src386
[SOLVED] chr-6.36 + dude-6.36 = default password ?
Mon Aug 01, 2016 11:10 am
Greetings,
I am unable to login in The Dude, using the Windows client or the Webui (http://ip/dude) :
08:21:07 echo: system,error,critical login failure for user admin via web
Steps to reproduce :
- Fresh chr-6.36.vdi (Virtualbox) installation.
- Fresh dude-6.36 installation.
- /dude set enable=yes
- try to connect using http://ip/dude or using Windows client
Looks like the default password is not empty any longer...
krisjanis
Re: chr-6.36 + dude-6.36 = default password ?
Mon Aug 01, 2016 11:52 am
1. Username/Password will be the same as your acc which you use to access the server host. The Dude now uses ROS AAA.
2. At the moment there is no web interface for The Dude sever.
src386
Mon Aug 01, 2016 3:01 pm
1. Username/Password will be the same as your acc which you use to access the server host. The Dude now uses ROS AAA.At the moment there is no web interface for The Dude sever.
1. Aw, I see, it's working now, thanks. Wiki just need an update.
2. That's what I thought, but I get a login page at http://ip/dude. So it's fake ? I have been Ackbared ?
krisjanis
Mon Aug 01, 2016 5:56 pm
Not fake, but not usable yet also.
Users browsing this forum: No registered users and 23 guests
