MUM Europe 2020
mistiq
hide ssid and access list does not working
Wed Aug 17, 2016 3:02 pm
I have rb751 and nanostation m2 in bridge mode:
NSM does not support any encryption except WEP in ap-repeater mode.
I try to restrict connection to SSID on wlan1
 /interface wireless print
 name="wlan1" mtu=1500 l2mtu=1600 mac-address=00:0C:42:D5:05:3C arp=enabled
      interface-type=Atheros AR92xx mode=bridge ssid="br" frequency=2412
      band=2ghz-b/g channel-width=20mhz scan-list=default wireless-protocol=any
      antenna-mode=rxa-txb vlan-mode=no-tag vlan-id=1 wds-mode=dynamic
      wds-default-bridge=bridge-wds wds-ignore-ssid=no bridge-mode=enabled
      default-authentication=no default-forwarding=no default-ap-tx-limit=0
      default-client-tx-limit=0 hide-ssid=yes security-profile=default
      compression=no
/interface wireless wds print
 name="wds1" mtu=1500 l2mtu=1600 mac-address=00:0C:42:D5:05:3C arp=enabled
       arp-timeout=auto master-interface=wlan1 wds-address=DC:9F:DB:06:87:32
 /interface wireless access-list print
 mac-address=DC:9F:DB:06:87:32 (NSM2 MAC) interface=wlan1 signal-range=-120..120
     authentication=no forwarding=no ap-tx-limit=0 client-tx-limit=0
     private-algo=none private-key="" private-pre-shared-key=""
     management-protection-key="" vlan-mode=no-tag vlan-id=1
In this case HIDE SSID and ACCESS LIST does not working. I can see ssid "br" and can connect to it.
What can i do to prohibit any connection to "br" except NSM2?
K.i.s.S.
ZeroByte
Re: hide ssid and access list does not working
Wed Aug 17, 2016 4:31 pm
Don't use AP repeater.... ESPECIALLY if it requires that you use WEP.
Even if you hide the SSID, this only stops the absolutely clueless people from finding and abusing your network.
In fact, if I were a hacker, I would specifically choose the hidden one to hack into.
Repeaters cut your bandwidth in half, too.
Install two radios - one to connect to the Mikrotik, and one to be the AP.
Why not get a dual radio Mikrotik and install that instead of the NSM?
When given a spoon,
you should not cling to your fork.
The soup will get cold.
mistiq
Wed Aug 17, 2016 4:49 pm
Because i`m already have NSM and mikrotik.
Radio chip in rb is so poor compared Nanostation.
How i can do this?
When i enable WDS on wlan1 interface, wds1 automatically appears as slave to wlan1.
/interface wireless print detail
 0  R name="wlan1" mtu=1500 l2mtu=1600 mac-address=00:0C:42:D5:05:3C arp=enabled
      compression=no
 1  R name="wlan_private" mtu=1500 l2mtu=1600 mac-address=02:0C:42:D5:05:3C
      arp=enabled interface-type=virtual-AP master-interface=wlan1
      ssid="area51" vlan-mode=no-tag vlan-id=1 wds-mode=disabled
      wds-default-bridge=bridge_private wds-ignore-ssid=no bridge-mode=enabled
      default-authentication=yes default-forwarding=yes default-ap-tx-limit=0
      default-client-tx-limit=0 hide-ssid=no security-profile=WPA
Flags: X - disabled, R - running, D - dynamic
 0  DR  name="wds1" mtu=1500 l2mtu=1600 mac-address=00:0C:42:D5:05:3C arp=enabled
K.i.s.S.
Users browsing this forum: No registered users and 15 guests
