MUM Europe 2020
PaulsMT
Winbox 3.5 released!
Thu Sep 01, 2016 9:30 am
What's new in v3.5:
*) fixed file upload via Upload button;
*) do not disconnect from router if none of the windows are open;
*) report error if telnet failed;
*) handle properly romon authentication failures;
If you experience version related issues, then please report them to support@mikrotik.com.
Winbox is available here:
http://www.mikrotik.com/download
If you try to upgrade directly from Winbox loader and version is not available, then you might need to wait for a while until cache in path between your device and our servers is refreshed.
freemannnn
Long time Member
Long time Member
Re: Winbox 3.5 released!
Thu Sep 01, 2016 9:47 am
please make windows winbox version working folder to be the same where winbox.exe exists. why we have to mess with "user\appdata\roaming" folder?
notToNew
Thu Sep 01, 2016 10:11 am
+1. This would allow me to sync it to several desktops
CCR1036-12G-4S, several 952Ui-5ac2nD, ...
fposavec
Thu Sep 01, 2016 4:24 pm
You can move session folder, and also database folder to some custom location and then sync it whitout problem
notToNew
Thu Sep 01, 2016 4:31 pm
How??
mrz
Thu Sep 01, 2016 4:33 pm
Tools-> Move session folder
raffav
Thu Sep 01, 2016 4:38 pm
How??
move database
open winbox
file>new or save as> choose the destination path i.e dropbox/onedrive/drive
move Session folder
Open winbox
tool>move session folder> choose the destination path i.e dropbox/onedrive/drive
w0lt
Thu Sep 01, 2016 7:10 pm
I would like to see a change that would allow you to do "multiple selects" from the "Show Columns" drop down menu that seems to be accessible from most windows instead of having to do one select/deselect at a time. That would be cool !!!
MTCNA - 2011
" The Bitterness of Poor Quality Remains Long After the Sweetness of Low Price is Forgotten "
raffav
Thu Sep 01, 2016 7:18 pm
+1
lekozs
Fri Sep 02, 2016 1:26 am
+1
Finally, someone said it out loud!
Actually, we need checkboxes in those "Show Columns" menus!
However... I can foresee a reply from MikroTik where they're going to explain that the new Winbox has such and such features, that renders this request unnecessary... :-?
Fraction
Fri Sep 02, 2016 5:02 pm
Secure Mode is still broken in Windows 10. The connection is not encrypted.
pe1chl
Fri Sep 02, 2016 5:14 pm
It is Microsoft Windows coding requirement not to store user data in program directories, but use the appdata directory for that.
And it is good, because you don't want your program directories to be writable for the user.
jarda
Mon Sep 05, 2016 12:34 am
It was already requested more than year ago:
http://forum.mikrotik.com/viewtopic.php ... 13#p479413
You could join the request...
raffav
Mon Sep 05, 2016 4:56 am
Using the version is not possible to save fallback to on partition if the option next is in use, you can only change via cli
Enviado do meu iPad usando Tapatalk
Deantwo
Mon Sep 05, 2016 12:09 pm
I just finished configuring a large batch of routers, all of which opened two "RouterOS Default Configuration" dialog boxes.
This is not a new problem though, as it was also there before the v3.5 update.
Anyone else seeing this after resetting the configuration of a router?
I wish my FTP was FTL.
sosobobo
Sun Sep 11, 2016 1:42 pm
That's really nice one functionality -
Phaere
Wed Sep 14, 2016 9:44 pm
I cannot configure existing VLAN entry in /switch vlan menu on CRS. "Qos Group" field marked by red color and even if i change it, color does not change. I can create new vlan entry without problem and i can manage existing entries with Winbox 3.4 without problems. Webfig also working.
Fix this please :(
skuykend
Fri Sep 16, 2016 7:57 am
On CRS226 - Can not set 'Ingress Mirror To' and 'Egress Mirror To' on any of the Switch Ports Interfaces. Label shows in Red and none of the three options will allow you to hit OK.
Reverted to winbox 3.4 and is working fine.
SiB
Fri Sep 16, 2016 1:00 pm
WinBox still show us in many paces the "zombie" tabs like comment
Please remove it because all new users try use the comment even from terminal.
MTCNA + MTCRE + MTCINE | ~600 users at ~150 RouterBoards in EMEA | Telegram: @SiB_PL
WinBox Tip: F6 works as ALT+TAB | Gliffy.com - free network schematic | prnt.sc - free ScreenShot software
I will be at MUMEUROPE Prague on 26-27 march 2020
Chupaka
Mon Sep 19, 2016 3:00 pm
I don't have this column :) so new users won't see it too, I think
Russian-speaking forum: https://forum.mikrotik.by/. Welcome!
For every complex problem, there is a solution that is simple, neat, and wrong.
MikroTik. Your life. Your routing.
strods
Thu Sep 29, 2016 3:43 pm
Users browsing this forum: gpglang and 16 guests
