tomasi
Generate Backup and RSC based on Router Name + Date + Time
Mon Aug 01, 2016 11:46 pm
I tried to execute the following script to get a backup and .rsc file (with name + date + time) but it gave me errors:
:log info "STARTING BACKUP"
:global backupfile ([/system identity get name] . "-" . [/system clock get date] . "-" . [/system clock get time])
/system backup save name=$backupfile
:log info "DELAY 3S"
:delay 3s
:log info "GENERATING RSC"
:global rsc ([/system identity get name] . "-" . [/system clock get date] . "-" . [/system clock get time])
/export file=$rsc
:log info "BACKUP FINISHED"
It gives me:
#[in backup section]
Saving system configuration
Failed to save system configuration backup
action failed (6)
#[in rsc section]
file operation error
I don't know, may be system doesn't accept some special character.
I was not able to copy RB-16:42:00.rsc to my local computer. I suspect it could be the colons in the name.
How do I can change the colon to dash, for example, via script?
Is there a solution to these errors?
stam
Re: Generate Backup and RSC based on Router Name + Date + Time
Tue Aug 02, 2016 10:10 am
hello Tomasi and welcome aboard,
The problem occurs at line 3, when you try to give a name containing a backslash (in date format) and a column (in time format).
Your script produce a name like "RouterName-aug/02/2016-09:53:08.backup". Underlined characters are not allowed for almost every OS not only ROS.
So, you have to make a few changes in order to remove these characters
:log info "STARTING BACKUP";
:local filename;
:local date [/system clock get date];
:local time [/system clock get time];
:local name [/system identity get name];
:local months ("jan","feb","mar","apr","may","jun","jul","aug","sep","oct","nov","dec");
:local varHour [:pick $time 0 2];
:local varMin [:pick $time 3 5];
:local varSec [:pick $time 6 8];
:local varMonth [:pick $date 0 3];
:set varMonth ([ :find $months $varMonth -1 ] + 1);
:if ($varMonth < 10) do={ :set varMonth ("0" . $varMonth); }
:local varDay [:pick $date 4 6];
:local varYear [:pick $date 7 11];
:set filename ($name. "-" .$varYear."-".$varMonth."-".$varDay."-".$varHour.$varMin.$varSec);
/system backup save name=$filename;
:delay 3s;
:log info "GENERATING RSC";
:global rsc $filename;
/export file=$rsc;
:log info "BACKUP FINISHED";
RouterName-2016-08-02-095308.backup
RouterName-2016-08-02-095308.rsc
tomasi
Tue Aug 02, 2016 4:02 pm
Thank you for your reply :)
I tested the new script in my RB2011 6.34.4, but it gave me some errors. Another issue was it did not generate the RSC.
Some idea about this?
tomasi
Tue Aug 02, 2016 9:26 pm
I've changed a bit your example (all local to global).
Now the BACKUP and RSC were sucessfully created.
Can I have problems using global instead of local?
:global filename;
:global date [/system clock get date];
:global time [/system clock get time];
:global name [/system identity get name];
:global months ("jan","feb","mar","apr","may","jun","jul","aug","sep","oct","nov","dec");
:global hour [:pick $time 0 2];
:global min [:pick $time 3 5];
:global sec [:pick $time 6 8];
:global month [:pick $date 0 3];
:set month ([ :find $months $month -1 ] + 1);
:if ($month < 10) do={ :set month ("0" . $month); }
:global day [:pick $date 4 6];
:global year [:pick $date 7 11];
:set filename ($name. "-" .$year."-".$month."-".$day."-".$hour.$min.$sec);
:delay 3s;
/export file=$rsc;
:D
stam
Fri Aug 05, 2016 11:20 am
I am not an expert on programming, but i think that a global variable consume more resources.
Because a local's variable value discarded from memory when script execution ends but a global's variable value is not discarded from memory and you can use it later from the same or another script.
marlab
Thu Nov 02, 2017 1:59 am
Maybe someone finds the below useful - a modification of known script I use to send both attachments in a single email to my Gmail account.
Please notice you need ROS version at least 6.40 to be able to attach multiple files to a single email.
#### Modify these values to match your requirements ####
#Your email address to receive the backups
:local toemail "nice.guy@gmail.com"
#The From address (you can use your own address if you want)
:local fromemail "MikrotikBackup"
#A mail server your machines can send through
:local emailserver "smtp.gmail.com"
############## Don’t edit below this line ##############
:local textfilename
:local backupfilename
:local allfiles
:local filedate
:local sysname [/system identity get name];
:set filedate ($varYear."-".$varMonth."-".$varDay);
:set textfilename ($"filedate" . "-" . $"sysname" . ".rsc")
:set backupfilename ($"filedate" . "-" . $"sysname" . ".backup")
:set allfiles ($"textfilename" . "," . $"backupfilename")
:execute [/export file=$"textfilename"]
:execute [/system backup save name=$"backupfilename"]
#Allow time for export to complete
:delay 2s
#email copies
:log info "Emailing backups"
/tool e-mail send to=$"toemail" from=$"fromemail" server=[:resolve $emailserver] port=587 subject="[Config Backup] $sysname" file=$"allfiles"
#Allow time to send
:delay 10s
#delete copies
/file remove $textfilename
/file remove $backupfilename
And of course you'd need to set your settings for /tool e-mail service, in my case I use similar to
       address: smtp.gmail.com
          port: 587
     start-tls: yes
          user: nice.guy@gmail.com
      password: yourgmailpassword
EMSebi
Fri Nov 10, 2017 11:48 am
HI
I created a script to create daily backup and send it to Server FTP
Copy this to your router terminal
# Create Script For Add Backup every day with name and date
# Change Or Set Router Identity Unique name
# Generate By Iran FCP
/system scheduler
add comment="--==  Create Backup By Date ==--" interval=1d name=Backup-Day \
    on-event=":local day ([:pick [/system clock get date] 4 6]);\r\
    \n:local mon ([:pick [/system clock get date] 0 3]);\r\
    \n:local yer ([:pick [/system clock get date] 7 11]);\r\
    \n:local date \"\$day-\$mon-\$yer\";\r\
    \n:local iden [/system identity get name];\r\
    \n:local name \"\$date_{\$iden}\";\r\
    \n\r\
    \nexport compact file= \$name\r\
    \nsystem backup save dont-encrypt=yes name= \$name" policy=\
    ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon \
    start-date=may/21/2017 start-time=23:20:00
add comment="--== SEND Backup -- >  FTP ==--" interval=1d name=Send-BK-TO-FTP \
    \n\r\
    \n:local rec1 \"\$name.rsc\";\r\
    \n:local rec2 \"Backup/\$name.rsc\";\r\
    \n\r\
    \n:local bk1 \"\$name.backup\";\r\
    \n:local bk2 \"Backup/\$name.backup\";\r\
    \n\r\
    \n/tool fetch address=xxx.xxx.xxx.xxx src-path= \$rec1 user=UserFTP mode=ftp pas\
    sword=PasFTP dst-path= \$rec2 upload=yes\r\
    \n/tool fetch address=xxx.xxx.xxx.xxx src-path= \$bk1 user=UserFTP mode=ftp pass\
    word=PasFTP dst-path= \$bk2 upload=yes\r\
    \n\r\
    \n\r\
    \n# Change xxx.xxx.xxx.xxx To Ip FTP Server  And UserFTP - PasFTP\r\
    \n# Create Backup Folder To FTP Server \r\
    \n# EMSebi@Gmail.Com\r\
    \n# My Tel & Telegram : 00989195999975   @EMSebi" policy=\
    start-date=may/21/2017 start-time=23:30:00
Users browsing this forum: dpgovlv and 20 guests
