MUM Europe 2020
Lucky Phil
Dynamic DNS - FTP Server
Sun Oct 01, 2006 1:13 am
I am trying to access my FTP Server from the outside world but my ISP changes my real IP Address when there is an outage or I have a power blackout. I have a dstnat rule added but have to put my current IP Address in the (destination address) it after it changes. Is there a way for it to be changed automatically for me.
I am running MikroTik RouterOS 2.9.29, my FTP Server changes its ip automatically with a dns updater.
changeip
Sun Oct 01, 2006 5:10 am
Do not use dst-address, only use in-interface. This will mean 'anything' coming into your wan port on port X, no matter what the current IP is.
Sam
Lucky Phil
Sun Oct 01, 2006 7:34 am
Just tried that and it didn't work, I then put ip address back in aswell but still didn't work untill I took out in interface.
Philip
GWISA
Mon Oct 02, 2006 1:32 am
You can register with the dyndns.com service, get a dns name with them and then use the
[:resolve www.yourdnsname.com]
command instead of the IP address in a scheduled script to set your dst-nat rule...
changeip
Mon Oct 02, 2006 4:09 am
Seriously, don't specify the IP...
add chain=dstnat in-interface=MYCABLEMODEM protocol=tcp src-port=20-21 \
action=dst-nat to-addresses=10.20.1.2 to-ports=0-65535 comment="EXAMPLE PORT 20-21 for FTP" \
disabled=no
GWISA
Mon Oct 02, 2006 11:55 am
If you don't specify the IP, how will you ever dst-nat?
I understand the question as how to put the IP of the dst-nat address to redirect to....
am I wrong?
changeip
Mon Oct 02, 2006 6:46 pm
Leaving the ip address out of the filter will force anything coming into that interface to be dst-natted ... if you have a single IP or 8 ips, anything coming to any of them will use those rules.
Sam
GWISA
Mon Oct 02, 2006 11:24 pm
I think the question is referring to a different field than the one you are...
Are you talking about the dst-address field as found in the 'General' tab in winbox, while I am indicating the dst-nat address in the action=dst-nat to-addresses=10.20.1.2...?
disabled=no
sure, and then add
/system script
add name="resolve-ip" source="ip firewall nat set EXAMPLE \
PORT 20-21 for FTP to-addresses=[:resolve yourdns.homedns.org]"
/system scheduler
add name="resolve-ip" on-event=resolve-ip start-date=jan/01/1970 \
    start-time=05:00:00 interval=12h comment="" disabled=no
This will check, resolve and reset your IP in the dst-nat rule at whatever interval you specify from whatever your dyndns registered name is - and voila! Automatic IP address-changing...
Surely that's what you meant...
changeip
Tue Oct 03, 2006 12:02 am
LuckyPhil said he didn't want to have to change his IP address on the dst-address of the dst-nat rule everytime it changes. Well, leaving it out will solve that. No need for a script in this case, just don't specify it and it will automatically apply that rule to incoming traffic.
Sam
GWISA
Tue Oct 03, 2006 1:16 am
and
and
so I assumed he was using something like dyndns and connecting to his FTP by a dns name to a dynamic ip... and trying to get the MT to accomplish this automatically...
ah well...
Lucky Phil
Tue Oct 03, 2006 11:36 am
Gwisa,
Thats it exactly, I have a dyndns that updates by itself but if i'm on the outside and don't know that my ip has changed I can't access the ftp.
By having mt find the ip and change it in the dstnat rule or something would be great.
Philip
GWISA
Tue Oct 03, 2006 1:11 pm
:twisted:
Told you so!
Just follow my instructions above with the [:resolve yourdyndns.homedns.org] command...
Take note that the only way you can refer to a (for e.g.) NAT rule is by the Comment - so if you comment your NAT rule as 'resolve-dyndns' then you'll use 'resolve-dyndns' instead of the 'EXAMPLE PORT 20-21 for FTP' etc etc comment above...
cheers!
Lucky Phil
Thu Oct 05, 2006 1:49 pm
Thanks everyone for you input have it working now.
Philip
Users browsing this forum: No registered users and 88 guests
