something like this and follow the instructions:
$HAInstall interface=$haInterface macA=$haMacMe macB="[NEW MAC FOR B]" password=$haPassword
If it is B:
$HAInstall interface=$haInterface macB=$haMacMe macA="[NEW MAC FOR A]" password=$haPassword
This just pulls the global variables (the current config) for redeployment, you could also just populate them all again with constants like you originally did.
Try this just to see how your variables will populate (it only prints):
:put "interface=$haInterface macA=$haMacA macA=$haMacB macMe=$haMacMe password=$haPassword"
millenium7
Tue Feb 26, 2019 5:20 am
Awesome, i'll give it a go next time i'm at the DC but backup beforehand. Thanks
raffav
Sat Mar 02, 2019 5:32 pm
Wow, this project still alive...
Good I never had a chance to put it in production..
But very nice
Sent from my XT1580 using Tapatalk
christopherh
Mon Mar 18, 2019 10:10 am
Hello All,
I've followed the instructions from 1 to 8 on the GitHub page, however before $HAInstall gives me the info to bootstrap the second router, it reboots and kicks me out.
How do I bootstrap the second router?
Thanks,
Christopher H.
**EDIT: I worked it out - had to re-run the $HAInstall command to generate the commands to bootstrap the second router.
millenium7
Mon Mar 25, 2019 1:29 am
Went to change out the dead router and noticed MikroTik has a new hardware revision of CCR series which require 6.43.5 as the minimum RouterOS version and cannot be downgraded any further. I've read on the github page there's a known bug with 6.43.x and its causing reboots and intermittent issues
Can anyone confirm if this has been fixed?
nathan1
Mon Mar 25, 2019 1:52 am
Interesting. I will begin testing some newer versions and let you know if they look stable.
nathan1
Mon Mar 25, 2019 2:02 am
I have deployed 6.43.13 to a pair and I will report back if it appears stable.
raystream
Mon Mar 25, 2019 10:33 am
how can i do a software upgrade after installing your ha sytem?
Just update the primary and then the secondary goes active when the primary reboots
after that upgrade the second one
will the patch be still there after upgrade?
nathan1
Mon Mar 25, 2019 2:23 pm
Yes, this is the easiest way to do it, if you don't mind the extra reboots of the active router. If you want to reduce the reboots of the active and test a little, you can upgrade the standby (login with /system ssh $haAddressOther from the active) and then test $HASyncStandby (and $HAPushStandby) from the active once the standby comes back from the upgrade.
Make sure you are upgrading to a version that you know to work.
nathan1
Mon Mar 25, 2019 4:24 pm
Please see this issue on github for folks looking for updates on newer RouterOS: https://github.com/svlsResearch/ha-mikrotik/issues/7
TLDR: 6.43.13 is testing well so far. See more on the github issue.
nathan1
Tue Mar 26, 2019 2:27 pm
6.43.13 is going to require that you upgrade ha-mikrotik before you upgrade to 6.43.13 to safely use. The existing code will not work reliably. The fixed code is still being tested and I expect it will be tested/working within a few days, please check here for updates: https://github.com/svlsResearch/ha-mikrotik/issues/7
I will make a new release of ha-mikrotik on github once testing is complete.
millenium7
Tue Mar 26, 2019 2:43 pm
You're a legend for following up with this so quickly and in depth. Thank you very much
I'll wait for the tested update
nathan1
Thu Mar 28, 2019 5:15 pm
This is the rc1 for 6.42.11 / 6.43.13 / 6.44.1 and I expect it to be the final release. I am now running it on 6 pairs in production.
If anyone wants to test this on their lab setup and report back, please do:
https://github.com/svlsResearch/ha-mikr ... ag/v0.6rc1
Following along from this issue:
I will stamp v0.6 tomorrow.
@millenium7 You mentioned a new hardware release of the CCR model you had. I don't have any of this updated gear, is it done as the same exact model # (/system routerboard print)?
nathan1
Thu Mar 28, 2019 5:45 pm
See prior post but specifically for you, since you are dealing with recovering a failed standby, I wanted to double check that it still works as expected and write some docs.
I just simulated a hardware failure on a standby:
/file remove [find]; /system reset-configuration keep-users=no no-defaults=yes skip-backup=yes
I then did a rebuild based on the instructions I published here and it was all set and worked well: https://github.com/svlsResearch/ha-mikr ... ed-standby
For you, I would recommend that you upgrade your new standby to v6.43.13 or v6.44.1 and then follow the above procedure. Once you confirm the standby looks good and is rebuilt, do a $HASwitchRole to have the standby takeover. You can now upgrade the standby (original active) to the same RouterOS version you have on the replaced hardware and get everything consistent.
If you have any questions, let me know. I know you are going to wait for the final release, which is fine. Instructions remain the same.
millenium7
Thu Mar 28, 2019 11:51 pm
CCR1036-8G-2S+ on both but the new one has a normal USB port, 2x AC input and RJ45 console port
Unsure of any other changes internally
millenium7
Thu Mar 28, 2019 11:57 pm
One thing that's not so clear in your rebuild instructions
[NEW MAC FOR A]
Because you say 'FOR' A. Do you mean the new MAC you are going to give out, or put in the existing MAC that A has?
I.e.
OldA (dead)
- Ether1: 11:11:11:11:11:11
- Ether8: 11:11:11:11:11:18
OldB
- Ether1: 22:22:22:22:22:21
- Ether8: 22:22:22:22:22:28
NewA
- Ether1: 33:33:33:33:33:31
- Ether8: 33:33:33:33:33:38
So do I put in 11:11:11:11:11:18 or 33:33:33:33:33:38 when running $HAInstall on OldB?
And would that cause NewA's MAC addresses to be used on OldB. Or would it make NewA use the MAC addresses of OldB?
If its the former wouldn't that cause downtime as all MAC addresses would change?
nathan1
Fri Mar 29, 2019 12:10 am
[NEW MAC FOR A]
I.e.
OldA (dead)
OldB
NewA
You would put in 33:33:33:33:33:38 (new device ether8 MAC), this is the one you would see in /ip neighbor print with ether8 connected between them.
These MACs are not used for assignment, they are only used to detect which device is which during initialization. There should be no downtime, even if you get them wrong (assuming you don't get them wrong and then reboot the current working one).
Take a look here at ha_startup to see how the MACs are used to determine A vs B at startup and only at startup:
https://github.com/svlsResearch/ha-mikr ... script#L87
Does that answer your question?
PS: Also just updated github to include different wording, similar to the install wording (MAC_OF_A_ETHER8).
millenium7
Fri Mar 29, 2019 12:13 am
It does yes. Can I suggest changing the wording though?, 'FOR A' implies the mac you are giving it
Maybe 'NEW MAC OF A' is clearer?
nathan1
Fri Mar 29, 2019 12:19 am
Definitely. I just changed it to be consistent with the original installation instructions. Let me know if you think it still needs more clarification.
nathan1
Fri Mar 29, 2019 12:58 pm
Do not proceed with the upgrade, hopefully you did not use rc1. There is an issue after ~24 hours of runtime with the new RouterOS that I am trying to debug.
Problem is with RouterOS (old versions still appear stable with new ha-mikrotik) but newer ones have a problem.
millenium7
Fri Mar 29, 2019 1:38 pm
Havn't updated yet. In the meantime we're waiting for our old device to get back from an RMA request, new one not going in yet and probably won't as i'm unsure of any config differences. I know for instance the new one has 2x SFP+ instead of 1x SFP+ and 1x SFP so that could cause an issue. But do still want to run the latest MikroTik firmware on this pair if possible. 6.44 does have some improvements that are useful to us
I'll wait until its confirmed working. Once again thanks for going out of your way to actually bug test this
nathan1
Fri Mar 29, 2019 2:21 pm
Sounds good. Take a look at the latest update on the github issues, if you haven't. I believe the problem is an out of memory caused by another script that I run that is misbehaving with 6.44, so everything is still looking good for ha-mikrotik on the newer OS. Will definitely know more in a day or two.
I do agree, I thought it was odd that they changed up the hardware and didn't rev the model number. I always run ha-mikrotik pairs with the exact same hardware. I keep spares of my original CCR that I use to swap out when needed.
nathan1
Mon Apr 01, 2019 5:27 pm
v0.6 is stamped. Everything has been stable for multiple days now.
https://github.com/svlsResearch/ha-mikrotik/releases
danypd69
Wed Apr 17, 2019 12:08 am
Hello, I am trying to use the scripts with two routers (1100Hx2 and 1100Dx4) with RouterOS version 6.44.2 but I am unable to make it working.
Are these models ok?
My problem is that after the initial $HAPushStandby any connection to the slave does not work anymore, if I try to do $HAPushStandby again to copy the configuration I get a connection failed error.
Here are the configuration (except scripts) of the routers
MASTER
# model = RouterBOARD 1100Dx4
# serial number = 735B078BE677
/interface vrrp
add interface=ether8 name=HA_VRRP on-backup=ha_onbackup on-master=ha_onmaster
set 0 default-vlan-id=0
set 1 default-vlan-id=0
set 2 default-vlan-id=0
set 3 default-vlan-id=0
set 4 default-vlan-id=0
set 5 default-vlan-id=0
set 6 default-vlan-id=0
set 7 default-vlan-id=0
set 8 default-vlan-id=0
set 9 default-vlan-id=0
set 10 default-vlan-id=0
set 11 default-vlan-id=0
set 12 default-vlan-id=0
set 13 default-vlan-id=0
set 14 default-vlan-id=0
set 15 default-vlan-id=0
add address=169.254.23.1/24 comment=HA_AUTO interface=ether8 network=\
    169.254.23.0
add address=169.254.23.10 comment=HA_AUTO interface=HA_VRRP network=\
    169.254.23.10
add address=192.168.0.9/24 interface=ether1 network=192.168.0.0
set servers=8.8.8.8
add action=accept chain=output comment=HA_AUTO out-interface=ether8
add action=accept chain=input comment=HA_AUTO in-interface=ether8
add distance=1 gateway=192.168.0.254
add comment=HA_AUTO distance=250 gateway=169.254.23.2
/ip service
set ftp address=169.254.23.1/32,169.254.23.2/32,169.254.23.10/32
/system clock
set time-zone-name=Europe/Rome
/system identity
set name=MikroTik_HA_A_ACTIVE
set silent-boot=yes
/system scheduler
add comment=HA_AUTO name=ha_startup on-event=":do {:global haInterface; /syste\
    m script run [find name=ha_startup]; } on-error={ :delay 5; /interface eth\
    ernet disable [find default-name!=\"\$haInterface\"]; /log error \"ha_star\
    tup: FAILED - DISABLED ALL INTERFACES\" }" policy=\
    ftp,reboot,read,write,policy,test,password,sniff,sensitive start-time=\
    startup
add comment=HA_AUTO name=ha_report_startup on-event=ha_report_startup policy=\
    startup
    "/export file=\"HA_current.rsc\"" policy=\
    ftp,reboot,read,write,policy,test,password,sniff,sensitive start-date=\
    jan/01/1970 start-time=00:05:00
add comment=HA_AUTO interval=10m name=ha_checkchanges on-event=\
    ha_checkchanges policy=\
    jan/01/1970 start-time=00:10:00
add comment=HA_AUTO interval=1d name=ha_auto_pushbackup on-event=\
    ha_pushbackup policy=\
    jan/01/1970 start-time=05:00:00
add dont-require-permissions=no name=ha_config_base owner=admin policy=\
    ftp,reboot,read,write,policy,test,password,sniff,sensitive source=":global\
    \_haPassword \"123451234512345\"\
    \n:global haInterface \"ether8\"\
    \n:global haMacA \"64:D1:54:FF:52:CA\"\
    \n:global haMacB \"D4:CA:6D:42:2D:86\""
SLAVE
# model = 1100Hx2
# serial number = 3E6A02BF6232
set [ find default-name=ether1 ] disabled=yes l2mtu=1592 mac-address=64:D1:54:FF:52:C4 name=ether2
set [ find default-name=ether2 ] disabled=yes l2mtu=1592 mac-address=64:D1:54:FF:52:C5 name=ether3
set [ find default-name=ether3 ] disabled=yes l2mtu=1592 mac-address=64:D1:54:FF:52:C6 name=ether4
set [ find default-name=ether4 ] disabled=yes l2mtu=1592 mac-address=64:D1:54:FF:52:C7 name=ether5
set [ find default-name=ether6 ] disabled=yes l2mtu=1592 mac-address=64:D1:54:FF:52:C9 name=ether7
set [ find default-name=ether7 ] disabled=yes l2mtu=1592 mac-address=64:D1:54:FF:52:CA name=ether8
set [ find default-name=ether8 ] l2mtu=1592 name=ether9
set [ find default-name=ether9 ] disabled=yes l2mtu=1592 mac-address=64:D1:54:FF:52:CC name=ether10
set [ find default-name=ether5 ] disabled=yes name=ether14
set [ find default-name=ether10 ] disabled=yes name=ether15
set [ find default-name=ether11 ] disabled=yes name=ether16
set [ find default-name=ether12 ] name=ether17
set [ find default-name=ether13 ] name=ether18
/interface vrrp
/interface ethernet switch
set 2 name=switch3
set 5 default-vlan-id=0 vlan-mode=fallback
set 6 default-vlan-id=0 vlan-mode=fallback
set 7 default-vlan-id=0 vlan-mode=fallback
set 8 default-vlan-id=0 vlan-mode=fallback
add address=169.254.23.2/24 comment=HA_AUTO interface=ether8 network=169.254.23.0
add address=169.254.23.10 comment=HA_AUTO interface=HA_VRRP network=169.254.23.10
add comment=HA_AUTO distance=250 gateway=169.254.23.1
/ip service
/system identity
set name=MikroTik_HA__STANDBY
set silent-boot=yes
/system scheduler
add comment=HA_AUTO name=ha_startup on-event=":do {:global haInterface; /system script run [find name=ha_startup]; } on-error={ :delay 5; /interface ethernet disab\
    le [find default-name!=\"\$haInterface\"]; /log error \"ha_startup: FAILED - DISABLED ALL INTERFACES\" }" policy=\
add comment=HA_AUTO name=ha_report_startup on-event=ha_report_startup policy=ftp,reboot,read,write,policy,test,password,sniff,sensitive start-time=startup
add comment=HA_AUTO interval=10m name=ha_exportcurrent on-event="/export file=\"HA_current.rsc\"" policy=\
    ftp,reboot,read,write,policy,test,password,sniff,sensitive start-date=jan/01/1970 start-time=00:05:00
add comment=HA_AUTO interval=10m name=ha_checkchanges on-event=ha_checkchanges policy=ftp,reboot,read,write,policy,test,password,sniff,sensitive start-date=\
add comment=HA_AUTO interval=1d name=ha_auto_pushbackup on-event=ha_pushbackup policy=ftp,reboot,read,write,policy,test,password,sniff,sensitive start-date=\
add dont-require-permissions=no name=ha_config_base owner=admin policy=ftp,reboot,read,write,policy,test,password,sniff,sensitive source=\
    ":global haPassword \"123451234512345\"\
Can someone tell me what I am doing wrong?
Daniele
nathan1
Wed Apr 17, 2019 12:36 am
Do not do this. Never try to use this without exactly the same hardware, you are going to run into some serious problems.
danypd69
Wed Apr 17, 2019 9:51 am
Ok, thanks for the info. I will try to get another router.
danypd69
Wed Apr 17, 2019 2:32 pm
Just a question ,should it work if i use two RB1100AHx4?
nathan1
Wed Apr 17, 2019 3:02 pm
I'm not sure I've seen anyone use RB1100 yet, most of us us the CCR line. If I remember correctly, someone did successfully run it on the RB750, which I think bodes well for you. You may be the first on the RB1100. I believe it should work and I'm willing to offer advice if something seems odd with it and the platform.
Edit: Look here viewtopic.php?t=110690#p640702 for someone that was using different RB models. I don't know if they went to production or not but did have it in the lab.
danypd69
Wed Apr 17, 2019 3:13 pm
Ok I will let you know what happens.
raffav
Fri Apr 26, 2019 2:40 pm
Nathan1
It's a long time when I had played with this.
So I don't know if have this already.
It's possible to have a public management ip active on the standby router?
If this already have ignore this post.
nathan1
Fri Apr 26, 2019 2:54 pm
Nathan1
Hey Raffav,
I do this with NAT from the master to the standby, there is nothing built in to do it. May I ask why you are looking to do this? Monitoring? I did not build anything in for this because the only use case I see is monitoring, you do not want to make any configuration changes on the standby. I really don't want to have any interface up except for the $haInterface on the standby, it makes for cleaner cutovers, which makes exposing a public IP via a different interface somewhat cumbersome.
Monitoring is a valid use case though, I figure folks can configure NAT for that though, if they want it. For example, I also have masquerading setup so the standby can deliver logs to my central syslog server.
Happy to help you figure something out that works for you, if you have a specific use case in mind.
jandres
Fri May 03, 2019 12:33 pm
Hi nathan1, I'm trying to put vrrp interface HA_VRRP on a bride, but i'm not be able to do this. Is it possible or not? Thanks,
nathan1
Fri May 03, 2019 9:27 pm
I have never tried nor would I recommend this. May I ask what the design is to require this?
jandres
Thu May 09, 2019 5:49 pm
It's a bit complicated to explain and my english is not so good.
I've made some changes to avoid that need, and all it's working fine.
Very great job Nathan1, congratulations
nathan1
Thu May 09, 2019 6:14 pm
Sounds great, glad you got it to work.
raffav
Fri May 10, 2019 3:49 am
Nathan1
Hey Raffav,
Monitoring, and like access inspection, for helth check,
Nat is not a good because you use the mastar as a entry point.
Think something like that,
Something went wrong on master, that trigger the swap but for some reasons both became master.(vrrp stop to receive vvrp protocol and trigger the swap)
How do you access the standby if you use Nat
nathan1
Fri May 10, 2019 4:22 am
Nathan1
Hey Raffav,
You should have serial out of band access to both devices. If you don’t, I really don’t suggest running this. Health inspections and monitoring are all viable via current master (NAT). If you ever have a double master situation, you really should have serial.
I’ve been running this for years and I’ve never had a situation like this, it doesn’t mean it won’t happen but it makes the entire setup more complicated. The standby is simply a slave device when it is waiting.
millenium7
Thu Jun 13, 2019 10:22 am
Do you run this on any routers other than 1009's?
I also want to ask if its normal behavior for the standby to regularly reboot? I don't know the exact interval but maybe once every 2 hours?
We were running the older version on 6.42.3 and aside from the standby rebooting it did seem to work fine for months. However we've had another issue come up, details are here viewtopic.php?f=3&t=149273
I don't think your script has anything to do with it. Infact I don't think you can make an interface stop transmitting any packets at all even if you try to. But it's either some sort of configuration, script issue perhaps due to the repeated reboots which could have corrupted something, firmware bug or hardware issue
Long story short is i've now upgraded the script, updated both routers to 6.44.3, then removed one of the routers and replaced with dual PSU version (same model number), so far stable but interval between issues is unknown, can be a couple hours or a full day
If we have this issue occur again will be replacing both routers with CCR1016's, have you run the script on those before?
nathan1
Thu Jun 13, 2019 1:11 pm
I exclusively use 1009s but I know others have tried with success using other devices. As always, make sure you have serial access and exactly matched pairs. It is normal for the standby to regularly reboot, it will happen automatically at least once a day (scheduled) and regularly if there is a configuration change on the primary. This is how the standby stays in sync.
The configuration changes are detected via: /system history print
If you look at that on the primary, you should find what configuration is changing regularly that causes the standby to reboot. The reboots are "normal reboots", it is scripted and shouldn't just be going down hard. If you find there is nothing in the system history but you are still seeing reboots, then it is something that probably needs to be looked into. The one daily reboot is a forced one regardless of the history but that should only happen once a day (you will see ha_auto_pushbackup in /system scheduler print)
Your issue with the transmitting is odd, I don't really see how ha-mikrotik could cause this. I still have 5+ pairs of CCR1009 running flawlessly for years with this process.
millenium7
Mon Jun 17, 2019 5:55 am
Ok. As I said I don't think its the script because I can't think of any way to even make an interface do that, even if intentionally trying
Good to know the reboots are a normal thing. It was happening more than once a day but knowing that its also caused by 'system history print' answers why because we have a script that removes and replaces RADIUS information regularly, and that shows up in the history log. So if I fix that script so it instead looks for a change before replacing rather than hard remove/add it should reduce the number of reboots
When there is a change detected in config, what is the procedure the standby router does to update its config?
Does it find the exact change and then input that command. Or does it do a backup/restore from the config on the active router?
nathan1
Mon Jun 17, 2019 6:13 am
It does a backup and restore along with copying files it finds on the filesystem. You should definitely try to reduce extraneous config changes.
millenium7
Mon Jun 17, 2019 10:08 am
I noticed the copying of files to be a problem. Is it possible for you to change that in your script to exclude anything beginning with 'log.' ?
Reason is I was logging to disk any errors to try and help troubleshoot the issues we were having when we couldn't catch it in time, but when the router rebooted, the new active would override the log files that were stored.
The issue we were/are having doesn't seem to log anything but the scripts I run to detect interface issues does and then the files get overwritten
nathan1
Mon Jun 17, 2019 2:20 pm
How are you logging it? Can you change the name to start with HA_? If you can, it will be excluded without any changes to the code.
millenium7
Tue Jun 18, 2019 6:04 am
Just with the default 'disk' action which creates file beginning with 'log.' then the sequence number, then ends in txt i.e.
log.0.txt and log.1.txt by default
The reason for logging to disk is incase connectivity is lost i.e. interfaces locking up, at least logs would be stored if theres no other way for the router to reach the internet
If these sorts of nuances were published on the github page it would have been helpful. I didn't know HA files weren't mirrored, if I had I would have changed the disk action to start with that (or just used different names for each routers logs)
Granted MikroTik should pull their finger out and write a proper High Availability module instead of wasting time on stupid crap like 'Kid Control'
It's not your responsibility to do it for them, and i'm grateful for you publishing your scripts and being so helpful with your responses
bbs2web
Tue Aug 06, 2019 1:51 am
RouterOS 6.45+ sets the VRRP interface to standby when the associated parent interface is not running. Whilst this makes perfect sense for classic VRRP implementations it causes a problem with the use of VRRP in the context of this high availability implementation. The problem is that since the sync interface, which VRRP is bound to, is directly connected to the partner router; VRRP will stay down when the second router is restarted or failed. The master router will essentially immediately shut all its ports the moment the standby router is restarted and the act of firing scripts when the partner router flaps its ports during initialisation can result in routers having an inconsistent state (we had one pair where both had their ports enabled).
Whilst I've logged a query with MikroTik, noting the lack of reference in the change log archives, I unfortunately don't expect anything to happen.
A work around to the problem was for us to migrate VRRP on to a bridge, to which we then add the sync interface.
To change a stack running eg 6.44.5 to 6.45.3:
  • Apply the following changes to the ha_startup script
  • Run ha_pushback on master to transfer config to slave
  • Upgrade slave to 6.45.3
  • Upgrade firmware and restart slave
  • Upgrade master to 6.45.3 (initiates failover)
  • Upgrade firmware and restart slave (previous master)
  • Restart master, to switch slave back to master
Patch:
@@ -38,10 +38,10 @@
-/ip address remove [find interface="$haInterface"]
+/interface bridge port remove [find comment="HA_AUTO"]
+/interface bridge remove [find comment="HA_AUTO"]
-/ip address remove [find interface="HA_VRRP"]
 /ip firewall filter remove [find comment="HA_AUTO"]
 /ip service set [find name="ftp"] disabled=yes
@@ -50,11 +50,14 @@
 /interface ethernet get [find default-name="$haInterface"] orig-mac-address
 /log warning "ha_startup: 2.2"
 :local mac [[/interface ethernet get [find default-name="$haInterface"] orig-mac-address]]
+/log warning "ha_startup: 2.3"
+/interface bridge add name="bridge-$haInterface" comment="HA_AUTO"
+/interface bridge port add bridge="bridge-$haInterface" interface="$haInterface" comment="HA_AUTO"
 /log warning "ha_startup: 3"
 :if ("$mac" = "$haMacA") do {
    :global haIdentity "A"
    /log warning "I AM A"
-   /ip address add interface=$haInterface address=$haAddressA netmask=$haNetmask comment="HA_AUTO"
+   /ip address add interface="bridge-$haInterface" address=$haAddressA netmask=$haNetmask comment="HA_AUTO"
    :global haAddressMe $haAddressA
    :global haAddressOther $haAddressB
    :global haMacMe $haMacA
@@ -63,7 +66,7 @@
    :if ("$mac" = "$haMacB") do {
       :global haIdentity "B"
       /log warning "I AM B"
-      /ip address add interface=$haInterface address=$haAddressB netmask=$haNetmask comment="HA_AUTO"
+      /ip address add interface="bridge-$haInterface" address=$haAddressB netmask=$haNetmask comment="HA_AUTO"
       :global haAddressMe $haAddressB
       :global haAddressOther $haAddressA
       :global haMacMe $haMacB
@@ -90,17 +93,17 @@
 #If firewall is empty, place-before=0 won't work. Add first rule.
 :if ([:len [/ip firewall filter find]] = 0) do {
    /log warning "ha_startup: 4.1"
-   /ip firewall filter add chain=output action=accept out-interface=$haInterface comment="HA_AUTO"
-   /ip firewall filter add chain=input action=accept in-interface=$haInterface comment="HA_AUTO"
+   /ip firewall filter add chain=output action=accept out-interface="bridge-$haInterface" comment="HA_AUTO"
+   /ip firewall filter add chain=input action=accept in-interface="bridge-$haInterface" comment="HA_AUTO"
 } else {
    /log warning "ha_startup: 4.2"
-   /ip firewall filter add chain=output action=accept out-interface=$haInterface comment="HA_AUTO" place-before=0
-   /ip firewall filter add chain=input action=accept in-interface=$haInterface comment="HA_AUTO" place-before=0
+   /ip firewall filter add chain=output action=accept out-interface="bridge-$haInterface" comment="HA_AUTO" place-before=0
+   /ip firewall filter add chain=input action=accept in-interface="bridge-$haInterface" comment="HA_AUTO" place-before=0
 /log warning "ha_startup: 4.3"
 /log warning "ha_startup: 5"
-/interface vrrp add interface=$haInterface version=3 interval=1 name=HA_VRRP on-backup="ha_onbackup" on-master="ha_onmaster"
+/interface vrrp add interface="bridge-$haInterface" version=3 interval=1 name=HA_VRRP on-backup="ha_onbackup" on-master="ha_onmaster"
nathan1
Re: Suggestion: Completely virtual router based on two physical routers
Tue Aug 06, 2019 2:08 am
This is a disappointing behavioral change from them, thanks for investigating it. I have entered a bug on github for now: https://github.com/svlsResearch/ha-mikrotik/issues/11
jandres
Thu Sep 12, 2019 9:05 pm
I'm testing with a pair of CCR1036 with 6.44.5 software, and it's not working well. At first, i bootstrapped correctly router A, i can see it active but, once router B is synced, after reboot, B becomes active and automatically A becomes in standby mode. Then, if i try to switchrole, i get this error:
/ip smb shares remove [find comment=HA_AUTO]
end_mkDirCode
status: failed
failure: connection failed
or if i reboot router B, router A appears like active, but when B is back online again, it takes active rol and A takes standby rol. Always B is active and A inactive.
Have someone tried with this hardware? Maybe that model isn't compatible, or am i making something wrong? Thanks,
nathan1
Thu Sep 12, 2019 10:00 pm
end_mkDirCode
status: failed
Did you do this bootstrapping from reset routers?
This platform/version should work fine. Can you send some more logs from when you first issue the switchrole?
From the current master (in each case), does this succeed?
/tool fetch src-path=HA_boot_log.txt dst-path=testing.txt address=$haAddressOther user=ha password=$haPassword mode=ftp
jandres
Fri Sep 13, 2019 10:22 am
Thanks for the reply nathan1. Yes, both routers are reset to defaults before bootstraping. I'll try to exec that commend and i'll post it here, I have a look to log file and it seems nothing wrong, maybe the log debug is not set to a detailed level.
jandres
Fri Sep 13, 2019 3:33 pm
This is what i get when i try to sync router B at first time
Code: Select all
[admin@MikroTik_HA_A_ACTIVE] > $HASyncStandby
status: finished
downloaded: 0KiBC-z pause]
total: 0KiB
duration: 1s
status: finished
duration: 1s
MASTER VERSION: ! history=.id=*b3;action=script removed;by=admin;policy=write;time=jan/02/1970 00:10:41 file=*d105d certificate= !
STANDB VERSION: ! !
NEED TO PUSH
mkdirCode: :foreach k in=[/file find type!="directory"] do={ :local xferfile [/file get $k name]; if ([:pick "$xferfile" 0 3] != "HA_") do={ :put "removing $xfe
rfile"; /file remove $k; } };
/delay 2;
:do { /ip smb shares add comment=HA_AUTO name=mkdir disabled=yes directory=/skins } on-error={}
/ip smb shares set [find comment=HA_AUTO] directory="pub"
end_mkDirCode
status: finished
downloaded: 0KiB
total: 0KiB
duration: 3s
status: finished
total: 0KiB
duration: 1s
status: finished
downloaded: 1KiBC-z pause]
total: 1KiB
duration: 1s
status: finished
total: 0KiB
duration: 1s
Saving system configuration
Configuration backup saved
status: finished
downloaded: 31KiB-z pause]
total: 31KiB
duration: 1s
status: finished
downloaded: 44KiB-z pause]
total: 44KiB
duration: 1s
status: failed
OK - status failed is OK from last fetch, standby is rebooting.
00:15:53 echo: ssh,critical SSH host keys exported!
And the other command
Code: Select all
[admin@MikroTik_HA_B_ACTIVE] > $HASwitchRole
I am master - switching role
xferfile"; /file remove $k; } };
/delay 2;
/ip smb shares set [find comment=HA_AUTO] directory="skins"
end_mkDirCode
status: failed
[admin@MikroTik_HA_B_ACTIVE] > /tool fetch src-path=HA_boot_log.txt dst-path=testing.txt address=$haAddressOther user=ha password=$haPassword mode=ftp
status: failed
nathan1
Fri Sep 13, 2019 3:50 pm
status: failed
[admin@MikroTik_HA_B_ACTIVE] >[/Codebox]
Please try it again but run the test command before you do a switch role, I’m trying to figure out if the FTP server is somehow broken from B to A or if it is somehow dying during the switch.
jandres
Fri Sep 13, 2019 4:33 pm
Code: Select all
status: failed
On router A, ftp server is always disabled. If I enable it manually
Code: Select all
status: failed
failure: poll err
nathan1
Fri Sep 13, 2019 5:42 pm
Code: Select all
status: failed
Code: Select all
status: failed
failure: poll err
Can you show a /log print and /file print on A after it boots and becomes standby? It seems like something is going wrong with the startup of this guy, the FTP server should definitely be enabled automatically.
jandres
Fri Sep 13, 2019 6:19 pm
/log print
Code: Select all
[admin@MikroTik_HA_A_ACTIVE] > /log print
00:25:28 system,info router rebooted
00:25:28 health,warning PSU2 entered state FAIL
00:25:33 interface,info ether8 link up (speed 100M, full duplex)
00:25:33 interface,info ether1 link up (speed 100M, full duplex)
00:26:02 system,info,account user admin logged in from 20:CF:30:C1:88:C7 via winbox
00:26:03 system,info,account user admin logged in via local
00:26:07 system,info new script added by admin
00:26:07 system,info changed script settings by admin
00:26:08 system,info changed script settings by admin
00:26:11 system,info new script added by admin
00:26:13 smb,info created new share: pub
00:26:14 script,warning ha_startup: START
00:26:14 script,warning ha_startup: 0.1
00:26:14 script,warning ha_startup: 0.2
00:26:14 script,warning ha_startup: 0.3
00:26:14 interface,info ether1 link down
00:26:14 system,info device changed by admin
00:26:14 interface,info ether8 link down
00:26:14 script,warning ha_startup: version 0.6 - 8b14022883a2b1e541d1579e70e11b6bd023d601
00:26:14 script,warning ha_startup: 1 ether8
00:26:14 system,info new script scheduled by admin
00:26:14 script,warning ha_startup: 2
00:26:14 system,info ip service changed by admin
00:26:14 script,warning ha_startup: 2.1 1
00:26:14 script,warning ha_startup: 2.2 1
00:26:14 script,warning ha_startup: 3 74:4D:28:C7:80:BB 1
00:26:14 script,warning ha_startup: 3.1 74:4D:28:C7:80:BB 1
00:26:14 script,warning I AM A
00:26:14 system,info address added by admin
00:26:14 system,info route added by admin
00:26:14 script,warning ha_startup: 4
00:26:14 script,warning ha_startup: 4.1
00:26:14 system,info filter rule added by admin
00:26:15 system,info filter rule added by admin
00:26:15 script,warning ha_startup: 4.3
00:26:15 script,warning ha_startup: 5
00:26:15 system,info device added by admin
00:26:15 system,info address added by admin
00:26:15 script,warning ha_startup: 6
00:26:15 system,info new script scheduled by admin
00:26:15 script,warning ha_startup: 7
00:26:15 system,info user ha added by admin
00:26:15 script,warning ha_startup: 8
00:26:15 system,info tile rb settings changed by admin
00:26:15 system,info ip service changed by admin
00:26:15 vrrp,info HA_VRRP now BACKUP
00:26:15 system,info device changed by admin
00:26:15 system,info system identity changed by admin
00:26:17 system,info,account user admin logged out from 20:CF:30:C1:88:C7 via winbox
00:26:17 system,info,account user admin logged out via local
00:26:19 interface,info ether8 link up (speed 100M, full duplex)
00:26:24 vrrp,info HA_VRRP now MASTER, master down timer
00:26:24 system,info device changed by admin
00:26:25 system,info device changed by admin
00:26:26 system,info device changed by admin
00:26:26 system,info system identity changed by admin
00:26:26 interface,info ether1 link up (speed 100M, full duplex)
00:27:14 system,info,account user admin logged in from 20:CF:30:C1:88:C7 via winbox
00:27:14 system,info,account user admin logged in via local
/file print
Code: Select all
[admin@MikroTik_HA_A_ACTIVE] > /file print
# NAME TYPE SIZE CREATION-TIME
0 HA_init.rsc script 28.2KiB jan/02/1970 00:25:20
1 HA_backup_beforeHA.backup backup 37.4KiB jan/02/1970 00:26:11
2 HA_backup_beforeHA.rsc script 30.0KiB jan/02/1970 00:26:13
3 pub directory jan/02/1970 00:26:13
4 HA_boot_interface_print.txt .txt file 1909 jan/02/1970 00:26:14
nathan1
Fri Sep 13, 2019 6:53 pm
/log print
Code: Select all
/file print
Code: Select all
This log looks like it is from when A is ACTIVE? Can you do the same thing when it is STANDBY? or do you think it should be STANDBY here?
Can you get the two to the state where switch role would fail (but don't run any scripts yet) and produce a /log print from each.
It seems like this log shows it working correctly but it is hard to tell without observing the state of both.
Is there any notable difference in configuration on these vs the github ha-mikrotik code or any other global configuration?
jandres
Fri Sep 13, 2019 7:19 pm
Thanks again Nathan1.
The init script from github is the same, i haven't added or removed any line.
Yes you're right, this is router A active. This is the same with router A when it becomes standby itself after bootstrap of router B
I've doing some tests, and if i enable ftp server on router A and i set vrrp priority of router A to 101, then A becomes active and all is working well. Also, i have to update the 60 seconds delay on Switchrole script because the router takes more time to reboot.
Log print (without exec any command)
Code: Select all
[admin@MikroTik_HA_A_STANDBY] > /log print
01:16:27 system,info script removed by admin
01:16:27 system,info new script added by admin
01:20:01 info fetch: file "HA_standby-haConfigVer.txt" downloaded
01:21:26 vrrp,info HA_VRRP now BACKUP, got higher priority 100 from 169.254.23.2
01:21:26 interface,info ether1 link down
01:21:26 system,info device changed by admin
01:21:26 system,info system identity changed by admin
01:21:28 system,info,account user admin logged out from 20:CF:30:C1:88:C7 via winbox
01:21:28 system,info,account user admin logged out via local
01:22:05 system,info,account user admin logged in from 20:CF:30:C1:88:C7 via winbox
01:22:05 system,info,account user admin logged in via local
File print
Code: Select all
[admin@MikroTik_HA_A_STANDBY] > /file print
5 HA_get-version.txt .txt file 51 jan/02/1970 01:20:00
6 HA_current.rsc script 31.9KiB jan/02/1970 01:15:01
7 HA_mkdirs.txt .txt file 393 jan/02/1970 01:20:02
8 HA_rsa file 1704 jan/02/1970 01:20:08
9 HA_rsa.pub ssh key 451 jan/02/1970 01:20:08
10 HA_dsa file 668 jan/02/1970 01:20:08
11 HA_dsa.pub ssh key 604 jan/02/1970 01:20:08
12 HA_run-after-hastartup.txt .txt file 132 jan/02/1970 01:20:10
13 HA_b2s.rsc script 31.9KiB jan/02/1970 01:20:12
14 HA_b2s.backup backup 44.1KiB jan/02/1970 01:20:12
15 HA_restore-backup.rsc.txt .txt file 49 jan/02/1970 01:20:14
nathan1
Fri Sep 13, 2019 7:36 pm
Aha, I do see something wrong. Your ha_startup is never making it beyond 8.
https://github.com/svlsResearch/ha-mikr ... cript#L153
So it never makes it to where the FTP is enabled:
https://github.com/svlsResearch/ha-mikr ... cript#L174
and we never see ha_startup: DONE
Can you show me "/system resource print" and "/system routerboard print"?
There seems to be something in this code that isn't working on your unit:
#So you dont get annoyed with constant beeping - try catch because this may fail on some platforms (x86).
:foreach service in=[:toarray "ftp"] do={
      :if ($k != "$haAddressA/32" and $k != "$haAddressB/32" and $k != "$haAddressVRRP/32") do={
         :set serviceAddresses "$serviceAddresses,$k"
   :set serviceAddresses "$serviceAddresses,$haAddressA,$haAddressB,$haAddressVRRP"
Can you try to run those lines by hand and see if you can get an error produced? It might be easier to upload it to a file and then /import it interactively.
A few :put traces might also help. Let me know if you need help with that.
Edit: can you please also show "/ip service export" as well.
jandres
Fri Sep 13, 2019 8:07 pm
All commands run on router A as standby
Code: Select all
[admin@MikroTik_HA_A_STANDBY] > /system resource print
uptime: 1h44m47s
version: 6.44.5 (long-term)
build-time: Jul/04/2019 10:32:21
factory-software: 6.43.10
free-memory: 3673.3MiB
total-memory: 3968.0MiB
cpu: tilegx
cpu-count: 36
cpu-frequency: 1200MHz
cpu-load: 0%
free-hdd-space: 885.0MiB
total-hdd-space: 1024.0MiB
architecture-name: tile
board-name: CCR1036-8G-2S+
platform: MikroTik
Code: Select all
[admin@MikroTik_HA_A_STANDBY] > /system routerboard print
routerboard: yes
model: CCR1036-8G-2S+
revision: r2
serial-number: 968E0A064382
firmware-type: tilegx
factory-firmware: 6.44.3
current-firmware: 6.44.3
upgrade-firmware: 6.44.5
ip service export
Code: Select all
[admin@MikroTik_HA_A_STANDBY] > /ip service export
# jan/02/1970 02:11:49 by RouterOS 6.44.5
# software id = JZU2-0TFL
# model = CCR1036-8G-2S+
# serial number = 968E0A064382
/ip service
set ftp address=169.254.23.1/32,169.254.23.2/32,169.254.23.10/32 disabled=yes
And the result of those lines copy&paste, no errors reported neither log file or screen, and ftp remains disabled
Code: Select all
[admin@MikroTik_HA_A_STANDBY] > :do {/system routerboard settings set silent-boot=yes} on-error={};
[admin@MikroTik_HA_A_STANDBY] > :foreach service in=[:toarray "ftp"] do={
{... :local serviceAddresses ""
{... :foreach k in=[/ip service get [find name=$service] address] do={
{{... :if ($k != "$haAddressA/32" and $k != "$haAddressB/32" and $k != "$haAddressVRRP/32") do={
{{{... :set serviceAddresses "$serviceAddresses,$k"
{... :set serviceAddresses "$serviceAddresses,$haAddressA,$haAddressB,$haAddressVRRP"
{... /ip service set [find name=$service] address=[:toarray $serviceAddresses]
nathan1
Fri Sep 13, 2019 8:23 pm
Any errors running this?
:if ([:len [/file find where name="HA_run-after-hastartup.rsc"]] > 0) do={
/delay 5
#We need FTP to do our HA work
/ip service set [find name="ftp"] disabled=no
jandres
Fri Sep 13, 2019 8:32 pm
No errors shown again and ftp is enabled
Code: Select all
[admin@MikroTik_HA_A_STANDBY] > :if ([:len [/file find where name="HA_run-after-hastartup.rsc"]] > 0) do={
{... /import HA_run-after-hastartup.rsc
[admin@MikroTik_HA_A_STANDBY] > /delay 5
[admin@MikroTik_HA_A_STANDBY] > #We need FTP to do our HA work
[admin@MikroTik_HA_A_STANDBY] > /ip service set [find name="ftp"] disabled=no
nathan1
Fri Sep 13, 2019 8:37 pm
Very odd. Everything seems to be working but for some reason the script is not completing. I think I need to put some more trace in and give you another build to try to track this down. I can put a test release on github in about 2 hours.
Just to confirm, if you enable ftp on the standby. Does a $HAPushBackup work from the active(B) to standby(A)? And it always works from A to B?
jandres
Fri Sep 13, 2019 8:49 pm
$HAPushBackup seems to do nothing.
If i run on active (router B), i can see at log file how user ha has logged in and out, but if i run $HAPushBackup on standby (router A), i can't see any log on active (router B)
nathan1
Fri Sep 13, 2019 8:55 pm
Sorry, wrong command. Try $HAPushStandby. It will only work from active to standby. Can you try it in both cases of A being master and then B being master? You will need to enable FTP by hand when A is standby.
jandres
Fri Sep 13, 2019 8:59 pm
The result of $HAPushStandby, router A (standby) reboots
Code: Select all
[admin@MikroTik_HA_B_ACTIVE] > $HAPushStandby
/delay 2;
end_mkDirCode
status: finished
downloaded: 0KiB
total: 0KiB
duration: 3s
status: finished
total: 0KiB
duration: 1s
status: finished
total: 1KiB
duration: 1s
status: finished
total: 0KiB
duration: 1s
status: finished
downloaded: 32KiB-z pause]
total: 32KiB
duration: 1s
status: finished
total: 44KiB
duration: 1s
status: failed
nathan1
Fri Sep 13, 2019 9:02 pm
Code: Select all
/delay 2;
end_mkDirCode
status: finished
downloaded: 0KiB
total: 0KiB
duration: 3s
status: finished
total: 0KiB
duration: 1s
status: finished
total: 1KiB
duration: 1s
status: finished
total: 0KiB
duration: 1s
status: finished
total: 32KiB
duration: 1s
status: finished
total: 44KiB
duration: 1s
status: failed
Looks good. Did you need to enable ftp by hand on A for this? When it comes back after, are you able to issue another $HAPushStandby or do you need to enable FTP again? Our debugging so far suggests you need to enable FTP but I just wanted to double check.
jandres
Fri Sep 13, 2019 9:10 pm
Ftp was enabled when i put that code
Code: Select all
[admin@MikroTik_HA_A_STANDBY] > /ip service set [find name="ftp"] disabled = no
And after that, ftp is always enabled
raffav
Fri Sep 13, 2019 9:16 pm
Hi nathan1
This solution can work on the Chr version?
nathan1
Fri Sep 13, 2019 9:21 pm
Code: Select all
Pretty strange. Can you see if you can switch roles reliably now?
nathan1
Fri Sep 13, 2019 9:22 pm
Hi nathan1
I believe there were some folks that tried successfully but I have not personally done it.
jandres
Fri Sep 13, 2019 9:35 pm
$HASwitchRole now is working. Router A becomes active after run that command, but when router B reboots, router A change its role to standby and always router B becomes active router
Code: Select all
[admin@MikroTik_HA_A_STANDBY] > log print
00:25:29 script,warning ha_startup: START
00:25:29 script,warning ha_startup: 0.1
00:25:29 script,warning ha_startup: 0.2
00:25:31 vrrp,info HA_VRRP now BACKUP
00:25:31 script,warning ha_startup: 0.3
00:25:31 system,info device changed by admin
00:25:31 script,warning ha_startup: version 0.6 - 8b14022883a2b1e541d1579e70e11b6bd023d601
00:25:31 script,warning ha_startup: 1 ether8
00:25:31 system,info script removed from scheduler by admin
00:25:31 system,info system identity changed by admin
00:25:31 system,info new script scheduled by admin
00:25:31 script,warning ha_startup: 2
00:25:31 system,info address removed by admin
00:25:31 system,info device removed by admin
00:25:31 system,info filter rule removed by admin
00:25:31 system,info ip service changed by admin
00:25:31 script,warning ha_startup: 2.1 1
00:25:31 script,warning ha_startup: 2.2 1
00:25:31 script,warning ha_startup: 3 74:4D:28:C7:80:BB 1
00:25:31 script,warning ha_startup: 3.1 74:4D:28:C7:80:BB 1
00:25:31 script,warning I AM A
00:25:31 system,info address added by admin
00:25:31 system,info route removed by admin
00:25:31 system,info route added by admin
00:25:32 script,warning ha_startup: 4
00:25:32 script,warning ha_startup: 4.1
00:25:32 system,info filter rule added by admin
00:25:32 script,warning ha_startup: 4.3
00:25:32 script,warning ha_startup: 5
00:25:32 system,info device added by admin
00:25:32 system,info address added by admin
00:25:32 script,warning ha_startup: 6
00:25:32 system,info new script scheduled by admin
00:25:32 script,warning ha_startup: 7
00:25:32 vrrp,info HA_VRRP now BACKUP
00:25:32 system,info device changed by admin
00:25:32 system,info system identity changed by admin
00:25:32 system,info user ha removed by admin
00:25:32 system,info user ha added by admin
00:25:32 script,warning ha_startup: 8
00:25:32 system,info tile rb settings changed by admin
00:25:32 system,info ip service changed by admin
00:25:37 system,info ip service changed by admin
00:25:37 script,warning ha_startup: DONE
00:25:40 vrrp,info HA_VRRP now MASTER, master down timer
00:25:40 system,info device changed by admin
00:25:41 system,info device changed by admin
00:25:42 system,info device changed by admin
00:25:42 system,info system identity changed by admin
00:25:42 interface,info ether1 link up (speed 100M, full duplex)
00:26:03 vrrp,info HA_VRRP now BACKUP, got higher priority 100 from 169.254.23.2
00:26:03 interface,info ether1 link down
00:26:03 system,info device changed by admin
00:26:04 system,info device changed by admin
00:26:04 system,info system identity changed by admin
00:26:07 vrrp,info HA_VRRP now MASTER, master down timer
00:26:07 system,info device changed by admin
00:26:08 system,info device changed by admin
00:26:09 system,info device changed by admin
00:26:09 system,info system identity changed by admin
00:26:12 interface,info ether1 link up (speed 100M, full duplex)
00:26:33 system,info,account user admin logged in from 20:CF:30:C1:88:C7 via winbox
00:26:34 script,info ha_startup: ha_report_startup debug version=6.44.5 (long-term) firmware=6.44.3 badC=0 goodC=1 delay1C=0 delay2C=0 uptime=00:01:28 isMaster=
true haInitTries=1 haStartupHasRun=00:00:23 haStartupHAVersion=0.6 - 8b14022883a2b1e541d1579e70e11b6bd023d601
00:26:34 system,info,account user admin logged in via local
00:27:15 vrrp,info HA_VRRP now BACKUP, got higher priority 100 from 169.254.23.2
00:27:15 interface,info ether1 link down
00:27:15 system,info device changed by admin
00:27:15 system,info system identity changed by admin
00:27:16 system,info,account user admin logged out from 20:CF:30:C1:88:C7 via winbox
00:27:16 system,info,account user admin logged out via local
00:28:28 system,info,account user admin logged in from 20:CF:30:C1:88:C7 via winbox
00:28:28 system,info,account user admin logged in via local
jandres
Fri Sep 13, 2019 9:37 pm
Hi nathan1
Yes, i tried it on chr image 6.41 and it was working fine, now i'm trying to run it on ccr1036 and i'm having some issues with the script.
nathan1
Fri Sep 13, 2019 9:46 pm
Code: Select all
Do you have these in an isolated lab setup? Would it be possible for you to screen share to me so I can take a look in realtime? We can take it to private message for debugging if that works.
nathan1
Fri Sep 13, 2019 9:49 pm
Code: Select all
Actually, can you do "/interface vrrp print" on both? Did you keep that vrrp priority change that you temporarily added? They should both be 100 and it should be reset by ha_startup, ha-mikrotik does not support different VRRP priorities - it has no preference for A vs B and cannot currently support this.
raffav
Fri Sep 13, 2019 10:23 pm
Hi My last time I had played with this was very time ago
I am trying to play it again but I can't find it to make it work
I got stuck after importing the file to load the scripts them I do not what to do it
I past this on the terminal but nothing happens
`$HAInstall interface="ether3" macA="00:0C:29:42:A6:67" macB="00:0C:29:D8:83:02" password="1q2w3e4r5t6y"`
nathan1
Fri Sep 13, 2019 10:29 pm
Did you /import HA_init.rsc ? Were there any errors?
raffav
Fri Sep 13, 2019 10:30 pm
yes I imported
no no error /no logs
nathan1
Fri Sep 13, 2019 10:32 pm
yes I imported
Did it say anything? like "Script file loaded and executed successfully"?
What RouterOS version?
raffav
Fri Sep 13, 2019 10:39 pm
last stable one
When I load the ha_init.rsc I got this msg
that was loaded
if I go to the sys scripts I see a bunch of scripts added
nathan1
Fri Sep 13, 2019 10:40 pm
last stable one
that was loaded
Can you confirm the version? It does not work beyond 6.44.5 right now (see bbs2web post above).
What does " :put $HAInstall" show?
raffav
Fri Sep 13, 2019 10:49 pm
6.45.6
When I run I just got a blank space like is was no value
[admin@MikroTik1] > :put $HAInstall
[admin@MikroTik1] >
nathan1
Fri Sep 13, 2019 10:59 pm
6.45.6
[admin@MikroTik1] >
Please try with 6.44.5 if you want to try it.
jandres
Mon Sep 16, 2019 8:30 am
Code: Select all
[admin@MikroTik_HA_B_ACTIVE] > interface vrrp print
Flags: X - disabled, I - invalid, R - running, M - master, B - backup
# NAME INTERFACE MAC-ADDRESS VRID PRIORITY INTERVAL VERSION V3-PROTOCOL
0 RM HA_VRRP ether8 00:00:5E:00:01:01 1 100 1s 3 ipv4
If I change priority of router A by hand, A becomes active router, but if I run $HASwitchRole, the change is reverted and it's 100 back again, that's correct.
I can share my screen no problem, let's talk by PM if you want, thanks a lot for your time Nathan1
nathan1
Mon Sep 16, 2019 3:32 pm
Code: Select all
So if you leave all of the priorities alone - are you able to $HASwitchRole reliably now or is there still a problem on one of them? If so, can you outline which switchrole fails and provide a log both master and standby when you get into that state?
jandres
Mon Sep 16, 2019 11:07 pm
The problem is after switchrole. When active reboots, always B becomes active router. The sequence is as follows:
Router B(active) - switchrole - router A (standby) reboots - router B reboots also after a 60s delay - router A is online again at first as active - router B is online a little bit time that router A - router B becomes active - router A becomes standby again
So, switchrole is performed, but automatically reverted after reboot. Router A is active only a few seconds.
Regards
dmitk
Tue Sep 24, 2019 3:35 pm
trying to install ha-mikrotik on two fresh long term ROS 6.44.5 CCR1036-8G-2S+ :
On the first node:
[admin@HA-1] > /import HA_init.rsc
[admin@HA-1] > $HAInstall interface="ether8" macA="CC:2D:E0:BD:9F:A8" macB="CC:2D:E0:BD:9F:D4" password="passw0rd"
CC:2D:E0:BD:9F:A8
CC:2D:E0:BD:9F:D4
SEQ HOST SIZE TTL TIME STATUS
0 CC:2D:E0:BD:9F:D4 70 0ms
sent=1 received=1 packet-loss=0% min-rtt=0ms avg-rtt=0ms max-rtt=0ms
I am not master - running ha_startup first
ha_startup: ERROR ATTEMPTED TO RUN AGAIN!!! 01:02:33
#Maybe try: /tool mac-telnet
###PASTE THIS ON THE OTHER DEVICE - YOUR CONFIG WILL BE RESET AND LOST!!!###
:global mac [[/interface ethernet get [find default-name="ether8"] orig-mac-address]]
:if ($mac = "CC:2D:E0:BD:9F:A8" and $mac = "CC:2D:E0:BD:9F:D4") do={
:error "Interface ether8 MAC $mac does not match (A=CC:2D:E0:BD:9F:A8 or B=CC:2D:E0:BD:9F:D4) - please check config\r\nUse orig-mac address!"
:if ([:len [/file find name=HA_backup_beforeHA.backup]] = 0) do={
/system backup save name=HA_backup_beforeHA dont-encrypt=yes
/export file=HA_backup_beforeHA.rsc
/export file=HA_bootstrap.rsc
/delay 2
/file print file=HA_bootstrap.rsc
/file set [find name=HA_bootstrap.rsc] contents="/ip address add address=\"/24\" interface=ether8; /user add name=ha group=full password=\"passw0rd\";"
/system reset-configuration no-defaults=yes keep-users=no skip-backup=yes run-after-reset=HA_bootstrap.rsc
###END OF PASTE FOR OTHER DEVICE###
On second node:
Used part of config above, node restarted and nothing happens. If I run manually HA_bootstrap.rsc on second node, I'll get an error:
[admin@MikroTik] > /import HA_bootstrap.rsc
failure: local address cannot be 0.0.0.0
[admin@MikroTik] >
also user ha has not been created on the second node.
I have seen above that people successfully used ha-mikrotik on ROS 6.44.5
Any suggestions ?
n4p
Wed Sep 25, 2019 12:55 pm
Thanks for this great script, i try to get it working on two CCR1009-7G-1C-1S+.
After Some troubles it seems to work.
Another question, is there any possibility to use the usr-led for showing which router is active and which one is passive?
Thanks in advance.
nathan1
Wed Sep 25, 2019 2:22 pm
Regards
Email me at nathan4321 at Google’s mail service, if you want to setup a time to debug this in screen sharing.
nathan1
Wed Sep 25, 2019 2:24 pm
On the first node:
CC:2D:E0:BD:9F:A8
CC:2D:E0:BD:9F:D4
/delay 2
On second node:
[admin@MikroTik] >
Any suggestions ?
Are these MACs correct? They should be the MACs of each ether8.
nathan1
Wed Sep 25, 2019 2:27 pm
Thanks in advance.
You can create two scripts that will automatically be called to do this. “on_backup” and “on_master”.
n4p
Thu Sep 26, 2019 11:44 am
but i need to add those scripts on the vrrp (on Master and on Backup) or?
Or is there any logic included, that all scripts with *_on_backup will be executed?
nathan1
Thu Sep 26, 2019 1:44 pm
Only on the master, you never make changes on the standby once you have setup ha-mikrotik. Add the scripts on the master and either wait for a normal sync or $HASyncStandby on from the master to force it sooner. Note that the LEDs will only be right when the pair is in sync, there will be periods when the current standby has the LEDs of the master until it completes booting.
n4p
Thu Sep 26, 2019 2:02 pm
Thanks!
It's working now :)
Just another question, if I execute SwitchRole i get the following output:
/delay 2;
 end_mkDirCode
      status: finished
  downloaded: 0KiB
       total: 0KiB
    duration: 3s
      status: finished
       total: 0KiB
    duration: 1s
      status: finished
       total: 1KiB
    duration: 1s
      status: finished
       total: 0KiB
    duration: 1s
      status: finished
       total: 32KiB
    duration: 1s
      status: finished
  downloaded: 45KiB-z pause]
       total: 45KiB
    duration: 1s
  status: failed
delaying 60
Just asking because the status : failed
Is that a critical issue? Or is there any configuration error.
nathan1
Thu Sep 26, 2019 2:33 pm
Thanks!
It's working now :)
/delay 2;
 end_mkDirCode
      status: finished
  downloaded: 0KiB
       total: 0KiB
    duration: 3s
      status: finished
       total: 0KiB
    duration: 1s
      status: finished
       total: 1KiB
    duration: 1s
      status: finished
       total: 0KiB
    duration: 1s
      status: finished
       total: 32KiB
    duration: 1s
      status: finished
       total: 45KiB
    duration: 1s
  status: failed
delaying 60
Expected, it is fine. Note the message “ OK - status failed is OK from last fetch, standby is rebooting.”.
It happens because the service is abruptly stopped during the standby reboot while fetch is still connected.
n4p
Thu Sep 26, 2019 8:16 pm
OK,
One Last question, would it be possible to secure the Sync Ports especually through EOIP Tunnel or something?
I need to make a Setup where the routers are not placed in the same room.
And is it possible to build IPSec Tunnels with certificates? With PSK it works great in a failover, but will the certificates also get synced between activ and passive?
Thanks!
nathan1
Thu Sep 26, 2019 8:44 pm
OK,
Thanks!
No built in way to secure the sync ports beyond the VRRP auth. For them to be in different locations, don’t you need to extend layer2 anyway? Folks have reported extending the layer2 for the sync ports with a switch, but I have not personally done this.
For certificates, you will want to write a script to import keys from the filesystem into the certificate store. Files on the master will be synchronized and you can then have a startup script import them. I do this on all of my pairs for OpenVPN certificates.
n4p
Thu Sep 26, 2019 9:03 pm
OK, yes the layer2 ist extented but i would use a complete different way for Sync. So If i Install a EOIP Tunnel before hainstall would this Work if i select the EOIP Interface?
May you Share your Script?
nathan1
Thu Sep 26, 2019 9:17 pm
No, that won't work and I'd strongly advise against trying to do something like that. The sync port is critical to operation and any additional failure modes increases the chances of split brain. Adding a switch already increases these odds.
Can you help me understand what you are trying to do by "securing" the sync port and what you mean by "secure"?
For certificate imports, pretty straight forward scheduler task on startup (runs on both and the files once placed on the master filesystem will be pushed from master):
/system scheduler
add name=on_reboot_fix_certifcates on-event="/certificate remove [find]\
    \n/certificate import file-name=SOMEWHERE.com.crt passphrase=\"\"\
    \n/certificate import file-name=SOMEWHERE.com.key passphrase=PASSPHRASE" \
n4p
Thu Sep 26, 2019 9:58 pm
Thanks for sharing your script.
Yes, i was thinking about a man in the middle Attack on this Board. As far as i know the file Sync goes through smb or FTP? So with man in the middle you can gather information about PSK etc.
Or i am completley wrong?
I know it depends on my different Setup were the routers Not placed in the same room.
I agree with you more devices in the Sync Channel reduces the available.
Thanks for discussion!
nathan1
Thu Sep 26, 2019 10:09 pm
Yes, it is true that the sync uses FTP. SMB is not actually used for communication but it is used as a hack to mkdir because Mikrotik has not exposed another way to create a directory (last I checked).
A MITM attack could gather quite a bit of information but a MITM attack in this scenario could also potentially attack the VRRP layer and cause all sorts of network issues. Is this not going to be on a trusted layer 2 network? Or your concerns are beyond that and simply trying to reduce the attack surface of cleartext information?
The reason why I had to use FTP is due to this feature: https://wiki.mikrotik.com/wiki/Manual:C ... tic_Import
Unless something has changed from when I first developed it, FTP is the only method that supports automatic imports. The entire ha-mikrotik setup hinges on this functionality right now.
It is a bummer that they haven't exposed more robust functionality onboard that I can leverage...but that goes for why ha-mikrotik had to be created in the first place too. It would be nice if they had this all built in.
ha-mikrotik was designed to have a point to point physical connection between the two devices.
So unfortunately, I don't know an easy way around this. You really want to make sure that the layer 2 between these devices can be trusted.
I know this isn't the solution you were looking for but hopefully it gives some clarity.
n4p
Thu Sep 26, 2019 10:40 pm
Yes, i would use a dark fiber for the Sync. But your right, the Problem ist the cleartext...
Especually i get an Idea for Monitoring those Connection.
DMccabe
Thu Oct 17, 2019 5:39 pm
On the first node:
CC:2D:E0:BD:9F:A8
CC:2D:E0:BD:9F:D4
/delay 2
On second node:
[admin@MikroTik] >
Any suggestions ?
Has there been any more progress on this? I'm stuck at the same position, and am about to completely disassemble the script and start from scratch if it fails on this error.
nathan1
Thu Oct 17, 2019 7:33 pm
On the first node:
CC:2D:E0:BD:9F:A8
CC:2D:E0:BD:9F:D4
/delay 2
On second node:
[admin@MikroTik] >
Any suggestions ?
The user emailed me and I attempted to help them but they never responded. Can you provide me access to your kit? I still haven't seen this in the wild and I am unable to reproduce it.
Users browsing this forum: MSN [Bot] and 84 guests
