d3tonador
PS4 One Public IP for all?
Fri Aug 05, 2016 5:43 pm
Hi all,
I have been reading through the forum, still dont find the answer...
I manage a network of about 500 clients. I have 1 public IP for the Router and some public IPs for those who requested access to the PSN. The thing is that I ran out of Public IPs, so im wondering if there is any work around to this mapping. Those the UPnP function achieve this goal?
Thanks in advance!!
Best regards,
Zorro
Long time Member
Long time Member
Re: PS4 One Public IP for all?
Fri Aug 05, 2016 11:26 pm
ideally would be increase pressure on Sony to speed up implementation(as 1st grade, major level) of IPv6 support for PSN and devices(not only "gaming"-labeled), made by them.
they did it(albeit very slow)for "industrial" gear they offer, but not for PS4, yet, sadly :/
d3tonador
Mon Aug 08, 2016 2:37 am
Any suggestions??
diablothebest
Mon Aug 08, 2016 11:20 pm
Please tell me - your clients talks about errors in Destiny last time?
I have same network - over 30-40 PS4 over NAT.
d3tonador
Tue Aug 09, 2016 5:45 pm
This is my NAT, still cant join the PSN:
What's wrong?
EDIT: Its disabled, I know... It didnt work anyway so I disabled it.
61 X ;;; Mannini - DST-TCP
chain=dstnat action=dst-nat to-addresses=62.62.62.106 to-ports=0-65535
protocol=tcp dst-address=190.104.246.XXX (Routers WAN Port NOT GW IP)
62 X ;;; Mannini - DST-UDP
protocol=udp dst-address=190.104.246.XXX
63 X ;;; Mannini - SRC-TCP
chain=srcnat action=src-nat to-addresses=190.104.246.XXX to-ports=0-6553
protocol=tcp src-address=62.62.62.106
64 X ;;; Mannini - SRC-UDP
protocol=udp src-address=62.62.62.106
d3tonador
Tue Aug 09, 2016 6:06 pm
diablothebest, not sure about the exact msg as I didnt ask. I guess its the generical Could not access network message.
mrz
Tue Aug 09, 2016 6:24 pm
Enable UPNP, it should solve the problem.
d3tonador
Tue Aug 09, 2016 6:38 pm
MRZ, its enabled:
ROUTER_CENTRAL] /ip upnp> print
enabled: yes
allow-disable-external-interface: no
show-dummy-rule: no
Should I enable the dummy-rule?
d3tonador
Tue Aug 09, 2016 6:40 pm
Also, it looks like when it was enabled one of the admin guys couldnt access the Winbox. ??
EDIT: Afirmative, I cant access the Winbox if the nat above is enabled.
mrz
Tue Aug 09, 2016 7:12 pm
Write to support with attached supout file.
diablothebest
Tue Aug 09, 2016 8:42 pm
I solve my problem - just changed DNS server.
diablothebest
Tue Aug 09, 2016 8:46 pm
Why you make 4 rules?
Need just one rule for NAT:
add action=masquerade chain=srcnat out-interface=pppoe-out (or ethernet-out)
diablothebest
Wed Aug 10, 2016 12:52 pm
Nothing changed with Destiny!
This is game bug!
d3tonador
Sun Aug 14, 2016 3:36 am
At first I created only the masquerade then one rule, the two and then all of them but no luck.
d3tonador
Mon Aug 22, 2016 3:21 pm
Hi all,
Any update on this?
Still cant make it work.
Does anyone have this rule set?
Zorro
Long time Member
Long time Member
Wed Aug 24, 2016 12:32 am
as long as game didn't support "slightly different" port (in some range) choice(to override manually in config files of it)instead of default - nope, there isn't any.
using UPNP only make issues instant, instead of ~ activity-based(even more for static port forwarding).not sure about PMP or PCP(both not not implemented yet not only in ROS, but most other brands).
d3tonador
Mon Aug 29, 2016 1:28 am
So we all agree this is a bug on MT but no action were taken from MT at all?
Im expecting MT to jump in, please!
jarda
Mon Aug 29, 2016 8:17 am
How it could be a bug if you are running out of the ip addresses?
d3tonador
Tue Aug 30, 2016 4:51 am
Because I tried all the configuration possible but no luck, I cant get it to work.
I have asked many times, I posted the command lines I used but no answer. and I see some other people have the same issue.
How can I get it to work? is it possible at all, one public I for all the PS3/4?
Thanks in advance!
jarda
Tue Aug 30, 2016 8:21 am
It's about general principle how ipv4 works. You should use ipv6 if the game supports it or ask a game developers to issue an update that enables using multiple port mapping by upnp /nat. Its not mikrotik's fault that the Playstation has such limitation.
Users browsing this forum: AleSeth, RobertsN and 201 guests
