jscoulter
RouterOS on USB PenDrive??
Sun Oct 01, 2006 10:33 pm
Hi all.
Has anyone ever attempted to put the RouterOS onto a USB PendDrive?
A lot of more modern PC's and Laptops will boot from a USB PenDrive and I as thinking that its a cheaper alternative to a Disk On Module solution which is connectd to an IDE 2 USB adapter.....well....only in my case as I seem to have some old PenDrives laying around.
Just courious if anyone has done it....and if so, how....
Thanks, Jeremy
BrianHiggins
Long time Member
Long time Member
Sun Oct 01, 2006 11:23 pm
I think i remember someone asking for support for that in v3.0, so I assume it doesn't work currently...
csickles
Re: RouterOS on USB PenDrive??
Sun Jun 07, 2009 10:16 pm
Yes it can boot / run on a flash drive..
The issue is the system bios and the device the flash device emulates.
Things that make you go "Hmmmmmmmm"...
Craig
conjurer
Wed Jun 10, 2009 11:06 am
If you have modern pc you can. Bios must support usb boot.
NetworkPro
Thu Jan 21, 2010 8:27 pm
RouterOS on one PC may give you one SoftID to activate, and on the next PC, when booted from the same USB flash drive, may give you another SoftID. So first choose your PC. And first try with a Demo license to see if all is fine.
wiki.mikrotik.com/wiki/NetworkPro_on_Quality_of_Service
jauer
Thu Feb 11, 2010 1:08 am
I am running RouterOS off of a USB thumb drive.
I've tried it on two different computers and it worked on both of them without losing the license.
Granted, both of them had the same kind of processor (P4) so I don't know if it will work going from a P4 to, say, a Core 2 duo.
NetworkPro
Thu Feb 11, 2010 2:42 am
Yes, thank you for the addition. Appreciated.
I think it depends on how the BIOS interprets the USB thumbdrive. :)
Hey by the way, it turns out you can reuse an old SD card, to boot up your Router, WHEN USED WITH AN EXTERNAL USB CADDY (small reader). :)
janisk
Thu Feb 11, 2010 12:31 pm
if you have centered your x86 routers around one platform with same settings on all, there should not be problem with migrating usb drives with routeros installed. different platforms etc. can cause softid to change. so, handle with care.
Users browsing this forum: mkx and 26 guests
